[U-Boot] [PATCH v1 0/3] rtc, dm: add DM/Kconfig support for RTC_RX8025 driver
add DM and Kconfig support for RTC_RX8025 driver.
Based on mainline commit: 6070ef409c - Merge branch '2019-07-12-master-imports'
Travis build: https://travis-ci.org/hsdenx/u-boot-test/builds/558787565
Heiko Schocher (3): rtc: move RTC_RX8025 to Kconfig rtc, rx8025: fix Coding Style rtc, rx8025: add DM support
configs/caddy2_defconfig | 1 + configs/socrates_defconfig | 1 + configs/vme8349_defconfig | 1 + drivers/rtc/Kconfig | 5 + drivers/rtc/rx8025.c | 180 ++++++++++++++++++++++++++++------- include/configs/caddy2.h | 1 - include/configs/socrates.h | 1 - include/configs/vme8349.h | 1 - scripts/config_whitelist.txt | 1 - 9 files changed, 156 insertions(+), 36 deletions(-)
move RTC_RX8025 to Kconfig and fixup board configs.
Signed-off-by: Heiko Schocher hs@denx.de ---
configs/caddy2_defconfig | 1 + configs/socrates_defconfig | 1 + configs/vme8349_defconfig | 1 + drivers/rtc/Kconfig | 5 +++++ include/configs/caddy2.h | 1 - include/configs/socrates.h | 1 - include/configs/vme8349.h | 1 - scripts/config_whitelist.txt | 1 - 8 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 33253b1332..51c37e2e1a 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -111,6 +111,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_E1000=y +CONFIG_RTC_RX8025=y CONFIG_BAUDRATE=9600 CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 2d5e158871..1dadc122cf 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_MARVELL=y CONFIG_MII=y CONFIG_TSEC_ENET=y +CONFIG_RTC_RX8025=y CONFIG_SYS_NS16550=y CONFIG_USB=y # CONFIG_USB_EHCI_HCD is not set diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 77c7904a2c..f6b9eb6c2c 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -114,6 +114,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_MARVELL=y CONFIG_TSEC_ENET=y +CONFIG_RTC_RX8025=y CONFIG_BAUDRATE=9600 CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index 532e94d337..023bcac286 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -86,6 +86,11 @@ config RTC_RX8010SJ help Support for Epson RX8010SJ Real Time Clock devices.
+config RTC_RX8025 + bool "Enable RX8025 driver" + help + Support for Epson RX8025 Real Time Clock devices. + config RTC_PL031 bool "Enable ARM AMBA PL031 RTC driver" help diff --git a/include/configs/caddy2.h b/include/configs/caddy2.h index 15ac17985f..89deeac4e7 100644 --- a/include/configs/caddy2.h +++ b/include/configs/caddy2.h @@ -225,7 +225,6 @@ */ #define CONFIG_SYS_RTC_BUS_NUM 0x01 #define CONFIG_SYS_I2C_RTC_ADDR 0x32 -#define CONFIG_RTC_RX8025
/* Pass Ethernet MAC to VxWorks */ #define CONFIG_SYS_VXWORKS_MAC_PTR 0x000043f0 diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 3f84fabdb6..7d266d1bcd 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -187,7 +187,6 @@ #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100
/* I2C RTC */ -#define CONFIG_RTC_RX8025 /* Use Epson rx8025 rtc via i2c */ #define CONFIG_SYS_I2C_RTC_ADDR 0x32 /* at address 0x32 */
/* I2C W83782G HW-Monitoring IC */ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 1c3430d849..a4f2af4962 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -225,7 +225,6 @@ */ #define CONFIG_SYS_RTC_BUS_NUM 0x01 #define CONFIG_SYS_I2C_RTC_ADDR 0x32 -#define CONFIG_RTC_RX8025
/* Pass Ethernet MAC to VxWorks */ #define CONFIG_SYS_VXWORKS_MAC_PTR 0x000043f0 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2c9cfb450d..4ffc4bb9ec 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1559,7 +1559,6 @@ CONFIG_RTC_MCP79411 CONFIG_RTC_MXS CONFIG_RTC_PCF8563 CONFIG_RTC_PT7C4338 -CONFIG_RTC_RX8025 CONFIG_RUN_FROM_DDR0 CONFIG_RUN_FROM_DDR1 CONFIG_RUN_FROM_IRAM_ONLY
fix Coding Style for this driver.
