[PATCH 1/4] usb: Move SPL_USB_HOST Kconfig symbol to drivers/usb/
To avoid piling up all the various Kconfig symbols in one place, i.e. common/spl/Kconfig, move the USB Kconfig symbols into drivers/usb/ . This commit moves SPL_USB_HOST and updates help text of both USB_HOST and SPL_USB_HOST .
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andrew Davis afd@ti.com Cc: Chris Packham judge.packham@gmail.com Cc: Jim Liu jim.t90615@gmail.com Cc: Lukasz Majewski lukma@denx.de Cc: Samuel Holland samuel@sholland.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Weijie Gao weijie.gao@mediatek.com --- common/spl/Kconfig | 10 ---------- drivers/usb/host/Kconfig | 13 +++++++++++++ 2 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 2c042ad3066..03d0fd90e09 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1345,16 +1345,6 @@ config SPL_THERMAL automatic power-off when the temperature gets too high or low. Other devices may be discrete but connected on a suitable bus.
-config SPL_USB_HOST - bool "Support USB host drivers" - help - Enable access to USB (Universal Serial Bus) host devices so that - SPL can load U-Boot from a connected USB peripheral, such as a USB - flash stick. While USB takes a little longer to start up than most - buses, it is very flexible since many different types of storage - device can be attached. This option enables the drivers in - drivers/usb/host as part of an SPL build. - config SPL_USB_STORAGE bool "Support loading from USB" depends on SPL_USB_HOST diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 6213b3c95fa..1a883babf4c 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -6,6 +6,19 @@ comment "USB Host Controller Drivers" config USB_HOST bool select DM_USB + help + Enable access to USB (Universal Serial Bus) host devices so that + SPL can load U-Boot from a connected USB peripheral, such as a USB + flash stick. While USB takes a little longer to start up than most + buses, it is very flexible since many different types of storage + device can be attached. + +config SPL_USB_HOST + bool "Support USB host drivers" + depends on SPL + help + For detailed help see USB_HOST Kconfig symbol. This option enables + the drivers in drivers/usb/host as part of an SPL build.
config USB_XHCI_HCD bool "xHCI HCD (USB 3.0) support"
To avoid piling up all the various Kconfig symbols in one place, i.e. common/spl/Kconfig, move the USB Kconfig symbols into drivers/usb/ . This commit moves SPL_USB_STORAGE and matching SYS_USB_FAT_BOOT_PARTITION .
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andrew Davis afd@ti.com Cc: Chris Packham judge.packham@gmail.com Cc: Jim Liu jim.t90615@gmail.com Cc: Lukasz Majewski lukma@denx.de Cc: Samuel Holland samuel@sholland.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Weijie Gao weijie.gao@mediatek.com --- common/spl/Kconfig | 17 ----------------- drivers/usb/Kconfig | 22 ++++++++++++++++++++++ 2 files changed, 22 insertions(+), 17 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 03d0fd90e09..5ad29af21cb 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1345,23 +1345,6 @@ config SPL_THERMAL automatic power-off when the temperature gets too high or low. Other devices may be discrete but connected on a suitable bus.
-config SPL_USB_STORAGE - bool "Support loading from USB" - depends on SPL_USB_HOST - help - Enable support for USB devices in SPL. This allows use of USB - devices such as hard drives and flash drivers for loading U-Boot. - The actual drivers are enabled separately using the normal U-Boot - config options. This enables loading from USB using a configured - device. - -config SYS_USB_FAT_BOOT_PARTITION - int "Partition on USB to use to load U-Boot from" - depends on SPL_USB_STORAGE - default 1 - help - Partition on the USB storage device to load U-Boot from - config SPL_USB_GADGET bool "Suppport USB Gadget drivers" help diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 94fb32d107c..a972d87c7ad 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -126,6 +126,28 @@ config USB_HUB_DEBOUNCE_TIMEOUT value = 1s because some usb device needs around 1.5s to be initialized and a 2s value should solve detection issue on problematic USB keys.
+if SPL_USB_HOST + +comment "USB peripherals in SPL" + +config SPL_USB_STORAGE + bool "Support loading from USB" + help + Enable support for USB devices in SPL. This allows use of USB + devices such as hard drives and flash drivers for loading U-Boot. + The actual drivers are enabled separately using the normal U-Boot + config options. This enables loading from USB using a configured + device. + +config SYS_USB_FAT_BOOT_PARTITION + int "Partition on USB to use to load U-Boot from" + depends on SPL_USB_STORAGE + default 1 + help + Partition on the USB storage device to load U-Boot from. + +endif + if USB_KEYBOARD
config USB_KEYBOARD_FN_KEYS
To avoid piling up all the various Kconfig symbols in one place, i.e. common/spl/Kconfig, move the USB Kconfig symbols into drivers/usb/ . This commit moves SPL_USB_GADGET and related symbols. Fix typo and rename SPL_USB_GADGET to "USB Gadget Support in SPL" .
