Re: [U-Boot] [PATCH RESEND 2/2 v2] lib: Add hexdump
Hi Thomas,
I was pretty sure I saw it before but today having no idea how that thing might be called I grepped for something like "dump", "buffer" etc but within tons of unrelated things I failed to find that "print_buffer"... such a shame...
-Alexey
10 июня 2016 г. 18:32 пользователь "Langer, Thomas" thomas.langer@intel.com написал: Hello Alexey,
This feature is already available in u-boot, please look for 'print_buffer'.
Best regards, Thomas
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Alexey Brodkin Sent: Friday, June 10, 2016 2:43 PM To: u-boot@lists.denx.de Cc: Tom Rini trini@konsulko.com; Alexey Brodkin Alexey.Brodkin@synopsys.com Subject: [U-Boot] [PATCH RESEND 2/2 v2] lib: Add hexdump
Often during debugging session it's very interesting to see what data we were dealing with. For example what we write or read to/from memory or peripherals.
This change introduces functions that allow to dump binary data with one simple function invocation like: ------------------->8---------------- print_hex_dump_bytes("", DUMP_PREFIX_OFFSET, buf, len); ------------------->8----------------
which gives us the following: ------------------->8---------------- 00000000: f2 b7 c9 88 62 61 75 64 72 61 74 65 3d 31 31 35 ....baudrate=115 00000010: 32 30 30 00 62 6f 6f 74 61 72 67 73 3d 63 6f 6e 200.bootargs=con 00000020: 73 6f 6c 65 3d 74 74 79 53 33 2c 31 31 35 32 30 sole=ttyS3,11520 00000030: 30 6e 38 00 62 6f 6f 74 64 65 6c 61 79 3d 33 00 0n8.bootdelay=3. 00000040: 62 6f 6f 74 66 69 6c 65 3d 75 49 6d 61 67 65 00 bootfile=uImage. 00000050: 66 64 74 63 6f 6e 74 72 6f 6c 61 64 64 72 3d 39 fdtcontroladdr=9 00000060: 66 66 62 31 62 61 30 00 6c 6f 61 64 61 64 64 72 ffb1ba0.loadaddr 00000070: 3d 30 78 38 32 30 30 30 30 30 30 00 73 74 64 65 =0x82000000.stde 00000080: 72 72 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 rr=serial0@e0022 00000090: 30 30 30 00 73 74 64 69 6e 3d 73 65 72 69 61 6c 000.stdin=serial 000000a0: 30 40 65 30 30 32 32 30 30 30 00 73 74 64 6f 75 0@e0022000.stdou 000000b0: 74 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 30 t=serial0@e00220 000000c0: 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00.............. ... ------------------->8----------------
Source of hexdump.c was copied from Linux kernel v4.7-rc2.
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Reviewed-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com
Changes v1 -> v2:
- Move hexdump definitions to a separate header.
- Move helper funcions to the header so they might be used even if CONFIG_HEXDUMP is not enabled and if not used they will not occupy extra bytes of memory being "static inline" ones.
- While at it replace its own hex_asc[], hex_asc_{lo|hi}() and pack_hex_byte() in lib/vsprintf.c with generic ones from hexdump.
- In print_hex_dump() revert back first parametr for debug level, otherwise existing users of the function will be broken.
include/common.h | 1 + include/hexdump.h | 108 +++++++++++++++++++++++ include/linux/compat.h | 1 - lib/Kconfig | 5 ++ lib/Makefile | 1 + lib/hexdump.c | 233 +++++++++++++++++++++++++++++++++++++++++++++++++ lib/vsprintf.c | 17 +--- 7 files changed, 351 insertions(+), 15 deletions(-) create mode 100644 include/hexdump.h create mode 100644 lib/hexdump.c
diff --git a/include/common.h b/include/common.h index f9f4605..51a438c 100644 --- a/include/common.h +++ b/include/common.h @@ -23,6 +23,7 @@ typedef volatile unsigned char vu_char; #include <linux/stringify.h> #include <asm/ptrace.h> #include <stdarg.h> +#include <hexdump.h> #include <linux/kernel.h> #if defined(CONFIG_PCI) && defined(CONFIG_4xx) #include <pci.h> diff --git a/include/hexdump.h b/include/hexdump.h new file mode 100644 index 0000000..de2e565 --- /dev/null +++ b/include/hexdump.h @@ -0,0 +1,108 @@ +/*
- Copyright (C) 2016 Synopsys, Inc. All rights reserved.
