[PATCH] rockchip: i2c: fix switch to new implementation for rk3188
The commit e7ae4cf27a6d 'pinctrl: rockchip: Add common rockchip pinctrl driver' dropped rk3188_pinctrl_request operation, that did switching to new implementation.
This commit implement switching to new implementation using writing bits to GRF.
I don't have rk3060 board to test, so switching implemented as a stub returning -ENOSYS.
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com --- drivers/i2c/rk_i2c.c | 42 +++++++++++++++++++++++++++++++----------- 1 file changed, 31 insertions(+), 11 deletions(-)
diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 32b2ee8578..ad3c66843b 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -15,6 +15,8 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/i2c.h> #include <asm/arch-rockchip/periph.h> +#include <asm/arch-rockchip/grf_rk3188.h> +#include <syscon.h> #include <dm/pinctrl.h> #include <linux/sizes.h>
@@ -41,6 +43,7 @@ enum { */ struct rk_i2c_soc_data { int controller_type; + int (*switch_to_new_type)(int bus_nr); };
static inline void rk_i2c_get_div(int div, int *divh, int *divl) @@ -388,11 +391,33 @@ static int rockchip_i2c_ofdata_to_platdata(struct udevice *bus) return 0; }
+static int rockchip_i2c_switch_to_new_type_rk3066(int bus_nr) +{ + return -ENOSYS; +} + +static int rockchip_i2c_switch_to_new_type_rk3188(int bus_nr) +{ + struct rk3188_grf *grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + + if (grf == NULL) + return -ENOSYS; + + if (bus_nr < 0 || bus_nr > (RKI2C4_SEL_SHIFT - RKI2C0_SEL_SHIFT)) + return -EINVAL; + + /* enable new i2c controller */ + rk_clrsetreg(&grf->soc_con1, + 1 << (RKI2C0_SEL_SHIFT + bus_nr), + 1 << (RKI2C0_SEL_SHIFT + bus_nr)); + + return 0; +} + static int rockchip_i2c_probe(struct udevice *bus) { struct rk_i2c *priv = dev_get_priv(bus); struct rk_i2c_soc_data *soc_data; - struct udevice *pinctrl; int bus_nr; int ret;
@@ -408,17 +433,10 @@ static int rockchip_i2c_probe(struct udevice *bus) return ret; }
- ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); - if (ret) { - debug("%s: Cannot find pinctrl device\n", __func__); - return ret; - } - - /* pinctrl will switch I2C to new type */ - ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_I2C0 + bus_nr); - if (ret) { + ret = soc_data->switch_to_new_type(bus_nr); + if (ret < 0) { debug("%s: Failed to switch I2C to new type %s: %d\n", - __func__, bus->name, ret); + __func__, bus->name, ret); return ret; } } @@ -433,10 +451,12 @@ static const struct dm_i2c_ops rockchip_i2c_ops = {
static const struct rk_i2c_soc_data rk3066_soc_data = { .controller_type = RK_I2C_LEGACY, + .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3066, };
static const struct rk_i2c_soc_data rk3188_soc_data = { .controller_type = RK_I2C_LEGACY, + .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3188, };
static const struct rk_i2c_soc_data rk3228_soc_data = {
+David,
Hi David,
Could you help to commend on this?
Hi Alex,
Thanks for your patch.
I don't have rk3060
rk3066
- return -ENOSYS;
- struct rk3188_grf *grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- if (grf == NULL)
return -ENOSYS;
- if (bus_nr < 0 || bus_nr > (RKI2C4_SEL_SHIFT - RKI2C0_SEL_SHIFT))
return -EINVAL;
- /* enable new i2c controller */
- rk_clrsetreg(&grf->soc_con1,
- static int rockchip_i2c_probe(struct udevice *bus) { struct rk_i2c *priv = dev_get_priv(bus); struct rk_i2c_soc_data *soc_data;
if (ret) {
return ret;
if (ret) {
} }__func__, bus->name, ret); return ret;
To make clear, there is kernel driver i2c-rk3x.c. For rk3066 it write bits in the GRF word at offset 0x154. See [1] and [2].
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv... [2] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/driv...
In u-boot there is include file cru_rk3036.h [3]. If this include file valid for rk3066, than offset 0x154 correspond to soc_con3 register. But all documentation I found for 30xx SoC clarify that I2C switch bits located in the soc_con1 registers.
So I don’t know correct location for I2C switch bits.
[3] https://github.com/u-boot/u-boot/blob/master/arch/arm/include/asm/arch-rockc...
