[U-Boot] [PATCH] ARM: tegra: rm Jetson TK1 PMIC GPIO programming
The PMIC is configured such that its GPIOs have the correct configuration at power-up, so no programming is required.
In fact, the current programming is actively wrong, since:
(a) the AS3722 driver configures the GPIO to be an output before setting its output value, which causes a 0v glitch on the output.
(b) the AS3722 driver configures the GPIO to drive a high voltage from its VSUP_GPIO power source rather than its VDD_GPIO_LV power source, so the pin drives 5V not 1.8V as desired.
Solve these problems by removing the code which configures the PMIC GPIOs.
Note that this patch was tested directly on top of v2016.01; since then, commit 96350f729c42 "dm: tegra: net: Convert tegra boards to driver model for Ethernet" prevents PCIe from being initialized. Alternatively, simply revert that commit to get PCIe Ethernet working again, then apply this patch to test.
Signed-off-by: Stephen Warren swarren@nvidia.com --- board/nvidia/jetson-tk1/jetson-tk1.c | 13 ------------- 1 file changed, 13 deletions(-)
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson-tk1/jetson-tk1.c index e929a1c1ea27..a66b710cddab 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -60,19 +60,6 @@ int tegra_pcie_board_init(void) return err; }
- err = as3722_gpio_configure(pmic, 1, AS3722_GPIO_OUTPUT_VDDH | - AS3722_GPIO_INVERT); - if (err < 0) { - error("failed to configure GPIO#1 as output: %d\n", err); - return err; - } - - err = as3722_gpio_direction_output(pmic, 2, 1); - if (err < 0) { - error("failed to set GPIO#2 high: %d\n", err); - return err; - } - return 0; } #endif /* PCI */
Stephen,
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Monday, January 18, 2016 11:23 AM To: u-boot@lists.denx.de; Simon Glass sjg@chromium.org; Tom Warren TWarren@nvidia.com; Stephen Warren swarren@nvidia.com Cc: Thierry Reding treding@nvidia.com Subject: [PATCH] ARM: tegra: rm Jetson TK1 PMIC GPIO programming
Acked-by: Tom Warren twarren@nvidia.com I'll apply this to u-boot-tegra/next ASAP.
diff --git a/board/nvidia/jetson-tk1/jetson-tk1.c b/board/nvidia/jetson- tk1/jetson-tk1.c index e929a1c1ea27..a66b710cddab 100644 --- a/board/nvidia/jetson-tk1/jetson-tk1.c +++ b/board/nvidia/jetson-tk1/jetson-tk1.c @@ -60,19 +60,6 @@ int tegra_pcie_board_init(void) return err; }
- if (err < 0) {
return err;
- if (err < 0) {
return err;
#endif /* PCI */
2.7.0
----------------------------------------------------------------------------------- This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message. -----------------------------------------------------------------------------------
On 01/18/2016 12:16 PM, Tom Warren wrote:
Stephen Warren wrotea tMonday, January 18, 2016 11:23 AM:
I don't see this patch there yet. It'd be good to get it pulled upstream ASAP since the merge window for v2016.03 closes this weekend.
OK. I was waiting to see if Simon's dm display driver changes would go in via the Tegra repo (they apply / build OK now, but I've had no time for testing).
With the merge window closing, I'll send a PR with just this fix. Thanks.
Tom
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Thursday, January 28, 2016 10:11 AM To: Tom Warren TWarren@nvidia.com Cc: u-boot@lists.denx.de; Simon Glass sjg@chromium.org; Stephen Warren swarren@nvidia.com; Thierry Reding treding@nvidia.com Subject: Re: [PATCH] ARM: tegra: rm Jetson TK1 PMIC GPIO programming
GPIOs.
this patch to test.
Looks reasonable to me:
Acked-by: Thierry Reding treding@nvidia.com
After applying your other patch:
pci: restore initialization for DM_PCI
to restore PCI networking on Jetson TK1 I was able to verify that this still works for me. Interestingly the code before seems to trigger a visual glitch in the serial output, though I'm not sure I had seen one like that back when I initially added this support.
Either way, this patch:
Tested-by: Thierry Reding treding@nvidia.com
Stephen Warren
Thierry Reding
Thierry Reding
Tom Warren
