[PATCH 16/20] ram: add SDRAM driver for i.MXRT SoCs
Add SDRAM driver for i.MXRT SoCs.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/ram/Kconfig | 8 + drivers/ram/Makefile | 2 + drivers/ram/imxrt_sdram.c | 439 +++++++++++++++++++++++ include/dt-bindings/memory/imxrt-sdram.h | 100 ++++++ 4 files changed, 549 insertions(+) create mode 100644 drivers/ram/imxrt_sdram.c create mode 100644 include/dt-bindings/memory/imxrt-sdram.h
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index b454ceb599..56fea7c94c 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -65,5 +65,13 @@ config K3_J721E_DDRSS Enabling this config adds support for the DDR memory controller on J721E family of SoCs.
+config IMXRT_SDRAM + bool "Enable i.MXRT SDRAM support" + depends on RAM + help + i.MXRT family devices support smart external memory controller(SEMC) + to support external memories like sdram, psram & nand. + This driver is for the sdram memory interface with the SEMC. + source "drivers/ram/rockchip/Kconfig" source "drivers/ram/stm32mp1/Kconfig" diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 4b77969b39..5c897410c6 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -15,3 +15,5 @@ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_K3_AM654_DDRSS) += k3-am654-ddrss.o obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_K3_J721E_DDRSS) += k3-j721e/ + +obj-$(CONFIG_IMXRT_SDRAM) += imxrt_sdram.o diff --git a/drivers/ram/imxrt_sdram.c b/drivers/ram/imxrt_sdram.c new file mode 100644 index 0000000000..af7400be82 --- /dev/null +++ b/drivers/ram/imxrt_sdram.c @@ -0,0 +1,439 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <ram.h> +#include <asm/io.h> + +/* SDRAM Command Code */ +#define SD_CC_ARD 0x0 /* Master Bus (AXI) command - Read */ +#define SD_CC_AWR 0x1 /* Master Bus (AXI) command - Write */ +#define SD_CC_IRD 0x8 /* IP command - Read */ +#define SD_CC_IWR 0x9 /* IP command - Write */ +#define SD_CC_IMS 0xA /* IP command - Set Mode Register */ +#define SD_CC_IACT 0xB /* IP command - ACTIVE */ +#define SD_CC_IAF 0xC /* IP command - Auto Refresh */ +#define SD_CC_ISF 0xD /* IP Command - Self Refresh */ +#define SD_CC_IPRE 0xE /* IP command - Precharge */ +#define SD_CC_IPREA 0xF /* IP command - Precharge ALL */ + +#define SEMC_MCR_MDIS BIT(1) +#define SEMC_MCR_DQSMD BIT(2) + +#define SEMC_INTR_IPCMDERR BIT(1) +#define SEMC_INTR_IPCMDDONE BIT(0) + +#define SEMC_IPCMD_KEY 0xA55A0000 + +struct imxrt_semc_regs { + /* 0x0 */ + u32 mcr; + u32 iocr; + u32 bmcr0; + u32 bmcr1; + u32 br[9]; + + /* 0x34 */ + u32 res1; + u32 inten; + u32 intr; + /* 0x40 */ + u32 sdramcr0; + u32 sdramcr1; + u32 sdramcr2; + u32 sdramcr3; + /* 0x50 */ + u32 nandcr0; + u32 nandcr1; + u32 nandcr2; + u32 nandcr3; + /* 0x60 */ + u32 norcr0; + u32 norcr1; + u32 norcr2; + u32 norcr3; + /* 0x70 */ + u32 sramcr0; + u32 sramcr1; + u32 sramcr2; + u32 sramcr3; + /* 0x80 */ + u32 dbicr0; + u32 dbicr1; + u32 res2[2]; + /* 0x90 */ + u32 ipcr0; + u32 ipcr1; + u32 ipcr2; + u32 ipcmd; + /* 0xA0 */ + u32 iptxdat; + u32 res3[3]; + /* 0xB0 */ + u32 iprxdat; + u32 res4[3]; + /* 0xC0 */ + u32 sts[16]; +}; + +#define SEMC_IOCR_MUX_A8_SHIFT 0 +#define SEMC_IOCR_MUX_CSX0_SHIFT 3 +#define SEMC_IOCR_MUX_CSX1_SHIFT 6 +#define SEMC_IOCR_MUX_CSX2_SHIFT 9 +#define SEMC_IOCR_MUX_CSX3_SHIFT 12 +#define SEMC_IOCR_MUX_RDY_SHIFT 15 + +struct imxrt_sdram_mux { + u8 a8; + u8 csx0; + u8 csx1; + u8 csx2; + u8 csx3; + u8 rdy; +}; + +#define SEMC_SDRAMCR0_PS_SHIFT 0 +#define SEMC_SDRAMCR0_BL_SHIFT 4 +#define SEMC_SDRAMCR0_COL_SHIFT 8 +#define SEMC_SDRAMCR0_CL_SHIFT 10 + +struct imxrt_sdram_control { + u8 memory_width; + u8 burst_len; + u8 no_columns; + u8 cas_latency; +}; + +#define SEMC_SDRAMCR1_PRE2ACT_SHIFT 0 +#define SEMC_SDRAMCR1_ACT2RW_SHIFT 4 +#define SEMC_SDRAMCR1_RFRC_SHIFT 8 +#define SEMC_SDRAMCR1_WRC_SHIFT 13 +#define SEMC_SDRAMCR1_CKEOFF_SHIFT 16 +#define SEMC_SDRAMCR1_ACT2PRE_SHIFT 20 + +#define SEMC_SDRAMCR2_SRRC_SHIFT 0 +#define SEMC_SDRAMCR2_REF2REF_SHIFT 8 +#define SEMC_SDRAMCR2_ACT2ACT_SHIFT 16 +#define SEMC_SDRAMCR2_ITO_SHIFT 24 + +#define SEMC_SDRAMCR3_REN BIT(0) +#define