[U-Boot-Users] [PATCH] [ads5121] DDR2 init/timing update.
From Chris Alger's CW bluestone config file.
Signed-off-by: John Rigby jrigby@freescale.com Signed-off-by: Grzegorz Bernacki gjb@semihalf.com --- This patch was created by John Rigby. I tested it and rebased against current top of the tree.
board/ads5121/ads5121.c | 36 ++++++++++++++++++++++-------------- include/configs/ads5121.h | 10 +++++----- 2 files changed, 27 insertions(+), 19 deletions(-)
diff --git a/board/ads5121/ads5121.c b/board/ads5121/ads5121.c index 1582c22..b89dca8 100644 --- a/board/ads5121/ads5121.c +++ b/board/ads5121/ads5121.c @@ -126,24 +126,24 @@ long int fixed_sdram (void) im->mddrc.prioman_config2 = CFG_MDDRCGRP_PM_CFG2; im->mddrc.hiprio_config = CFG_MDDRCGRP_HIPRIO_CFG; im->mddrc.lut_table0_main_upper = CFG_MDDRCGRP_LUT0_MU; - im->mddrc.lut_table1_main_upper = CFG_MDDRCGRP_LUT1_MU; - im->mddrc.lut_table2_main_upper = CFG_MDDRCGRP_LUT2_MU; - im->mddrc.lut_table3_main_upper = CFG_MDDRCGRP_LUT3_MU; - im->mddrc.lut_table4_main_upper = CFG_MDDRCGRP_LUT4_MU; im->mddrc.lut_table0_main_lower = CFG_MDDRCGRP_LUT0_ML; + im->mddrc.lut_table1_main_upper = CFG_MDDRCGRP_LUT1_MU; im->mddrc.lut_table1_main_lower = CFG_MDDRCGRP_LUT1_ML; + im->mddrc.lut_table2_main_upper = CFG_MDDRCGRP_LUT2_MU; im->mddrc.lut_table2_main_lower = CFG_MDDRCGRP_LUT2_ML; + im->mddrc.lut_table3_main_upper = CFG_MDDRCGRP_LUT3_MU; im->mddrc.lut_table3_main_lower = CFG_MDDRCGRP_LUT3_ML; + im->mddrc.lut_table4_main_upper = CFG_MDDRCGRP_LUT4_MU; im->mddrc.lut_table4_main_lower = CFG_MDDRCGRP_LUT4_ML; im->mddrc.lut_table0_alternate_upper = CFG_MDDRCGRP_LUT0_AU; - im->mddrc.lut_table1_alternate_upper = CFG_MDDRCGRP_LUT1_AU; - im->mddrc.lut_table2_alternate_upper = CFG_MDDRCGRP_LUT2_AU; - im->mddrc.lut_table3_alternate_upper = CFG_MDDRCGRP_LUT3_AU; - im->mddrc.lut_table4_alternate_upper = CFG_MDDRCGRP_LUT4_AU; im->mddrc.lut_table0_alternate_lower = CFG_MDDRCGRP_LUT0_AL; + im->mddrc.lut_table1_alternate_upper = CFG_MDDRCGRP_LUT1_AU; im->mddrc.lut_table1_alternate_lower = CFG_MDDRCGRP_LUT1_AL; + im->mddrc.lut_table2_alternate_upper = CFG_MDDRCGRP_LUT2_AU; im->mddrc.lut_table2_alternate_lower = CFG_MDDRCGRP_LUT2_AL; + im->mddrc.lut_table3_alternate_upper = CFG_MDDRCGRP_LUT3_AU; im->mddrc.lut_table3_alternate_lower = CFG_MDDRCGRP_LUT3_AL; + im->mddrc.lut_table4_alternate_upper = CFG_MDDRCGRP_LUT4_AU; im->mddrc.lut_table4_alternate_lower = CFG_MDDRCGRP_LUT4_AL;
/* Initialize MDDRC */ @@ -157,18 +157,26 @@ long int fixed_sdram (void) im->mddrc.ddr_command = CFG_MICRON_NOP;
im->mddrc.ddr_command = CFG_MICRON_PCHG_ALL; + im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = CFG_MICRON_RFSH; + im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = CFG_MICRON_RFSH; + im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = 0x01000432; + im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = CFG_MICRON_EM2; + im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = CFG_MICRON_PCHG_ALL; im->mddrc.ddr_command = CFG_MICRON_EM2; im->mddrc.ddr_command = CFG_MICRON_EM3; im->mddrc.ddr_command = CFG_MICRON_EN_DLL; - im->mddrc.ddr_command = CFG_MICRON_RST_DLL; + im->mddrc.ddr_command = 0x01000432; im->mddrc.ddr_command = CFG_MICRON_PCHG_ALL; im->mddrc.ddr_command = CFG_MICRON_RFSH; - im->mddrc.ddr_command = CFG_MICRON_INIT_DEV_OP; + im->mddrc.ddr_command = 0x01000432; im->mddrc.ddr_command = CFG_MICRON_OCD_DEFAULT; - im->mddrc.ddr_command = CFG_MICRON_OCD_EXIT; - - for (i = 0; i < 10; i++) - im->mddrc.ddr_command = CFG_MICRON_NOP; + im->mddrc.ddr_command = CFG_MICRON_PCHG_ALL; + im->mddrc.ddr_command = CFG_MICRON_NOP;
/* Start MDDRC */ im->mddrc.ddr_time_config0 = CFG_MDDRC_TIME_CFG0_RUN; diff --git a/include/configs/ads5121.h b/include/configs/ads5121.h index ce458ae..d741fc4 100644 --- a/include/configs/ads5121.h +++ b/include/configs/ads5121.h @@ -109,11 +109,11 @@ * [04:00] DRAM tRPA */
-#define CFG_MDDRC_SYS_CFG 0xF8604200 -#define CFG_MDDRC_SYS_CFG_RUN 0xE8604200 -#define CFG_MDDRC_SYS_CFG_EN 0x30000000 -#define CFG_MDDRC_TIME_CFG0 0x0000281E -#define CFG_MDDRC_TIME_CFG0_RUN 0x01F4281E +#define CFG_MDDRC_SYS_CFG 0xF8604A00 +#define CFG_MDDRC_SYS_CFG_RUN 0xE8604A00 +#define CFG_MDDRC_SYS_CFG_EN 0xF0000000 +#define CFG_MDDRC_TIME_CFG0 0x00003D2E +#define CFG_MDDRC_TIME_CFG0_RUN 0x06183D2E #define CFG_MDDRC_TIME_CFG1 0x54EC1168 #define CFG_MDDRC_TIME_CFG2 0x35210864
Grzegorz Bernacki
