[U-Boot] [PATCH 0/2] ARM: cache: clean up the code to drop the empty stub functions
This series is based on the patch I sent: http://patchwork.ozlabs.org/patch/481095/ As above introduces the default empty function for invalidate_dcache_range() & flush_dcache_range() in arch/arm/lib/cache.c. So in this series, we can drop the empty stubs in arch/arm/cpu/
Also this series introduces a default function for flush_cache().
Josh Wu (2): ARM: cache: drop the empty dcache functions as we have it in lib/cache.c ARM: cache: implement a default flush_cache() function
arch/arm/cpu/arm1136/cpu.c | 17 ----------------- arch/arm/cpu/arm926ejs/cache.c | 17 ----------------- arch/arm/cpu/armv7/cache_v7.c | 21 --------------------- arch/arm/cpu/armv8/cache_v8.c | 16 ---------------- arch/arm/lib/cache.c | 26 +++++--------------------- 5 files changed, 5 insertions(+), 92 deletions(-)
Signed-off-by: Josh Wu josh.wu@atmel.com ---
arch/arm/cpu/arm1136/cpu.c | 8 -------- arch/arm/cpu/arm926ejs/cache.c | 8 -------- arch/arm/cpu/armv7/cache_v7.c | 8 -------- arch/arm/cpu/armv8/cache_v8.c | 8 -------- 4 files changed, 32 deletions(-)
diff --git a/arch/arm/cpu/arm1136/cpu.c b/arch/arm/cpu/arm1136/cpu.c index a7aed4b..b4d1d54 100644 --- a/arch/arm/cpu/arm1136/cpu.c +++ b/arch/arm/cpu/arm1136/cpu.c @@ -134,14 +134,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void flush_cache(unsigned long start, unsigned long size) { } diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 8d7873c..99d1a13 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -83,14 +83,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void flush_cache(unsigned long start, unsigned long size) { } diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index e8ee875..4f0e406 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -304,14 +304,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void arm_init_before_mmu(void) { } diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index c5ec529..f8c17cc 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -149,14 +149,6 @@ void flush_dcache_all(void) { }
-void invalidate_dcache_range(unsigned long start, unsigned long stop) -{ -} - -void flush_dcache_range(unsigned long start, unsigned long stop) -{ -} - void dcache_enable(void) { }
It will just call flush_dcache_range().
As ARM1136 & ARM926ejs already implemented their own flush_cache(), those code in weak function in arch/arm/lib/cache.c can be dropped.
arch/arm/cpu/arm1136/cpu.c | 9 --------- arch/arm/cpu/arm926ejs/cache.c | 9 --------- arch/arm/cpu/armv7/cache_v7.c | 13 ------------- arch/arm/cpu/armv8/cache_v8.c | 8 -------- arch/arm/lib/cache.c | 26 +++++--------------------- 5 files changed, 5 insertions(+), 60 deletions(-)
diff --git a/arch/arm/cpu/arm1136/cpu.c b/arch/arm/cpu/arm1136/cpu.c index b4d1d54..f092ffc 100644 --- a/arch/arm/cpu/arm1136/cpu.c +++ b/arch/arm/cpu/arm1136/cpu.c @@ -120,11 +120,6 @@ void flush_dcache_range(unsigned long start, unsigned long stop) asm volatile("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); }
-void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} - #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -133,10 +128,6 @@ void invalidate_dcache_all(void) void flush_dcache_all(void) { } - -void flush_cache(unsigned long start, unsigned long size) -{ -} #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */
#if !defined(CONFIG_SYS_ICACHE_OFF) || !defined(CONFIG_SYS_DCACHE_OFF) diff --git a/arch/arm/cpu/arm926ejs/cache.c b/arch/arm/cpu/arm926ejs/cache.c index 99d1a13..e5c1a6a 100644 --- a/arch/arm/cpu/arm926ejs/cache.c +++ b/arch/arm/cpu/arm926ejs/cache.c @@ -69,11 +69,6 @@ void flush_dcache_range(unsigned long start, unsigned long stop)
asm volatile("mcr p15, 0, %0, c7, c10, 4\n" : : "r"(0)); } - -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -82,10 +77,6 @@ void invalidate_dcache_all(void) void flush_dcache_all(void) { } - -void flush_cache(unsigned long start, unsigned long size) -{ -} #endif /* #ifndef CONFIG_SYS_DCACHE_OFF */
/* diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index 4f0e406..a5aa4fa 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -286,15 +286,6 @@ void mmu_page_table_flush(unsigned long start, unsigned long stop) flush_dcache_range(start, stop); v7_inval_tlb(); } - -/* - * Flush range from all levels of d-cache/unified-cache used: - * Affects the range [start, start + size - 1] - */ -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} #else /* #ifndef CONFIG_SYS_DCACHE_OFF */ void invalidate_dcache_all(void) { @@ -308,10 +299,6 @@ void arm_init_before_mmu(void) { }
-void flush_cache(unsigned long start, unsigned long size) -{ -} - void mmu_page_table_flush(unsigned long start, unsigned long stop) { } diff --git a/arch/arm/cpu/armv8/cache_v8.c b/arch/arm/cpu/armv8/cache_v8.c index f8c17cc..92b66c3 100644 --- a/arch/arm/cpu/armv8/cache_v8.c +++ b/arch/arm/cpu/armv8/cache_v8.c @@ -217,11 +217,3 @@ void __weak enable_caches(void) icache_enable(); dcache_enable(); } - -/* - * Flush range from all levels of d-cache/unified-cache - */ -void flush_cache(unsigned long start, unsigned long size) -{ - flush_dcache_range(start, start + size); -} diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index bc48f53..cd13db3 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -10,29 +10,13 @@ #include <common.h> #include <malloc.h>
+/* + * Flush range from all levels of d-cache/unified-cache. + * Affects the range [start, start + size - 1]. + */ __weak void flush_cache(unsigned long start, unsigned long size) { -#if defined(CONFIG_CPU_ARM1136) - -#if !defined(CONFIG_SYS_ICACHE_OFF) - asm("mcr p15, 0, r1, c7, c5, 0"); /* invalidate I cache */ -#endif - -#if !defined(CONFIG_SYS_DCACHE_OFF) - asm("mcr p15, 0, r1, c7, c14, 0"); /* Clean+invalidate D cache */ -#endif - -#endif /* CONFIG_CPU_ARM1136 */ - -#ifdef CONFIG_CPU_ARM926EJS -#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) - /* test and clean, page 2-23 of arm926ejs manual */ - asm("0: mrc p15, 0, r15, c7, c10, 3\n\t" "bne 0b\n" : : : "memory"); - /* disable write buffer as well (page 2-22) */ - asm("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); -#endif -#endif /* CONFIG_CPU_ARM926EJS */ - return; + flush_dcache_range(start, start + size); }
Josh Wu