SEMC_SDRAMCR3_REBL_SHIFT 1 +#define SEMC_SDRAMCR3_PRESCALE_SHIFT 8 +#define SEMC_SDRAMCR3_RT_SHIFT 16 +#define SEMC_SDRAMCR3_UT_SHIFT 24 + +struct imxrt_sdram_timing { + u8 pre2act; + u8 act2rw; + u8 rfrc; + u8 wrc; + u8 ckeoff; + u8 act2pre; + + u8 srrc; + u8 ref2ref; + u8 act2act; + u8 ito; + + u8 rebl; + u8 prescale; + u8 rt; + u8 ut; +}; + +enum imxrt_semc_bank { + SDRAM_BANK1, + SDRAM_BANK2, + SDRAM_BANK3, + SDRAM_BANK4, + MAX_SDRAM_BANK, +}; + +#define SEMC_BR_VLD_MASK 1 +#define SEMC_BR_MS_SHIFT 1 + +struct bank_params { + enum imxrt_semc_bank target_bank; + u32 base_address; + u32 memory_size; +}; + +struct imxrt_sdram_params { + struct imxrt_semc_regs *base; + + struct imxrt_sdram_mux *sdram_mux; + struct imxrt_sdram_control *sdram_control; + struct imxrt_sdram_timing *sdram_timing; + + struct bank_params bank_params[MAX_SDRAM_BANK]; + u8 no_sdram_banks; +}; + +static int imxrt_sdram_wait_ipcmd_done(struct imxrt_semc_regs *regs) +{ + do { + readl(®s->intr); + + if (regs->intr & SEMC_INTR_IPCMDDONE) + return 0; + if (regs->intr & SEMC_INTR_IPCMDERR) + return -EIO; + + mdelay(50); + } while (1); +} + +static int imxrt_sdram_ipcmd(struct imxrt_semc_regs *regs, u32 mem_addr, + u32 ipcmd, u32 wd, u32 *rd) +{ + int ret; + + if (ipcmd == SD_CC_IWR || ipcmd == SD_CC_IMS) + writel(wd, ®s->iptxdat); + + /* set slave address for every command as specified on RM */ + writel(mem_addr, ®s->ipcr0); + + /* execute command */ + writel(SEMC_IPCMD_KEY | ipcmd, ®s->ipcmd); + + ret = imxrt_sdram_wait_ipcmd_done(regs); + if (ret < 0) + return ret; + + if (ipcmd == SD_CC_IRD) { + if (!rd) + return -EINVAL; + + *rd = readl(®s->iprxdat); + } + + return 0; +} + +int imxrt_sdram_init(struct udevice *dev) +{ + struct imxrt_sdram_params *params = dev_get_platdata(dev); + struct imxrt_sdram_mux *mux = params->sdram_mux; + struct imxrt_sdram_control *ctrl = params->sdram_control; + struct imxrt_sdram_timing *time = params->sdram_timing; + struct imxrt_semc_regs *regs = params->base; + struct bank_params *bank_params; + u32 rd; + int i; + + /* enable the SEMC controller */ + clrbits_le32(®s->mcr, SEMC_MCR_MDIS); + /* set DQS mode from DQS pad */ + setbits_le32(®s->mcr, SEMC_MCR_DQSMD); + + for (i = 0, bank_params = params->bank_params; + i < params->no_sdram_banks; bank_params++, + i++) + writel((bank_params->base_address & 0xfffff000) + | bank_params->memory_size << SEMC_BR_MS_SHIFT + | SEMC_BR_VLD_MASK, + ®s->br[bank_params->target_bank]); + + writel(mux->a8 << SEMC_IOCR_MUX_A8_SHIFT + | mux->csx0 << SEMC_IOCR_MUX_CSX0_SHIFT + | mux->csx1 << SEMC_IOCR_MUX_CSX1_SHIFT + | mux->csx2 << SEMC_IOCR_MUX_CSX2_SHIFT + | mux->csx3 << SEMC_IOCR_MUX_CSX3_SHIFT + | mux->rdy << SEMC_IOCR_MUX_RDY_SHIFT, + ®s->iocr); + + writel(ctrl->memory_width << SEMC_SDRAMCR0_PS_SHIFT + | ctrl->burst_len << SEMC_SDRAMCR0_BL_SHIFT + | ctrl->no_columns << SEMC_SDRAMCR0_COL_SHIFT + | ctrl->cas_latency << SEMC_SDRAMCR0_CL_SHIFT, + ®s->sdramcr0); + + writel(time->pre2act << SEMC_SDRAMCR1_PRE2ACT_SHIFT + | time->act2rw << SEMC_SDRAMCR1_ACT2RW_SHIFT + | time->rfrc << SEMC_SDRAMCR1_RFRC_SHIFT + | time->wrc << SEMC_SDRAMCR1_WRC_SHIFT + | time->ckeoff << SEMC_SDRAMCR1_CKEOFF_SHIFT + | time->act2pre << SEMC_SDRAMCR1_ACT2PRE_SHIFT, + ®s->sdramcr1); + + writel(time->srrc << SEMC_SDRAMCR2_SRRC_SHIFT + | time->ref2ref << SEMC_SDRAMCR2_REF2REF_SHIFT + | time->act2act << SEMC_SDRAMCR2_ACT2ACT_SHIFT + | time->ito << SEMC_SDRAMCR2_ITO_SHIFT, + ®s->sdramcr2); + + writel(time->rebl << SEMC_SDRAMCR3_REBL_SHIFT + | time->prescale << SEMC_SDRAMCR3_PRESCALE_SHIFT + | time->rt << SEMC_SDRAMCR3_RT_SHIFT + | time->ut << SEMC_SDRAMCR3_UT_SHIFT + | SEMC_SDRAMCR3_REN, + ®s->sdramcr3); + + writel(2, ®s->ipcr1); + + for (i = 0, bank_params = params->bank_params; + i < params->no_sdram_banks; bank_params++, + i++) { + mdelay(250); + imxrt_sdram_ipcmd(regs, bank_params->base_address, SD_CC_IPREA, + 0, &rd); + imxrt_sdram_ipcmd(regs, bank_params->base_address, SD_CC_IAF, + 0, &rd); + imxrt_sdram_ipcmd(regs, bank_params->base_address, SD_CC_IAF, + 