[PATCH] arm: dts: stm32mp15: alignment with v5.18
Device tree alignment with Linux kernel v5.18-rc2: - ARM: dts: stm32: Add support for the emtrion emSBC-Argon (only the pincontrol part) - ARM: dts: stm32: Drop duplicate status okay from DHCOM gpioc node - ARM: dts: stm32: add st,stm32-sdmmc2 compatible on stm32mp151 - ARM: dts: stm32: fix AV96 board SAI2 pin muxing on stm32mp15 - ARM: dts: stm32: use exti 19 as main interrupt to support RTC wakeup on stm32mp157 - ARM: dts: stm32: add DMA configuration to UART nodes on stm32mp151 - ARM: dts: stm32: keep uart4 behavior on * - ARM: dts: stm32: Correct masks for GIC PPI interrupts on stm32mp15
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/dts/stm32mp15-pinctrl.dtsi | 92 +++++++++++++++++++ arch/arm/dts/stm32mp15-u-boot.dtsi | 12 --- arch/arm/dts/stm32mp151.dtsi | 37 ++++++-- arch/arm/dts/stm32mp153.dtsi | 7 ++ .../stm32mp157a-icore-stm32mp1-ctouch2.dts | 2 + .../stm32mp157a-icore-stm32mp1-edimm2.2.dts | 2 + ...157a-microgea-stm32mp1-microdev2.0-of7.dts | 4 + ...32mp157a-microgea-stm32mp1-microdev2.0.dts | 4 + arch/arm/dts/stm32mp157c-ed1.dts | 2 + arch/arm/dts/stm32mp157c-odyssey.dts | 2 + arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi | 4 + arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi | 4 + arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi | 4 + arch/arm/dts/stm32mp15xx-dhcom-som.dtsi | 3 +- arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 6 ++ arch/arm/dts/stm32mp15xx-dkx.dtsi | 4 + 16 files changed, 168 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-pinctrl.dtsi b/arch/arm/dts/stm32mp15-pinctrl.dtsi index 6161f5906e..f0d66d8c6e 100644 --- a/arch/arm/dts/stm32mp15-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp15-pinctrl.dtsi @@ -338,6 +338,47 @@ }; };
+ ethernet0_rmii_pins_b: rmii-1 { + pins1 { + pinmux = <STM32_PINMUX('B', 5, AF0)>, /* ETH1_CLK */ + <STM32_PINMUX('C', 1, AF11)>, /* ETH1_MDC */ + <STM32_PINMUX('G', 13, AF11)>, /* ETH1_TXD0 */ + <STM32_PINMUX('G', 14, AF11)>; /* ETH1_TXD1 */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + pins2 { + pinmux = <STM32_PINMUX('A', 2, AF11)>; /* ETH1_MDIO */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins3 { + pinmux = <STM32_PINMUX('A', 7, AF11)>, /* ETH1_CRS_DV */ + <STM32_PINMUX('C', 4, AF11)>, /* ETH1_RXD0 */ + <STM32_PINMUX('C', 5, AF11)>; /* ETH1_RXD1 */ + bias-disable; + }; + pins4 { + pinmux = <STM32_PINMUX('B', 11, AF11)>; /* ETH1_TX_EN */ + }; + }; + + ethernet0_rmii_sleep_pins_b: rmii-sleep-1 { + pins1 { + pinmux = <STM32_PINMUX('A', 2, ANALOG)>, /* ETH1_MDIO */ + <STM32_PINMUX('A', 7, ANALOG)>, /* ETH1_CRS_DV */ + <STM32_PINMUX('B', 5, ANALOG)>, /* ETH1_CLK */ + <STM32_PINMUX('B', 11, ANALOG)>, /* ETH1_TX_EN */ + <STM32_PINMUX('C', 1, ANALOG)>, /* ETH1_MDC */ + <STM32_PINMUX('C', 4, ANALOG)>, /* ETH1_RXD0 */ + <STM32_PINMUX('C', 5, ANALOG)>, /* ETH1_RXD1 */ + <STM32_PINMUX('G', 13, ANALOG)>, /* ETH1_TXD0 */ + <STM32_PINMUX('G', 14, ANALOG)>; /* ETH1_TXD1 */ + }; + }; + fmc_pins_a: fmc-0 { pins1 { pinmux = <STM32_PINMUX('D', 4, AF12)>, /* FMC_NOE */ @@ -927,6 +968,21 @@ }; };
+ pwm1_pins_b: pwm1-1 { + pins { + pinmux = <STM32_PINMUX('E', 9, AF1)>; /* TIM1_CH1 */ + bias-pull-down; + drive-push-pull; + slew-rate = <0>; + }; + }; + + pwm1_sleep_pins_b: pwm1-sleep-1 { + pins { + pinmux = <STM32_PINMUX('E', 9, ANALOG)>; /* TIM1_CH1 */ + }; + }; + pwm2_pins_a: pwm2-0 { pins { pinmux = <STM32_PINMUX('A', 3, AF1)>; /* TIM2_CH4 */ @@ -2042,6 +2098,42 @@ }; };