+#ifndef HEXDUMP_H +#define HEXDUMP_H
+#include <linux/ctype.h>
+enum {
DUMP_PREFIX_NONE,
DUMP_PREFIX_ADDRESS,
DUMP_PREFIX_OFFSET
+extern const char hex_asc[]; +#define hex_asc_lo(x) hex_asc[((x) & 0x0f)] +#define hex_asc_hi(x) hex_asc[((x) & 0xf0) >> 4]
+static inline char *hex_byte_pack(char *buf, u8 byte) +{
*buf++ = hex_asc_hi(byte);
*buf++ = hex_asc_lo(byte);
return buf;
- hex_to_bin - convert a hex digit to its real value
- @ch: ascii character represents hex digit
- hex_to_bin() converts one hex digit to its actual value or -1 in case of bad
- input.
+static inline int hex_to_bin(char ch) +{
if ((ch >= '0') && (ch <= '9'))
return ch - '0';
ch = tolower(ch);
if ((ch >= 'a') && (ch <= 'f'))
return ch - 'a' + 10;
return -1;
- hex2bin - convert an ascii hexadecimal string to its binary representation
- @dst: binary result
- @src: ascii hexadecimal string
- @count: result length
- Return 0 on success, -1 in case of bad input.
+static inline int hex2bin(u8 *dst, const char *src, size_t count) +{
while (count--) {
int hi = hex_to_bin(*src++);
int lo = hex_to_bin(*src++);
if ((hi < 0) || (lo < 0))
return -1;
*dst++ = (hi << 4) | lo;
- bin2hex - convert binary data to an ascii hexadecimal string
- @dst: ascii hexadecimal result
- @src: binary data
- @count: binary data length
+static inline char *bin2hex(char *dst, const void *src, size_t count) +{
const unsigned char *_src = src;
while (count--)
dst = hex_byte_pack(dst, *_src++);
return dst;
+#ifdef CONFIG_HEXDUMP +int hex_dump_to_buffer(const void *buf, size_t len, int rowsize, int groupsize,
char *linebuf, size_t linebuflen, bool ascii);
+void print_hex_dump(const char *level, const char *prefix_str, int prefix_type,
int rowsize, int groupsize, const void *buf, size_t len,
bool ascii);
+void print_hex_dump_bytes(const char *prefix_str, int prefix_type,
const void *buf, size_t len);
+#else /* !CONFIG_HEXDUMP */ +/*
- Some code in U-Boot copy-pasted from Linux kernel uses both
- functions below so to keep stuff compilable we keep these stubs here.
+static inline void print_hex_dump(const char *level, const char *prefix_str,
int prefix_type, int rowsize, int groupsize,
const void *buf, size_t len, bool ascii)
+{ +} +static inline void print_hex_dump_bytes(const char *prefix_str, int prefix_type,
+{ +} +#endif /* CONFIG_HEXDUMP */
+#endif /* HEXDUMP_H */ diff --git a/include/linux/compat.h b/include/linux/compat.h index 0ce7d65..074a85e 100644 --- a/include/linux/compat.h +++ b/include/linux/compat.h @@ -193,7 +193,6 @@ typedef unsigned long blkcnt_t; #define init_waitqueue_head(...) do { } while (0) #define wait_event_interruptible(...) 0 #define wake_up_interruptible(...) do { } while (0) -#define print_hex_dump(...) do { } while (0) #define dump_stack(...) do { } while (0)
#define task_pid_nr(x) 0 diff --git a/lib/Kconfig b/lib/Kconfig index 2b97c2b..a563b5e 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -128,6 +128,11 @@ config ERRNO_STR - if errno is null or positive number - a pointer to "Success" message - if errno is negative - a pointer to errno related message
+config HEXDUMP
bool "Enable hexdump"
help
This enables functions for printing dumps of binary data.