0, &rd); + imxrt_sdram_ipcmd(regs, bank_params->base_address, SD_CC_IMS, + ctrl->burst_len | (ctrl->cas_latency << 4), + &rd); + mdelay(250); + } + + return 0; +} + +static int imxrt_semc_ofdata_to_platdata(struct udevice *dev) +{ + struct imxrt_sdram_params *params = dev_get_platdata(dev); + ofnode bank_node; + u8 bank = 0; + + params->sdram_mux = + (struct imxrt_sdram_mux *) + dev_read_u8_array_ptr(dev, + "fsl,sdram-mux", + sizeof(struct imxrt_sdram_mux)); + if (!params->sdram_mux) { + pr_err("fsl,sdram-mux not found"); + return -EINVAL; + } + + params->sdram_control = + (struct imxrt_sdram_control *) + dev_read_u8_array_ptr(dev, + "fsl,sdram-control", + sizeof(struct imxrt_sdram_control)); + if (!params->sdram_control) { + pr_err("fsl,sdram-control not found"); + return -EINVAL; + } + + params->sdram_timing = + (struct imxrt_sdram_timing *) + dev_read_u8_array_ptr(dev, + "fsl,sdram-timing", + sizeof(struct imxrt_sdram_timing)); + if (!params->sdram_timing) { + pr_err("fsl,sdram-timing not found"); + return -EINVAL; + } + + dev_for_each_subnode(bank_node, dev) { + struct bank_params *bank_params; + char *bank_name; + int ret; + + /* extract the bank index from DT */ + bank_name = (char *)ofnode_get_name(bank_node); + strsep(&bank_name, "@"); + if (!bank_name) { + pr_err("missing sdram bank index"); + return -EINVAL; + } + + bank_params = ¶ms->bank_params[bank]; + strict_strtoul(bank_name, 10, + (unsigned long *)&bank_params->target_bank); + if (bank_params->target_bank >= MAX_SDRAM_BANK) { + pr_err("Found bank %d , but only bank 0,1,2,3 are supported", + bank_params->target_bank); + return -EINVAL; + } + + ret = ofnode_read_u32(bank_node, + "fsl,memory-size", + &bank_params->memory_size); + if (ret < 0) { + pr_err("fsl,memory-size not found"); + return -EINVAL; + } + + ret = ofnode_read_u32(bank_node, + "fsl,base-address", + &bank_params->base_address); + if (ret < 0) { + pr_err("fsl,base-address not found"); + return -EINVAL; + } + + debug("Found bank %s %u\n", bank_name, + bank_params->target_bank); + bank++; + } + + params->no_sdram_banks = bank; + debug("%s, no of banks = %d\n", __func__, params->no_sdram_banks); + + return 0; +} + +static int imxrt_semc_probe(struct udevice *dev) +{ + struct imxrt_sdram_params *params = dev_get_platdata(dev); + int ret; + fdt_addr_t addr; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + params->base = (struct imxrt_semc_regs *)addr; + +#ifdef CONFIG_CLK + struct clk clk; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + + if (ret) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } +#endif + ret = imxrt_sdram_init(dev); + if (ret) + return ret; + + return 0; +} + +static int imxrt_semc_get_info(struct udevice *dev, struct ram_info *info) +{ + return 0; +} + +static struct ram_ops imxrt_semc_ops = { + .get_info = imxrt_semc_get_info, +}; + +static const struct udevice_id imxrt_semc_ids[] = { + { .compatible = "fsl,imxrt-semc", .data = 0 }, + { } +}; + +U_BOOT_DRIVER(imxrt_semc) = { + .name = "imxrt_semc", + .id = UCLASS_RAM, + .of_match = imxrt_semc_ids, + .ops = &imxrt_semc_ops, + .ofdata_to_platdata = imxrt_semc_ofdata_to_platdata, + .probe = imxrt_semc_probe, + .platdata_auto_alloc_size = sizeof(struct imxrt_sdram_params), +}; diff --git a/include/dt-bindings/memory/imxrt-sdram.h b/include/dt-bindings/memory/imxrt-sdram.h new file mode 100644 index 0000000000..acb35bce27 --- /dev/null +++ b/include/dt-bindings/memory/imxrt-sdram.h @@ -0,0 +1,100 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef DT_BINDINGS_IMXRT_SDRAM_H +#define DT_BINDINGS_IMXRT_SDRAM_H + +#define MEM_SIZE_4K 0x00 +#define MEM_SIZE_8K 0x01 +#define MEM_SIZE_16K 0x02 +#define MEM_SIZE_32K 0x03 +#define MEM_SIZE_64K 0x04 +#define MEM_SIZE_128K 0x05 +#define MEM_SIZE_256K 0x06 +#define MEM_SIZE_512K 0x07 +#define MEM_SIZE_1M 0x08 +#define MEM_SIZE_2M 0x09 +#define MEM_SIZE_4M 0x0A +#define MEM_SIZE_8M 0x0B +#define MEM_SIZE_16M 0x0C +#define MEM_SIZE_32M 0x0D +#define MEM_SIZE_64M 0x0E +#define MEM_SIZE_128M 0x0F +#define MEM_SIZE_256M 0x10 +#define MEM_SIZE_512M 0x11 +#define MEM_SIZE_1G 0x12 +#define MEM_SIZE_2G 0x13 +#define