[PATCH v2 1/2] ARM: cache: Allow SPL to build cache-pl310.c
Before this commit, the SPL could enable the PL310 L2 cache [1], but the cache maintenance functions from cache-pl310.c were only useable for non-SPL builds.
After enabling the cache one must be able to flush it, too. Thus this commit allows cache-pl310.c to be included in the SPL build.
[1] See for example arch/arm/mach-imx/cache.c: v7_outer_cache_enable()
Signed-off-by: Philip Oberfichtner pro@denx.de ---
(no changes since v1)
arch/arm/lib/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c603fe61bc..ac1d4245bb 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -33,7 +33,6 @@ obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o -obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o else obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o @@ -46,6 +45,7 @@ else obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o endif +obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += semihosting.o
ifneq ($(filter y,$(CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR) $(CONFIG_SAVE_PREV_BL_FDT_ADDR)),)
Enable d-cache early in SPL right after DRAM is started up. This reduces U-Boot proper load time by 650ms when loaded from SPI NOR.
Signed-off-by: Marek Vasut marex@denx.de Signed-off-by: Philip Oberfichtner pro@denx.de
Changes in v2: - Add comment to explain the relevance of dcache_disable()
board/dhelectronics/dh_imx6/dh_imx6_spl.c | 28 +++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index e49e97724a..4b0e13493d 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <cpu_func.h> #include <init.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> @@ -14,11 +15,13 @@ #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/sys_proto.h> +#include <asm/cache.h> #include <asm/gpio.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <asm/io.h> +#include <asm/system.h> #include <errno.h> #include <fuse.h> #include <fsl_esdhc_imx.h> @@ -610,6 +613,20 @@ static void dhcom_spl_dram_init(void) } }
+void dram_bank_mmu_setup(int bank) +{ + int i; + + set_section_dcache(ROMCP_ARB_BASE_ADDR >> MMU_SECTION_SHIFT, DCACHE_DEFAULT_OPTION); + set_section_dcache(IRAM_BASE_ADDR >> MMU_SECTION_SHIFT, DCACHE_DEFAULT_OPTION); + + for (i = MMDC0_ARB_BASE_ADDR >> MMU_SECTION_SHIFT; + i < ((MMDC0_ARB_BASE_ADDR >> MMU_SECTION_SHIFT) + + (SZ_1G >> MMU_SECTION_SHIFT)); + i++) + set_section_dcache(i, DCACHE_DEFAULT_OPTION); +} + void board_init_f(ulong dummy) { /* setup AIPS and disable watchdog */ @@ -636,9 +653,20 @@ void board_init_f(ulong dummy) /* DDR3 initialization */ dhcom_spl_dram_init();
+ /* Set up early MMU tables at the beginning of DRAM and start d-cache */ + gd->arch.tlb_addr = MMDC0_ARB_BASE_ADDR + SZ_32M; + gd->arch.tlb_size = PGTABLE_SIZE; + enable_caches(); + /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
/* load/boot image from boot device */ board_init_r(NULL, 0); } + +void spl_board_prepare_for_boot(void) +{ + /* Flush dcache. Without it U-Boot proper would hang at random locations. */ + dcache_disable(); +}
It should be rather direct to migrate this to Kconfig, please do that first, and introduce CONFIG_SPL_SYS_L2_PL310. Thanks!
converting CONFIG_SYS_L2_PL310 - no problem. For SYS_PL310_BASE the moveconfig tool just hangs indefinitely on every defconfig that needs conversion. Do you have any hints on this issue?
Below the Kconfig entry, that I used.
config SYS_PL310_BASE depends on SYS_L2_PL310 hex "Base address of PL310" help Physical base address of PL310 controller register space
Try adding default values for known architectures/socs (use git grep in include/configs/ and sort -u to find out) default 0x1234ab00 if ARCH_FOO default 0x4321cd00 if ARCH_BAR
We can just skip that one for the moment, it's a bit tricky. It shouldn't be asked for as it's not configurable, it needs to be a list of default X if ARCH_Y. Thanks for looking at this one too!
Philip Oberfichtner
