[PULL] Pull request for u-boot master / v2023.07 = u-boot-stm32_20230409
Hi Tom
Please pull the STM32 related fixes for u-boot/master, v2023.07: u-boot-stm32-20230419
CI status: https://source.denx.de/u-boot/custodians/u-boot-stm/-/pipelines/16033
The following changes since commit 5db4972a5bbdbf9e3af48ffc9bc4fec73b7b6a79:
Merge tag 'u-boot-nand-20230417' of https://source.denx.de/u-boot/custodians/u-boot-nand-flash (2023-04-17 10:47:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-stm.git tags/u-boot-stm32-20230419
for you to fetch changes up to 0d5bd362f61dd3dc54f9a32fd38541b8d5c5d869:
configs: stm32mp15: set CONFIG_USB_HUB_DEBOUNCE_TIMEOUT=2s (2023-04-19 10:10:17 +0200)
---------------------------------------------------------------- configs: _ Add usb_pgood_delay for ST boards _ increase malloc size for pre-reloc for stm32mp15 _ Set CONFIG_USB_HUB_DEBOUNCE_TIMEOUT=2s for stm32mp15
dts: _ Add QSPI support on STM32MP13x SoC family _ Add FMC support on STM32MP13x SoC family
drivers/machine: _ pinctrl_stm32: Add slew rate support for stm32_pinctrl_get_pin_muxing() _ spi: stm32_qspi: Remove useless struct stm32_qspi_flash _ rawnand: stm32_fmc2: remove unsupported EDO mode _ stm32mp: fix various array bounds checks
---------------------------------------------------------------- Christophe Kerello (2): ARM: dts: stm32: add FMC support on STM32MP13x SoC family mtd: rawnand: stm32_fmc2: remove unsupported EDO mode
Patrice Chotard (5): configs: stm32mp15: Add usb_pgood_delay for ST boards configs: stm32mp13: Increase usb_pgood_delay for ST boards pinctrl: pinctrl_stm32: Add slew rate support for stm32_pinctrl_get_pin_muxing() ARM: dts: stm32: Add QSPI support on STM32MP13x SoC family spi: stm32_qspi: Remove useless struct stm32_qspi_flash
Patrick Delaunay (2): configs: stm32mp15: increase malloc size for pre-reloc configs: stm32mp15: set CONFIG_USB_HUB_DEBOUNCE_TIMEOUT=2s
Rasmus Villemoes (1): stm32mp: fix various array bounds checks
arch/arm/dts/stm32mp131.dtsi | 48 ++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-stm32mp/cpu.c | 4 ++-- board/st/stm32mp1/stm32mp1.c | 2 +- configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_defconfig | 3 ++- configs/stm32mp15_trusted_defconfig | 1 + drivers/mtd/nand/raw/stm32_fmc2_nand.c | 3 +++ drivers/pinctrl/pinctrl_stm32.c | 19 +++++++++++++++---- drivers/ram/stm32mp1/stm32mp1_interactive.c | 2 +- drivers/spi/stm32_qspi.c | 27 +++------------------------ include/configs/stm32mp13_st_common.h | 2 +- include/configs/stm32mp15_st_common.h | 1 + 12 files changed, 79 insertions(+), 34 deletions(-)
On Wed, Apr 19, 2023 at 11:35:58AM +0200, Patrice CHOTARD wrote:
Hi Tom
Patrice CHOTARD
