[PATCH v2] riscv: Fix arch_fixup_fdt always failing without /chosen
If /chosen was missing, chosen_offset would never get updated with the new /chosen node. This would cause fdt_setprop_u32 to fail. This patch fixes this by setting chosen_offset. In addition, log any errors from setting boot-hartid as well.
Fixes: 5370478d1c7 ("riscv: Add boot hartid to device tree") Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com Reviewed-by: Atish Patra atish.patra@wdc.com --- I have not actually tested this (nor observed the original failure). But this seemed buggy from inspection.
Changes in v2: - Fix "Fixes" pointing to wrong commit
arch/riscv/lib/fdt_fixup.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index 1f3f23621c..f636b28449 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -151,14 +151,17 @@ int arch_fixup_fdt(void *blob) } chosen_offset = fdt_path_offset(blob, "/chosen"); if (chosen_offset < 0) { - err = fdt_add_subnode(blob, 0, "chosen"); - if (err < 0) { + chosen_offset = fdt_add_subnode(blob, 0, "chosen"); + if (chosen_offset < 0) { log_err("chosen node cannot be added\n"); - return err; + return chosen_offset; } } /* Overwrite the boot-hartid as U-Boot is the last stage BL */ - fdt_setprop_u32(blob, chosen_offset, "boot-hartid", gd->arch.boot_hart); + err = fdt_setprop_u32(blob, chosen_offset, "boot-hartid", + gd->arch.boot_hart); + if (err < 0) + return log_msg_ret("could not set boot-hartid", err); #endif
/* Copy the reserved-memory node to the DT used by OS */
Sean Anderson
