[U-Boot] [PATCH v2 0/4] Introducing the Broadcom Cygnus and NSP boards.
This series adds the bcm958300k and the bcm958622hr boards which share the iproc architecture code.
Changes in v2: - remove unused include file - reformat multi-line comment(s) - remove deprecated "SZ_" definitions - remove misc_init_r() - update CONFIG_ENV_SIZE
Scott Branden (4): arm: iproc: Initial commit of iproc architecture code arm: bcmcygnus: Add bcmcygnus u-architecture arm: bcmnsp: Add bcmnsp u-architecture arm: add Cygnus and NSP boards
arch/arm/cpu/armv7/Makefile | 1 + arch/arm/cpu/armv7/bcmcygnus/Makefile | 7 + arch/arm/cpu/armv7/bcmcygnus/reset.c | 20 +++ arch/arm/cpu/armv7/bcmnsp/Makefile | 7 + arch/arm/cpu/armv7/bcmnsp/reset.c | 19 +++ arch/arm/cpu/armv7/iproc-common/Makefile | 9 ++ arch/arm/cpu/armv7/iproc-common/armpll.c | 170 ++++++++++++++++++++++++ arch/arm/cpu/armv7/iproc-common/hwinit-common.c | 15 +++ arch/arm/cpu/armv7/iproc-common/timer.c | 130 ++++++++++++++++++ arch/arm/include/asm/arch-bcmcygnus/configs.h | 25 ++++ arch/arm/include/asm/arch-bcmnsp/configs.h | 22 +++ arch/arm/include/asm/iproc-common/armpll.h | 14 ++ arch/arm/include/asm/iproc-common/configs.h | 20 +++ arch/arm/include/asm/iproc-common/sysmap.h | 47 +++++++ arch/arm/include/asm/iproc-common/timer.h | 37 ++++++ board/broadcom/bcm_ep/Makefile | 7 + board/broadcom/bcm_ep/board.c | 55 ++++++++ boards.cfg | 2 + include/configs/bcm_ep_board.h | 107 +++++++++++++++ 19 files changed, 714 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcmcygnus/Makefile create mode 100644 arch/arm/cpu/armv7/bcmcygnus/reset.c create mode 100644 arch/arm/cpu/armv7/bcmnsp/Makefile create mode 100644 arch/arm/cpu/armv7/bcmnsp/reset.c create mode 100644 arch/arm/cpu/armv7/iproc-common/Makefile create mode 100644 arch/arm/cpu/armv7/iproc-common/armpll.c create mode 100644 arch/arm/cpu/armv7/iproc-common/hwinit-common.c create mode 100644 arch/arm/cpu/armv7/iproc-common/timer.c create mode 100644 arch/arm/include/asm/arch-bcmcygnus/configs.h create mode 100644 arch/arm/include/asm/arch-bcmnsp/configs.h create mode 100644 arch/arm/include/asm/iproc-common/armpll.h create mode 100644 arch/arm/include/asm/iproc-common/configs.h create mode 100644 arch/arm/include/asm/iproc-common/sysmap.h create mode 100644 arch/arm/include/asm/iproc-common/timer.h create mode 100644 board/broadcom/bcm_ep/Makefile create mode 100644 board/broadcom/bcm_ep/board.c create mode 100644 include/configs/bcm_ep_board.h
The iproc architecture code is present in several Broadcom chip architectures, including Cygnus and NSP.
