[U-Boot] [PATCH 0/2] scripts/kernel-doc: update script from Linux 5.2
Avoid some warnings when running 'make htmldocs'.
Correctly generate documentation for functions with function pointers as paramaters.
Heinrich Schuchardt (2): scripts/kernel-doc: update script from Linux 5.2 scripts/kernel-doc: fix parsing of function pointers
scripts/kernel-doc | 39 ++++++++++++++++++++------------------- 1 file changed, 20 insertions(+), 19 deletions(-)
-- 2.20.1
Update the script from Linux 5.2 to avoid some warnings.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- scripts/kernel-doc | 37 +++++++++++++++++++------------------ 1 file changed, 19 insertions(+), 18 deletions(-)
diff --git a/scripts/kernel-doc b/scripts/kernel-doc index 3cb6259182..3350e498b4 100755 --- a/scripts/kernel-doc +++ b/scripts/kernel-doc @@ -212,7 +212,7 @@ my $anon_struct_union = 0; my $type_constant = '\b``([^`]+)``\b'; my $type_constant2 = '%([-_\w]+)'; my $type_func = '(\w+)()'; -my $type_param = '@(\w*(.\w+)*(...)?)'; +my $type_param = '@(\w*((.\w+)|(->\w+))*(...)?)'; my $type_fp_param = '@(\w+)()'; # Special RST handling for func ptr params my $type_env = '($\w+)'; my $type_enum = '&(enum\s*([_\w]+))'; @@ -1062,7 +1062,7 @@ sub dump_struct($$) { my $x = shift; my $file = shift;
- if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}/) { + if ($x =~ /(struct|union)\s+(\w+)\s*{(.*)}(\s*(__packed|__aligned|__attribute__\s*(([a-z0-9,_\s()]*))))*/) { my $decl_type = $1; $declaration_name = $2; my $members = $3; @@ -1073,8 +1073,9 @@ sub dump_struct($$) { # strip comments: $members =~ s//*.*?*///gos; # strip attributes - $members =~ s/__attribute__\s*(([a-z,_*\s()]*))//i; - $members =~ s/__aligned\s*([^;]*)//gos; + $members =~ s/\s*__attribute__\s*(([a-z0-9,_*\s()]*))//gi; + $members =~ s/\s*__aligned\s*([^;]*)//gos; + $members =~ s/\s*__packed\s*//gos; $members =~ s/\s*CRYPTO_MINALIGN_ATTR//gos; # replace DECLARE_BITMAP $members =~ s/DECLARE_BITMAP\s*(([^,)]+),\s*([^,)]+))/unsigned long $1[BITS_TO_LONGS($2)]/gos; @@ -1148,20 +1149,20 @@ sub dump_struct($$) { } } } - $members =~ s/(struct|union)([^{};]+){([^{}]*)}([^{};]*);/$newmember/; + $members =~ s/(struct|union)([^{};]+){([^{}]*)}([^{};]*);/$newmember/; }
# Ignore other nested elements, like enums - $members =~ s/({[^{}]*})//g; + $members =~ s/({[^{}]*})//g;
create_parameterlist($members, ';', $file, $declaration_name); check_sections($file, $declaration_name, $decl_type, $sectcheck, $struct_actual);
# Adjust declaration for better display - $declaration =~ s/([{;])/$1\n/g; - $declaration =~ s/}\s+;/};/g; + $declaration =~ s/([{;])/$1\n/g; + $declaration =~ s/}\s+;/};/g; # Better handle inlined enums - do {} while ($declaration =~ s/(enum\s+{[^}]+),([^\n])/$1,\n$2/); + do {} while ($declaration =~ s/(enum\s+{[^}]+),([^\n])/$1,\n$2/);
my @def_args = split /\n/, $declaration; my $level = 1; @@ -1171,12 +1172,12 @@ sub dump_struct($$) { $clause =~ s/\s+$//; $clause =~ s/\s+/ /; next if (!$clause); - $level-- if ($clause =~ m/(})/ && $level > 1); + $level-- if ($clause =~ m/(})/ && $level > 1); if (!($clause =~ m/^\s*#/)) { $declaration .= "\t" x $level; } $declaration .= "\t" . $clause . "\n"; - $level++ if ($clause =~ m/({)/ && !($clause =~m/}/)); + $level++ if ($clause =~ m/({)/ && !($clause =~m/}/)); } output_declaration($declaration_name, 'struct', @@ -1244,7 +1245,7 @@ sub dump_enum($$) { # strip #define macros inside enums $x =~ s@#\s*((define|ifdef)\s+|endif)[^;]*;@@gos;
- if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { + if ($x =~ /enum\s+(\w+)\s*{(.*)}/) { $declaration_name = $1; my $members = $2; my %_members; @@ -1473,7 +1474,7 @@ sub push_parameter($$$$) { if (!defined $parameterdescs{$param} && $param !~ /^#/) { $parameterdescs{$param} = $undescribed;
- if (show_warnings($type, $declaration_name)) { + if (show_warnings($type, $declaration_name) && $param !~ /./) { print STDERR "${file}:$.: warning: Function parameter or member '$param' not described in '$declaration_name'\n"; ++$warnings; @@ -1785,7 +1786,7 @@ sub process_proto_type($$) { }
while (1) { - if ( $x =~ /([^{};]*)([{};])(.*)/ ) { + if ( $x =~ /([^{};]*)([{};])(.*)/ ) { if( length $prototype ) { $prototype .= " " } @@ -1904,13 +1905,13 @@ sub process_name($$) { ++$warnings; }
- if ($identifier =~ m/^struct/) { + if ($identifier =~ m/^struct\b/) { $decl_type = 'struct'; - } elsif ($identifier =~ m/^union/) { + } elsif ($identifier =~ m/^union\b/) { $decl_type = 'union'; - } elsif ($identifier =~ m/^enum/) { + } elsif ($identifier =~ m/^enum\b/) { $decl_type = 'enum'; - } elsif ($identifier =~ m/^typedef/) { + } elsif ($identifier =~ m/^typedef\b/) { $decl_type = 'typedef'; } else { $decl_type = 'function'; -- 2.20.1
kernel-doc fails to parse function definitions like the one below
efi_status_t efi_create_event(uint32_t type, efi_uintn_t notify_tpl, void (EFIAPI *notify_function) ( struct efi_event *event, void *context), void *notify_context, efi_guid_t *group, struct efi_event **event) {
due to the "EFIAPI" attribute preceding the function name.
cf. https://lkml.org/lkml/2018/9/3/1185
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- scripts/kernel-doc | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/kernel-doc b/scripts/kernel-doc index 3350e498b4..516cf1db32 100755 --- a/scripts/kernel-doc +++ b/scripts/kernel-doc @@ -1382,7 +1382,7 @@ sub create_parameterlist($$$$) { } elsif ($arg =~ m/(.+)\s*(/) { # pointer-to-function $arg =~ tr/#/,/; - $arg =~ m/[^(]+(*?\s*([\w.]*)\s*)/; + $arg =~ m/[^(]+([\w\s]**?\s*([\w.]*)\s*)/; $param = $1; $type = $arg; $type =~ s/([^(]+(*?)\s*$param/$1/; -- 2.20.1