drivers/rtc/rx8025.c | 58 ++++++++++++++++++++++---------------------- 1 file changed, 29 insertions(+), 29 deletions(-)
diff --git a/drivers/rtc/rx8025.c b/drivers/rtc/rx8025.c index 7bd9f8b42a..b3826e950d 100644 --- a/drivers/rtc/rx8025.c +++ b/drivers/rtc/rx8025.c @@ -70,12 +70,12 @@ /* static uchar rtc_read (uchar reg); */ #define rtc_read(reg) buf[((reg) + 1) & 0xf]
-static void rtc_write (uchar reg, uchar val); +static void rtc_write(uchar reg, uchar val);
/* * Get the current time from the RTC */ -int rtc_get (struct rtc_time *tmp) +int rtc_get(struct rtc_time *tmp) { int rel = 0; uchar sec, min, hour, mday, wday, mon, year, ctl2; @@ -92,9 +92,9 @@ int rtc_get (struct rtc_time *tmp) mon = rtc_read(RTC_MON_REG_ADDR); year = rtc_read(RTC_YR_REG_ADDR);
- DEBUGR ("Get RTC year: %02x mon: %02x mday: %02x wday: %02x " - "hr: %02x min: %02x sec: %02x\n", - year, mon, mday, wday, hour, min, sec); + DEBUGR("Get RTC year: %02x mon: %02x mday: %02x wday: %02x " + "hr: %02x min: %02x sec: %02x\n", + year, mon, mday, wday, hour, min, sec);
/* dump status */ ctl2 = rtc_read(RTC_CTL2_REG_ADDR); @@ -113,13 +113,14 @@ int rtc_get (struct rtc_time *tmp) rel = -1; }
- tmp->tm_sec = bcd2bin (sec & 0x7F); - tmp->tm_min = bcd2bin (min & 0x7F); + tmp->tm_sec = bcd2bin(sec & 0x7F); + tmp->tm_min = bcd2bin(min & 0x7F); if (rtc_read(RTC_CTL1_REG_ADDR) & RTC_CTL1_BIT_2412) - tmp->tm_hour = bcd2bin (hour & 0x3F); + tmp->tm_hour = bcd2bin(hour & 0x3F); else - tmp->tm_hour = bcd2bin (hour & 0x1F) % 12 + + tmp->tm_hour = bcd2bin(hour & 0x1F) % 12 + ((hour & 0x20) ? 12 : 0); + tmp->tm_mday = bcd2bin (mday & 0x3F); tmp->tm_mon = bcd2bin (mon & 0x1F); tmp->tm_year = bcd2bin (year) + ( bcd2bin (year) >= 70 ? 1900 : 2000); @@ -127,9 +128,9 @@ int rtc_get (struct rtc_time *tmp) tmp->tm_yday = 0; tmp->tm_isdst= 0;
- DEBUGR ("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + DEBUGR("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec);
return rel; } @@ -137,24 +138,24 @@ int rtc_get (struct rtc_time *tmp) /* * Set the RTC */ -int rtc_set (struct rtc_time *tmp) +int rtc_set(struct rtc_time *tmp) { - DEBUGR ("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + DEBUGR("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec);
if (tmp->tm_year < 1970 || tmp->tm_year > 2069) printf("WARNING: year should be between 1970 and 2069!\n");
- rtc_write (RTC_YR_REG_ADDR, bin2bcd (tmp->tm_year % 100)); - rtc_write (RTC_MON_REG_ADDR, bin2bcd (tmp->tm_mon)); - rtc_write (RTC_DAY_REG_ADDR, bin2bcd (tmp->tm_wday)); - rtc_write (RTC_DATE_REG_ADDR, bin2bcd (tmp->tm_mday)); - rtc_write (RTC_HR_REG_ADDR, bin2bcd (tmp->tm_hour)); - rtc_write (RTC_MIN_REG_ADDR, bin2bcd (tmp->tm_min)); - rtc_write (RTC_SEC_REG_ADDR, bin2bcd (tmp->tm_sec)); + rtc_write(RTC_YR_REG_ADDR, bin2bcd(tmp->tm_year % 100)); + rtc_write(RTC_MON_REG_ADDR, bin2bcd(tmp->tm_mon)); + rtc_write(RTC_DAY_REG_ADDR, bin2bcd(tmp->tm_wday)); + rtc_write(RTC_DATE_REG_ADDR, bin2bcd(tmp->tm_mday)); + rtc_write(RTC_HR_REG_ADDR, bin2bcd(tmp->tm_hour)); + rtc_write(RTC_MIN_REG_ADDR, bin2bcd(tmp->tm_min)); + rtc_write(RTC_SEC_REG_ADDR, bin2bcd(tmp->tm_sec));