27 июня 2020 г., в 17:17, Kever Yang kever.yang@rock-chips.com написал(а):
+David,
Hi David,
Hi Alex,
I don't have rk3060
rk3066
diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 32b2ee8578..ad3c66843b 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -15,6 +15,8 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/i2c.h> #include <asm/arch-rockchip/periph.h> +#include <asm/arch-rockchip/grf_rk3188.h> +#include <syscon.h> #include <dm/pinctrl.h> #include <linux/sizes.h> @@ -41,6 +43,7 @@ enum { */ struct rk_i2c_soc_data { int controller_type;
- int (*switch_to_new_type)(int bus_nr);
}; static inline void rk_i2c_get_div(int div, int *divh, int *divl) @@ -388,11 +391,33 @@ static int rockchip_i2c_ofdata_to_platdata(struct udevice *bus) return 0; } +static int rockchip_i2c_switch_to_new_type_rk3066(int bus_nr) +{
- return -ENOSYS;
- if (grf == NULL)
return -ENOSYS;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
@@ -433,10 +451,12 @@ static const struct dm_i2c_ops rockchip_i2c_ops = { static const struct rk_i2c_soc_data rk3066_soc_data = { .controller_type = RK_I2C_LEGACY,
- .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3066,
}; static const struct rk_i2c_soc_data rk3188_soc_data = { .controller_type = RK_I2C_LEGACY,
- .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3188,
}; static const struct rk_i2c_soc_data rk3228_soc_data = {
Hi Alexander,
Thank you for your patch, the grf header file is missing for rk3066, the GRF_SOC_CON1 offset of 3066 is 0x154, the corresponding bit of i2c0~i2c4 is also bit11 ~ bit15.
There is currently no support for rk3066 at mainline, rk3066 is not handled here, I think it’s okay, so,
Reviewed-by: David Wu david.wu@rock-chips.com
在 2020/6/27 下午11:03, Alexander Kochetkov 写道:
+David,
Hi David,
Hi Alex,
I don't have rk3060
rk3066
- int (*switch_to_new_type)(int bus_nr); }; static inline void rk_i2c_get_div(int div, int *divh, int *divl)
- return -ENOSYS;
- if (grf == NULL)
return -ENOSYS;
return -EINVAL;
- struct udevice *pinctrl; int bus_nr; int ret; @@ -408,17 +433,10 @@ static int rockchip_i2c_probe(struct udevice *bus) return ret; }
if (ret) {
return ret;
if (ret) {
- .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3066, }; static const struct rk_i2c_soc_data rk3188_soc_data = { .controller_type = RK_I2C_LEGACY,
- .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3188, }; static const struct rk_i2c_soc_data rk3228_soc_data = {
Hi Alex,
Am 29.06.2020 um 05:23 schrieb David Wu:
Hi Alexander,
Reviewed-by: Heiko Schocher hs@denx.de
@Kever: Do you pickup this patch? (I cannot find it in patchwork, is it assigned to you?)
bye, Heiko
+David,
Hi David,
Hi Alex,
I don't have rk3060
rk3066
diff --git a/drivers/i2c/rk_i2c.c b/drivers/i2c/rk_i2c.c index 32b2ee8578..ad3c66843b 100644 --- a/drivers/i2c/rk_i2c.c +++ b/drivers/i2c/rk_i2c.c @@ -15,6 +15,8 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/i2c.h> #include <asm/arch-rockchip/periph.h> +#include <asm/arch-rockchip/grf_rk3188.h> +#include <syscon.h> #include <dm/pinctrl.h> #include <linux/sizes.h> @@ -41,6 +43,7 @@ enum { */ struct rk_i2c_soc_data { int controller_type; + int (*switch_to_new_type)(int bus_nr); }; static inline void rk_i2c_get_div(int div, int *divh, int *divl) @@ -388,11 +391,33 @@ static int rockchip_i2c_ofdata_to_platdata(struct udevice *bus) return 0; } +static int rockchip_i2c_switch_to_new_type_rk3066(int bus_nr) +{ + return -ENOSYS; +}
+ return 0; +}
static int rockchip_i2c_probe(struct udevice *bus) { struct rk_i2c *priv = dev_get_priv(bus); struct rk_i2c_soc_data *soc_data; - struct udevice *pinctrl; int bus_nr; int ret; @@ -408,17 +433,10 @@ static int rockchip_i2c_probe(struct udevice *bus) return ret; } - ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); - if (ret) { - debug("%s: Cannot find pinctrl device\n", __func__); - return ret; - }
- /* pinctrl will switch I2C to new type */ - ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_I2C0 + bus_nr); - if (ret) { + ret = soc_data->switch_to_new_type(bus_nr); + if (ret < 0) { debug("%s: Failed to switch I2C to new type %s: %d\n", - __func__, bus->name, ret); + __func__, bus->name, ret); return ret; } } @@ -433,10 +451,12 @@ static const struct dm_i2c_ops rockchip_i2c_ops = { static const struct rk_i2c_soc_data rk3066_soc_data = { .controller_type = RK_I2C_LEGACY, + .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3066, }; static const struct rk_i2c_soc_data rk3188_soc_data = { .controller_type = RK_I2C_LEGACY, + .switch_to_new_type = rockchip_i2c_switch_to_new_type_rk3188, }; static const struct rk_i2c_soc_data rk3228_soc_data = {
Alexander Kochetkov
David Wu
Heiko Schocher
Kever Yang
