[U-Boot] [PATCH v3 0/8] dm: x86: PCI/SPI fixes for minnowboard MAX
The SPI flash starts off protected on baytrail. The code which is supposed to fix this is broken. This series fixes that, enables the SPI environment and adds documentation.
Also when driver model is enabled for PCI some bugs appear. This series fixes those and enables driver model for PCI on minnowboard MAX.
Changes in v3: - Correct parameter order with ich_writeb() - Drop the asm/pci.h header file also - Drop the patch to board_f.c as it is not needed, and interferes with the fix - Add a comment about why gd->pci_ram_top is being set
Changes in v2: - Continue to use writew for ICH7 - Use ich_read/write() for BIOS protection update - Fix typos in README.x86 - Rename the ops and ids arrays for consistency - Drop the coreboot PCI driver which is no-longer needed - Only limit the PCI system memory region on x86 machines - Use md5sum -b - Rebase on x86/master
Simon Glass (8): dm: spi: Correct status register access width dm: spi: Correct BIOS protection logic for ICH9 dm: spi: Enable environment for minnowmax x86: Add ROM image description for minnowmax x86: pci: Tidy up the generic x86 PCI driver dm: x86: minnowmax: Move PCI to use driver model dm: x86: baytrail: Correct PCI region 3 when driver model is used x86: Add binary blob checksums for Minnowboard MAX
arch/x86/cpu/baytrail/Makefile | 1 - arch/x86/cpu/baytrail/pci.c | 46 --------------------------------------- arch/x86/cpu/coreboot/pci.c | 22 ------------------- arch/x86/cpu/cpu.c | 2 ++ arch/x86/dts/minnowmax.dts | 10 +++++++++ configs/minnowmax_defconfig | 1 + doc/README.x86 | 25 +++++++++++++++++++++ drivers/pci/pci-uclass.c | 8 +++++-- drivers/pci/pci_x86.c | 13 ++++++----- drivers/spi/ich.c | 15 ++++++++----- include/asm-generic/global_data.h | 1 + include/configs/minnowmax.h | 6 ++--- 12 files changed, 65 insertions(+), 85 deletions(-) delete mode 100644 arch/x86/cpu/baytrail/pci.c
The status register on ICH9 is a single byte, so use byte access when writing to it, to avoid updating the control register also.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Jagan Teki jteki@openedev.com ---
Changes in v3: None Changes in v2: - Continue to use writew for ICH7
drivers/spi/ich.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 6b6cfbf..66a5cba 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -411,6 +411,7 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { struct udevice *bus = dev_get_parent(dev); + struct ich_spi_platdata *plat = dev_get_platdata(bus); struct ich_spi_priv *ctlr = dev_get_priv(bus); uint16_t control; int16_t opcode_index; @@ -477,7 +478,10 @@ static int ich_spi_xfer(struct udevice *dev, unsigned int bitlen, if (ret < 0) return ret;
- ich_writew(ctlr, SPIS_CDS | SPIS_FCERR, ctlr->status); + if (plat->ich_version == 7) + ich_writew(ctlr, SPIS_CDS | SPIS_FCERR, ctlr->status); + else + ich_writeb(ctlr, SPIS_CDS | SPIS_FCERR, ctlr->status);
spi_setup_type(trans, using_cmd ? bytes : 0); opcode_index = spi_setup_opcode(ctlr, trans);
Applied to u-boot-x86.
The logic is incorrect and currently has no effect. Fix it so that we can write to SPI flash, since by default it is write-protected.