MEM_SIZE_4G 0x14 + +#define MUX_A8_SDRAM_A8 0x0 +#define MUX_A8_NAND_CE 0x1 +#define MUX_A8_NOR_CE 0x2 +#define MUX_A8_PSRAM_CE 0x3 +#define MUX_A8_DBI_CSX 0x4 + +#define MUX_CSX0_NOR_PSRAM_A24 0x0 +#define MUX_CSX0_SDRAM_CS1 0x1 +#define MUX_CSX0_SDRAM_CS2 0x2 +#define MUX_CSX0_SDRAM_CS3 0x3 +#define MUX_CSX0_NAND_CE 0x4 +#define MUX_CSX0_NOR_CE 0x5 +#define MUX_CSX0_PSRAM_CE 0x6 +#define MUX_CSX0_DBI_CSX 0x7 + +#define MUX_CSX1_NOR_PSRAM_A25 0x0 +#define MUX_CSX1_SDRAM_CS1 0x1 +#define MUX_CSX1_SDRAM_CS2 0x2 +#define MUX_CSX1_SDRAM_CS3 0x3 +#define MUX_CSX1_NAND_CE 0x4 +#define MUX_CSX1_NOR_CE 0x5 +#define MUX_CSX1_PSRAM_CE 0x6 +#define MUX_CSX1_DBI_CSX 0x7 + +#define MUX_CSX2_NOR_PSRAM_A26 0x0 +#define MUX_CSX2_SDRAM_CS1 0x1 +#define MUX_CSX2_SDRAM_CS2 0x2 +#define MUX_CSX2_SDRAM_CS3 0x3 +#define MUX_CSX2_NAND_CE 0x4 +#define MUX_CSX2_NOR_CE 0x5 +#define MUX_CSX2_PSRAM_CE 0x6 +#define MUX_CSX2_DBI_CSX 0x7 + +#define MUX_CSX3_NOR_PSRAM_A27 0x0 +#define MUX_CSX3_SDRAM_CS1 0x1 +#define MUX_CSX3_SDRAM_CS2 0x2 +#define MUX_CSX3_SDRAM_CS3 0x3 +#define MUX_CSX3_NAND_CE 0x4 +#define MUX_CSX3_NOR_CE 0x5 +#define MUX_CSX3_PSRAM_CE 0x6 +#define MUX_CSX3_DBI_CSX 0x7 + +#define MUX_RDY_NAND_RDY_WAIT 0x0 +#define MUX_RDY_SDRAM_CS1 0x1 +#define MUX_RDY_SDRAM_CS2 0x2 +#define MUX_RDY_SDRAM_CS3 0x3 +#define MUX_RDY_NOR_CE 0x4 +#define MUX_RDY_PSRAM_CE 0x5 +#define MUX_RDY_DBI_CSX 0x6 +#define MUX_RDY_NOR_PSRAM_A27 0x7 + +#define MEM_WIDTH_8BITS 0x0 +#define MEM_WIDTH_16BITS 0x1 + +#define BL_1 0x0 +#define BL_2 0x1 +#define BL_4 0x2 +#define BL_8 0x3 + +#define COL_12BITS 0x0 +#define COL_11BITS 0x1 +#define COL_10BITS 0x2 +#define COL_9BITS 0x3 + +#define CL_1 0x0 +#define CL_2 0x2 +#define CL_3 0x3 + +#endif
Not all architectures(i.e. i.MXRT) support mxc_get_clock() and use DM_CLK instead. So building could result in failure due to missing mxc_get_clock().
Make if(CONFIG_IS_ENABLED(CLK)) an #if statement.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/mmc/fsl_esdhc_imx.c | 38 ++++++++++++++++++------------------- 1 file changed, 19 insertions(+), 19 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index f1afab742d..afdca9cd07 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1514,27 +1514,27 @@ static int fsl_esdhc_probe(struct udevice *dev)
init_clk_usdhc(dev->seq);
- if (CONFIG_IS_ENABLED(CLK)) { - /* Assigned clock already set clock */ - ret = clk_get_by_name(dev, "per", &priv->per_clk); - if (ret) { - printf("Failed to get per_clk\n"); - return ret; - } - ret = clk_enable(&priv->per_clk); - if (ret) { - printf("Failed to enable per_clk\n"); - return ret; - } +#if CONFIG_IS_ENABLED(CLK) + /* Assigned clock already set clock */ + ret = clk_get_by_name(dev, "per", &priv->per_clk); + if (ret) { + printf("Failed to get per_clk\n"); + return ret; + } + ret = clk_enable(&priv->per_clk); + if (ret) { + printf("Failed to enable per_clk\n"); + return ret; + }
- priv->sdhc_clk = clk_get_rate(&priv->per_clk); - } else { - priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); - if (priv->sdhc_clk <= 0) { - dev_err(dev, "Unable to get clk for %s\n", dev->name); - return -EINVAL; - } + priv->sdhc_clk = clk_get_rate(&priv->per_clk); +#else + priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); + if (priv->sdhc_clk <= 0) { + dev_err(dev, "Unable to get clk for %s\n", dev->name); + return -EINVAL; } +#endif
ret = fsl_esdhc_init(priv, plat); if (ret) {
Add compatible "fsl,imxrt-usdhc" to make mmc working on i.MXRT platforms with CONFIG_DM_MMC=y.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- drivers/mmc/Kconfig | 2 +- drivers/mmc/fsl_esdhc_imx.c | 3 ++- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 85fd1906bd..9974b995a2 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -732,7 +732,7 @@ config FSL_ESDHC_IMX
