[U-Boot] MPC8541 / MPC8555E: DDR_SDRAM_CLK_CNLT[SS_EN] handling
Hello,
I am curious about the setting of the SS_EN bit in the DDR_SDRAM_CLK_CNLT register:
Source synchronous enable. This bit field must be set during initialization. See Section 9.6.1, “DDR SDRAM Initialization Sequence,” for details.
0 - Reserved 1 - The address and command are sent to the DDR SDRAMs source synchronously.
The MPC8555E reference manual and this app note are pretty clear that this bit should be set:
http://cache.freescale.com/files/32bit/doc/app_note/AN2805.pdf (page 17)
set_ddr_sdram_clk_cntl() in u-boot/drivers/ddr/fsl/ctrl_regs.c has this:
clk_adjust = popts->clk_adjust; ddr->ddr_sdram_clk_cntl = (clk_adjust & 0xF) << 23;
There is no accounting for the SS_EN bit on 8541/8555E. I would have expected to see an #ifdef for the MPC8555 that sets the SS_EN bit.
I know 8541 has been around forever and is working fine. I am just trying to find some back ground information on this setting.
Searching the old mailing lists did not turn up anything useful.
Any insight is appreciated.
Cheers, Curt
You are right. We used to have this bit set for 8555 and 8541. I believe it was removed/dropped/lost by this commit 457caecdbca3df21a93abff19eab12dbc61b7897.
York
On 02/12/2015 11:35 PM, Curt Brune wrote:
Hello,
Cheers, Curt
Curt Brune
York Sun
