[PATCH v2] riscv: andes_plic: Fix riscv_get_ipi() mask
Current logic in riscv_get_ipi() for Andes PLICSW does not look correct. The mask to test IPI pending bits for a hart should be left shifted by (8 * gd->arch.boot_hart), just the same as what is done in riscv_send_ipi().
Fixes: 8b3e97badf97 ("riscv: add functions for reading the IPI status") Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com Tested-by: Rick Chen rick@andestech.com
Changes in v2: - remove RFT tag - update commit message with "Fixes" tag along with the commit id
arch/riscv/lib/andes_plic.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/lib/andes_plic.c b/arch/riscv/lib/andes_plic.c index 221a5fe324..5e113ee8c9 100644 --- a/arch/riscv/lib/andes_plic.c +++ b/arch/riscv/lib/andes_plic.c @@ -105,9 +105,11 @@ int riscv_clear_ipi(int hart)
int riscv_get_ipi(int hart, int *pending) { + unsigned int ipi = (SEND_IPI_TO_HART(hart) << (8 * gd->arch.boot_hart)); + *pending = readl((void __iomem *)PENDING_REG(gd->arch.plic, gd->arch.boot_hart)); - *pending = !!(*pending & SEND_IPI_TO_HART(hart)); + *pending = !!(*pending & ipi);
return 0; }
Bin Meng
