[U-Boot] [PATCH v2] x86: make the LAPIC / IOAPIC construct switchable with Kconfig
There are still systems running which do not have any LAPIC or even IOAPIC. Responsible MSRs for those do not exist and the systems are crashing on trying setup LAPIC.
So this commit makes the APIC stuff able to switch off for those boards which dont' have a LAPIC / IOAPIC.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at ---
Changes in v2: - rebase to curent master - reword commit message to be more clear - fix typo in Kconfig - re-add blank line in interrupt.c
arch/x86/Kconfig | 9 +++++++++ arch/x86/cpu/Makefile | 2 +- arch/x86/cpu/i386/interrupt.c | 2 ++ 3 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index a1c18d2..8d839e4 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -736,6 +736,15 @@ config I8259_PIC slave) interrupt controllers. Include this to have U-Boot set up the interrupt correctly.
+config APIC + bool + default y + help + The (A)dvanced (P)rogrammable (I)nterrupt (C)ontroller is responsible + for catching interrupts and distributing them to one more CPU cores. + In most cases there is some LAPIC (local) for each core and one + I/O APIC. This conjunction is found on most modern x86 systems. + config PINCTRL_ICH6 bool help diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index f862d8c..54668aa 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -35,7 +35,7 @@ obj-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += ivybridge/ obj-$(CONFIG_INTEL_QUARK) += quark/ obj-$(CONFIG_INTEL_QUEENSBAY) += queensbay/ obj-$(CONFIG_INTEL_TANGIER) += tangier/ -obj-y += lapic.o ioapic.o +obj-$(CONFIG_APIC) += lapic.o ioapic.o obj-y += irq.o ifndef CONFIG_$(SPL_)X86_64 obj-$(CONFIG_SMP) += mp_init.o diff --git a/arch/x86/cpu/i386/interrupt.c b/arch/x86/cpu/i386/interrupt.c index ed8423e..bf9526b 100644 --- a/arch/x86/cpu/i386/interrupt.c +++ b/arch/x86/cpu/i386/interrupt.c @@ -264,8 +264,10 @@ int interrupt_init(void) i8259_init(); #endif
+#ifdef CONFIG_APIC lapic_setup();
+#endif /* Initialize core interrupt and exception functionality of CPU */ cpu_init_interrupts();
Changes in v2:
+config APIC
bool
default y
help
one "or" more
There are some LAPICs
oops, I meant to say the #endif should be followed immediately and leave the blank line between the #endif and the next line.
I can fix all above nits when applying.
Regards, Bin
Changes in v2:
+config APIC
bool
default y
help
one "or" more
Fixed the nits, and applied to u-boot-x86, thanks!
Bin Meng
Hannes Schmelzer