Changes in v2: - Use ich_read/write() for BIOS protection update
drivers/spi/ich.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 66a5cba..2e388e7 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -40,6 +40,7 @@ struct ich_spi_priv { int status; int control; int bbar; + int bcr; uint32_t *pr; /* only for ich9 */ int speed; /* pointer to speed control */ ulong max_speed; /* Maximum bus speed in MHz */ @@ -239,6 +240,7 @@ static int ich_init_controller(struct ich_spi_platdata *plat, ctlr->speed = ctlr->control + 2; ctlr->bbar = offsetof(struct ich9_spi_regs, bbar); ctlr->preop = offsetof(struct ich9_spi_regs, preop); + ctlr->bcr = offsetof(struct ich9_spi_regs, bcr); ctlr->pr = &ich9_spi->pr[0]; ctlr->base = ich9_spi; } else { @@ -688,13 +690,10 @@ static int ich_spi_probe(struct udevice *bus) * v9, deassert SMM BIOS Write Protect Disable. */ if (plat->use_sbase) { - struct ich9_spi_regs *ich9_spi; - - ich9_spi = priv->base; - bios_cntl = ich_readb(priv, ich9_spi->bcr); + bios_cntl = ich_readb(priv, priv->bcr); bios_cntl &= ~(1 << 5); /* clear Enable InSMM_STS (EISS) */ bios_cntl |= 1; /* Write Protect Disable (WPD) */ - ich_writeb(priv, bios_cntl, ich9_spi->bcr); + ich_writeb(priv, bios_cntl, priv->bcr); } else { pci_read_config_byte(plat->dev, 0xdc, &bios_cntl); if (plat->ich_version == 9)
Changes in v3:
Changes in v2:
Changes in v3:
Changes in v2:
Tested-by: Andrew Bradford andrew.bradford@kodakalaris.com
Thanks! :) -Andrew
Changes in v3:
Changes in v2:
Thanks! :) -Andrew
Enable a SPI environment and store it in a suitable place.
include/configs/minnowmax.h | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index 547765d..d4d28a7 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -65,8 +65,7 @@ /* Avoid a warning in the Realtek Ethernet driver */ #define CONFIG_SYS_CACHELINE_SIZE 16
-/* Environment in SPI flash is unsupported for now */ -#undef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SECT_SIZE 0x1000 +#define CONFIG_ENV_OFFSET 0x007fe000
#endif /* __CONFIG_H */
The layout of the ROM is a bit hard to discover by reading the code. Add a table to make it easier.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v3: None Changes in v2: - Fix typos in README.x86
doc/README.x86 | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/doc/README.x86 b/doc/README.x86 index 49d6e83..e58ca19 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -160,6 +160,23 @@ Now you can build U-Boot and obtain u-boot.rom $ make minnowmax_defconfig $ make all
+The ROM image is broken up into these parts: + +Offset Description Controlling config +------------------------------------------------------------ +000000 descriptor.bin Hard-coded to 0 in ifdtool +001000 me.bin Set by the descriptor +500000 <spare> +700000 u-boot-dtb.bin CONFIG_SYS_TEXT_BASE +790000 vga.bin CONFIG_X86_OPTION_ROM_ADDR +7c0000 fsp.bin CONFIG_FSP_ADDR +7f8000 <spare> (depends on size of fsp.bin) +7fe000 Environment CONFIG_ENV_OFFSET +7ff800 U-Boot 16-bit boot CONFIG_SYS_X86_START16 + +Overall ROM image size is controlled by CONFIG_ROM_SIZE. + + Intel Galileo instructions:
Only one binary blob is needed for Remote Management Unit (RMU) within Intel
This driver should use the x86 PCI configuration functions. Also adjust its compatible string to something generic (i.e. without a vendor name).
