[PATCH 1/6] ARM: renesas: Enable LTO on R-Car3 ULCB
Enable LTO (link time optimization) to improve optimization and reduce code size by cca. 31 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/rcar3_ulcb_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index 729fbde18f..1e964880f6 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_ULCB=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
Enable LTO (link time optimization) to improve optimization and reduce code size by cca. 32 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/r8a77970_eagle_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index fac4ab66f7..62192ad389 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_EAGLE=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/r8a77980_condor_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index d2aeb9629b..2e2bb55ba2 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_CONDOR=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
Enable LTO (link time optimization) to improve optimization and reduce code size by cca. 34 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/r8a77990_ebisu_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index fe2a38da99..00337e07ee 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_EBISU=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
Enable LTO (link time optimization) to improve optimization and reduce code size by cca. 29 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/r8a77995_draak_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index 9ac70cba65..e6517ea34c 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_RCAR_GEN3=y CONFIG_TARGET_DRAAK=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
Enable LTO (link time optimization) to improve optimization and reduce code size by cca. 30 kiB.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- configs/r8a779a0_falcon_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/r8a779a0_falcon_defconfig b/configs/r8a779a0_falcon_defconfig index 8cf2921327..28fef6f16a 100644 --- a/configs/r8a779a0_falcon_defconfig +++ b/configs/r8a779a0_falcon_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CLK_FREQ=16666666 # CONFIG_PSCI_RESET is not set CONFIG_ARMV8_PSCI=y CONFIG_SYS_LOAD_ADDR=0x58000000 +CONFIG_LTO=y CONFIG_REMAKE_ELF=y CONFIG_SYS_MONITOR_LEN=1048576 CONFIG_FIT=y