Signed-off-by: Scott Branden sbranden@broadcom.com Signed-off-by: Steve Rae srae@broadcom.com ---
arch/arm/cpu/armv7/Makefile | 1 + arch/arm/cpu/armv7/iproc-common/Makefile | 9 ++ arch/arm/cpu/armv7/iproc-common/armpll.c | 170 ++++++++++++++++++++++++ arch/arm/cpu/armv7/iproc-common/hwinit-common.c | 15 +++ arch/arm/cpu/armv7/iproc-common/timer.c | 130 ++++++++++++++++++ arch/arm/include/asm/iproc-common/armpll.h | 14 ++ arch/arm/include/asm/iproc-common/sysmap.h | 47 +++++++ arch/arm/include/asm/iproc-common/timer.h | 37 ++++++ 8 files changed, 423 insertions(+) create mode 100644 arch/arm/cpu/armv7/iproc-common/Makefile create mode 100644 arch/arm/cpu/armv7/iproc-common/armpll.c create mode 100644 arch/arm/cpu/armv7/iproc-common/hwinit-common.c create mode 100644 arch/arm/cpu/armv7/iproc-common/timer.c create mode 100644 arch/arm/include/asm/iproc-common/armpll.h create mode 100644 arch/arm/include/asm/iproc-common/sysmap.h create mode 100644 arch/arm/include/asm/iproc-common/timer.h
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 232118d..d0cab8d 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -23,6 +23,7 @@ obj-y += nonsec_virt.o obj-y += virt-v7.o endif
+obj-$(CONFIG_IPROC) += iproc-common/ obj-$(CONFIG_KONA) += kona-common/ obj-$(CONFIG_OMAP_COMMON) += omap-common/ obj-$(CONFIG_SYS_ARCH_TIMER) += arch_timer.o diff --git a/arch/arm/cpu/armv7/iproc-common/Makefile b/arch/arm/cpu/armv7/iproc-common/Makefile new file mode 100644 index 0000000..c071a17 --- /dev/null +++ b/arch/arm/cpu/armv7/iproc-common/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2014 Broadcom Corporation. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += armpll.o +obj-y += hwinit-common.o +obj-y += timer.o diff --git a/arch/arm/cpu/armv7/iproc-common/armpll.c b/arch/arm/cpu/armv7/iproc-common/armpll.c new file mode 100644 index 0000000..49b61bf --- /dev/null +++ b/arch/arm/cpu/armv7/iproc-common/armpll.c @@ -0,0 +1,170 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/iproc-common/armpll.h> +#include <asm/iproc-common/sysmap.h> + +#define NELEMS(x) (sizeof(x) / sizeof(x[0])) + +struct armpll_parameters { + unsigned int mode; + unsigned int ndiv_int; + unsigned int ndiv_frac; + unsigned int pdiv; + unsigned int freqid; +}; + +struct armpll_parameters armpll_clk_tab[] = { + { 25, 64, 1, 1, 0}, + { 100, 64, 1, 1, 2}, + { 400, 64, 1, 1, 6}, + { 448, 71, 713050, 1, 6}, + { 500, 80, 1, 1, 6}, + { 560, 89, 629145, 1, 6}, + { 600, 96, 1, 1, 6}, + { 800, 64, 1, 1, 7}, + { 896, 71, 713050, 1, 7}, + { 1000, 80, 1, 1, 7}, + { 1100, 88, 1, 1, 7}, + { 1120, 89, 629145, 1, 7}, + { 1200, 96, 1, 1, 7}, +}; + +uint32_t armpll_config(uint32_t clkmhz) +{ + uint32_t freqid; + uint32_t ndiv_frac; + uint32_t pll; + uint32_t status = 1; + uint32_t timeout_countdown; + int i; + + for (i = 0; i < NELEMS(armpll_clk_tab); i++) { + if (armpll_clk_tab[i].mode == clkmhz) { + status = 0; + break; + } + } + + if (status) { + printf("Error: Clock configuration not supported\n"); + goto armpll_config_done; + } + + /* Enable write access */ + writel(IPROC_REG_WRITE_ACCESS, IHOST_PROC_CLK_WR_ACCESS); + + if (clkmhz == 25) + freqid = 0; + else + freqid = 2; + + /* Bypass ARM clock and run on sysclk */ + writel(1 << IHOST_PROC_CLK_POLICY_FREQ__PRIV_ACCESS_MODE | + freqid << IHOST_PROC_CLK_POLICY_FREQ__POLICY3_FREQ_R | + freqid << IHOST_PROC_CLK_POLICY_FREQ__POLICY2_FREQ_R | + freqid << IHOST_PROC_CLK_POLICY_FREQ__POLICY1_FREQ_R | + freqid << IHOST_PROC_CLK_POLICY_FREQ__POLICY0_FREQ_R, + IHOST_PROC_CLK_POLICY_FREQ); + + writel(1 << IHOST_PROC_CLK_POLICY_CTL__GO | + 1 << IHOST_PROC_CLK_POLICY_CTL__GO_AC, + IHOST_PROC_CLK_POLICY_CTL); + + /* Poll CCU until operation complete */ + timeout_countdown = 0x100000; + while (readl(IHOST_PROC_CLK_POLICY_CTL) & + (1 << IHOST_PROC_CLK_POLICY_CTL__GO)) { + timeout_countdown--; + if (timeout_countdown == 0) { + printf("CCU polling timedout\n"); + status = 1; + goto armpll_config_done; + } + } + + if (clkmhz == 25 || clkmhz == 100) { + status = 0; + goto armpll_config_done; + } + + /* Now it is safe to program the PLL */ + pll = readl(IHOST_PROC_CLK_PLLARMB); + pll &= ~((1 << IHOST_PROC_CLK_PLLARMB__PLLARM_NDIV_FRAC_WIDTH) - 1); + ndiv_frac = + ((1 << IHOST_PROC_CLK_PLLARMB__PLLARM_NDIV_FRAC_WIDTH) - 1) & + (armpll_clk_tab[i].ndiv_frac << + IHOST_PROC_CLK_PLLARMB__PLLARM_NDIV_FRAC_R); + pll |= ndiv_frac; + writel(pll, IHOST_PROC_CLK_PLLARMB); + + writel(1 << IHOST_PROC_CLK_PLLARMA__PLLARM_LOCK | + armpll_clk_tab[i].ndiv_int << + IHOST_PROC_CLK_PLLARMA__PLLARM_NDIV_INT_R | + armpll_clk_tab[i].pdiv << + IHOST_PROC_CLK_PLLARMA__PLLARM_PDIV_R | + 1 << IHOST_PROC_CLK_PLLARMA__PLLARM_SOFT_RESETB, + IHOST_PROC_CLK_PLLARMA); + + /* Poll ARM PLL Lock until operation complete */ + timeout_countdown = 0x100000; + while (readl(IHOST_PROC_CLK_PLLARMA) & + (1 << IHOST_PROC_CLK_PLLARMA__PLLARM_LOCK)) { + timeout_countdown--; + if (timeout_countdown == 0) { + printf("ARM PLL lock failed\n"); + status = 1; + goto armpll_config_done; + } + } + + pll = readl(IHOST_PROC_CLK_PLLARMA); + pll |= (1 << IHOST_PROC_CLK_PLLARMA__PLLARM_SOFT_POST_RESETB); + writel(pll, IHOST_PROC_CLK_PLLARMA); + + /* Set the policy */ + writel(1 << IHOST_PROC_CLK_POLICY_FREQ__PRIV_ACCESS_MODE | + armpll_clk_tab[i].freqid << + IHOST_PROC_CLK_POLICY_FREQ__POLICY3_FREQ_R | + armpll_clk_tab[i].freqid << + IHOST_PROC_CLK_POLICY_FREQ__POLICY2_FREQ_R | + armpll_clk_tab[i].freqid << + IHOST_PROC_CLK_POLICY_FREQ__POLICY1_FREQ_R | + armpll_clk_tab[i+4].freqid << + IHOST_PROC_CLK_POLICY_FREQ__POLICY0_FREQ_R, + IHOST_PROC_CLK_POLICY_FREQ); + + writel(IPROC_CLKCT_HDELAY_SW_EN, IHOST_PROC_CLK_CORE0_CLKGATE); + writel(IPROC_CLKCT_HDELAY_SW_EN, IHOST_PROC_CLK_CORE1_CLKGATE); + writel(IPROC_CLKCT_HDELAY_SW_EN, IHOST_PROC_CLK_ARM_SWITCH_CLKGATE); + writel(IPROC_CLKCT_HDELAY_SW_EN, IHOST_PROC_CLK_ARM_PERIPH_CLKGATE); + writel(IPROC_CLKCT_HDELAY_SW_EN, IHOST_PROC_CLK_APB0_CLKGATE); + + writel(1 << IHOST_PROC_CLK_POLICY_CTL__GO | + 1 << IHOST_PROC_CLK_POLICY_CTL__GO_AC, + IHOST_PROC_CLK_POLICY_CTL); + + /* Poll CCU until operation complete */ + timeout_countdown = 0x100000; + while (readl(IHOST_PROC_CLK_POLICY_CTL) & + (1 << IHOST_PROC_CLK_POLICY_CTL__GO)) { + timeout_countdown--; + if (timeout_countdown == 0) { + printf("CCU polling failed\n"); + status = 1; + goto armpll_config_done; + } + } + + status = 0; +armpll_config_done: + /* Disable access to PLL registers */ + writel(0, IHOST_PROC_CLK_WR_ACCESS); + + return