[PATCH] boot: fdt: Turn all addresses and sizes into u64
In case of systems where DRAM bank ends at the edge of 32bit boundary, start + size calculations would overflow. This happens on STM32MP15xx with 1 DRAM bank starting at 0xc0000000 and 1 GiB of DRAM. This is a usual 32bit system DRAM size overflow, fix it by doing all DRAM size and offset calculations using u64 types. This also covers a case where a 32bit PAE system might be able to address up to 36bits of DRAM.
Fixes: a4df06e41fa2 ("boot: fdt: Change type of env_get_bootm_low() to phys_addr_t") Signed-off-by: Marek Vasut marex@denx.de --- Cc: Laurent Pinchart laurent.pinchart@ideasonboard.com Cc: Matthias Schiffer matthias.schiffer@ew.tq-group.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- boot/image-fdt.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/boot/image-fdt.c b/boot/image-fdt.c index 2b92bdaff16..f09716cba30 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -158,13 +158,10 @@ void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob) */ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) { + u64 start, size, usable, addr, low, mapsize; void *fdt_blob = *of_flat_tree; void *of_start = NULL; - phys_addr_t start, size, usable; char *fdt_high; - phys_addr_t addr; - phys_addr_t low; - phys_size_t mapsize; ulong of_len = 0; int bank; int err;
Hi Marek,
Thank you for the patch.
I'm not sure I like this much, as it removes a useful indication regarding what the variables store. Wouldn't it be better if the code's logic could be modified to avoid those overflows ?
Shouldn't phys_addr_t be a 64-bit type on PAE systems ?
- u64 start, size, usable, addr, low, mapsize; void *fdt_blob = *of_flat_tree; void *of_start = NULL;
- phys_addr_t addr;
- phys_addr_t low;
On 4/14/24 9:29 PM, Laurent Pinchart wrote:
Hi Marek,
That's what the variable name is for, not variable type.
I'd prefer to keep the code simple and blanket avoid the overflows for a very long time, rather than play whack-a-mole with various odd corner cases here.
Note that this is a fix for a previous series which changed from u64/ulong to phys_addr/size_t , which clearly was incorrect .
That depends on CONFIG_PHYS_64BIT , on am57xx this is not set for example, so there phys_addr_t is 32bit .
Hi Marek,
Up to you.
The system won't be able to address more than 32 bits of memory in that case, would it ?
Hi Marek,
Up to you.
It might do so through some memory window, like PCIe, but I never used the am57xx so I cannot tell what it really does.
Laurent Pinchart
