[U-Boot] [PATCH v2 3/8] arm: Move MAX_CPUS to Kconfig
Move MAX_CPUS option to Kconfig and clean up existing uses for ARM. This option is used by Freescale Layerscape SoCs.
Signed-off-by: York Sun york.sun@nxp.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/arm/cpu/armv7/ls102xa/Kconfig | 11 +++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 13 +++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 4 ---- arch/arm/include/asm/arch-ls102xa/config.h | 1 - 4 files changed, 24 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 2648416..e8264f5 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -9,6 +9,17 @@ config LS1_DEEP_SLEEP bool "Deep sleep" depends on ARCH_LS1021A
+config MAX_CPUS + int "Maximum number of CPUs permitted for LS102xA" + depends on ARCH_LS1021A + default 2 + help + Set this number to the maximum number of possible CPUs in the SoC. + SoCs may have multiple clusters with each cluster may have multiple + ports. If some ports are reserved but higher ports are used for + cores, count the reserved ports. This will allocate enough memory + in spin table to properly handle all cores. + config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5619e0d..6d87fd8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -32,4 +32,17 @@ config SYS_FSL_MMDC config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
+config MAX_CPUS + int "Maximum number of CPUs permitted for Layerscape" + default 4 if ARCH_LS1043A + default 4 if ARCH_LS1046A + default 16 if ARCH_LS2080A + default 1 + help + Set this number to the maximum number of possible CPUs in the SoC. + SoCs may have multiple clusters with each cluster may have multiple + ports. If some ports are reserved but higher ports are used for + cores, count the reserved ports. This will allocate enough memory + in spin table to properly handle all cores. + endmenu diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index a5c6c4c..572fa94 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_MEM_RESERVE_SECURE (2048 * 1024) /* 2MB */
#ifdef CONFIG_LS2080A -#define CONFIG_MAX_CPUS 16 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_NUM_DDR_CONTROLLERS 3 #define CONFIG_SYS_FSL_HAS_DP_DDR /* Runtime check to confirm */ @@ -171,7 +170,6 @@
/* SoC related */ #ifdef CONFIG_LS1043A -#define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 7 @@ -206,13 +204,11 @@ #define CONFIG_SYS_FSL_ERRATUM_A009660 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 #elif defined(CONFIG_ARCH_LS1012A) -#define CONFIG_MAX_CPUS 1 #undef CONFIG_SYS_FSL_DDRC_ARM_GEN3
#define GICD_BASE 0x01401000 #define GICC_BASE 0x01402000 #elif defined(CONFIG_ARCH_LS1046A) -#define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index fab8774..70cc703 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_FSL_SRDS_1
#ifdef CONFIG_LS102XA -#define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0
York Sun