status; +} diff --git a/arch/arm/cpu/armv7/iproc-common/hwinit-common.c b/arch/arm/cpu/armv7/iproc-common/hwinit-common.c new file mode 100644 index 0000000..7131524 --- /dev/null +++ b/arch/arm/cpu/armv7/iproc-common/hwinit-common.c @@ -0,0 +1,15 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); +} +#endif diff --git a/arch/arm/cpu/armv7/iproc-common/timer.c b/arch/arm/cpu/armv7/iproc-common/timer.c new file mode 100644 index 0000000..373d8ec --- /dev/null +++ b/arch/arm/cpu/armv7/iproc-common/timer.c @@ -0,0 +1,130 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/iproc-common/timer.h> +#include <asm/iproc-common/sysmap.h> + +static inline uint64_t timer_global_read(void) +{ + uint64_t cur_tick; + uint32_t count_h; + uint32_t count_l; + + do { + count_h = readl(IPROC_PERIPH_GLB_TIM_REG_BASE + + TIMER_GLB_HI_OFFSET); + count_l = readl(IPROC_PERIPH_GLB_TIM_REG_BASE + + TIMER_GLB_LOW_OFFSET); + cur_tick = readl(IPROC_PERIPH_GLB_TIM_REG_BASE + + TIMER_GLB_HI_OFFSET); + } while (cur_tick != count_h); + + return (cur_tick << 32) + count_l; +} + +void timer_global_init(void) +{ + writel(0, IPROC_PERIPH_GLB_TIM_REG_BASE + TIMER_GLB_CTRL_OFFSET); + writel(0, IPROC_PERIPH_GLB_TIM_REG_BASE + TIMER_GLB_LOW_OFFSET); + writel(0, IPROC_PERIPH_GLB_TIM_REG_BASE + TIMER_GLB_HI_OFFSET); + writel(TIMER_GLB_TIM_CTRL_TIM_EN, + IPROC_PERIPH_GLB_TIM_REG_BASE + TIMER_GLB_CTRL_OFFSET); +} + +int timer_init(void) +{ + timer_global_init(); + return 0; +} + +unsigned long get_timer(unsigned long base) +{ + uint64_t count; + uint64_t ret; + uint64_t tim_clk; + uint64_t periph_clk; + + count = timer_global_read(); + + /* default arm clk is 1GHz, periph_clk=arm_clk/2, tick per msec */ + periph_clk = 500000; + tim_clk = lldiv(periph_clk, + (((readl(IPROC_PERIPH_GLB_TIM_REG_BASE + + TIMER_GLB_CTRL_OFFSET) & + TIMER_GLB_TIM_CTRL_PRESC_MASK) >> 8) + 1)); + + ret = lldiv(count, (uint32_t)tim_clk); + + /* returns msec */ + return ret - base; +} + +void __udelay(unsigned long usec) +{ + uint64_t cur_tick, end_tick; + uint64_t tim_clk; + uint64_t periph_clk; + + /* default arm clk is 1GHz, periph_clk=arm_clk/2, tick per usec */ + periph_clk = 500; + + tim_clk = lldiv(periph_clk, + (((readl(IPROC_PERIPH_GLB_TIM_REG_BASE + + TIMER_GLB_CTRL_OFFSET) & + TIMER_GLB_TIM_CTRL_PRESC_MASK) >> 8) + 1)); + + cur_tick = timer_global_read(); + + end_tick = tim_clk; + end_tick *= usec; + end_tick += cur_tick; + + do { + cur_tick = timer_global_read(); + + } while (cur_tick < end_tick); +} + +void timer_systick_init(uint32_t tick_ms) +{ + /* Disable timer and clear interrupt status*/ + writel(0, IPROC_PERIPH_PVT_TIM_REG_BASE + TIMER_PVT_CTRL_OFFSET); + writel(TIMER_PVT_TIM_INT_STATUS_SET, + IPROC_PERIPH_PVT_TIM_REG_BASE + TIMER_PVT_STATUS_OFFSET); + writel((PLL_AXI_CLK/1000) * tick_ms, + IPROC_PERIPH_PVT_TIM_REG_BASE + TIMER_PVT_LOAD_OFFSET); + writel(TIMER_PVT_TIM_CTRL_INT_EN | + TIMER_PVT_TIM_CTRL_AUTO_RELD | + TIMER_PVT_TIM_CTRL_TIM_EN, + IPROC_PERIPH_PVT_TIM_REG_BASE + TIMER_PVT_CTRL_OFFSET); +} + +void timer_systick_isr(void *data) +{ + writel(TIMER_PVT_TIM_INT_STATUS_SET, + IPROC_PERIPH_PVT_TIM_REG_BASE + TIMER_PVT_STATUS_OFFSET); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value in msec. