[PATCH v3 0/4] rockchip: Improve support for Bob chromebook and add support for Kevin
I have recently started testing booting U-Boot from SPI on my gru-kevin (as opposed to chainloading it from vendor coreboot + depthcharge) and brought it to a better working state based on an initial support patch from Marty [1][2] and some follow-up work by Simon [3].
I tried to keep them as the git author when I took things from their work, but squashing other changes into those and rewriting commit messages makes things a bit weird in my opinion, especially for keeping their signoff. Do tell me if there is a better way to that.
As the Kevin and Bob boards are very similar, I assumed the config and devicetree changes will be appropriate for Bob as well, and applied them to it first. I do not have a Bob, so could not test on one myself, but Simon did test an earlier version of this and it appears to work [4].
Other useful things for these boards: - Patch to fix a hang when usb controllers exit [5] (or [6]) - Series to support HS400ES mode as HS400 training fails [7] (but faster speeds are kept disabled in this series since v3) - Hack to skip eMMC reinitialization so it keeps working [8]
[1] https://patchwork.ozlabs.org/patch/1053386/ [2] https://patchwork.ozlabs.org/comment/2488899/ [3] https://github.com/sjg20/u-boot/commits/kevin [4] https://patchwork.ozlabs.org/comment/2799106/ [5] https://patchwork.ozlabs.org/project/uboot/patch/20210406151059.1187379-1-ic... [6] https://patchwork.ozlabs.org/project/uboot/patch/20211224130549.20276-1-alpe... [7] https://patchwork.ozlabs.org/project/uboot/list/?series=269768 [8] https://patchwork.ozlabs.org/comment/2779784/
Changes in v3: - Unset configs MMC_IO_VOLTAGE, MMC_UHS_SUPPORT, MMC_HS400_SUPPORT, MMC_HS400_ES_SUPPORT, MMC_SDHCI_SDMA. - Add tag: "Reviewed-by: Kever Yang kever.yang@rock-chips.com"
v2: https://patchwork.ozlabs.org/project/uboot/list/?series=276629
Changes in v2: - Drop unnecessary ifdef. - Clarify commit message regarding 'values set in coreboot'. - Rebase on u-boot/next, fixing conflict in board_debug_uart_init()
v1: https://patchwork.ozlabs.org/project/uboot/list/?series=273848
Alper Nebi Yasak (2): rockchip: gru: Set up SoC IO domain registers rockchip: bob: Enable more configs
Marty E. Plummer (1): rockchip: rk3399: Add support for chromebook_kevin
Simon Glass (1): rockchip: gru: Add more devicetree settings
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi | 11 ++ arch/arm/dts/rk3399-gru-u-boot.dtsi | 55 +++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 11 ++ arch/arm/mach-rockchip/rk3399/rk3399.c | 3 +- arch/arm/mach-rockchip/spl.c | 3 +- board/google/gru/Kconfig | 16 +++ board/google/gru/MAINTAINERS | 8 ++ board/google/gru/gru.c | 54 ++++++++- configs/chromebook_bob_defconfig | 22 +++- configs/chromebook_kevin_defconfig | 111 ++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/gru.h | 3 + include/dt-bindings/input/linux-event-codes.h | 3 +- 14 files changed, 297 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi create mode 100644 configs/chromebook_kevin_defconfig
The RK3399 SoC needs to know the voltage value provided by some regulators, which is done by setting relevant register bits. Configure these the way other RK3399 boards do, but with the same values as are set in the equivalent code in coreboot.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- There is a driver for this on Rockchip's repo, I managed to forward-port it and get it working. If that's more desirable than doing it per-board like this I can send that upstream (but I'd prefer to do it after this).
