[U-Boot] [PATCH v4] spi: davinci: Full dm conversion
davinci_spi now support dt along with platform data, respective boards need to switch into dm for the same.
Cc: Adam Ford aford173@gmail.com Cc: Vitaly Andrianov vitalya@ti.com Cc: Stefano Babic sbabic@denx.de Cc: Peter Howard phoward@gme.net.au Cc: Tom Rini trini@konsulko.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v4, v3, v2: - rebased to master
drivers/spi/Kconfig | 12 +- drivers/spi/davinci_spi.c | 289 +++++++------------------ include/dm/platform_data/spi_davinci.h | 15 ++ 3 files changed, 97 insertions(+), 219 deletions(-) create mode 100644 include/dm/platform_data/spi_davinci.h
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index d046e919b4..18ebff0231 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -80,6 +80,12 @@ config CADENCE_QSPI used to access the SPI NOR flash on platforms embedding this Cadence IP core.
+config DAVINCI_SPI + bool "Davinci & Keystone SPI driver" + depends on ARCH_DAVINCI || ARCH_KEYSTONE + help + Enable the Davinci SPI driver + config DESIGNWARE_SPI bool "Designware SPI driver" help @@ -281,12 +287,6 @@ config FSL_QSPI used to access the SPI NOR flash on platforms embedding this Freescale IP core.
-config DAVINCI_SPI - bool "Davinci & Keystone SPI driver" - depends on ARCH_DAVINCI || ARCH_KEYSTONE - help - Enable the Davinci SPI driver - config SH_SPI bool "SuperH SPI driver" help diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index a822858323..5007e6c618 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -14,6 +14,7 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <dm.h> +#include <dm/platform_data/spi_davinci.h>
/* SPIGCR0 */ #define SPIGCR0_SPIENA_MASK 0x1 @@ -118,9 +119,6 @@ struct davinci_spi_regs {
/* davinci spi slave */ struct davinci_spi_slave { -#ifndef CONFIG_DM_SPI - struct spi_slave slave; -#endif struct davinci_spi_regs *regs; unsigned int freq; /* current SPI bus frequency */ unsigned int mode; /* current SPI mode used */ @@ -240,11 +238,43 @@ static int davinci_spi_read_write(struct davinci_spi_slave *ds, unsigned return 0; }
+static int davinci_spi_set_speed(struct udevice *bus, uint max_hz) +{ + struct davinci_spi_slave *ds = dev_get_priv(bus);
-static int __davinci_spi_claim_bus(struct davinci_spi_slave *ds, int cs) + debug("%s speed %u\n", __func__, max_hz); + if (max_hz > CONFIG_SYS_SPI_CLK / 2) + return -EINVAL; + + ds->freq = max_hz; + + return 0; +} + +static int davinci_spi_set_mode(struct udevice *bus, uint mode) +{ + struct davinci_spi_slave *ds = dev_get_priv(bus); + + debug("%s mode %u\n", __func__, mode); + ds->mode = mode; + + return 0; +} + +static int davinci_spi_claim_bus(struct udevice *dev) { + struct dm_spi_slave_platdata *slave_plat = + dev_get_parent_platdata(dev); + struct udevice *bus = dev->parent; + struct davinci_spi_slave *ds = dev_get_priv(bus); unsigned int mode = 0, scalar;
+ if (slave_plat->cs >= ds->num_cs) { + printf("Invalid SPI chipselect\n"); + return -EINVAL; + } + ds->half_duplex = slave_plat->mode & SPI_PREAMBLE; + /* Enable the SPI hardware */ writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0); udelay(1000); @@ -254,7 +284,7 @@ static int __davinci_spi_claim_bus(struct davinci_spi_slave *ds, int cs) writel(SPIGCR1_MASTER_MASK | SPIGCR1_CLKMOD_MASK, &ds->regs->gcr1);
/* CS, CLK, SIMO and SOMI are functional pins */ - writel(((1 << cs) | SPIPC0_CLKFUN_MASK | + writel(((1 << slave_plat->cs) | SPIPC0_CLKFUN_MASK | SPIPC0_DOFUN_MASK | SPIPC0_DIFUN_MASK), &ds->regs->pc0);
/* setup format */ @@ -292,20 +322,32 @@ static int __davinci_spi_claim_bus(struct davinci_spi_slave *ds, int cs) return 0; }