+ usart3_pins_d: usart3-3 { + pins1 { + pinmux = <STM32_PINMUX('B', 10, AF7)>, /* USART3_TX */ + <STM32_PINMUX('G', 8, AF8)>; /* USART3_RTS */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 9, AF7)>, /* USART3_RX */ + <STM32_PINMUX('D', 11, AF7)>; /* USART3_CTS_NSS */ + bias-disable; + }; + }; + + usart3_idle_pins_d: usart3-idle-3 { + pins1 { + pinmux = <STM32_PINMUX('B', 10, ANALOG)>, /* USART3_TX */ + <STM32_PINMUX('G', 8, ANALOG)>, /* USART3_RTS */ + <STM32_PINMUX('D', 11, ANALOG)>; /* USART3_CTS_NSS */ + }; + pins2 { + pinmux = <STM32_PINMUX('D', 9, AF7)>; /* USART3_RX */ + bias-disable; + }; + }; + + usart3_sleep_pins_d: usart3-sleep-3 { + pins { + pinmux = <STM32_PINMUX('B', 10, ANALOG)>, /* USART3_TX */ + <STM32_PINMUX('G', 8, ANALOG)>, /* USART3_RTS */ + <STM32_PINMUX('D', 11, ANALOG)>, /* USART3_CTS_NSS */ + <STM32_PINMUX('D', 9, ANALOG)>; /* USART3_RX */ + }; + }; + usbotg_hs_pins_a: usbotg-hs-0 { pins { pinmux = <STM32_PINMUX('A', 10, ANALOG)>; /* OTG_ID */ diff --git a/arch/arm/dts/stm32mp15-u-boot.dtsi b/arch/arm/dts/stm32mp15-u-boot.dtsi index e23d6c7d7e..d9d04743ac 100644 --- a/arch/arm/dts/stm32mp15-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15-u-boot.dtsi @@ -188,18 +188,6 @@ #size-cells = <0>; };
-&sdmmc1 { - compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; -}; - -&sdmmc2 { - compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; -}; - -&sdmmc3 { - compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; -}; - &usart1 { resets = <&rcc USART1_R>; }; diff --git a/arch/arm/dts/stm32mp151.dtsi b/arch/arm/dts/stm32mp151.dtsi index 5a2be00758..e74a5faf4a 100644 --- a/arch/arm/dts/stm32mp151.dtsi +++ b/arch/arm/dts/stm32mp151.dtsi @@ -63,10 +63,10 @@
timer { compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; interrupt-parent = <&intc>; };
@@ -473,6 +473,9 @@ interrupts-extended = <&exti 27 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc USART2_K>; wakeup-source; + dmas = <&dmamux1 43 0x400 0x15>, + <&dmamux1 44 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -482,6 +485,9 @@ interrupts-extended = <&exti 28 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc USART3_K>; wakeup-source; + dmas = <&dmamux1 45 0x400 0x15>, + <&dmamux1 46 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -491,6 +497,9 @@ interrupts-extended = <&exti 30 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc UART4_K>; wakeup-source; + dmas = <&dmamux1 63 0x400 0x15>, + <&dmamux1 64 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -500,6 +509,9 @@ interrupts-extended = <&exti 31 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc UART5_K>; wakeup-source; + dmas = <&dmamux1 65 0x400 0x15>, + <&dmamux1 66 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -606,6 +618,9 @@ interrupts-extended = <&exti 32 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc UART7_K>; wakeup-source; + dmas = <&dmamux1 79 0x400 0x15>, + <&dmamux1 80 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -615,6 +630,9 @@ interrupts-extended = <&exti 33 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc UART8_K>; wakeup-source; + dmas = <&dmamux1 81 0x400 0x15>, + <&dmamux1 82 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -696,6 +714,9 @@ interrupts-extended = <&exti 29 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc USART6_K>; wakeup-source; + dmas = <&dmamux1 71 0x400 0x15>, + <&dmamux1 72 0x400 0x11>; + dma-names = "rx", "tx"; status = "disabled"; };
@@ -1077,7 +1098,7 @@ };
sdmmc3: mmc@48004000 { - compatible = "arm,pl18x", "arm,primecell"; + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; arm,primecell-periphid = <0x00253180>; reg = <0x48004000 0x400>; interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; @@ -1411,7 +1432,7 @@ };
sdmmc1: mmc@58005000 { - compatible = "arm,pl18x", "arm,primecell"; + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; arm,primecell-periphid = <0x00253180>; reg = <0x58005000 0x1000>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; @@ -1426,7 +1447,7 @@ };