Changes in v3: - Add tag: "Reviewed-by: Kever Yang kever.yang@rock-chips.com"
board/google/gru/gru.c | 52 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 52 insertions(+)
diff --git a/board/google/gru/gru.c b/board/google/gru/gru.c index 23080c1798b7..cbf62a9427c9 100644 --- a/board/google/gru/gru.c +++ b/board/google/gru/gru.c @@ -6,6 +6,17 @@ #include <common.h> #include <dm.h> #include <init.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/grf_rk3399.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/misc.h> + +#define GRF_IO_VSEL_BT656_SHIFT 0 +#define GRF_IO_VSEL_AUDIO_SHIFT 1 +#define PMUGRF_CON0_VSEL_SHIFT 8 +#define PMUGRF_CON0_VOL_SHIFT 9
#ifdef CONFIG_SPL_BUILD /* provided to defeat compiler optimisation in board_init_f() */ @@ -54,3 +65,44 @@ int board_early_init_r(void) return 0; } #endif + +static void setup_iodomain(void) +{ + struct rk3399_grf_regs *grf = + syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + struct rk3399_pmugrf_regs *pmugrf = + syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + + /* BT656 and audio is in 1.8v domain */ + rk_setreg(&grf->io_vsel, (1 << GRF_IO_VSEL_BT656_SHIFT | + 1 << GRF_IO_VSEL_AUDIO_SHIFT)); + + /* + * Set GPIO1 1.8v/3.0v source select to PMU1830_VOL + * and explicitly configure that PMU1830_VOL to be 1.8V + */ + rk_setreg(&pmugrf->soc_con0, (1 << PMUGRF_CON0_VSEL_SHIFT | + 1 << PMUGRF_CON0_VOL_SHIFT)); +} + +int misc_init_r(void) +{ + const u32 cpuid_offset = 0x7; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + setup_iodomain(); + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + if (ret) + return ret; + + ret = rockchip_setup_macaddr(); + + return ret; +}
On Fri, 24 Dec 2021 at 06:44, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Changes in v3:
Changes in v2:
Reviewed-by: Simon Glass sjg@chromium.org Tested on bob, kevin Tested-by: Simon Glass sjg@chromium.org
Yes I think a driver would be a good idea.
On Fri, Dec 24, 2021 at 7:14 PM Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Changes in v3:
Changes in v2:
int ret;
setup_iodomain();
if (ret)
return ret;
if (ret)
return ret;
return ret;
This looks like a board hack code for me, which is difficult to maintain in the long run. Better go with UCLASS_POWER_DOMAIN, I believe it would be a straightforward implementation.
Thanks, Jagan.
Yeah, it's a board hack that several other boards also do. I've got a driver working for this as mentioned above, but that adds a new UCLASS_IO_DOMAIN instead of using UCLASS_POWER_DOMAIN like you suggest.
I had been tired of carrying these patches, so wanted to get any working version merged before attempting to upstream the driver and remove the hacky parts from all boards at once. I'm not sure how long would that take, and I didn't want this to be blocked by that.
I've got to work on binman things for a while, so I might not be able to get to that and your other suggestions soon enough.
On Mon, 14 Mar 2022 at 15:32, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
+1 let's get this merged as I have been waiting two releases for this now. I can't really test anything since the base hardware is not functional on mainline.
This adds some devicetree settings for the Gru-based boards, based on what works on a Kevin board.
Gru-based boards usually have an 8MiB SPI flash chip and boot from it. Make the u-boot.rom file intended to be flashed on it match its size. Add properties for booting from SPI, and only try to boot from SPI as MMC and SD card don't seem to work in SPL yet.
The Chromium OS EC needs a delay between transactions so it can get itself ready. Also it currently uses a non-standard way of specifying the interrupt. Add these so that the EC works reliably.
The Rockchip Embedded DisplayPort driver is looking for a rockchip,panel property to find the panel it should work on. Add the property for the Gru-based boards.
The U-Boot GPIO controlled regulator driver only considers the "enable-gpios" devicetree property, not the singular "enable-gpio" one. Some devicetree source files have the singular form as they were added to Linux kernel when it used that form, and imported to U-Boot as is. Fix one instance of this in the Gru boards' devicetree to the form that works in U-Boot.
The PWM controlled regulator driver complains that there is no init voltage set for a regulator it drives, though it's not clear which one. Set them all to the voltage levels coreboot sets them: 900 mV.
The RK3399 SoC needs to know the voltage level that some supplies provides, including one fixed 1.8V audio-related regulator. Although this synchronization is currently statically done in the board init functions, a not-so-hypothetical driver that does this dynamically would query the regulator only to get -ENODATA and be confused. Make sure U-Boot knows this supply is at 1.8V by setting its limits to that.