config FSL_USDHC bool "Freescale/NXP i.MX uSDHC controller support" - depends on MX6 || MX7 ||ARCH_MX7ULP || IMX8 || IMX8M || TARGET_S32V234EVB + depends on MX6 || MX7 ||ARCH_MX7ULP || IMX8 || IMX8M || TARGET_S32V234EVB || ARCH_IMXRT select FSL_ESDHC_IMX help This enables the Ultra Secured Digital Host Controller enhancements diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index afdca9cd07..318c1a1913 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -78,7 +78,7 @@ struct fsl_esdhc { uint vendorspec; uint mmcboot; uint vendorspec2; - uint tuning_ctrl; /* on i.MX6/7/8 */ + uint tuning_ctrl; /* on i.MX6/7/8/RT */ char reserved5[44]; uint hostver; /* Host controller version register */ char reserved6[4]; /* reserved */ @@ -1651,6 +1651,7 @@ static const struct udevice_id fsl_esdhc_ids[] = { { .compatible = "fsl,imx8mm-usdhc", .data = (ulong)&usdhc_imx8qm_data,}, { .compatible = "fsl,imx8mn-usdhc", .data = (ulong)&usdhc_imx8qm_data,}, { .compatible = "fsl,imx8mq-usdhc", .data = (ulong)&usdhc_imx8qm_data,}, + { .compatible = "fsl,imxrt-usdhc", }, { .compatible = "fsl,esdhc", }, { /* sentinel */ } };
Add i.IMXRT family basic support.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/Kconfig | 10 ++++++ arch/arm/Makefile | 4 +-- arch/arm/include/asm/arch-imxrt/clock.h | 10 ++++++ arch/arm/include/asm/arch-imxrt/gpio.h | 19 +++++++++++ arch/arm/include/asm/arch-imxrt/imx-regs.h | 20 ++++++++++++ arch/arm/include/asm/arch-imxrt/imxrt.h | 11 +++++++ arch/arm/include/asm/arch-imxrt/sys_proto.h | 11 +++++++ arch/arm/mach-imx/Makefile | 3 +- arch/arm/mach-imx/imxrt/Kconfig | 21 +++++++++++++ arch/arm/mach-imx/imxrt/Makefile | 7 +++++ arch/arm/mach-imx/imxrt/soc.c | 35 +++++++++++++++++++++ 11 files changed, 148 insertions(+), 3 deletions(-) create mode 100644 arch/arm/include/asm/arch-imxrt/clock.h create mode 100644 arch/arm/include/asm/arch-imxrt/gpio.h create mode 100644 arch/arm/include/asm/arch-imxrt/imx-regs.h create mode 100644 arch/arm/include/asm/arch-imxrt/imxrt.h create mode 100644 arch/arm/include/asm/arch-imxrt/sys_proto.h create mode 100644 arch/arm/mach-imx/imxrt/Kconfig create mode 100644 arch/arm/mach-imx/imxrt/Makefile create mode 100644 arch/arm/mach-imx/imxrt/soc.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f96841c777..24c6a6dbbf 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -797,6 +797,14 @@ config ARCH_IMX8M select SUPPORT_SPL imply CMD_DM
+config ARCH_IMXRT + bool "NXP i.MXRT platform" + select CPU_V7M + select DM + select DM_SERIAL + select SUPPORT_SPL + imply CMD_DM + config ARCH_MX23 bool "NXP i.MX23 family" select CPU_ARM926EJS @@ -1720,6 +1728,8 @@ source "arch/arm/mach-imx/imx8/Kconfig"
source "arch/arm/mach-imx/imx8m/Kconfig"
+source "arch/arm/mach-imx/imxrt/Kconfig" + source "arch/arm/mach-imx/mxs/Kconfig"
source "arch/arm/mach-omap2/Kconfig" diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 60af7e3199..22e2815cc1 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -104,11 +104,11 @@ libs-y += arch/arm/cpu/ libs-y += arch/arm/lib/
ifeq ($(CONFIG_SPL_BUILD),y) -ifneq (,$(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_MX35)$(filter $(SOC), mx25 mx5 mx6 mx7 mx35 imx8m imx8)) +ifneq (,$(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_MX35)$(filter $(SOC), mx25 mx5 mx6 mx7 mx35 imx8m imx8 imxrt)) libs-y += arch/arm/mach-imx/ endif else -ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx7ulp mx31 mx35 mxs imx8m imx8 vf610)) +ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx7ulp mx31 mx35 mxs imx8m imx8 imxrt vf610)) libs-y += arch/arm/mach-imx/ endif endif diff --git a/arch/arm/include/asm/arch-imxrt/clock.h b/arch/arm/include/asm/arch-imxrt/clock.h new file mode 100644 index 0000000000..7409028b9a --- /dev/null +++ b/arch/arm/include/asm/arch-imxrt/clock.h @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __ASM_ARCH_CLOCK_H +#define __ASM_ARCH_CLOCK_H + +#endif /* __ASM_ARCH_CLOCK_H */ diff --git a/arch/arm/include/asm/arch-imxrt/gpio.h b/arch/arm/include/asm/arch-imxrt/gpio.h new file mode 100644 index 0000000000..da31a7438a --- /dev/null +++ b/arch/arm/include/asm/arch-imxrt/gpio.