[U-Boot-Users] [PATCH]: Enable device and console for ARM (III).
Wolfgang,
Here is the patch re-submitted removing the movement of the trab specific code. I just rebuilt it and tried it out on my board and it works. No surprise as I don't have anything trab specific.
The trab not working still surprises me, hopefully this change will fix it. Getting the console working is a GOOD thing for ARM. Being able to use control^c and enabling a clean stdin/out/err is something which should be made to work.
The patch is as before, enables device and console on ARM and sets the baudrate such that bdinfo prints something reasonable.
Regards,
Richard W.
Dear Richard,
in message FD2AC9A020DDD51194710008C7089B20053D4C99@dlee17.itg.ti.com you wrote:
The TRAB is a bit special, for example as you can switch to console interface to a dial out/dial in modem connection, which requires some trickery.
You are right.
Thanks. Added.
A few requests though for your next patch:
* Please stick to the coding standards (i. e. 8 character indents using tab characters). * Do not add trailing white space to the lines * Make sure to run the MAKEALL script, and resolve ALL compiler warnings introduced by your patch.
Woodruff, Richard