Most of this is a reapplication of commit 08c85b57a5ec ("rockchip: gru: Add extra device-tree settings") whose changes were removed during a sync with Linux at commit 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux"). Apply things to rk3399-gru-u-boot.dtsi instead so they don't get lost again.
Signed-off-by: Simon Glass sjg@chromium.org [Alper: move to -u-boot.dtsi, rewrite commit message, add more nodes] Co-developed-by: Alper Nebi Yasak alpernebiyasak@gmail.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Kept sign-off and author as Simon based on the aforementioned commit.
arch/arm/dts/rk3399-gru-u-boot.dtsi | 55 +++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/arch/arm/dts/rk3399-gru-u-boot.dtsi b/arch/arm/dts/rk3399-gru-u-boot.dtsi index 390ac2bb5a9a..33734e99be50 100644 --- a/arch/arm/dts/rk3399-gru-u-boot.dtsi +++ b/arch/arm/dts/rk3399-gru-u-boot.dtsi @@ -5,6 +5,61 @@
#include "rk3399-u-boot.dtsi"
+/ { + chosen { + u-boot,spl-boot-order = &spi_flash; + }; + + config { + u-boot,spl-payload-offset = <0x40000>; + }; +}; + +&binman { + rom { + size = <0x800000>; + }; +}; + +&cros_ec { + ec-interrupt = <&gpio0 RK_PA1 GPIO_ACTIVE_LOW>; +}; + +&edp { + rockchip,panel = <&edp_panel>; +}; + +&pp1800_audio { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; +}; + +&ppvar_bigcpu_pwm { + regulator-init-microvolt = <900000>; +}; + +&ppvar_centerlogic_pwm { + regulator-init-microvolt = <900000>; +}; + +&ppvar_gpu_pwm { + regulator-init-microvolt = <900000>; +}; + +&ppvar_litcpu_pwm { + regulator-init-microvolt = <900000>; +}; + +&ppvar_sd_card_io { + enable-gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; +}; + +&spi5 { + spi-activate-delay = <100>; + spi-max-frequency = <3000000>; + spi-deactivate-delay = <200>; +}; + &spi_flash { u-boot,dm-pre-reloc; };
Changes in v3:
This patch enables some configs that should be working on the Bob board, based on what is observed to work on the Kevin board.
The Bob board uses an Embedded DisplayPort panel compatible with the simple panel and Rockchip eDP drivers. Its backlight is controlled by the Chromium OS Embedded Controller Pulse Width Modulator. Enable these for the board.
Also set VIDEO_ROCKCHIP_MAX_{XRES,YRES} to 1280x800, the resolution of its panel. This had to be done for the Kevin board, but it's untested if this is actually necessary for Bob.
The Rockchip video driver needs to assert/deassert some resets, so also enable the reset controller. RESET_ROCKCHIP defaults to y for this board when DM_RESET=y, so it's enough to set that.
The Bob board has two USB 3.0 Type-C ports and one USB 2.0 Type-A port on its right side. Enable the configs relevant to USB devices so these can be used. This is despite a known issue with RK3399 boards where USB de-init causes a hang, as there is a known workaround.
Some other rk3399-based devices enable support for the SoC's random number generator in commit a475bef5340c ("configs: rk3399: enable rng on firefly/rock960/rockpro64"), as it can provide a KASLR seed when booting using UEFI. Enable it for Bob as well.
The default misc_init_r() for Rockchip boards sets cpuid and ethernet MAC address based on e-fuse block. A previous patch extends this on Gru boards to set registers related to SoC IO domains as is necessary on these boards. Enable this function and configs for it on Bob.
The microSD card slot on this board (and others based on Gru) is connected to a GPIO controlled regulator (ppvar-sd-card-io), which must be operable by U-Boot. Enable the relevant config option to allow this.