-static int __davinci_spi_release_bus(struct davinci_spi_slave *ds) +static int davinci_spi_release_bus(struct udevice *dev) { + struct davinci_spi_slave *ds = dev_get_priv(dev->parent); + /* Disable the SPI hardware */ writel(SPIGCR0_SPIRST_MASK, &ds->regs->gcr0);
return 0; }
-static int __davinci_spi_xfer(struct davinci_spi_slave *ds, - unsigned int bitlen, const void *dout, void *din, - unsigned long flags) +static int davinci_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, + unsigned long flags) { + struct dm_spi_slave_platdata *slave = + dev_get_parent_platdata(dev); + struct udevice *bus = dev->parent; + struct davinci_spi_slave *ds = dev_get_priv(bus); unsigned int len;
+ if (slave->cs >= ds->num_cs) { + printf("Invalid SPI chipselect\n"); + return -EINVAL; + } + ds->cur_cs = slave->cs; + if (bitlen == 0) /* Finish any previously submitted transfers */ goto out; @@ -339,240 +381,61 @@ out: u8 dummy = 0; davinci_spi_write(ds, 1, &dummy, flags); } - return 0; -} - -#ifndef CONFIG_DM_SPI - -static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) -{ - return container_of(slave, struct davinci_spi_slave, slave); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - int ret = 0; - - switch (bus) { - case SPI0_BUS: - if (cs < SPI0_NUM_CS) - ret = 1; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - if (cs < SPI1_NUM_CS) - ret = 1; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - if (cs < SPI2_NUM_CS) - ret = 1; - break; -#endif - default: - /* Invalid bus number. Do nothing */ - break; - } - return ret; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* do nothing */ -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* do nothing */ -} - -void spi_init(void) -{ - /* do nothing */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct davinci_spi_slave *ds; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ds = spi_alloc_slave(struct davinci_spi_slave, bus, cs); - if (!ds) - return NULL; - - switch (bus) { - case SPI0_BUS: - ds->regs = (struct davinci_spi_regs *)SPI0_BASE; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - ds->regs = (struct davinci_spi_regs *)SPI1_BASE; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - ds->regs = (struct davinci_spi_regs *)SPI2_BASE; - break; -#endif - default: /* Invalid bus number */ - return NULL; - } - - ds->freq = max_hz; - ds->mode = mode; - - return &ds->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - free(ds); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - ds->cur_cs = slave->cs; - - return __davinci_spi_xfer(ds, bitlen, dout, din, flags); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - -#ifdef CONFIG_SPI_HALF_DUPLEX - ds->half_duplex = true; -#else - ds->half_duplex = false; -#endif - return __davinci_spi_claim_bus(ds, ds->slave.cs); -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - __davinci_spi_release_bus(ds); -} - -#else -static int davinci_spi_set_speed(struct udevice *bus, uint max_hz) -{ - struct davinci_spi_slave *ds = dev_get_priv(bus); - - debug("%s speed %u\n", __func__, max_hz); - if (max_hz > CONFIG_SYS_SPI_CLK / 2) - return -EINVAL; - - ds->freq = max_hz;
return 0; }