config OF_LIBFDT bool "Enable the FDT library" default y if OF_CONTROL diff --git a/lib/Makefile b/lib/Makefile index 02dfa29..1bf7c37 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -76,6 +76,7 @@ obj-y += membuff.o obj-$(CONFIG_REGEX) += slre.o obj-y += string.o obj-y += time.o +obj-y += hexdump.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_LIB_UUID) += uuid.o obj-$(CONFIG_LIB_RAND) += rand.o diff --git a/lib/hexdump.c b/lib/hexdump.c new file mode 100644 index 0000000..ffee5ce --- /dev/null +++ b/lib/hexdump.c @@ -0,0 +1,233 @@ +/*
- lib/hexdump.c
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation. See README and COPYING
for
- more details.
+#include <common.h> +#include <linux/ctype.h> +#include <linux/compat.h> +#include <linux/log2.h> +#include <asm/unaligned.h>
+const char hex_asc[] = "0123456789abcdef"; +const char hex_asc_upper[] = "0123456789ABCDEF";
+#ifdef CONFIG_HEXDUMP +/**
- hex_dump_to_buffer - convert a blob of data to "hex ASCII" in memory
- @buf: data blob to dump
- @len: number of bytes in the @buf
- @rowsize: number of bytes to print per line; must be 16 or 32
- @groupsize: number of bytes to print at a time (1, 2, 4, 8; default = 1)
- @linebuf: where to put the converted data
- @linebuflen: total size of @linebuf, including space for terminating NUL
- @ascii: include ASCII after the hex output
- hex_dump_to_buffer() works on one "line" of output at a time, i.e.,
- 16 or 32 bytes of input data converted to hex + ASCII output.
- Given a buffer of u8 data, hex_dump_to_buffer() converts the input data
- to a hex + ASCII dump at the supplied memory location.
- The converted output is always NUL-terminated.
- E.g.:
- hex_dump_to_buffer(frame->data, frame->len, 16, 1,
linebuf, sizeof(linebuf), true);
- example output buffer:
- 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f @ABCDEFGHIJKLMNO
- Return:
- The amount of bytes placed in the buffer without terminating NUL. If the
- output was truncated, then the return value is the number of bytes
- (excluding the terminating NUL) which would have been written to the
final
- string if enough space had been available.
const u8 *ptr = buf;
int ngroups;
u8 ch;
int j, lx = 0;
int ascii_column;
int ret;
if (rowsize != 16 && rowsize != 32)
rowsize = 16;
if (len > rowsize) /* limit to one line at a time */
len = rowsize;
if (!is_power_of_2(groupsize) || groupsize > 8)
groupsize = 1;
if ((len % groupsize) != 0) /* no mixed size output */
groupsize = 1;
ngroups = len / groupsize;
ascii_column = rowsize * 2 + rowsize / groupsize + 1;
if (!linebuflen)
goto overflow1;
if (!len)
goto nil;
if (groupsize == 8) {
const u64 *ptr8 = buf;
for (j = 0; j < ngroups; j++) {
ret = snprintf(linebuf + lx, linebuflen - lx,
"%s%16.16llx", j ? " " : "",
get_unaligned(ptr8 + j));
if (ret >= linebuflen - lx)
goto overflow1;
lx += ret;
} else if (groupsize == 4) {
const u32 *ptr4 = buf;
"%s%8.8x", j ? " " : "",
get_unaligned(ptr4 + j));
goto overflow1;
lx += ret;
} else if (groupsize == 2) {
const u16 *ptr2 = buf;
"%s%4.4x", j ? " " : "",
get_unaligned(ptr2 + j));
goto overflow1;
lx += ret;
} else {
for (j = 0; j < len; j++) {
if (linebuflen < lx + 2)
goto overflow2;
ch = ptr[j];
linebuf[lx++] = hex_asc_hi(ch);
goto overflow2;
linebuf[lx++] = hex_asc_lo(ch);
goto overflow2;
linebuf[lx++] = ' ';
if (j)
lx--;
if (!ascii)
goto nil;
while (lx < ascii_column) {
goto overflow2;
goto overflow2;
ch = ptr[j];
linebuf[lx++] = (isascii(ch) && isprint(ch)) ? ch : '.';
+nil:
linebuf[lx] = '\0';
return lx;
+overflow2:
linebuf[lx++] = '\0';
+overflow1:
return ascii ? ascii_column + len : (groupsize * 2 + 1) * ngroups - 1;
- print_hex_dump - print a text hex dump to syslog for a binary blob of
data
- @level: kernel log level (e.g. KERN_DEBUG)
- @prefix_str: string to prefix each line with;
- caller supplies trailing spaces for alignment if desired
- @prefix_type: controls whether prefix of an offset, address, or none
- is printed (%DUMP_PREFIX_OFFSET, %DUMP_PREFIX_ADDRESS,
%DUMP_PREFIX_NONE)
- Given a buffer of u8 data, print_hex_dump() prints a hex + ASCII dump
- to the kernel log at the specified kernel log level, with an optional
- leading prefix.
