[U-Boot] [PATCH] mx6ull_14x14_evk: Add README file
Add a README file to help users getting started with the board.
Signed-off-by: Diego Dorta diego.dorta@nxp.com --- board/freescale/mx6ullevk/README | 36 ++++++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+) create mode 100644 board/freescale/mx6ullevk/README
diff --git a/board/freescale/mx6ullevk/README b/board/freescale/mx6ullevk/README new file mode 100644 index 0000000..d5c8770 --- /dev/null +++ b/board/freescale/mx6ullevk/README @@ -0,0 +1,36 @@ +How to use U-Boot on Freescale MX6ULL 14x14 EVK +---------------------------------------------- + +- First make sure you have installed the dtc package (device tree compiler): + +$ sudo apt-get install device-tree-compiler + +- Build U-Boot for MX6ULL 14x14 EVK: + +$ make mrproper +$ make mx6ull_14x14_evk_defconfig +$ make + +This generates the u-boot-dtb.imx image in the current directory. + +- Flash the u-boot-dtb.imx image into the micro SD card: + +$ sudo dd if=u-boot-dtb.imx of=/dev/sdb bs=1K seek=1 && sync + +- Jumper settings: + +SW601: 0 0 1 0 +Sw602: 1 0 + +Where 0 means bottom position and 1 means top position (from the switch label +numbers reference). + +Connect the USB cable between the EVK and the PC for the console. +(The USB console connector is the one close the push buttons) + +Insert the micro SD card in the board, power it up and U-Boot messages should +come up. + +The link for the board: http://www.nxp.com/products/microcontrollers-and- \ +processors/arm-processors/i.mx-applications-processors/i.mx-6-processors/ \ +i.mx6qp/evaluation-kit-for-the-i.mx-6ull-applications-processor:MCIMX6ULL-EVK
Looks good:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Hi Diego,
-----Original Message----- From: Diego Dorta [mailto:diego.dorta@nxp.com] Sent: Friday, November 11, 2016 1:06 AM To: sbabic@denx.de; Peng Fan peng.fan@nxp.com; u-boot@lists.denx.de Cc: Diego Dorta diego.dorta@nxp.com Subject: [PATCH] mx6ull_14x14_evk: Add README file
Reviewed-by: Peng Fan peng.fan@nxp.com
Thanks, Peng.
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Signed-off-by: Diego Dorta diego.dorta@nxp.com Reviewed-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Jagan Teki jagan@openedev.com
participants (5)
Diego Dorta
Fabio Estevam
Jagan Teki
Peng Fan