sdmmc2: mmc@58007000 { - compatible = "arm,pl18x", "arm,primecell"; + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; arm,primecell-periphid = <0x00253180>; reg = <0x58007000 0x1000>; interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; @@ -1590,7 +1611,7 @@ reg = <0x5c004000 0x400>; clocks = <&rcc RTCAPB>, <&rcc RTC>; clock-names = "pclk", "rtc_ck"; - interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + interrupts-extended = <&exti 19 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; };
diff --git a/arch/arm/dts/stm32mp153.dtsi b/arch/arm/dts/stm32mp153.dtsi index 1c1889b194..486084e0b8 100644 --- a/arch/arm/dts/stm32mp153.dtsi +++ b/arch/arm/dts/stm32mp153.dtsi @@ -22,6 +22,13 @@ interrupt-affinity = <&cpu0>, <&cpu1>; };
+ timer { + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; + }; + soc { m_can1: can@4400e000 { compatible = "bosch,m_can"; diff --git a/arch/arm/dts/stm32mp157a-icore-stm32mp1-ctouch2.dts b/arch/arm/dts/stm32mp157a-icore-stm32mp1-ctouch2.dts index d3058a036c..1f75f1d451 100644 --- a/arch/arm/dts/stm32mp157a-icore-stm32mp1-ctouch2.dts +++ b/arch/arm/dts/stm32mp157a-icore-stm32mp1-ctouch2.dts @@ -43,5 +43,7 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; }; diff --git a/arch/arm/dts/stm32mp157a-icore-stm32mp1-edimm2.2.dts b/arch/arm/dts/stm32mp157a-icore-stm32mp1-edimm2.2.dts index ec9f1d1cd5..3a1295cfa9 100644 --- a/arch/arm/dts/stm32mp157a-icore-stm32mp1-edimm2.2.dts +++ b/arch/arm/dts/stm32mp157a-icore-stm32mp1-edimm2.2.dts @@ -43,5 +43,7 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; }; diff --git a/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0-of7.dts b/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0-of7.dts index 5670b23812..fae656edd8 100644 --- a/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0-of7.dts +++ b/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0-of7.dts @@ -143,6 +143,8 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -150,5 +152,7 @@ &uart8 { pinctrl-names = "default"; pinctrl-0 = <&uart8_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; }; diff --git a/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0.dts b/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0.dts index 7a75868164..b9d0d3d6ad 100644 --- a/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0.dts +++ b/arch/arm/dts/stm32mp157a-microgea-stm32mp1-microdev2.0.dts @@ -44,6 +44,8 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -51,5 +53,7 @@ &uart8 { pinctrl-names = "default"; pinctrl-0 = <&uart8_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; }; diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index f62b46b8dd..fe5c8f25ce 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -392,6 +392,8 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp157c-odyssey.dts b/arch/arm/dts/stm32mp157c-odyssey.dts index 0e725498dd..17bcf56f74 100644 --- a/arch/arm/dts/stm32mp157c-odyssey.dts +++ b/arch/arm/dts/stm32mp157c-odyssey.dts @@ -132,6 +132,8 @@ &uart4 { pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi index 4b10b013ff..35b1034aa3 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi @@ -131,6 +131,8 @@ &usart3 { pinctrl-names = "default"; pinctrl-0 = <&usart3_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -144,6 +146,8 @@ pinctrl-names = "default"; pinctrl-0 = <&uart8_pins_a>; rts-gpios = <&gpioe 6 GPIO_ACTIVE_HIGH>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi index fbf3826933..5f586f0240 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi @@ -287,6 +287,8 @@ &usart3 { pinctrl-names = "default"; pinctrl-0 = <&usart3_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -294,6 +296,8 @@ pinctrl-names = "default"; pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; uart-has-rtscts; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi index ba816ef8b9..abc595350e 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi @@ -105,12 +105,16 @@ &usart3 { pinctrl-names = "default"; pinctrl-0 = <&usart3_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
