[PATCH V2] rockchip: rk3328: add rockpie-rk3328_defconfig
From f4253df37579aa9d48f98738eb7db3b6a3b9dff5 Mon Sep 17 00:00:00 2001 From: "banglang.huang" <banglang.huang@foxmail.com> Date: Thu, 9 Apr 2020 11:49:31 +0800 Subject: [PATCH V2] rockchip: rk3328: add rockpie-rk3328_defconfig
The ROCKPI-E is a credit card size SBC based on Rockchip RK3328 Quad-Core ARM Cortex A53.
Net - Dual ethernet port, 1 X Gbe, 1 X 100M USB - USB 3.0 DC - USB-Type C, 5V 2A Storage - TF card, eMMC
Just build u-boot-dtb.bin for Rockpi E board and follow the blow steps to replace the relevant partition.
./rkbin/tools/loaderimage --pack --uboot u-boot-dtb.bin \ uboot.img 0x200000 --size 1024 1 dd if=uboot.img of=/dev/sdcard seek=16384 conv=notrunc
Signed-off-by: banglang.huang <banglang.huang@foxmail.com> ---
Changes for v2
- add introduction for rockpie in doc/README.rockchip - enable CONFIG_MISC_INIT_R, CONFIG_SMBIOS_MANUFACTURER, and CONFIG_SMBIOS_PRODUCT_NAME
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3328-rockpie-u-boot.dtsi | 12 ++ arch/arm/dts/rk3328-rockpie.dts | 256 ++++++++++++++++++++++++ board/rockchip/evb_rk3328/MAINTAINERS | 7 + configs/rockpie-rk3328_defconfig | 99 +++++++++ doc/README.rockchip | 3 +- 6 files changed, 378 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/rk3328-rockpie-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-rockpie.dts create mode 100644 configs/rockpie-rk3328_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 820ee9733a..ca8c35e497 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -104,7 +104,8 @@ dtb-$(CONFIG_ROCKCHIP_RK3308) += \ dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ - rk3328-rock64.dtb + rk3328-rock64.dtb \ + rk3328-rockpie.dtb dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-lion.dtb \ diff --git a/arch/arm/dts/rk3328-rockpie-u-boot.dtsi b/arch/arm/dts/rk3328-rockpie-u-boot.dtsi new file mode 100644 index 0000000000..012209110a --- /dev/null +++ b/arch/arm/dts/rk3328-rockpie-u-boot.dtsi @@ -0,0 +1,12 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Radxa + */ + +#include "rk3328-u-boot.dtsi" +#include "rk3328-sdram-ddr3-666.dtsi" + +&usb_host0_xhci { + vbus-supply = <&vcc5v0_host_xhci>; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3328-rockpie.dts b/arch/arm/dts/rk3328-rockpie.dts new file mode 100644 index 0000000000..56b8c3f1e6 --- /dev/null +++ b/arch/arm/dts/rk3328-rockpie.dts @@ -0,0 +1,256 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Radxa + */ + +/dts-v1/; +#include "rk3328.dtsi" + +/ { + model = "Radxa Rockpi E"; + compatible = "radxa,rockpie", "rockchip,rk3328"; + + chosen { + stdout-path = &uart2; + }; + + gmac_clkin: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac_clkin"; + #clock-cells = <0>; + }; + + vcc3v3_sdmmc: sdmmc-pwren { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + gpio = <&gpio0 30 GPIO_ACTIVE_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0m1_gpio>; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_io>; + }; + + vcc5v0_host_xhci: vcc5v0-host-xhci-drv { + compatible = "regulator-fixed"; + enable-active-high; + regulator-name = "vcc5v0_host_xhci"; + gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&cpu1 { + cpu-supply = <&vdd_arm>; +}; + +&cpu2 { + cpu-supply = <&vdd_arm>; +}; + +&cpu3 { + cpu-supply = <&vdd_arm>; +}; + +&saradc { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + disable-wp; + max-frequency = <150000000>; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; + supports-sd; + vmmc-supply = <&vcc3v3_sdmmc>; + status = "okay"; +}; + +&emmc { + bus-width = <8>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + supports-emmc; + disable-wp; + non-removable; + num-slots = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; + vmmc-supply = <&vcc_io>; + vqmmc-supply = <&vcc_18emmc>; + status = "okay"; +}; + +&gmac2io { + phy-supply = <&vcc_io>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; + assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmiim1_pins>; + tx_delay = <0x26>; + rx_delay = <0x11>; + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb20_otg { + status = "okay"; +}; + +&i2c1 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + rk805: pmic@18 { + compatible = "rockchip,rk805"; + status = "okay"; + reg = <0x18>; + interrupt-parent = <&gpio2>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + gpio-controller; + #gpio-cells = <2>; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk805-clkout2"; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-name = "vdd_arm"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1450000>; + regulator-ramp-delay = <6001>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_io: DCDC_REG4 { + regulator-name = "vcc_io"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vdd_18: LDO_REG1 { + regulator-name = "vdd_18"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_18emmc: LDO_REG2 { + regulator-name = "vcc_18emmc"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_10: LDO_REG3 { + regulator-name = "vdd_10"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1000000>; + }; + }; + }; + }; +}; + +&io_domains { + status = "okay"; + vccio1-supply = <&vcc_io>; + vccio2-supply = <&vcc_18emmc>; + vccio3-supply = <&vcc_io>; + vccio4-supply = <&vcc_io>; + vccio5-supply = <&vcc_io>; + vccio6-supply = <&vcc_io>; + pmuio-supply = <&vcc_io>; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; /* gpio2_a6 */ + }; + }; +}; + diff --git a/board/rockchip/evb_rk3328/MAINTAINERS b/board/rockchip/evb_rk3328/MAINTAINERS index c661d2e06a..8ded56b30a 100644 --- a/board/rockchip/evb_rk3328/MAINTAINERS +++ b/board/rockchip/evb_rk3328/MAINTAINERS @@ -10,3 +10,10 @@ M: Matwey V. Kornilov <matwey.kornilov@gmail.com> S: Maintained F: configs/rock64-rk3328_defconfig F: arch/arm/dts/rk3328-rock64-u-boot.dtsi + +ROCKPIE-RK3328 +M: Banglang Huang <banglang.huang@foxmail.com> +S: Maintained +F: configs/rockpie-rk3328_defconfig +F: arch/arm/dts/rk3328-rockpie.dts +F: arch/arm/dts/rk3328-rockpie-u-boot.dtsi diff --git a/configs/rockpie-rk3328_defconfig b/configs/rockpie-rk3328_defconfig new file mode 100644 index 0000000000..0f7fd4a02d --- /dev/null +++ b/configs/rockpie-rk3328_defconfig @@ -0,0 +1,99 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3328=y +CONFIG_TPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x4000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x4000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF130000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SMBIOS_PRODUCT_NAME="rockpie_rk3328" +CONFIG_DEBUG_UART=y +CONFIG_TPL_SYS_MALLOC_F_LEN=0x800 +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rockpie.dtb" +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_TPL_DRIVERS_MISC_SUPPORT=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3328-rockpie" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_FASTBOOT_BUF_ADDR=0x800800 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_TPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_SMBIOS_MANUFACTURER="radxa" diff --git a/doc/README.rockchip b/doc/README.rockchip index 9b699b9ae5..6e7828a252 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -52,10 +52,11 @@ Two RK3308 boards are supported: - EVB RK3308 - use evb-rk3308 configuration - ROC-CC-RK3308 - use roc-cc-rk3308 configuration -Two RK3328 board are supported: +Three RK3328 board are supported: - EVB RK3328 - use evb-rk3328_defconfig - Pine64 Rock64 board - use rock64-rk3328_defconfig + - Radxa Rockpi E board - use rockpie-rk3328_defconfig Size RK3399 boards are supported (aarch64):
b.l.huang
