[U-Boot] Please pull u-boot-x86
Hi Tom,
The following changes since commit 81cf7c8d45935a295991fe2cd1df286f0f47511f:
Merge git://git.denx.de/u-boot-ubi (2018-03-25 12:02:13 -0400)
git://git.denx.de/u-boot-x86.git
for you to fetch changes up to 5d73292cf84db1e8f7d99dd27100ef2e8ac15c4e:
x86: zImage: Pass working device tree data to the kernel (2018-03-30 16:06:58 +0800)
---------------------------------------------------------------- Alexander Graf (1): efi_stub: Fix GDT_NOTSYS check
Bernhard Messerklinger (1): x86: mmc: Fix mapping of BAR memory
Bin Meng (2): dm: pci: Check board information pointer in decode_regions() dm: pci: Avoid setting a PCI region that has 0 size
Ivan Gorinov (1): x86: zImage: Pass working device tree data to the kernel
arch/x86/include/asm/bootparam.h | 7 +++++-- arch/x86/lib/zimage.c | 35 +++++++++++++++++++++++++++++++++++ drivers/mmc/pci_mmc.c | 5 ++--- drivers/pci/pci-uclass.c | 8 ++++++-- lib/efi/efi_stub.c | 2 +- 5 files changed, 49 insertions(+), 8 deletions(-)
Regards, Bin
On Fri, Mar 30, 2018 at 04:12:19PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