-static int davinci_spi_set_mode(struct udevice *bus, uint mode) -{ - struct davinci_spi_slave *ds = dev_get_priv(bus); - - debug("%s mode %u\n", __func__, mode); - ds->mode = mode; - - return 0; -} - -static int davinci_spi_claim_bus(struct udevice *dev) -{ - struct dm_spi_slave_platdata *slave_plat = - dev_get_parent_platdata(dev); - struct udevice *bus = dev->parent; - struct davinci_spi_slave *ds = dev_get_priv(bus); - - if (slave_plat->cs >= ds->num_cs) { - printf("Invalid SPI chipselect\n"); - return -EINVAL; - } - ds->half_duplex = slave_plat->mode & SPI_PREAMBLE; - - return __davinci_spi_claim_bus(ds, slave_plat->cs); -} - -static int davinci_spi_release_bus(struct udevice *dev) -{ - struct davinci_spi_slave *ds = dev_get_priv(dev->parent); - - return __davinci_spi_release_bus(ds); -} +static const struct dm_spi_ops davinci_spi_ops = { + .claim_bus = davinci_spi_claim_bus, + .release_bus = davinci_spi_release_bus, + .xfer = davinci_spi_xfer, + .set_speed = davinci_spi_set_speed, + .set_mode = davinci_spi_set_mode, +};
-static int davinci_spi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, - unsigned long flags) +static int davinci_spi_probe(struct udevice *bus) { - struct dm_spi_slave_platdata *slave = - dev_get_parent_platdata(dev); - struct udevice *bus = dev->parent; struct davinci_spi_slave *ds = dev_get_priv(bus); + struct davinci_spi_platdata *plat = bus->platdata; + ds->regs = plat->regs; + ds->num_cs = plat->num_cs;
- if (slave->cs >= ds->num_cs) { - printf("Invalid SPI chipselect\n"); - return -EINVAL; - } - ds->cur_cs = slave->cs; - - return __davinci_spi_xfer(ds, bitlen, dout, din, flags); -} - -static int davinci_spi_probe(struct udevice *bus) -{ - /* Nothing to do */ return 0; }
+#if CONFIG_IS_ENABLED(OF_CONTROL) static int davinci_ofdata_to_platadata(struct udevice *bus) { - struct davinci_spi_slave *ds = dev_get_priv(bus); - const void *blob = gd->fdt_blob; - int node = dev_of_offset(bus); + struct davinci_spi_platdata *plat = bus->platdata; + fdt_addr_t addr;
- ds->regs = devfdt_map_physmem(bus, sizeof(struct davinci_spi_regs)); - if (!ds->regs) { - printf("%s: could not map device address\n", __func__); + addr = devfdt_get_addr(bus); + if (addr == FDT_ADDR_T_NONE) return -EINVAL; - } - ds->num_cs = fdtdec_get_int(blob, node, "num-cs", 4); + + plat->regs = (struct davinci_spi_regs *)addr; + plat->num_cs = fdtdec_get_int(gd->fdt_blob, dev_of_offset(bus), "num-cs", 4);
return 0; }
-static const struct dm_spi_ops davinci_spi_ops = { - .claim_bus = davinci_spi_claim_bus, - .release_bus = davinci_spi_release_bus, - .xfer = davinci_spi_xfer, - .set_speed = davinci_spi_set_speed, - .set_mode = davinci_spi_set_mode, -}; - static const struct udevice_id davinci_spi_ids[] = { { .compatible = "ti,keystone-spi" }, { .compatible = "ti,dm6441-spi" }, { .compatible = "ti,da830-spi" }, { } }; +#endif
U_BOOT_DRIVER(davinci_spi) = { .name = "davinci_spi", .id = UCLASS_SPI, +#if CONFIG_IS_ENABLED(OF_CONTROL) .of_match = davinci_spi_ids, - .ops = &davinci_spi_ops, .ofdata_to_platdata = davinci_ofdata_to_platadata, - .priv_auto_alloc_size = sizeof(struct davinci_spi_slave), + .platdata_auto_alloc_size = sizeof(struct davinci_spi_platdata), +#endif .probe = davinci_spi_probe, + .ops = &davinci_spi_ops, + .priv_auto_alloc_size = sizeof(struct davinci_spi_slave), }; -#endif diff --git a/include/dm/platform_data/spi_davinci.h b/include/dm/platform_data/spi_davinci.h new file mode 100644 index 0000000000..fbc62c262a --- /dev/null +++ b/include/dm/platform_data/spi_davinci.h @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2018 Jagan Teki jagan@amarulasolutions.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __spi_davinci_h +#define __spi_davinci_h + +struct davinci_spi_platdata { + struct davinci_spi_regs *regs; + u8 num_cs; /* total no. of CS available */ +}; + +#endif /* __spi_davinci_h */
- rebased to master
I reset to origin/master and applied this patch and attempted to build da850evm_defconfig, but I got build errors.