- rtc_write (RTC_CTL1_REG_ADDR, RTC_CTL1_BIT_2412); + rtc_write(RTC_CTL1_REG_ADDR, RTC_CTL1_BIT_2412);
return 0; } @@ -162,29 +163,28 @@ int rtc_set (struct rtc_time *tmp) /* * Reset the RTC */ -void rtc_reset (void) +void rtc_reset(void) { uchar buf[16]; uchar ctl2;
- if (i2c_read(CONFIG_SYS_I2C_RTC_ADDR, 0, 0, buf, 16)) + if (i2c_read(CONFIG_SYS_I2C_RTC_ADDR, 0, 0, buf, 16)) printf("Error reading from RTC\n");
ctl2 = rtc_read(RTC_CTL2_REG_ADDR); ctl2 &= ~(RTC_CTL2_BIT_PON | RTC_CTL2_BIT_VDET); ctl2 |= RTC_CTL2_BIT_XST | RTC_CTL2_BIT_VDSL; - rtc_write (RTC_CTL2_REG_ADDR, ctl2); + rtc_write(RTC_CTL2_REG_ADDR, ctl2); }
/* * Helper functions */ -static void rtc_write (uchar reg, uchar val) +static void rtc_write(uchar reg, uchar val) { uchar buf[2]; buf[0] = reg << 4; buf[1] = val; if (i2c_write(CONFIG_SYS_I2C_RTC_ADDR, 0, 0, buf, 2) != 0) printf("Error writing to RTC\n"); - }
add DM support for this RTC driver.
drivers/rtc/rx8025.c | 154 +++++++++++++++++++++++++++++++++++++------ 1 file changed, 135 insertions(+), 19 deletions(-)
diff --git a/drivers/rtc/rx8025.c b/drivers/rtc/rx8025.c index b3826e950d..e717dcbbfe 100644 --- a/drivers/rtc/rx8025.c +++ b/drivers/rtc/rx8025.c @@ -10,8 +10,9 @@
#include <common.h> #include <command.h> -#include <rtc.h> +#include <dm.h> #include <i2c.h> +#include <rtc.h>
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC @@ -27,6 +28,18 @@ # define CONFIG_SYS_I2C_RTC_ADDR 0x32 #endif
+#ifdef CONFIG_DM_RTC +#define DEV_TYPE struct udevice +#else +/* Local udevice */ +struct ludevice { + u8 chip; +}; + +#define DEV_TYPE struct ludevice + +#endif + /* * RTC register addresses */ @@ -68,21 +81,35 @@ */
/* static uchar rtc_read (uchar reg); */ +#ifdef CONFIG_DM_RTC +/* + * on mpc85xx based board with DM and offset len 1 + * accessing rtc works fine. May we can drop this ? + */ +#define rtc_read(reg) buf[(reg) & 0xf] +#else #define rtc_read(reg) buf[((reg) + 1) & 0xf] +#endif
-static void rtc_write(uchar reg, uchar val); +static int rtc_write(DEV_TYPE *dev, uchar reg, uchar val);
/* * Get the current time from the RTC */ -int rtc_get(struct rtc_time *tmp) +static int rx8025_rtc_get(DEV_TYPE *dev, struct rtc_time *tmp) { int rel = 0; uchar sec, min, hour, mday, wday, mon, year, ctl2; uchar buf[16];
- if (i2c_read(CONFIG_SYS_I2C_RTC_ADDR, 0, 0, buf, 16)) +#ifdef CONFIG_DM_RTC + if (dm_i2c_read(dev, 0, buf, sizeof(buf))) { +#else + if (i2c_read(dev->chip, 0, 0, buf, 16)) { +#endif printf("Error reading from RTC\n"); + return -EIO; + }
sec = rtc_read(RTC_SEC_REG_ADDR); min = rtc_read(RTC_MIN_REG_ADDR); @@ -138,7 +165,7 @@ int rtc_get(struct rtc_time *tmp) /* * Set the RTC */ -int rtc_set(struct rtc_time *tmp) +static int rx8025_rtc_set(DEV_TYPE *dev, const struct rtc_time *tmp) { DEBUGR("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, @@ -147,44 +174,133 @@ int rtc_set(struct rtc_time *tmp) if (tmp->tm_year < 1970 || tmp->tm_year > 2069) printf("WARNING: year should be between 1970 and 2069!\n");