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This is used in conjuction with get_ticks, which returns msec as ticks. + * Here we just return ticks/sec = msec/sec = 1000 + */ +ulong get_tbclk(void) +{ + return 1000; +} diff --git a/arch/arm/include/asm/iproc-common/armpll.h b/arch/arm/include/asm/iproc-common/armpll.h new file mode 100644 index 0000000..1bee350 --- /dev/null +++ b/arch/arm/include/asm/iproc-common/armpll.h @@ -0,0 +1,14 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARMPLL_H +#define __ARMPLL_H + +#include <linux/types.h> + +uint32_t armpll_config(uint32_t clkmhz); + +#endif /*__ARMPLL_H */ diff --git a/arch/arm/include/asm/iproc-common/sysmap.h b/arch/arm/include/asm/iproc-common/sysmap.h new file mode 100644 index 0000000..5766dc9 --- /dev/null +++ b/arch/arm/include/asm/iproc-common/sysmap.h @@ -0,0 +1,47 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SYSMAP_H +#define __SYSMAP_H + +#define IHOST_PROC_CLK_PLLARMA 0X19000C00 +#define IHOST_PROC_CLK_PLLARMB 0X19000C04 +#define IHOST_PROC_CLK_PLLARMA__PLLARM_PDIV_R 24 + +#define IHOST_PROC_CLK_WR_ACCESS 0X19000000 +#define IHOST_PROC_CLK_POLICY_FREQ 0X19000008 +#define IHOST_PROC_CLK_POLICY_FREQ__PRIV_ACCESS_MODE 31 +#define IHOST_PROC_CLK_POLICY_FREQ__POLICY3_FREQ_R 24 +#define IHOST_PROC_CLK_POLICY_FREQ__POLICY2_FREQ_R 16 +#define IHOST_PROC_CLK_POLICY_FREQ__POLICY1_FREQ_R 8 +#define IHOST_PROC_CLK_POLICY_CTL 0X1900000C +#define IHOST_PROC_CLK_POLICY_CTL__GO 0 +#define IHOST_PROC_CLK_POLICY_CTL__GO_AC 1 +#define IHOST_PROC_CLK_PLLARMB__PLLARM_NDIV_FRAC_R 0 +#define IHOST_PROC_CLK_PLLARMB__PLLARM_NDIV_FRAC_WIDTH 20 +#define IHOST_PROC_CLK_PLLARMA__PLLARM_LOCK 28 +#define IHOST_PROC_CLK_POLICY_FREQ__POLICY0_FREQ_R 0 +#define IHOST_PROC_CLK_PLLARMA__PLLARM_NDIV_INT_R 8 +#define IHOST_PROC_CLK_PLLARMA__PLLARM_SOFT_POST_RESETB 1 +#define IHOST_PROC_CLK_PLLARMA__PLLARM_SOFT_RESETB 0 +#define IHOST_PROC_CLK_CORE0_CLKGATE 0X19000200 +#define IHOST_PROC_CLK_CORE1_CLKGATE 0X19000204 +#define IHOST_PROC_CLK_ARM_SWITCH_CLKGATE 0X19000210 +#define IHOST_PROC_CLK_ARM_PERIPH_CLKGATE 0X19000300 +#define IHOST_PROC_CLK_APB0_CLKGATE 0X19000400 +#define IPROC_CLKCT_HDELAY_SW_EN 0x00000303 + +#define IPROC_REG_WRITE_ACCESS 0x00a5a501 + +#define IPROC_PERIPH_BASE 0x19020000 +#define IPROC_PERIPH_INT_CTRL_REG_BASE (IPROC_PERIPH_BASE + 0x100) +#define IPROC_PERIPH_GLB_TIM_REG_BASE (IPROC_PERIPH_BASE + 0x200) +#define IPROC_PERIPH_PVT_TIM_REG_BASE (IPROC_PERIPH_BASE + 0x600) +#define IPROC_PERIPH_INT_DISTR_REG_BASE (IPROC_PERIPH_BASE + 0x1000) + +#define PLL_AXI_CLK 0x1DCD6500 + +#endif /* __SYSMAP_H */ diff --git a/arch/arm/include/asm/iproc-common/timer.h b/arch/arm/include/asm/iproc-common/timer.h new file mode 100644 index 0000000..2bc2322 --- /dev/null +++ b/arch/arm/include/asm/iproc-common/timer.h @@ -0,0 +1,37 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __TIMER_H +#define __TIMER_H + +#include <linux/types.h> + +void timer_systick_init(uint32_t tick_ms); +void timer_global_init(void); + +/* ARM A9 Private Timer */ +#define TIMER_PVT_LOAD_OFFSET 0x00000000 +#define TIMER_PVT_COUNTER_OFFSET 0x00000004 +#define TIMER_PVT_CTRL_OFFSET 0x00000008 +#define TIMER_PVT_STATUS_OFFSET 