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __ASM_ARCH_GPIO_H__ +#define __ASM_ARCH_GPIO_H__ + +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +/* GPIO registers */ +struct gpio_regs { + u32 gpio_dr; /* data */ + u32 gpio_dir; /* direction */ + u32 gpio_psr; /* pad satus */ +}; +#endif + +#endif /* __ASM_ARCH_GPIO_H__ */ diff --git a/arch/arm/include/asm/arch-imxrt/imx-regs.h b/arch/arm/include/asm/arch-imxrt/imx-regs.h new file mode 100644 index 0000000000..d21450cfc6 --- /dev/null +++ b/arch/arm/include/asm/arch-imxrt/imx-regs.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright(C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __ASM_ARCH_IMX_REGS_H__ +#define __ASM_ARCH_IMX_REGS_H__ + +#define ARCH_MXC + +#define ANATOP_BASE_ADDR 0x400d8000 + +#define MXS_LCDIF_BASE 0x402b8000 + +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/mach-imx/regs-lcdif.h> +#endif + +#endif /* __ASM_ARCH_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-imxrt/imxrt.h b/arch/arm/include/asm/arch-imxrt/imxrt.h new file mode 100644 index 0000000000..1cb2c57d31 --- /dev/null +++ b/arch/arm/include/asm/arch-imxrt/imxrt.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef _ASM_ARCH_IMXRT_H +#define _ASM_ARCH_IMXRT_H + +#endif /* _ASM_ARCH_IMXRT_H */ + diff --git a/arch/arm/include/asm/arch-imxrt/sys_proto.h b/arch/arm/include/asm/arch-imxrt/sys_proto.h new file mode 100644 index 0000000000..eb878e672e --- /dev/null +++ b/arch/arm/include/asm/arch-imxrt/sys_proto.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017 NXP + */ + +#ifndef _ASM_ARCH_SYS_PROTO_H +#define _ASM_ARCH_SYS_PROTO_H + +#include <asm/mach-imx/sys_proto.h> + +#endif /* _ASM_ARCH_SYS_PROTO_H */ diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index e14713c5c4..a70d51b5cf 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -27,7 +27,7 @@ endif obj-$(CONFIG_GPT_TIMER) += timer.o obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o endif -ifeq ($(SOC),$(filter $(SOC),mx7 mx6 mxs imx8m imx8)) +ifeq ($(SOC),$(filter $(SOC),mx7 mx6 mxs imx8m imx8 imxrt)) obj-y += misc.o obj-$(CONFIG_SPL_BUILD) += spl.o endif @@ -226,5 +226,6 @@ obj-$(CONFIG_MX7) += mx7/ obj-$(CONFIG_ARCH_MX7ULP) += mx7ulp/ obj-$(CONFIG_IMX8M) += imx8m/ obj-$(CONFIG_ARCH_IMX8) += imx8/ +obj-$(CONFIG_ARCH_IMXRT) += imxrt/
obj-$(CONFIG_SPL_BOOTROM_SUPPORT) += spl_imx_romapi.o diff --git a/arch/arm/mach-imx/imxrt/Kconfig b/arch/arm/mach-imx/imxrt/Kconfig new file mode 100644 index 0000000000..22f130e79a --- /dev/null +++ b/arch/arm/mach-imx/imxrt/Kconfig @@ -0,0 +1,21 @@ +if ARCH_IMXRT + +config IMXRT1050 + bool + +config SYS_SOC + default "imxrt" + +choice + prompt "NXP i.MXRT board select" + optional + +config TARGET_IMXRT1050_EVK + bool "Support imxrt1050 EVK board" + select IMXRT1050 + +endchoice + +source "board/freescale/imxrt1050-evk/Kconfig" + +endif diff --git a/arch/arm/mach-imx/imxrt/Makefile b/arch/arm/mach-imx/imxrt/Makefile new file mode 100644 index 0000000000..9621a8335a --- /dev/null +++ b/arch/arm/mach-imx/imxrt/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2019 +# Author(s): Giulio Benetti giulio.benetti@benettiengineering.com +# + +obj-y := soc.o diff --git a/arch/arm/mach-imx/imxrt/soc.c b/arch/arm/mach-imx/imxrt/soc.c new file mode 100644 index 0000000000..e1eea23035 --- /dev/null +++ b/arch/arm/mach-imx/imxrt/soc.c @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7_mpu.h> + +int arch_cpu_init(void) +{ + int i; + + struct mpu_region_config imxrt1050_region_config[] = { + { 0x00000000, REGION_0, XN_DIS, PRIV_RW_USR_RW, + STRONG_ORDER, REGION_4GB }, + { PHYS_SDRAM, REGION_1, XN_DIS, PRIV_RW_USR_RW, + O_I_WB_RD_WR_ALLOC, (ffs(PHYS_SDRAM_SIZE) - 2) }, + { DMAMEM_BASE, + REGION_2, XN_DIS, PRIV_RW_USR_RW, + STRONG_ORDER, (ffs(DMAMEM_SZ_ALL) - 2) }, + }; + + /* + * Configure the memory protection unit (MPU) to allow full access to + * the whole 4GB address space. + */ + disable_mpu(); + for (i = 0; i < ARRAY_SIZE(imxrt1050_region_config); i++) + mpu_config(&imxrt1050_region_config[i]); + enable_mpu(); + + return 0; +}
This commit adds board support for i.MXRT1050-EVK from NXP. This board is an evaluation kit provided by NXP for i.MXRT105x processor family.
More information about this board can be found here: https://www.nxp.com/design/development-boards/i.mx-evaluation-and-developmen...