I confirmed that both DM_SPI and DM_SPI_FLASH are both 'y'
drivers/spi/davinci_spi.c: In function ‘davinci_spi_claim_bus’: drivers/spi/davinci_spi.c:272:16: error: dereferencing pointer to incomplete type ‘struct dm_spi_slave_platdata’ if (slave_plat->cs >= ds->num_cs) { ^~ drivers/spi/davinci_spi.c: In function ‘davinci_spi_xfer’: drivers/spi/davinci_spi.c:345:11: error: dereferencing pointer to incomplete type ‘struct dm_spi_slave_platdata’ if (slave->cs >= ds->num_cs) { ^~ drivers/spi/davinci_spi.c: At top level: drivers/spi/davinci_spi.c:388:21: error: variable ‘davinci_spi_ops’ has initializer but incomplete type static const struct dm_spi_ops davinci_spi_ops = { ^~~~~~~~~~ drivers/spi/davinci_spi.c:389:3: error: ‘const struct dm_spi_ops’ has no member named ‘claim_bus’ .claim_bus = davinci_spi_claim_bus, ^~~~~~~~~ drivers/spi/davinci_spi.c:389:15: warning: excess elements in struct initializer .claim_bus = davinci_spi_claim_bus, ^~~~~~~~~~~~~~~~~~~~~ drivers/spi/davinci_spi.c:389:15: note: (near initialization for ‘davinci_spi_ops’) drivers/spi/davinci_spi.c:390:3: error: ‘const struct dm_spi_ops’ has no member named ‘release_bus’ .release_bus = davinci_spi_release_bus, ^~~~~~~~~~~ drivers/spi/davinci_spi.c:390:17: warning: excess elements in struct initializer .release_bus = davinci_spi_release_bus, ^~~~~~~~~~~~~~~~~~~~~~~ drivers/spi/davinci_spi.c:390:17: note: (near initialization for ‘davinci_spi_ops’) drivers/spi/davinci_spi.c:391:3: error: ‘const struct dm_spi_ops’ has no member named ‘xfer’ .xfer = davinci_spi_xfer, ^~~~ drivers/spi/davinci_spi.c:391:11: warning: excess elements in struct initializer .xfer = davinci_spi_xfer, ^~~~~~~~~~~~~~~~ drivers/spi/davinci_spi.c:391:11: note: (near initialization for ‘davinci_spi_ops’) drivers/spi/davinci_spi.c:392:3: error: ‘const struct dm_spi_ops’ has no member named ‘set_speed’ .set_speed = davinci_spi_set_speed, ^~~~~~~~~ drivers/spi/davinci_spi.c:392:15: warning: excess elements in struct initializer .set_speed = davinci_spi_set_speed, ^~~~~~~~~~~~~~~~~~~~~ drivers/spi/davinci_spi.c:392:15: note: (near initialization for ‘davinci_spi_ops’) drivers/spi/davinci_spi.c:393:3: error: ‘const struct dm_spi_ops’ has no member named ‘set_mode’ .set_mode = davinci_spi_set_mode, ^~~~~~~~ drivers/spi/davinci_spi.c:393:14: warning: excess elements in struct initializer .set_mode = davinci_spi_set_mode, ^~~~~~~~~~~~~~~~~~~~ drivers/spi/davinci_spi.c:393:14: note: (near initialization for ‘davinci_spi_ops’) drivers/spi/davinci_spi.c:388:32: error: storage size of ‘davinci_spi_ops’ isn’t known static const struct dm_spi_ops davinci_spi_ops = { ^~~~~~~~~~~~~~~ scripts/Makefile.build:278: recipe for target 'spl/drivers/spi/davinci_spi.o' failed
[snip]
-- 2.18.0.321.gffc6fa0e3
Adam Ford
Jagan Teki