0x0000000C +#define TIMER_PVT_TIM_CTRL_TIM_EN 0x00000001 +#define TIMER_PVT_TIM_CTRL_AUTO_RELD 0x00000002 +#define TIMER_PVT_TIM_CTRL_INT_EN 0x00000004 +#define TIMER_PVT_TIM_CTRL_PRESC_MASK 0x0000FF00 +#define TIMER_PVT_TIM_INT_STATUS_SET 0x00000001 + +/* Global timer */ +#define TIMER_GLB_LOW_OFFSET 0x00000000 +#define TIMER_GLB_HI_OFFSET 0x00000004 +#define TIMER_GLB_CTRL_OFFSET 0x00000008 +#define TIMER_GLB_TIM_CTRL_TIM_EN 0x00000001 +#define TIMER_GLB_TIM_CTRL_COMP_EN 0x00000002 +#define TIMER_GLB_TIM_CTRL_INT_EN 0x00000004 +#define TIMER_GLB_TIM_CTRL_AUTO_INC 0x00000008 +#define TIMER_GLB_TIM_CTRL_PRESC_MASK 0x0000FF00 +#define TIMER_GLB_TIM_INT_STATUS_SET 0x00000001 + +#endif /*__TIMER_H */
Base support for the Broadcom Cygnus SoC. Based on iproc-common and the SoC specific reset function.
Changes in v2: None
arch/arm/cpu/armv7/bcmcygnus/Makefile | 7 +++++++ arch/arm/cpu/armv7/bcmcygnus/reset.c | 20 ++++++++++++++++++++ 2 files changed, 27 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcmcygnus/Makefile create mode 100644 arch/arm/cpu/armv7/bcmcygnus/reset.c
diff --git a/arch/arm/cpu/armv7/bcmcygnus/Makefile b/arch/arm/cpu/armv7/bcmcygnus/Makefile new file mode 100644 index 0000000..04afcf9 --- /dev/null +++ b/arch/arm/cpu/armv7/bcmcygnus/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2014 Broadcom Corporation. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += reset.o diff --git a/arch/arm/cpu/armv7/bcmcygnus/reset.c b/arch/arm/cpu/armv7/bcmcygnus/reset.c new file mode 100644 index 0000000..53ecc0c --- /dev/null +++ b/arch/arm/cpu/armv7/bcmcygnus/reset.c @@ -0,0 +1,20 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> + +#define CRMU_MAIL_BOX1 0x03024028 +#define CRMU_SOFT_RESET_CMD 0xFFFFFFFF + +void reset_cpu(ulong ignored) +{ + /* Send soft reset command via Mailbox. */ + writel(CRMU_SOFT_RESET_CMD, CRMU_MAIL_BOX1); + + while (1) + ; /* loop forever till reset */ +}
Base support for the Broadcom NSP SoC. Based on iproc-common and the SoC specific reset function.
Changes in v2: None
arch/arm/cpu/armv7/bcmnsp/Makefile | 7 +++++++ arch/arm/cpu/armv7/bcmnsp/reset.c | 19 +++++++++++++++++++ 2 files changed, 26 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcmnsp/Makefile create mode 100644 arch/arm/cpu/armv7/bcmnsp/reset.c
diff --git a/arch/arm/cpu/armv7/bcmnsp/Makefile b/arch/arm/cpu/armv7/bcmnsp/Makefile new file mode 100644 index 0000000..04afcf9 --- /dev/null +++ b/arch/arm/cpu/armv7/bcmnsp/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2014 Broadcom Corporation. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += reset.o diff --git a/arch/arm/cpu/armv7/bcmnsp/reset.c b/arch/arm/cpu/armv7/bcmnsp/reset.c new file mode 100644 index 0000000..d79d9aa --- /dev/null +++ b/arch/arm/cpu/armv7/bcmnsp/reset.c @@ -0,0 +1,19 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> + +#define CRU_RESET_OFFSET 0x1803F184 + +void reset_cpu(ulong ignored) +{ + /* Reset the cpu by setting software reset request bit */ + writel(0x1, CRU_RESET_OFFSET); + + while (1) + ; /* loop forever till reset */ +}
The bcm_ep board configuration is used by a number of boards including Cygnus and NSP. Add builds for the bcm958300k and the bcm958622hr boards.