Changes in v3: - Drop the asm/pci.h header file also
Changes in v2: - Rename the ops and ids arrays for consistency - Drop the coreboot PCI driver which is no-longer needed
arch/x86/cpu/coreboot/pci.c | 22 ---------------------- drivers/pci/pci_x86.c | 13 ++++++++----- 2 files changed, 8 insertions(+), 27 deletions(-)
diff --git a/arch/x86/cpu/coreboot/pci.c b/arch/x86/cpu/coreboot/pci.c index 67eb14c..41e29a6 100644 --- a/arch/x86/cpu/coreboot/pci.c +++ b/arch/x86/cpu/coreboot/pci.c @@ -11,29 +11,7 @@
#include <common.h> #include <dm.h> -#include <errno.h> #include <pci.h> -#include <asm/io.h> -#include <asm/pci.h> - -DECLARE_GLOBAL_DATA_PTR; - -static const struct dm_pci_ops pci_x86_ops = { - .read_config = pci_x86_read_config, - .write_config = pci_x86_write_config, -}; - -static const struct udevice_id pci_x86_ids[] = { - { .compatible = "pci-x86" }, - { } -}; - -U_BOOT_DRIVER(pci_x86_drv) = { - .name = "pci_x86", - .id = UCLASS_PCI, - .of_match = pci_x86_ids, - .ops = &pci_x86_ops, -};
static const struct udevice_id generic_pch_ids[] = { { .compatible = "intel,pch" }, diff --git a/drivers/pci/pci_x86.c b/drivers/pci/pci_x86.c index 901bdca..89e8c11 100644 --- a/drivers/pci/pci_x86.c +++ b/drivers/pci/pci_x86.c @@ -7,18 +7,21 @@ #include <common.h> #include <dm.h> #include <pci.h> +#include <asm/pci.h>
-static const struct dm_pci_ops x86_pci_ops = { +static const struct dm_pci_ops pci_x86_ops = { + .read_config = pci_x86_read_config, + .write_config = pci_x86_write_config, };
-static const struct udevice_id x86_pci_ids[] = { - { .compatible = "x86,pci" }, +static const struct udevice_id pci_x86_ids[] = { + { .compatible = "pci-x86" }, { } };
U_BOOT_DRIVER(pci_x86) = { .name = "pci_x86", .id = UCLASS_PCI, - .of_match = x86_pci_ids, - .ops = &x86_pci_ops, + .of_match = pci_x86_ids, + .ops = &pci_x86_ops, };
Changes in v3:
Changes in v2:
.name = "pci_x86",
.id = UCLASS_PCI,
Changes in v3:
Changes in v2:
.name = "pci_x86",
.id = UCLASS_PCI,
Adjust minnowmax to use driver model for PCI. This requires adding a device tree node to specify the ranges, removing the board-specific PCI code and ensuring that the host bridge is configured.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Simon Glass sjg@chromium.org ---
arch/x86/cpu/baytrail/Makefile | 1 - arch/x86/cpu/baytrail/pci.c | 46 ------------------------------------------ arch/x86/dts/minnowmax.dts | 10 +++++++++ configs/minnowmax_defconfig | 1 + include/configs/minnowmax.h | 1 + 5 files changed, 12 insertions(+), 47 deletions(-) delete mode 100644 arch/x86/cpu/baytrail/pci.c
diff --git a/arch/x86/cpu/baytrail/Makefile b/arch/x86/cpu/baytrail/Makefile index c78b644..5be5491 100644 --- a/arch/x86/cpu/baytrail/Makefile +++ b/arch/x86/cpu/baytrail/Makefile @@ -7,5 +7,4 @@ obj-y += cpu.o obj-y += early_uart.o obj-y += fsp_configs.o -obj-y += pci.o obj-y += valleyview.o diff --git a/arch/x86/cpu/baytrail/pci.c b/arch/x86/cpu/baytrail/pci.c deleted file mode 100644 index 48409de..0000000 --- a/arch/x86/cpu/baytrail/pci.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * Copyright (C) 2014, Bin Meng bmeng.cn@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <pci.h> -#include <asm/pci.h> -#include <asm/fsp/fsp_support.h> - -DECLARE_GLOBAL_DATA_PTR; - -void board_pci_setup_hose(struct pci_controller *hose) -{ - hose->first_busno = 0; - hose->last_busno = 0; - - /* PCI memory space */ - pci_set_region(hose->regions + 0, - CONFIG_PCI_MEM_BUS, - CONFIG_PCI_MEM_PHYS, - CONFIG_PCI_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI IO space */ - pci_set_region(hose->regions + 1, - CONFIG_PCI_IO_BUS, - CONFIG_PCI_IO_PHYS, - CONFIG_PCI_IO_SIZE, - PCI_REGION_IO); - - pci_set_region(hose->regions + 2, - CONFIG_PCI_PREF_BUS, - CONFIG_PCI_PREF_PHYS, - CONFIG_PCI_PREF_SIZE, - PCI_REGION_PREFETCH); - - pci_set_region(hose->regions + 3, - 0, - 0, - gd->ram_size < 0x80000000 ? gd->ram_size : 0x80000000, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - hose->region_count = 4; -} diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index bd21bfb..0e59b18 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -111,6 +111,16 @@
+ pci { + compatible = "intel,pci-baytrail", "pci-x86"; + #address-cells = <3>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + ranges = <0x02000000 0x0 0xd0000000 0xd0000000 0 0x10000000 + 0x42000000 0x0 0xc0000000 0xc0000000 0 0x10000000 + 0x01000000 0x0 0x2000 0x2000 0 0xe000>; + }; + spi { #address-cells = <1>; #size-cells = <0>; diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 744aca3..ff2bfda 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -12,3 +12,4 @@ CONFIG_CMD_CPU=y CONFIG_CMD_NET=y CONFIG_OF_CONTROL=y CONFIG_CPU=y +CONFIG_DM_PCI=y diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index d4d28a7..41653ba 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -32,6 +32,7 @@ #define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS #define CONFIG_PCI_IO_SIZE 0xe000
+#define CONFIG_PCI_CONFIG_HOST_BRIDGE #define CONFIG_SYS_EARLY_PCI_INIT #define CONFIG_PCI_PNP #define CONFIG_RTL8169
Commit afbbd413a fixed this for non-driver-model. Make sure that the driver model code handles this also.