Update the gadget Makefile to match the symbol changes.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andrew Davis afd@ti.com Cc: Chris Packham judge.packham@gmail.com Cc: Jim Liu jim.t90615@gmail.com Cc: Lukasz Majewski lukma@denx.de Cc: Samuel Holland samuel@sholland.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Weijie Gao weijie.gao@mediatek.com --- common/spl/Kconfig | 63 ------------------------------------ drivers/usb/gadget/Kconfig | 64 +++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/Makefile | 5 ++- 3 files changed, 66 insertions(+), 66 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 5ad29af21cb..6774ba5b42e 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1345,69 +1345,6 @@ config SPL_THERMAL automatic power-off when the temperature gets too high or low. Other devices may be discrete but connected on a suitable bus.
-config SPL_USB_GADGET - bool "Suppport USB Gadget drivers" - help - Enable USB Gadget API which allows to enable USB device functions - in SPL. - -if SPL_USB_GADGET - -config SPL_USB_ETHER - bool "Support USB Ethernet drivers" - depends on SPL_NET - help - Enable access to the USB network subsystem and associated - drivers in SPL. This permits SPL to load U-Boot over a - USB-connected Ethernet link (such as a USB Ethernet dongle) rather - than from an onboard peripheral. Environment support is required - since the network stack uses a number of environment variables. - See also SPL_NET and SPL_ETH. - -config SPL_DFU - bool "Support DFU (Device Firmware Upgrade)" - select SPL_HASH - select SPL_DFU_NO_RESET - depends on SPL_RAM_SUPPORT - help - This feature enables the DFU (Device Firmware Upgrade) in SPL with - RAM memory device support. The ROM code will load and execute - the SPL built with dfu. The user can load binaries (u-boot/kernel) to - selected device partition from host-pc using dfu-utils. - This feature is useful to flash the binaries to factory or bare-metal - boards using USB interface. - -choice - bool "DFU device selection" - depends on SPL_DFU - -config SPL_DFU_RAM - bool "RAM device" - depends on SPL_DFU && SPL_RAM_SUPPORT - help - select RAM/DDR memory device for loading binary images - (u-boot/kernel) to the selected device partition using - DFU and execute the u-boot/kernel from RAM. - -endchoice - -config SPL_USB_SDP_SUPPORT - bool "Support SDP (Serial Download Protocol)" - depends on SPL_SERIAL - help - Enable Serial Download Protocol (SDP) device support in SPL. This - allows to download images into memory and execute (jump to) them - using the same protocol as implemented by the i.MX family's boot ROM. - -config SPL_SDP_USB_DEV - int "SDP USB controller index" - default 0 - depends on SPL_USB_SDP_SUPPORT - help - Some boards have USB controller other than 0. Define this option - so it can be used in compiled environment. -endif - config SPL_WATCHDOG bool "Support watchdog drivers" imply SPL_WDT if !HW_WATCHDOG diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 941f97c96d0..6f85089a9bf 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -36,6 +36,12 @@ menuconfig USB_GADGET peripheral/device side bus controller, and a "gadget driver" for your peripheral protocol.