Changes in v2: - reformat multi-line comment(s) - remove deprecated "SZ_" definitions - remove misc_init_r() - update CONFIG_ENV_SIZE
arch/arm/include/asm/arch-bcmcygnus/configs.h | 25 ++++++ arch/arm/include/asm/arch-bcmnsp/configs.h | 22 ++++++ arch/arm/include/asm/iproc-common/configs.h | 20 +++++ board/broadcom/bcm_ep/Makefile | 7 ++ board/broadcom/bcm_ep/board.c | 55 +++++++++++++ boards.cfg | 2 + include/configs/bcm_ep_board.h | 107 ++++++++++++++++++++++++++ 7 files changed, 238 insertions(+) create mode 100644 arch/arm/include/asm/arch-bcmcygnus/configs.h create mode 100644 arch/arm/include/asm/arch-bcmnsp/configs.h create mode 100644 arch/arm/include/asm/iproc-common/configs.h create mode 100644 board/broadcom/bcm_ep/Makefile create mode 100644 board/broadcom/bcm_ep/board.c create mode 100644 include/configs/bcm_ep_board.h
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h new file mode 100644 index 0000000..5354637 --- /dev/null +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -0,0 +1,25 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_CONFIGS_H +#define __ARCH_CONFIGS_H + +#include <asm/iproc-common/configs.h> + +/* uArchitecture specifics */ + +/* Serial Info */ +/* Post pad 3 bytes after each reg addr */ +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_MEM32 + +#define CONFIG_SYS_NS16550_CLK 100000000 +#define CONFIG_SYS_NS16550_CLK_DIV 54 +#define CONFIG_SERIAL_MULTI +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 0x18023000 + +#endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/arch-bcmnsp/configs.h b/arch/arm/include/asm/arch-bcmnsp/configs.h new file mode 100644 index 0000000..786deae --- /dev/null +++ b/arch/arm/include/asm/arch-bcmnsp/configs.h @@ -0,0 +1,22 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_CONFIGS_H +#define __ARCH_CONFIGS_H + +#include <asm/iproc-common/configs.h> + +/* uArchitecture specifics */ + +/* Serial Info */ +/* no padding */ +#define CONFIG_SYS_NS16550_REG_SIZE 1 + +#define CONFIG_SYS_NS16550_CLK 0x03b9aca0 +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 0x18000300 + +#endif /* __ARCH_CONFIGS_H */ diff --git a/arch/arm/include/asm/iproc-common/configs.h b/arch/arm/include/asm/iproc-common/configs.h new file mode 100644 index 0000000..c24de1f --- /dev/null +++ b/arch/arm/include/asm/iproc-common/configs.h @@ -0,0 +1,20 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __IPROC_COMMON_CONFIGS_H +#define __IPROC_COMMON_CONFIGS_H + +#include <linux/stringify.h> + +/* Architecture, CPU, chip, etc */ +#define CONFIG_IPROC +#define CONFIG_SYS_ARM_CACHE_WRITETHROUGH + +/* Memory Info */ +#define CONFIG_SYS_TEXT_BASE 0x61000000 +#define CONFIG_SYS_SDRAM_BASE 0x61000000 + +#endif /* __IPROC_COMMON_CONFIGS_H */ diff --git a/board/broadcom/bcm_ep/Makefile b/board/broadcom/bcm_ep/Makefile new file mode 100644 index 0000000..8914e54 --- /dev/null +++ b/board/broadcom/bcm_ep/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2014 Broadcom Corporation. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += board.o diff --git a/board/broadcom/bcm_ep/board.c b/board/broadcom/bcm_ep/board.c new file mode 100644 index 0000000..e48cd3f --- /dev/null +++ b/board/broadcom/bcm_ep/board.c @@ -0,0 +1,55 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <config.h> +#include <asm/system.h> +#include <asm/iproc-common/armpll.