[U-Boot] [PATCH v2] patman: add Commit-notes tag and section
Sometimes a commit should have notes enclosed with it rather than withing the cover letter -- possibly even because there is no cover letter. Add a 'Commit-notes' tag, similar to the 'Series-notes' one; lines between this tag and the next END line are inserted in the patch right after the '---' commit delimiter.
Signed-off-by: Albert ARIBAUD albert.u.boot@aribaud.net --- Yes, I am writing this note through the very feature that this patch intends to add. If you can read it just below the commit delimiter line ('---') then the feature works.
Well, at least, it works in this very case. :)
Changes in v2: - changed tag name from 'Series-commit-notes' to 'Commit-notes'
tools/patman/README | 2 +- tools/patman/commit.py | 2 ++ tools/patman/patchstream.py | 43 ++++++++++++++++++++++++++++++++++++------- 3 files changed, 39 insertions(+), 8 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index e6d3070..626dc86 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -227,7 +227,7 @@ TEST=... Change-Id: Review URL: Reviewed-on: - +Commit-xxxx: (except Commit-notes)
Exercise for the reader: Try adding some tags to one of your current patch series and see how the patches turn out. diff --git a/tools/patman/commit.py b/tools/patman/commit.py index 900cfb3..89cce7f 100644 --- a/tools/patman/commit.py +++ b/tools/patman/commit.py @@ -21,6 +21,7 @@ class Commit: changes: Dict containing a list of changes (single line strings). The dict is indexed by change version (an integer) cc_list: List of people to aliases/emails to cc on this commit + notes: List of lines in the commit (not series) notes """ def __init__(self, hash): self.hash = hash @@ -28,6 +29,7 @@ class Commit: self.tags = [] self.changes = {} self.cc_list = [] + self.notes = []
def AddChange(self, version, info): """Add a new change line to the change list for a version. diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index c204523..684204c 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -30,7 +30,10 @@ re_cover = re.compile('^Cover-letter:') re_cover_cc = re.compile('^Cover-letter-cc: *(.*)')
# Patch series tag -re_series = re.compile('^Series-([a-z-]*): *(.*)') +re_series_tag = re.compile('^Series-([a-z-]*): *(.*)') + +# Commit series tag +re_commit_tag = re.compile('^Commit-([a-z-]*): *(.*)')
# Commit tags that we want to collect and keep re_tag = re.compile('^(Tested-by|Acked-by|Reviewed-by|Cc): (.*)') @@ -90,6 +93,20 @@ class PatchStream: if self.is_log: self.series.AddTag(self.commit, line, name, value)
+ def AddToCommit(self, line, name, value): + """Add a new Commit-xxx tag. + + When a Commit-xxx tag is detected, we come here to record it. + + Args: + line: Source line containing tag (useful for debug/error messages) + name: Tag name (part after 'Commit-') + value: Tag value (part after 'Commit-xxx: ') + """ + if name == 'notes': + self.in_section = 'commit-' + name + self.skip_blank = False + def CloseCommit(self): """Save the current commit into our commit list, and reset our state""" if self.commit and self.is_log: @@ -138,7 +155,8 @@ class PatchStream: line = line[4:]
# Handle state transition and skipping blank lines - series_match = re_series.match(line) + series_tag_match = re_series_tag.match(line) + commit_tag_match = re_commit_tag.match(line) commit_match = re_commit.match(line) if self.is_log else None cover_cc_match = re_cover_cc.match(line) tag_match = None @@ -165,6 +183,9 @@ class PatchStream: elif self.in_section == 'notes': if self.is_log: self.series.notes += self.section + elif self.in_section == 'commit-notes': + if self.is_log: + self.commit.notes += self.section else: self.warn.append("Unknown section '%s'" % self.in_section) self.in_section = None @@ -178,7 +199,7 @@ class PatchStream: self.commit.subject = line
# Detect the tags we want to remove, and skip blank lines - elif re_remove.match(line): + elif re_remove.match(line) and not commit_tag_match: self.skip_blank = True
# TEST= should be the last thing in the commit, so remove @@ -211,9 +232,9 @@ class PatchStream: self.skip_blank = False
# Detect Series-xxx tags - elif series_match: - name = series_match.group(1) - value = series_match.group(2) + elif series_tag_match: + name = series_tag_match.group(1) + value = series_tag_match.group(2) if name == 'changes': # value is the version number: e.g. 1, or 2 try: @@ -226,6 +247,14 @@ class PatchStream: self.AddToSeries(line, name, value) self.skip_blank = True
+ # Detect Commit-xxx tags + elif commit_tag_match: + name = commit_tag_match.group(1) + value = commit_tag_match.group(2) + if name == 'notes': + self.AddToCommit(line, name, value) + self.skip_blank = True + # Detect the start of a new commit elif commit_match: self.CloseCommit() @@ -276,7 +305,7 @@ class PatchStream: out = [] log = self.series.MakeChangeLog(self.commit) out += self.FormatTags(self.tags) - out += [line] + log + out += [line] + self.commit.notes + [''] + log elif self.found_test: if not re_allowed_after_test.match(line): self.lines_after_test += 1
Applied to u-boot-x86 branch buildpatman, thank you.
(I added a little note to the README to describe your excellent new feature)
On Tue, Nov 12, 2013 at 3:14 AM, Albert ARIBAUD albert.u.boot@aribaud.netwrote:
Changes in v2:
""" def __init__(self, hash): self.hash = hashnotes: List of lines in the commit (not series) notes
self.notes = []
- def AddToCommit(self, line, name, value):
Args:
messages)
if name == 'notes':
- def CloseCommit(self): """Save the current commit into our commit list, and reset our
if self.is_log:
elif re_remove.match(line) and not commit_tag_match: self.skip_blank = True # TEST= should be the last thing in the commit, so remove
elif series_match:
if name == 'notes':
out += [line] + log
-- 1.8.3.2
Albert ARIBAUD
