[PATCH 1/2] i2c: pcf8575: Remove not used members of pcf8575_chip structure
Those members are not used anymore as ones from gpio_dev_priv structure (when DM_GPIO support is enabled) are used instead.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/gpio/pcf8575_gpio.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/gpio/pcf8575_gpio.c b/drivers/gpio/pcf8575_gpio.c index 359646266c93..bae9695f28b1 100644 --- a/drivers/gpio/pcf8575_gpio.c +++ b/drivers/gpio/pcf8575_gpio.c @@ -34,8 +34,6 @@ DECLARE_GLOBAL_DATA_PTR;
struct pcf8575_chip { - int gpio_count; /* No. GPIOs supported by the chip */ - /* NOTE: these chips have strange "quasi-bidirectional" I/O pins. * We can't actually know whether a pin is configured (a) as output * and driving the signal low, or (b) as input and reporting a low @@ -49,7 +47,6 @@ struct pcf8575_chip { * reset state. Otherwise it flags pins to be driven low. */ unsigned int out; /* software latch */ - const char *bank_name; /* Name of the expander bank */ };
/* Read/Write to 16-bit I/O expander */
This patch add support for using NXP's pca8574 I2C IO expander, which has only 8 IO lines.
After this change the .data member's information from struct udevice_id are used to either sent one or two bytes.
Moreover, the '_le16' suffix from pcf8575_i2c_{write|read}_le16() functions have been removed as now we also sent 8 bit data.
drivers/gpio/pcf8575_gpio.c | 40 ++++++++++++++++++------------------- 1 file changed, 19 insertions(+), 21 deletions(-)
diff --git a/drivers/gpio/pcf8575_gpio.c b/drivers/gpio/pcf8575_gpio.c index bae9695f28b1..d5930d941fc0 100644 --- a/drivers/gpio/pcf8575_gpio.c +++ b/drivers/gpio/pcf8575_gpio.c @@ -12,15 +12,9 @@ * * Copyright (C) 2007 David Brownell * - */ - -/* - * NOTE: The driver and devicetree bindings are borrowed from Linux - * Kernel, but driver does not support all PCF857x devices. It currently - * supports PCF8575 16-bit expander by TI and NXP. + * Add support for 8 bit expanders - like pca8574 + * Copyright (C) 2021 Lukasz Majewski - DENX Software Engineering * - * TODO(vigneshr@ti.com): - * Support 8 bit PCF857x compatible expanders. */
#include <common.h> @@ -49,15 +43,15 @@ struct pcf8575_chip { unsigned int out; /* software latch */ };
-/* Read/Write to 16-bit I/O expander */ +/* Read/Write to I/O expander */
-static int pcf8575_i2c_write_le16(struct udevice *dev, unsigned int word) +static int pcf8575_i2c_write(struct udevice *dev, unsigned int word) { struct dm_i2c_chip *chip = dev_get_parent_plat(dev); u8 buf[2] = { word & 0xff, word >> 8, }; int ret;
- ret = dm_i2c_write(dev, 0, buf, 2); + ret = dm_i2c_write(dev, 0, buf, dev_get_driver_data(dev)); if (ret) printf("%s i2c write failed to addr %x\n", __func__, chip->chip_addr); @@ -65,13 +59,13 @@ static int pcf8575_i2c_write_le16(struct udevice *dev, unsigned int word) return ret; }
-static int pcf8575_i2c_read_le16(struct udevice *dev) +static int pcf8575_i2c_read(struct udevice *dev) { struct dm_i2c_chip *chip = dev_get_parent_plat(dev); - u8 buf[2]; + u8 buf[2] = {0x00, 0x00}; int ret;
- ret = dm_i2c_read(dev, 0, buf, 2); + ret = dm_i2c_read(dev, 0, buf, dev_get_driver_data(dev)); if (ret) { printf("%s i2c read failed from addr %x\n", __func__, chip->chip_addr); @@ -87,7 +81,7 @@ static int pcf8575_direction_input(struct udevice *dev, unsigned offset) int status;
plat->out |= BIT(offset); - status = pcf8575_i2c_write_le16(dev, plat->out); + status = pcf8575_i2c_write(dev, plat->out);
return status; } @@ -103,7 +97,7 @@ static int pcf8575_direction_output(struct udevice *dev, else plat->out &= ~BIT(offset);
- ret = pcf8575_i2c_write_le16(dev, plat->out); + ret = pcf8575_i2c_write(dev, plat->out);
return ret; } @@ -112,7 +106,7 @@ static int pcf8575_get_value(struct udevice *dev, unsigned int offset) { int value;
- value = pcf8575_i2c_read_le16(dev); + value = pcf8575_i2c_read(dev);
return (value < 0) ? value : ((value & BIT(offset)) >> offset); } @@ -130,8 +124,11 @@ static int pcf8575_ofdata_plat(struct udevice *dev)
int n_latch;
- uc_priv->gpio_count = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "gpio-count", 16); + /* + * Number of pins depends on the expander device and is specified + * in the struct udevice_id (as in the Linue kernel). + */ + uc_priv->gpio_count = dev_get_driver_data(dev) * 8; uc_priv->bank_name = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), "gpio-bank-name", NULL); if (!uc_priv->bank_name) @@ -163,8 +160,9 @@ static const struct dm_gpio_ops pcf8575_gpio_ops = { };
static const struct udevice_id pcf8575_gpio_ids[] = { - { .compatible = "nxp,pcf8575" }, - { .compatible = "ti,pcf8575" }, + { .compatible = "nxp,pcf8575", .data = 2 }, + { .compatible = "ti,pcf8575", .data = 2 }, + { .compatible = "nxp,pca8574", .data = 1 }, { } };
Hello Lukasz,
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Heiko Schocher hs@denx.de
Hello Lukasz,
bye, Heiko
Heiko Schocher
Lukasz Majewski
