[U-Boot] [PATCH] ARM:PXA Use new definitions in mmc.h
In old code or current u-boot-arm MMC_CMD_WRITE_BLOCK == 24. In new mmc.h 24 is MMC_CMD_WRITE_SINGLE_BLOCK
Change mmc_read to conform to mmc.h declaration.
Signed-off-by: Tom Rix Tom.Rix@windriver.com --- cpu/pxa/mmc.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpu/pxa/mmc.c b/cpu/pxa/mmc.c index 8f5277e..f92c089 100644 --- a/cpu/pxa/mmc.c +++ b/cpu/pxa/mmc.c @@ -181,7 +181,7 @@ mmc_block_write(ulong dst, uchar * src, int len) MMC_STRPCL = MMC_STRPCL_STOP_CLK; MMC_NOB = 1; MMC_BLKLEN = len; - mmc_cmd(MMC_CMD_WRITE_BLOCK, argh, argl, + mmc_cmd(MMC_CMD_WRITE_SINGLE_BLOCK, argh, argl, MMC_CMDAT_R1 | MMC_CMDAT_WRITE | MMC_CMDAT_BLOCK | MMC_CMDAT_DATA_EN);
@@ -218,7 +218,7 @@ mmc_block_write(ulong dst, uchar * src, int len)
int /****************************************************/ -mmc_read(ulong src, uchar * dst, int size) +mmc_read(struct mmc *mmc, u64 src, uchar * dst, int size) /****************************************************/ { ulong end, part_start, part_end, part_len, aligned_start, aligned_end; @@ -383,7 +383,7 @@ mmc_bread(int dev_num, ulong blknr, lbaint_t blkcnt, void *dst) int mmc_block_size = MMC_BLOCK_SIZE; ulong src = blknr * mmc_block_size + CONFIG_SYS_MMC_BASE;
- mmc_read(src, (uchar *) dst, blkcnt * mmc_block_size); + mmc_read(NULL, src, (uchar *) dst, blkcnt * mmc_block_size); return blkcnt; }
NACK the drivers need to be really update but for now we juct rename this function
please take a look on this Subject: [PATCH 4/8 V2] Reduce the scope of PXA's mmc_read/mmc_write/mmc_bread functions
Best Regards, J.
Best Regards, J.
I see the patch at. http://www.mail-archive.com/u-boot@lists.denx.de/msg08137.html Do you want me to go ahead with this or wait for someone with a pxa target to run this down?
Tom
Best Regards, J.
I've send the updated patch and pull request
Best Regards, J.
Tom
Tom Rix
