[PATCH] lib: add crc16.o if CONFIG_MMC_SPI_CRC_ON for SPL build
CONFIG_MMC_SPI_CRC_ON needs the crc16 functions, but it was not included in an SPL build. For non-SPL builds, crc16.o is already added unconditionally. This also removes CONFIG_SPL_YMODEM_SUPPORT from the sifive board configs, which is only relevant for some ARM boards and was only set for its side effect of adding crc16.o.
Signed-off-by: Andreas Schwab schwab@suse.de --- configs/sifive_unleashed_defconfig | 1 - configs/sifive_unmatched_defconfig | 1 - lib/Makefile | 1 + 3 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/configs/sifive_unleashed_defconfig b/configs/sifive_unleashed_defconfig index fd686dfadc..d6448dbf5e 100644 --- a/configs/sifive_unleashed_defconfig +++ b/configs/sifive_unleashed_defconfig @@ -22,7 +22,6 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DM_SPI_FLASH=y CONFIG_SPL_DM_RESET=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_CLK=y diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 38b7acd536..d37c019cda 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -20,7 +20,6 @@ CONFIG_DISPLAY_BOARDINFO=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DM_RESET=y -CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_EEPROM=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_PWM=y diff --git a/lib/Makefile b/lib/Makefile index 07c2ccd7cf..7ae2ccf537 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -87,6 +87,7 @@ endif ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o obj-$(CONFIG_$(SPL_TPL_)HASH_SUPPORT) += crc16.o +obj-$(CONFIG_MMC_SPI_CRC_ON) += crc16.o obj-y += net_utils.o endif obj-$(CONFIG_ADDR_MAP) += addr_map.o
Andreas Schwab