+config SPL_USB_GADGET + bool "USB Gadget Support in SPL" + help + Enable USB Gadget API which allows to enable USB device functions + in SPL. + if USB_GADGET
config USB_GADGET_MANUFACTURER @@ -265,3 +271,61 @@ config USBNET_HOST_ADDR endif # USB_ETHER
endif # USB_GADGET + +if SPL_USB_GADGET + +config SPL_USB_ETHER + bool "Support USB Ethernet drivers in SPL" + depends on SPL_NET + help + Enable access to the USB network subsystem and associated + drivers in SPL. This permits SPL to load U-Boot over a + USB-connected Ethernet link (such as a USB Ethernet dongle) rather + than from an onboard peripheral. Environment support is required + since the network stack uses a number of environment variables. + See also SPL_NET and SPL_ETH. + +config SPL_DFU + bool "Support DFU (Device Firmware Upgrade) in SPL" + select SPL_HASH + select SPL_DFU_NO_RESET + depends on SPL_RAM_SUPPORT + help + This feature enables the DFU (Device Firmware Upgrade) in SPL with + RAM memory device support. The ROM code will load and execute + the SPL built with dfu. The user can load binaries (u-boot/kernel) to + selected device partition from host-pc using dfu-utils. + This feature is useful to flash the binaries to factory or bare-metal + boards using USB interface. + +choice + bool "DFU device selection in SPL" + depends on SPL_DFU + +config SPL_DFU_RAM + bool "RAM device" + depends on SPL_DFU && SPL_RAM_SUPPORT + help + select RAM/DDR memory device for loading binary images + (u-boot/kernel) to the selected device partition using + DFU and execute the u-boot/kernel from RAM. + +endchoice + +config SPL_USB_SDP_SUPPORT + bool "Support SDP (Serial Download Protocol) in SPL" + depends on SPL_SERIAL + help + Enable Serial Download Protocol (SDP) device support in SPL. This + allows to download images into memory and execute (jump to) them + using the same protocol as implemented by the i.MX family's boot ROM. + +config SPL_SDP_USB_DEV + int "SDP USB controller index in SPL" + default 0 + depends on SPL_USB_SDP_SUPPORT + help + Some boards have USB controller other than 0. Define this option + so it can be used in compiled environment. + +endif # SPL_USB_GADGET diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 6cfe0f3a041..a9edeb9f396 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -3,8 +3,8 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_USB_GADGET) += epautoconf.o config.o usbstring.o -obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o +obj-$(CONFIG_$(SPL_TPL_)USB_GADGET) += epautoconf.o config.o usbstring.o +obj-$(CONFIG_$(SPL_TPL_)USB_ETHER) += epautoconf.o config.o usbstring.o ether.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_USB_GADGET) += g_dnl.o @@ -34,7 +34,6 @@ endif
obj-$(CONFIG_CI_UDC) += ci_udc.o
-obj-$(CONFIG_USB_ETHER) += ether.o obj-$(CONFIG_USB_ETH_RNDIS) += rndis.o
# Devices not related to the new gadget layer depend on CONFIG_USB_DEVICE
Define SPL_USB_ETH_RNDIS symbol to make it possible to select USB gadget ethernet support in SPL and U-Boot separately in Kconfig . Make use of the new symbols in gadget Makefile and move the rndis.o just below the now merged USB_ETHER symbol in Makefile.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Andrew Davis afd@ti.com Cc: Chris Packham judge.packham@gmail.com Cc: Jim Liu jim.t90615@gmail.com Cc: Lukasz Majewski lukma@denx.de Cc: Samuel Holland samuel@sholland.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Weijie Gao weijie.gao@mediatek.com --- drivers/usb/gadget/Kconfig | 24 ++++++++++++++++++++++++ drivers/usb/gadget/Makefile | 3 +-- 2 files changed, 25 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/Kconfig b/drivers/usb/gadget/Kconfig index 6f85089a9bf..1cfe6022842 100644 --- a/drivers/usb/gadget/Kconfig +++ b/drivers/usb/gadget/Kconfig @@ -285,6 +285,30 @@ config SPL_USB_ETHER since the network stack uses a number of environment variables. See also SPL_NET and SPL_ETH.
+if SPL_USB_ETHER + +choice + prompt "USB Ethernet Gadget Model in SPL" + default SPL_USB_ETH_RNDIS + help + There is several models (protocols) to implement Ethernet over USB + devices. The main ones are Microsoft's RNDIS and USB's CDC-Ethernet + (also called CDC-ECM). RNDIS is obviously compatible with Windows, + while CDC-ECM is not. Most other operating systems support both, so + if inter-operability is a concern, RNDIS is to be preferred. + +config SPL_USB_ETH_RNDIS + bool "RNDIS Protocol" + help + The RNDIS (Remote Network Driver Interface Specification) is a + Microsoft proprietary protocol to create an Ethernet device over USB. + Windows obviously supports it, as well as all the major operating + systems, so it's the best option for compatibility. + +endchoice + +endif # SPL_USB_ETHER + config SPL_DFU bool "Support DFU (Device Firmware Upgrade) in SPL" select SPL_HASH diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index a9edeb9f396..6abcce0d9c7 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -5,6 +5,7 @@
obj-$(CONFIG_$(SPL_TPL_)USB_GADGET) += epautoconf.o config.o usbstring.o obj-$(CONFIG_$(SPL_TPL_)USB_ETHER) += epautoconf.o config.o usbstring.o ether.o +obj-$(CONFIG_$(SPL_TPL_)USB_ETH_RNDIS) += rndis.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_USB_GADGET) += g_dnl.o @@ -34,8 +35,6 @@ endif
-obj-$(CONFIG_USB_ETH_RNDIS) += rndis.o - # Devices not related to the new gadget layer depend on CONFIG_USB_DEVICE # This is really only N900 and USBTTY now. obj-$(CONFIG_USB_DEVICE) += core.o ep0.o
