[U-Boot] [PULL] u-boot-stm32 for v2019.07 (round 3)
Hi Tom
Please find the pull request for STM32 round 3
The following changes since commit a69120a0d7c8d4044cdaceea9eb03913ba4e49c7:
Prepare v2019.07-rc1 (2019-04-29 21:54:04 -0400)
https://github.com/pchotard/u-boot.git tags/u-boot-stm32-mcu-20190514
for you to fetch changes up to 1aaac8e60042b1e132f84184cfd9aa0f1a4afdde:
configs: stm32f469-disco: Disable PINCTRL_FULL flag (2019-05-06 11:15:16 +0200)
---------------------------------------------------------------- STM32 MCUs update: _ Add MPU region for SPI NOR memory mapped region _ Add missing QSPI flash compatible for STM32 F7 boards _ Update spi-tx-bus-width and spi-rx-bus-width properties _ Add QSPI support for STM32F469 Discovery board
---------------------------------------------------------------- Patrice Chotard (12): mach-stm32: Add MPU region for spi-nor memory mapped region ARM: dts: stm32: Fix qspi memory map size for stm32f7 boards ARM: dts: stm32: add qspi flash compatible string for stm32f769-disco ARM: dts: stm32: add qspi flash compatible string for stm32f746-eval ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f746-eval ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f746-disco ARM: dts: stm32: Remove useless spi-nor compatible string ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f769-disco ARM: dts: stm32: Add qspi support for stm32f469-disco board spi: Kconfig: Add STM32F4 support for STM32_QSPI driver configs: stm32f469-disco: Enable QSPI relative flags configs: stm32f469-disco: Disable PINCTRL_FULL flag
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 6 +++-- arch/arm/dts/stm32f469-disco-u-boot.dtsi | 39 ++++++++++++++++++++++++++++++++ arch/arm/dts/stm32f746-disco-u-boot.dtsi | 8 +++---- arch/arm/dts/stm32f769-disco-u-boot.dtsi | 3 +++ arch/arm/mach-stm32/soc.c | 3 +++ configs/stm32f469-discovery_defconfig | 9 ++++++++ drivers/spi/Kconfig | 2 +- 7 files changed, 63 insertions(+), 7 deletions(-)
On Tue, May 14, 2019 at 02:59:07PM +0000, Patrice CHOTARD wrote:
Hi Tom
Patrice CHOTARD