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * board_init - early hardware init + */ +int board_init(void) +{ + /* + * Address of boot parameters passed to kernel + * Use default offset 0x100 + */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + return 0; +} + +/* + * dram_init - sets u-boot's idea of sdram size + */ +int dram_init(void) +{ + gd->ram_size = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; +} + +int board_early_init_f(void) +{ + uint32_t status = 0; + + /* Setup PLL if required */ +#if defined(CONFIG_ARMCLK) + armpll_config(CONFIG_ARMCLK); +#endif + + return status; +} diff --git a/boards.cfg b/boards.cfg index 4b2bc19..b06bb32 100644 --- a/boards.cfg +++ b/boards.cfg @@ -289,6 +289,8 @@ Active arm armv7 at91 atmel sama5d3xek Active arm armv7 at91 atmel sama5d3xek sama5d3xek_nandflash sama5d3xek:SAMA5D3,SYS_USE_NANDFLASH Bo Shen voice.shen@atmel.com Active arm armv7 at91 atmel sama5d3xek sama5d3xek_spiflash sama5d3xek:SAMA5D3,SYS_USE_SERIALFLASH Bo Shen voice.shen@atmel.com Active arm armv7 bcm281xx broadcom bcm28155_ap bcm28155_ap bcm28155_ap Tim Kryger tim.kryger@linaro.org +Active arm armv7 bcmcygnus broadcom bcm_ep bcm958300k bcm_ep_board:SYS_SDRAM_SIZE=0x20000000 Steve Rae srae@broadcom.com +Active arm armv7 bcmnsp broadcom bcm_ep bcm958622hr bcm_ep_board:SYS_SDRAM_SIZE=0x01000000 Steve Rae srae@broadcom.com Active arm armv7 exynos samsung arndale arndale - Inderpal Singh inderpal.singh@linaro.org Active arm armv7 exynos samsung origen origen - Chander Kashyap k.chander@samsung.com Active arm armv7 exynos samsung smdk5250 smdk5250 - Chander Kashyap k.chander@samsung.com diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h new file mode 100644 index 0000000..fa80fd4 --- /dev/null +++ b/include/configs/bcm_ep_board.h @@ -0,0 +1,107 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __BCM_EP_BOARD_H +#define __BCM_EP_BOARD_H + +#include <asm/arch/configs.h> + +/* Architecture, CPU, chip, etc */ +#define CONFIG_ARMV7 +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_SYS_GENERIC_BOARD + +/* + * Memory configuration + * + * CONFIG_SYS_TEXT_BASE, CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE + * defined in boards.cfg + */ +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) +#define CONFIG_STACKSIZE (256 * 1024) + +/* Some commands use this as the default load address */ +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + +/* No mtest functions as recommended */ +#undef CONFIG_CMD_MEMORY + +/* + * This is the initial SP which is used only briefly for relocating the u-boot + * image to the top of SDRAM. After relocation u-boot moves the stack to the + * proper place. + */ +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_TEXT_BASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Serial Info */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_IS_NOWHERE + +#define CONFIG_SYS_NO_FLASH /* Not using NAND/NOR unmanaged flash */ + +/* console configuration */ +#define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) /* Printbuffer size */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * One partition type must be defined for part.c + * This is necessary for the fatls command to work on an SD card + * for example. + */ +#define CONFIG_DOS_PARTITION + +/* version string, parser, etc */ +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_CMDLINE_EDITING +#define CONFIG_COMMAND_HISTORY +#define CONFIG_SYS_LONGHELP + +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* Commands */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_FAT +#define CONFIG_FAT_WRITE + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +/* SHA hashing */ +#define CONFIG_CMD_HASH +#define CONFIG_HASH_VERIFY +#define CONFIG_SHA1 +#define CONFIG_SHA256 + +/* Enable Time Command */ +#define CONFIG_CMD_TIME + +#define CONFIG_CMD_BOOTZ + +/* Misc utility code */ +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CRC32_VERIFY + +#endif /* __BCM_EP_BOARD_H */
Changes in v2:
Albert, I notice that this patchset is assigned to you: http://patchwork.ozlabs.org/patch/371767/ I have more features to submit, which are dependant on this patchset. Is the process to submit those changes, and to put in the commit note that this patchset is a prerequisite, or ??? Thanks, Steve
Steve Rae