Bob boards also use the Winbond W25Q64DW SPI flash chip, enable support for Winbond SPI flash chips in the board config so U-Boot can boot with this chip.
configs/chromebook_bob_defconfig | 22 +++++++++++++++++++++- include/configs/gru.h | 3 +++ 2 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index fe938c659172..3f6c088352eb 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -21,6 +21,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_SIZE=0x1000 CONFIG_BLOBLIST_ADDR=0x100000 @@ -52,8 +53,9 @@ CONFIG_ROCKCHIP_GPIO=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_I2C_MUX=y -CONFIG_DM_KEYBOARD=y CONFIG_CROS_EC_KEYB=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y @@ -65,13 +67,21 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_GPIO=y CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_CROS_EC=y CONFIG_PWM_ROCKCHIP=y +CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SPI=y CONFIG_SYSRESET=y @@ -80,11 +90,21 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_VIDEO_ROCKCHIP_MAX_XRES=1280 +CONFIG_VIDEO_ROCKCHIP_MAX_YRES=800 +CONFIG_DISPLAY_ROCKCHIP_EDP=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/include/configs/gru.h b/include/configs/gru.h index be2dc79968c0..b1084bb21d4d 100644 --- a/include/configs/gru.h +++ b/include/configs/gru.h @@ -13,4 +13,7 @@
#include <configs/rk3399_common.h>
+#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 + #endif
Changes in v3:
Changes in v3:
Can you move them to Kconfig?
Jagan.
[...] --- a/include/configs/gru.h +++ b/include/configs/gru.h @@ -13,4 +13,7 @@
I'll try. Not much experience with the USB subsystem though, I may need to do some reading if things aren't trivial.
That should not block this patch, though.
Add support for Kevin, an RK3399-based convertible chromebook that is very similar to Bob. This patch is mostly based on existing support for Bob, with only minor changes for Kevin-specific things.
Unlike other Gru boards, coreboot sets Kevin's center logic to 925 mV, so adjust it here in the dts as well. The rk3399-gru-kevin devicetree has an unknown event code reference which has to be defined, set it to the Linux counterpart. The new defconfig is copied from Bob with the diffconfig:
DEFAULT_DEVICE_TREE "rk3399-gru-bob" -> "rk3399-gru-kevin" DEFAULT_FDT_FILE "rockchip/rk3399-gru-bob.dtb" -> "rockchip/rk3399-gru-kevin.dtb" VIDEO_ROCKCHIP_MAX_XRES 1280 -> 2400 VIDEO_ROCKCHIP_MAX_YRES 800 -> 1600 +TARGET_CHROMEBOOK_KEVIN y
With this Kevin can boot from SPI flash to a usable U-Boot prompt on the display with the keyboard working, but cannot boot into Linux for unknown reasons.
eMMC starts in a working state but fails to re-init, microSD card works but at a lower-than-expected speed, USB works but causes a hang on de-init. There are known workarounds to solve eMMC and USB issues.
Cc: Marty E. Plummer hanetzer@startmail.com Cc: Simon Glass sjg@chromium.org [Alper: commit message, resync config with Bob, update MAINTAINERS, add to Rockchip doc, add Kconfig help message, set regulator] Co-developed-by: Alper Nebi Yasak alpernebiyasak@gmail.com Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- Marty had signed-off an earlier version of this [1], but not the updated version I continued on top of [2]. So I'm not sure if I can add his sign-off to this as is, and I hope he can reply to this with a sign-off.
Changes in v2: - Rebase on u-boot/next, fixing conflict in board_debug_uart_init()
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi | 11 ++ arch/arm/mach-rockchip/rk3399/Kconfig | 11 ++ arch/arm/mach-rockchip/rk3399/rk3399.c | 3 +- arch/arm/mach-rockchip/spl.c | 3 +- board/google/gru/Kconfig | 16 +++ board/google/gru/MAINTAINERS | 8 ++ board/google/gru/gru.c | 2 +- configs/chromebook_kevin_defconfig | 111 ++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/dt-bindings/input/linux-event-codes.h | 3 +- 11 files changed, 166 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi create mode 100644 configs/chromebook_kevin_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7f622fedbda7..d6883994f21a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -132,6 +132,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3399) += \ rk3399-ficus.dtb \ rk3399-firefly.dtb \ rk3399-gru-bob.dtb \ + rk3399-gru-kevin.dtb \ rk3399-khadas-edge.dtb \ rk3399-khadas-edge-captain.dtb \ rk3399-khadas-edge-v.dtb \ diff --git a/arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi b/arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi new file mode 100644 index 000000000000..c03bd48e95d7 --- /dev/null +++ b/arch/arm/dts/rk3399-gru-kevin-u-boot.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com + */ + +#include "rk3399-gru-u-boot.dtsi" +#include "rk3399-sdram-lpddr3-samsung-4GB-1866.dtsi" + +&ppvar_centerlogic_pwm { + regulator-init-microvolt = <925000>; +}; diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 17628f917127..0833e083d9ef 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -14,6 +14,17 @@ config TARGET_CHROMEBOOK_BOB display. It includes a Chrome OS EC (Cortex-M3) to provide access to the keyboard and battery functions.