&uart8 { pinctrl-names = "default"; pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi index 8c41f819f7..83e2c87713 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi @@ -196,7 +196,6 @@ "", "", "DHCOM-E", "", "", "", "", "", "", "", "", ""; - status = "okay"; };
&gpiod { @@ -521,5 +520,7 @@ &uart4 { pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; }; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi index 6885948f30..61e17f44ce 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi @@ -376,6 +376,8 @@ label = "LS-UART1"; pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_b>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -385,6 +387,8 @@ pinctrl-names = "default"; pinctrl-0 = <&uart7_pins_a>; uart-has-rtscts; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -394,6 +398,8 @@ pinctrl-0 = <&usart2_pins_a>; pinctrl-1 = <&usart2_sleep_pins_a>; st,hw-flow-ctrl; + /delete-property/dmas; + /delete-property/dma-names; status = "okay";
bluetooth { diff --git a/arch/arm/dts/stm32mp15xx-dkx.dtsi b/arch/arm/dts/stm32mp15xx-dkx.dtsi index f8130bf445..3d36cac9ed 100644 --- a/arch/arm/dts/stm32mp15xx-dkx.dtsi +++ b/arch/arm/dts/stm32mp15xx-dkx.dtsi @@ -658,6 +658,8 @@ pinctrl-0 = <&uart4_pins_a>; pinctrl-1 = <&uart4_sleep_pins_a>; pinctrl-2 = <&uart4_idle_pins_a>; + /delete-property/dmas; + /delete-property/dma-names; status = "okay"; };
@@ -666,6 +668,8 @@ pinctrl-0 = <&uart7_pins_c>; pinctrl-1 = <&uart7_sleep_pins_c>; pinctrl-2 = <&uart7_idle_pins_c>; + /delete-property/dmas; + /delete-property/dma-names; status = "disabled"; };
Hi Patrick
- ethernet0_rmii_pins_b: rmii-1 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins3 {
bias-disable;
pins4 {
- ethernet0_rmii_sleep_pins_b: rmii-sleep-1 {
pins1 {
- fmc_pins_a: fmc-0 { pins1 { pinmux = <STM32_PINMUX('D', 4, AF12)>, /* FMC_NOE */
- pwm1_pins_b: pwm1-1 {
pins {
bias-pull-down;
drive-push-pull;
slew-rate = <0>;
- pwm1_sleep_pins_b: pwm1-sleep-1 {
pins {
- pwm2_pins_a: pwm2-0 { pins { pinmux = <STM32_PINMUX('A', 3, AF1)>; /* TIM2_CH4 */
- usart3_pins_d: usart3-3 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- usart3_idle_pins_d: usart3-idle-3 {
pins1 {
pins2 {
bias-disable;
- usart3_sleep_pins_d: usart3-sleep-3 {
pins {
- usbotg_hs_pins_a: usbotg-hs-0 { pins { pinmux = <STM32_PINMUX('A', 10, ANALOG)>; /* OTG_ID */
-&sdmmc1 {
-&sdmmc2 {
-&sdmmc3 {
interrupt-parent = <&intc>; };<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>;
};dma-names = "rx", "tx"; status = "disabled";
};interrupts-extended = <&exti 19 IRQ_TYPE_LEVEL_HIGH>; status = "disabled";
- timer {
- soc { m_can1: can@4400e000 { compatible = "bosch,m_can";
- /delete-property/dmas;
- /delete-property/dma-names; status = "okay";
- status = "okay";
bluetooth {
- /delete-property/dma-names; status = "disabled";
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
On 5/6/22 16:27, Patrice CHOTARD wrote:
Hi Patrick
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins3 {
bias-disable;
pins4 {
pins1 {
pins {
bias-pull-down;
drive-push-pull;
slew-rate = <0>;
pins {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins1 {
pins2 {
bias-disable;
pins {
-&sdmmc1 {
-&sdmmc2 {
-&sdmmc3 {
- timer {
- status = "okay";
bluetooth {
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm32
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
