[U-Boot] i.MX6Q SabreLite: Ethernet does not work at Gigabit speed
I just realized that I cannot download files on a Gitabit Ethernet network. I'm getting timeouts:
MX6QSABRELITE U-Boot > boot Using FEC device TFTP from server 172.16.0.1; our IP address is 172.16.0.100 Filename 'wolf/uImage-mx6q-mainline'. Load address: 0x10800000 Loading: error frame: 0x4fd76ca0 0x00000804 T error frame: 0x4fd77f00 0x00000804
Before I start digging, is this a known issue?
Wolfgang.
MX6QSABRELITE U-Boot> boot Using FEC device TFTP from server 172.16.0.1; our IP address is 172.16.0.100 Filename 'wolf/uImage-mx6q-mainline'. Load address: 0x10800000 Loading: error frame: 0x4fd76ca0 0x00000804 T error frame: 0x4fd77f00 0x00000804
Wolfgang.
Hi Wolfgang,
This is/was an issue on the first batch of Sabre Lites.
It stemmed from the proper connection of pin 9 on the ethernet jack (it shouldn't be connected):
https://wiki.linaro.org/Boards/MX6QSabreLite#Gigabit_Ethernet_issue
If you're not in a position to de-solder the pin, contact me off-list and we'll arrange for a swap.
Regards,
Eric
Also, I recently posted a patch for mainline u-boot. I'll repost with you and Joe Hershberger in cc.
Troy
Hi Troy,
Thanks for the patch. It help to some extend but I'm still getting timeouts. I need to fix the hardware as well, as Eric suggested.
Wolfgang.
Eric Nelson
Troy Kisky
Wolfgang Grandegger