Changes in v3: - Drop the patch to board_f.c as it is not needed, and interferes with the fix - Add a comment about why gd->pci_ram_top is being set
Changes in v2: - Only limit the PCI system memory region on x86 machines
arch/x86/cpu/cpu.c | 2 ++ drivers/pci/pci-uclass.c | 8 ++++++-- include/asm-generic/global_data.h | 1 + 3 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/cpu.c b/arch/x86/cpu/cpu.c index d108ee5..2b6ed11 100644 --- a/arch/x86/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -351,6 +351,8 @@ int x86_cpu_init_f(void)
gd->arch.has_mtrr = has_mtrr(); } + /* Don't allow PCI region 3 to use memory in the 2-4GB memory hole */ + gd->pci_ram_top = 0x80000000U;
return 0; } diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index edec93f..5b91fe3 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -444,6 +444,7 @@ static int decode_regions(struct pci_controller *hose, const void *blob, { int pci_addr_cells, addr_cells, size_cells; int cells_per_record; + phys_addr_t addr; const u32 *prop; int len; int i; @@ -494,8 +495,11 @@ static int decode_regions(struct pci_controller *hose, const void *blob, }
/* Add a region for our local memory */ - pci_set_region(hose->regions + hose->region_count++, 0, 0, - gd->ram_size, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); + addr = gd->ram_size; + if (gd->pci_ram_top && gd->pci_ram_top < addr) + addr = gd->pci_ram_top; + pci_set_region(hose->regions + hose->region_count++, 0, 0, addr, + PCI_REGION_MEM | PCI_REGION_SYS_MEMORY);
return 0; } diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 6747619..db0550b 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -93,6 +93,7 @@ typedef struct global_data { #endif #ifdef CONFIG_PCI struct pci_controller *hose; /* PCI hose for early use */ + phys_addr_t pci_ram_top; /* top of region accessible to PCI */ #endif #ifdef CONFIG_PCI_BOOTDELAY int pcidelay_done;
Changes in v3:
Changes in v2:
gd->pci_ram_top = 0x80000000U; return 0;
PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); return 0;
#endif #ifdef CONFIG_PCI_BOOTDELAY int pcidelay_done; --
Changes in v3:
Changes in v2:
To try to reduce the pain of confusion of binary blobs, add MD5 checksums for the current versions. This may worsen the situation as new versions appear, but it should still be possible to obtain these versions, and thus get a working setup.
Changes in v3: None Changes in v2: - Use md5sum -b - Rebase on x86/master
doc/README.x86 | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/doc/README.x86 b/doc/README.x86 index e58ca19..022898d 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -160,6 +160,14 @@ Now you can build U-Boot and obtain u-boot.rom $ make minnowmax_defconfig $ make all
+Checksums are as follows (but note that newer versions will invalidate this): + +$ md5sum -b board/intel/minnowmax/*.bin +ffda9a3b94df5b74323afb328d51e6b4 board/intel/minnowmax/descriptor.bin +69f65b9a580246291d20d08cbef9d7c5 board/intel/minnowmax/fsp.bin +894a97d371544ec21de9c3e8e1716c4b board/intel/minnowmax/me.bin +a2588537da387da592a27219d56e9962 board/intel/minnowmax/vga.bin + The ROM image is broken up into these parts:
- Use md5sum -b
- Use md5sum -b
Andrew Bradford
Bin Meng
