[U-Boot-Users] initializing environment buffer in flash
Hi -
I am saving my environment to flash and relocating it from flash to ram when uboot starts. After I burn the flash, and run uboot, I noticed that the environment that was relocated had garbage data in it. I need to figure out if my build is incorrect, and if not, how can I define a buffer in uboot that is located at a fixed address, and is intialized to all zeros
In message 200403301343.i2UDh7Ug029908@mxsf27.cluster1.charter.net you wrote:
Please restrict your line length to some 70 characters or so.
Your build is obviously incorrect, as it doesn't run correctly ;-)
You can create a data aobject of sufficient size and edit the linker sript to place it where you like, but I cannot see a valid reason why you would want to do that. If you need zeroed RAM, just use data in BSS.
jwalden123@charter.net