+config TARGET_CHROMEBOOK_KEVIN + bool "Samsung Chromebook Plus (RK3399)" + select HAS_ROM + select ROCKCHIP_SPI_IMAGE + help + Kevin is a RK3399-based convertible chromebook. It has two USB 3.0 + Type-C ports, 4GB of SDRAM, WiFi and a 12.3" 2400x1600 display. It + uses its USB ports for both power and external display. It includes + a Chromium OS EC (Cortex-M3) to provide access to the keyboard and + battery functions. + config TARGET_EVB_RK3399 bool "RK3399 evaluation board" help diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index d40969c88898..01a05599cd0d 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -140,7 +140,8 @@ void board_debug_uart_init(void) struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE;
if (IS_ENABLED(CONFIG_SPL_BUILD) && - IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_BOB)) { + (IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_BOB) || + IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_KEVIN))) { rk_setreg(&grf->io_vsel, 1 << 0);
/* diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index 02c40fb37ed6..7a8db632b80c 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -56,7 +56,8 @@ u32 spl_boot_device(void) defined(CONFIG_TARGET_CHROMEBIT_MICKEY) || \ defined(CONFIG_TARGET_CHROMEBOOK_MINNIE) || \ defined(CONFIG_TARGET_CHROMEBOOK_SPEEDY) || \ - defined(CONFIG_TARGET_CHROMEBOOK_BOB) + defined(CONFIG_TARGET_CHROMEBOOK_BOB) || \ + defined(CONFIG_TARGET_CHROMEBOOK_KEVIN) return BOOT_DEVICE_SPI; #endif if (CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM)) diff --git a/board/google/gru/Kconfig b/board/google/gru/Kconfig index 61f7bbca989b..1455e1481dc2 100644 --- a/board/google/gru/Kconfig +++ b/board/google/gru/Kconfig @@ -13,3 +13,19 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y
endif + +if TARGET_CHROMEBOOK_KEVIN + +config SYS_BOARD + default "gru" + +config SYS_VENDOR + default "google" + +config SYS_CONFIG_NAME + default "gru" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/google/gru/MAINTAINERS b/board/google/gru/MAINTAINERS index e1cda756b8c8..53257c52a04b 100644 --- a/board/google/gru/MAINTAINERS +++ b/board/google/gru/MAINTAINERS @@ -4,3 +4,11 @@ S: Maintained F: board/google/gru/ F: include/configs/gru.h F: configs/chromebook_bob_defconfig + +CHROMEBOOK KEVIN BOARD +M: Simon Glass sjg@chromium.org +M: Alper Nebi Yasak alpernebiyasak@gmail.com +S: Maintained +F: board/google/gru/ +F: include/configs/gru.h +F: configs/chromebook_kevin_defconfig diff --git a/board/google/gru/gru.c b/board/google/gru/gru.c index cbf62a9427c9..fbcf845e87dd 100644 --- a/board/google/gru/gru.c +++ b/board/google/gru/gru.c @@ -26,7 +26,7 @@ void gru_dummy_function(int i)
int board_early_init_f(void) { -# ifdef CONFIG_TARGET_CHROMEBOOK_BOB +# if defined(CONFIG_TARGET_CHROMEBOOK_BOB) || defined(CONFIG_TARGET_CHROMEBOOK_KEVIN) int sum, i;
/* diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig new file mode 100644 index 000000000000..831a6d3822b8 --- /dev/null +++ b/configs/chromebook_kevin_defconfig @@ -0,0 +1,111 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-gru-kevin" +CONFIG_SPL_TEXT_BASE=0xff8c2000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_BOOT_MODE_REG=0 +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +# CONFIG_SPL_MMC is not set +CONFIG_TARGET_CHROMEBOOK_KEVIN=y +CONFIG_DEBUG_UART_BASE=0xff1a0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_DEBUG_UART=y +CONFIG_SYS_LOAD_ADDR=0x800800 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-kevin.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_MISC_INIT_R=y +CONFIG_BLOBLIST=y +CONFIG_BLOBLIST_SIZE=0x1000 +CONFIG_BLOBLIST_ADDR=0x100000 +CONFIG_HANDOFF=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_LOG=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_I2C_CROS_EC_TUNNEL=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_I2C_MUX=y +CONFIG_CROS_EC_KEYB=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y +CONFIG_CROS_EC=y +CONFIG_CROS_EC_SPI=y +CONFIG_PWRSEQ=y +CONFIG_MMC_PWRSEQ=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_CROS_EC=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_VIDEO_ROCKCHIP_MAX_XRES=2400 +CONFIG_VIDEO_ROCKCHIP_MAX_YRES=1600 +CONFIG_DISPLAY_ROCKCHIP_EDP=y +CONFIG_CMD_DHRYSTONE=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 144cb98ef941..a75e60b9fa30 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -66,6 +66,7 @@ List of mainline supported Rockchip boards: - FriendlyElec NanoPi M4B (nanopi-m4b-rk3399) - FriendlyARM NanoPi NEO4 (nanopi-neo4-rk3399) - Google Bob (chromebook_bob) + - Google Kevin (chromebook_kevin) - Khadas Edge (khadas-edge-rk3399) - Khadas Edge-Captain (khadas-edge-captain-rk3399) - Khadas Edge-V (hadas-edge-v-rk3399) diff --git a/include/dt-bindings/input/linux-event-codes.h b/include/dt-bindings/input/linux-event-codes.h index 87cf351bab03..331458c0e710 100644 --- a/include/dt-bindings/input/linux-event-codes.h +++ b/include/dt-bindings/input/linux-event-codes.h @@ -749,7 +749,8 @@ #define SW_ROTATE_LOCK 0x0c /* set = rotate locked/disabled */ #define SW_LINEIN_INSERT 0x0d /* set = inserted */ #define SW_MUTE_DEVICE 0x0e /* set = device disabled */ -#define SW_MAX 0x0f +#define SW_PEN_INSERTED 0x0f /* set = pen inserted */ +#define SW_MAX 0x10 #define SW_CNT (SW_MAX+1)
Changes in v3:
Changes in v2:
Changes in v3:
Changes in v2:
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
select HAS_ROM
help
battery functions.
IS_ENABLED(CONFIG_TARGET_CHROMEBOOK_KEVIN))) { rk_setreg(&grf->io_vsel, 1 << 0); /*
endif
+config SYS_BOARD
default "gru"
+config SYS_VENDOR
default "google"
default "gru"
def_bool y
This change is not related to the actual patch - remove it from here.
Jagan.
[...] The rk3399-gru-kevin devicetree has an unknown event code reference which has to be defined, set it to the Linux counterpart.
[...] diff --git a/include/dt-bindings/input/linux-event-codes.h b/include/dt-bindings/input/linux-event-codes.h index 87cf351bab03..331458c0e710 100644 --- a/include/dt-bindings/input/linux-event-codes.h +++ b/include/dt-bindings/input/linux-event-codes.h @@ -749,7 +749,8 @@ #define SW_ROTATE_LOCK 0x0c /* set = rotate locked/disabled */ #define SW_LINEIN_INSERT 0x0d /* set = inserted */ #define SW_MUTE_DEVICE 0x0e /* set = device disabled */ -#define SW_MAX 0x0f +#define SW_PEN_INSERTED 0x0f /* set = pen inserted */ +#define SW_MAX 0x10
The definition's necessary to build rk3399-gru-kevin.dtb. But yes, it'd be better to sync linux-event-codes.h from Linux in a separate patch.
Alper Nebi Yasak
Jagan Teki