- print_hex_dump() works on one "line" of output at a time, i.e.,
- print_hex_dump() iterates over the entire input @buf, breaking it into
- "line size" chunks to format and print.
- E.g.:
- print_hex_dump(KERN_DEBUG, "raw data: ", DUMP_PREFIX_ADDRESS,
16, 1, frame->data, frame->len, true);
- Example output using %DUMP_PREFIX_OFFSET and 1-byte mode:
- 0009ab42: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
@ABCDEFGHIJKLMNO
- Example output using %DUMP_PREFIX_ADDRESS and 4-byte mode:
- ffffffff88089af0: 73727170 77767574 7b7a7978 7f7e7d7c
pqrstuvwxyz{|}~.
int i, linelen, remaining = len;
char linebuf[32 * 3 + 2 + 32 + 1];
rowsize = 16;
for (i = 0; i < len; i += rowsize) {
linelen = min(remaining, rowsize);
remaining -= rowsize;
hex_dump_to_buffer(ptr + i, linelen, rowsize, groupsize,
linebuf, sizeof(linebuf), ascii);
switch (prefix_type) {
case DUMP_PREFIX_ADDRESS:
printf("%s%p: %s\n", prefix_str, ptr + i, linebuf);
break;
case DUMP_PREFIX_OFFSET:
printf("%s%.8x: %s\n", prefix_str, i, linebuf);
break;
default:
printf("%s%s\n", prefix_str, linebuf);
break;
- print_hex_dump_bytes - shorthand form of print_hex_dump() with
default params
%DUMP_PREFIX_NONE)
- Calls print_hex_dump(), with log level of KERN_DEBUG,
- rowsize of 16, groupsize of 1, and ASCII output included.
print_hex_dump(KERN_DEBUG, prefix_str, prefix_type, 16, 1,
buf, len, true);
+#endif /* CONFIG_HEXDUMP */ diff --git a/lib/vsprintf.c b/lib/vsprintf.c index 874a295..c0a0aaa 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -271,17 +271,6 @@ static char *string(char *buf, char *end, char *s, int field_width, }
#ifdef CONFIG_CMD_NET -static const char hex_asc[] = "0123456789abcdef"; -#define hex_asc_lo(x) hex_asc[((x) & 0x0f)] -#define hex_asc_hi(x) hex_asc[((x) & 0xf0) >> 4]
-static inline char *pack_hex_byte(char *buf, u8 byte) -{
return buf;
static char *mac_address_string(char *buf, char *end, u8 *addr, int field_width, int precision, int flags) { @@ -291,7 +280,7 @@ static char *mac_address_string(char *buf, char *end, u8 *addr, int field_width, int i;
for (i = 0; i < 6; i++) {
p = pack_hex_byte(p, addr[i]);
p = hex_byte_pack(p, addr[i]); if (!(flags & SPECIAL) && i != 5) *p++ = ':'; }
@@ -310,8 +299,8 @@ static char *ip6_addr_string(char *buf, char *end, u8 *addr, int field_width, int i;
for (i = 0; i < 8; i++) {
p = pack_hex_byte(p, addr[2 * i]);
p = pack_hex_byte(p, addr[2 * i + 1]);
p = hex_byte_pack(p, addr[2 * i]);
p = hex_byte_pack(p, addr[2 * i + 1]); if (!(flags & SPECIAL) && i != 7) *p++ = ':'; }
-- 2.5.5
Alexey Brodkin