- rtc_write(RTC_YR_REG_ADDR, bin2bcd(tmp->tm_year % 100)); - rtc_write(RTC_MON_REG_ADDR, bin2bcd(tmp->tm_mon)); - rtc_write(RTC_DAY_REG_ADDR, bin2bcd(tmp->tm_wday)); - rtc_write(RTC_DATE_REG_ADDR, bin2bcd(tmp->tm_mday)); - rtc_write(RTC_HR_REG_ADDR, bin2bcd(tmp->tm_hour)); - rtc_write(RTC_MIN_REG_ADDR, bin2bcd(tmp->tm_min)); - rtc_write(RTC_SEC_REG_ADDR, bin2bcd(tmp->tm_sec)); + if (rtc_write(dev, RTC_YR_REG_ADDR, bin2bcd(tmp->tm_year % 100))) + return -EIO;
- rtc_write(RTC_CTL1_REG_ADDR, RTC_CTL1_BIT_2412); + if (rtc_write(dev, RTC_MON_REG_ADDR, bin2bcd(tmp->tm_mon))) + return -EIO;
- return 0; + if (rtc_write(dev, RTC_DAY_REG_ADDR, bin2bcd(tmp->tm_wday))) + return -EIO; + + if (rtc_write(dev, RTC_DATE_REG_ADDR, bin2bcd(tmp->tm_mday))) + return -EIO; + + if (rtc_write(dev, RTC_HR_REG_ADDR, bin2bcd(tmp->tm_hour))) + return -EIO; + + if (rtc_write(dev, RTC_MIN_REG_ADDR, bin2bcd(tmp->tm_min))) + return -EIO; + + if (rtc_write(dev, RTC_SEC_REG_ADDR, bin2bcd(tmp->tm_sec))) + return -EIO; + + return rtc_write(dev, RTC_CTL1_REG_ADDR, RTC_CTL1_BIT_2412); }
/* * Reset the RTC */ -void rtc_reset(void) +static int rx8025_rtc_reset(DEV_TYPE *dev) { uchar buf[16]; uchar ctl2;
ctl2 = rtc_read(RTC_CTL2_REG_ADDR); ctl2 &= ~(RTC_CTL2_BIT_PON | RTC_CTL2_BIT_VDET); ctl2 |= RTC_CTL2_BIT_XST | RTC_CTL2_BIT_VDSL; - rtc_write(RTC_CTL2_REG_ADDR, ctl2); + + return rtc_write(dev, RTC_CTL2_REG_ADDR, ctl2); }
/* * Helper functions */ -static void rtc_write(uchar reg, uchar val) +static int rtc_write(DEV_TYPE *dev, uchar reg, uchar val) { uchar buf[2]; buf[0] = reg << 4; buf[1] = val; - if (i2c_write(CONFIG_SYS_I2C_RTC_ADDR, 0, 0, buf, 2) != 0) + +#ifdef CONFIG_DM_RTC + if (dm_i2c_write(dev, 0, buf, 2)) { +#else + if (i2c_write(dev->chip, 0, 0, buf, 2) != 0) { +#endif printf("Error writing to RTC\n"); + return -EIO; + } + + return 0; +} + +#ifdef CONFIG_DM_RTC +static int rx8025_probe(struct udevice *dev) +{ + uchar buf[16]; + int ret = 0; + + if (i2c_get_chip_offset_len(dev) != 1) + ret = i2c_set_chip_offset_len(dev, 1); + + if (ret) + return ret; + + return dm_i2c_read(dev, 0, buf, sizeof(buf)); +} + +static const struct rtc_ops rx8025_rtc_ops = { + .get = rx8025_rtc_get, + .set = rx8025_rtc_set, + .reset = rx8025_rtc_reset, +}; + +static const struct udevice_id rx8025_rtc_ids[] = { + { .compatible = "epson,rx8025" }, + { } +}; + +U_BOOT_DRIVER(rx8010sj_rtc) = { + .name = "rx8025_rtc", + .id = UCLASS_RTC, + .probe = rx8025_probe, + .of_match = rx8025_rtc_ids, + .ops = &rx8025_rtc_ops, +}; +#else +int rtc_get(struct rtc_time *tm) +{ + struct ludevice dev = { + .chip = CONFIG_SYS_I2C_RTC_ADDR, + }; + + return rx8025_rtc_get(&dev, tm); +} + +int rtc_set(struct rtc_time *tm) +{ + struct ludevice dev = { + .chip = CONFIG_SYS_I2C_RTC_ADDR, + }; + + return rx8025_rtc_set(&dev, tm); } + +void rtc_reset(void) +{ + struct ludevice dev = { + .chip = CONFIG_SYS_I2C_RTC_ADDR, + }; + + rx8025_rtc_reset(&dev); +} +#endif
Heiko Schocher