The initial supported/tested devices include: - Debug serial - SD
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/imxrt1050-evk.dts | 209 ++++++++++++++++++ board/freescale/imxrt1050-evk/Kconfig | 22 ++ board/freescale/imxrt1050-evk/MAINTAINERS | 6 + board/freescale/imxrt1050-evk/Makefile | 6 + board/freescale/imxrt1050-evk/README | 31 +++ board/freescale/imxrt1050-evk/imximage.cfg | 36 +++ board/freescale/imxrt1050-evk/imxrt1050-evk.c | 81 +++++++ configs/imxrt1050-evk_defconfig | 74 +++++++ include/configs/imxrt1050-evk.h | 59 +++++ 10 files changed, 526 insertions(+) create mode 100644 arch/arm/dts/imxrt1050-evk.dts create mode 100644 board/freescale/imxrt1050-evk/Kconfig create mode 100644 board/freescale/imxrt1050-evk/MAINTAINERS create mode 100644 board/freescale/imxrt1050-evk/Makefile create mode 100644 board/freescale/imxrt1050-evk/README create mode 100644 board/freescale/imxrt1050-evk/imximage.cfg create mode 100644 board/freescale/imxrt1050-evk/imxrt1050-evk.c create mode 100644 configs/imxrt1050-evk_defconfig create mode 100644 include/configs/imxrt1050-evk.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 3dc9c4d41c..1cba8809f2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -672,6 +672,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mn-ddr4-evk.dtb \ imx8mq-evk.dtb
+dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb + dtb-$(CONFIG_RCAR_GEN2) += \ r8a7790-lager-u-boot.dtb \ r8a7790-stout-u-boot.dtb \ diff --git a/arch/arm/dts/imxrt1050-evk.dts b/arch/arm/dts/imxrt1050-evk.dts new file mode 100644 index 0000000000..28ec079129 --- /dev/null +++ b/arch/arm/dts/imxrt1050-evk.dts @@ -0,0 +1,209 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +/dts-v1/; +#include "imxrt1050.dtsi" +#include <dt-bindings/pinctrl/pins-imxrt1050.h> + +/ { + model = "NXP IMXRT1050-evk board"; + compatible = "fsl,imxrt1050-evk", "fsl,imxrt1050"; + + chosen { + u-boot,dm-spl; + bootargs = "root=/dev/ram"; + stdout-path = "serial0:115200n8"; + }; + + memory { + reg = <0x80000000 0x2000000>; + }; +}; + +&lpuart1 { /* console */ + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + status = "okay"; +}; + +&semc { + /* + * Memory configuration from sdram datasheet IS42S16160J-6BLI + */ + fsl,sdram-mux = /bits/ 8 <MUX_A8_SDRAM_A8 + MUX_CSX0_SDRAM_CS1 + 0 + 0 + 0 + 0>; + fsl,sdram-control = /bits/ 8 <MEM_WIDTH_16BITS + BL_8 + COL_9BITS + CL_3>; + fsl,sdram-timing = /bits/ 8 <0x2 + 0x2 + 0x9 + 0x1 + 0x5 + 0x6 + + 0x20 + 0x09 + 0x01 + 0x00 + + 0x04 + 0x0A + 0x21 + 0x50>; + + bank1: bank@0 { + u-boot,dm-spl; + fsl,base-address = <0x80000000>; + fsl,memory-size = <MEM_SIZE_32M>; + }; +}; + +&iomuxc { + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lpuart1>; + + imxrt1050-evk { + u-boot,dm-spl; + pinctrl_lpuart1: lpuart1grp { + u-boot,dm-spl; + fsl,pins = < + MXRT1050_IOMUXC_GPIO_AD_B0_12_LPUART1_TXD + 0xf1 + MXRT1050_IOMUXC_GPIO_AD_B0_13_LPUART1_RXD + 0xf1 + >; + }; + + pinctrl_semc: semcgrp { + u-boot,dm-spl; + fsl,pins = < + MXRT1050_IOMUXC_GPIO_EMC_00_SEMC_DA00 + 0xf1 /* SEMC_D0 */ + MXRT1050_IOMUXC_GPIO_EMC_01_SEMC_DA01 + 0xf1 /* SEMC_D1 */ + MXRT1050_IOMUXC_GPIO_EMC_02_SEMC_DA02 + 0xf1 /* SEMC_D2 */ + MXRT1050_IOMUXC_GPIO_EMC_03_SEMC_DA03 + 0xf1 /* SEMC_D3 */ + MXRT1050_IOMUXC_GPIO_EMC_04_SEMC_DA04 + 0xf1 /* SEMC_D4 */ + MXRT1050_IOMUXC_GPIO_EMC_05_SEMC_DA05 + 0xf1 /* SEMC_D5 */ + MXRT1050_IOMUXC_GPIO_EMC_06_SEMC_DA06 + 0xf1 /* SEMC_D6 */ + MXRT1050_IOMUXC_GPIO_EMC_07_SEMC_DA07 + 0xf1 /* SEMC_D7 */ + MXRT1050_IOMUXC_GPIO_EMC_08_SEMC_DM00 + 0xf1 /* SEMC_DM0 */ + MXRT1050_IOMUXC_GPIO_EMC_09_SEMC_ADDR00 + 0xf1 /* SEMC_A0 */ + MXRT1050_IOMUXC_GPIO_EMC_10_SEMC_ADDR01 + 0xf1 /* SEMC_A1 */ + MXRT1050_IOMUXC_GPIO_EMC_11_SEMC_ADDR02 + 0xf1 /* SEMC_A2 */ + MXRT1050_IOMUXC_GPIO_EMC_12_SEMC_ADDR03 + 0xf1 /* SEMC_A3 */ + MXRT1050_IOMUXC_GPIO_EMC_13_SEMC_ADDR04 + 0xf1 /* SEMC_A4 */ + MXRT1050_IOMUXC_GPIO_EMC_14_SEMC_ADDR05 + 0xf1 /* SEMC_A5 */ + MXRT1050_IOMUXC_GPIO_EMC_15_SEMC_ADDR06 + 0xf1 /* SEMC_A6 */ + MXRT1050_IOMUXC_GPIO_EMC_16_SEMC_ADDR07 + 0xf1 /* SEMC_A7 */ + MXRT1050_IOMUXC_GPIO_EMC_17_SEMC_ADDR08 + 0xf1 /* SEMC_A8 */ + MXRT1050_IOMUXC_GPIO_EMC_18_SEMC_ADDR09 + 0xf1 /* SEMC_A9 */ + MXRT1050_IOMUXC_GPIO_EMC_19_SEMC_ADDR11 + 0xf1 /* SEMC_A11 */ + MXRT1050_IOMUXC_GPIO_EMC_20_SEMC_ADDR12 + 0xf1 /* SEMC_A12 */ + MXRT1050_IOMUXC_GPIO_EMC_21_SEMC_BA0 + 0xf1 /* SEMC_BA0 */ + MXRT1050_IOMUXC_GPIO_EMC_22_SEMC_BA1 + 0xf1 /* SEMC_BA1 */ + MXRT1050_IOMUXC_GPIO_EMC_23_SEMC_ADDR10 + 0xf1 /* SEMC_A10 */ + MXRT1050_IOMUXC_GPIO_EMC_24_SEMC_CAS + 0xf1 /* SEMC_CAS */ + MXRT1050_IOMUXC_GPIO_EMC_25_SEMC_RAS + 0xf1 /* SEMC_RAS */ + MXRT1050_IOMUXC_GPIO_EMC_26_SEMC_CLK + 0xf1 /* SEMC_CLK */ + MXRT1050_IOMUXC_GPIO_EMC_27_SEMC_CKE + 0xf1 /* SEMC_CKE */ + MXRT1050_IOMUXC_GPIO_EMC_28_SEMC_WE + 0xf1 /* SEMC_WE */ + MXRT1050_IOMUXC_GPIO_EMC_29_SEMC_CS0 + 0xf1 /* SEMC_CS0 */ + MXRT1050_IOMUXC_GPIO_EMC_30_SEMC_DA08 + 0xf1 /* SEMC_D8 */ + MXRT1050_IOMUXC_GPIO_EMC_31_SEMC_DA09 + 0xf1 /* SEMC_D9 */ + MXRT1050_IOMUXC_GPIO_EMC_32_SEMC_DA10 + 0xf1 /* SEMC_D10 */ + MXRT1050_IOMUXC_GPIO_EMC_33_SEMC_DA11 + 0xf1 /* SEMC_D11 */ + MXRT1050_IOMUXC_GPIO_EMC_34_SEMC_DA12 + 0xf1 /* SEMC_D12 */ + MXRT1050_IOMUXC_GPIO_EMC_35_SEMC_DA13 + 0xf1 /* SEMC_D13 */ + MXRT1050_IOMUXC_GPIO_EMC_36_SEMC_DA14 + 0xf1 /* SEMC_D14 */ + MXRT1050_IOMUXC_GPIO_EMC_37_SEMC_DA15 + 0xf1 /* SEMC_D15 */ + MXRT1050_IOMUXC_GPIO_EMC_38_SEMC_DM01 + 0xf1 /* SEMC_DM1 */ + MXRT1050_IOMUXC_GPIO_EMC_39_SEMC_DQS + (IMX_PAD_SION | 0xf1) /* SEMC_DQS */ + >; + }; + + pinctrl_usdhc0: usdhc0grp { + u-boot,dm-spl; + fsl,pins = < + MXRT1050_IOMUXC_GPIO_B1_12_USDHC1_CD_B + 0x1B000 + MXRT1050_IOMUXC_GPIO_B1_14_USDHC1_VSELECT + 0xB069 + MXRT1050_IOMUXC_GPIO_SD_B0_00_USDHC1_CMD + 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_01_USDHC1_CLK + 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_05_USDHC1_DATA3 + 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_04_USDHC1_DATA2 + 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_03_USDHC1_DATA1 + 0x17061 + MXRT1050_IOMUXC_GPIO_SD_B0_02_USDHC1_DATA0 + 0x17061 + >; + }; + }; +}; + +&usdhc1 { + u-boot,dm-spl; + + pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; + pinctrl-0 = <&pinctrl_usdhc0>; + pinctrl-1 = <&pinctrl_usdhc0>; + pinctrl-2 = <&pinctrl_usdhc0>; + pinctrl-3 = <&pinctrl_usdhc0>; + status = "okay"; + + cd-gpios = <&gpio2 28 GPIO_ACTIVE_LOW>; +}; diff --git a/board/freescale/imxrt1050-evk/Kconfig b/board/freescale/imxrt1050-evk/Kconfig new file mode 100644 index 0000000000..79e6e4524a --- /dev/null +++ b/board/freescale/imxrt1050-evk/Kconfig @@ -0,0 +1,22 @@ +if TARGET_IMXRT1050_EVK + +config SYS_BOARD + string + default "imxrt1050-evk" + +config SYS_VENDOR + string + default "freescale" + +config SYS_SOC + string + default "imxrt1050" + +config SYS_CONFIG_NAME + string + default "imxrt1050-evk" + +config IMX_CONFIG + default "board/freescale/imxrt1050-evk/imximage.cfg" + +endif diff --git a/board/freescale/imxrt1050-evk/MAINTAINERS b/board/freescale/imxrt1050-evk/MAINTAINERS new file mode 100644 index 0000000000..a872855452 --- /dev/null +++ b/board/freescale/imxrt1050-evk/MAINTAINERS @@ -0,0 +1,6 @@ +IMXRT1050 EVALUATION KIT +M: Giulio Benetti giulio.benetti@benettiengineering.com +S: Maintained +F: board/freescale/imxrt1050-evk +F: include/configs/imxrt1050-evk.h +F: configs/imxrt1050-evk_defconfig diff --git a/board/freescale/imxrt1050-evk/Makefile b/board/freescale/imxrt1050-evk/Makefile new file mode 100644 index 0000000000..0e984d1d7a --- /dev/null +++ b/board/freescale/imxrt1050-evk/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 +# Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + +obj-y := imxrt1050-evk.o diff --git a/board/freescale/imxrt1050-evk/README b/board/freescale/imxrt1050-evk/README new file mode 100644 index 0000000000..f7e2894025 --- /dev/null +++ b/board/freescale/imxrt1050-evk/README @@ -0,0 +1,31 @@ +How to use U-Boot on NXP i.MXRT1050 EVK +----------------------------------------------- + +- Build U-Boot for i.MXRT1050 EVK: + +$ make mrproper +$ make imxrt1050-evk_defconfig +$ make + +This will generate the SPL image called SPL and the u-boot.img. + +- Flash the SPL image into the micro SD card: + +sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync + +- Flash the u-boot.img image into the micro SD card: + +sudo dd if=u-boot.img of=/dev/sdb bs=1k seek=128; sync + +- Jumper settings: + +SW7: 1 0 1 0 + +where 0 means bottom position and 1 means top position (from the +switch label numbers reference). + +- Connect the USB cable between the EVK and the PC for the console. +(The USB console connector is the one close the ethernet connector) + +- Insert the micro SD card in the board, power it up and U-Boot messages should +come up. diff --git a/board/freescale/imxrt1050-evk/imximage.cfg b/board/freescale/imxrt1050-evk/imximage.cfg new file mode 100644 index 0000000000..cf1665be61 --- /dev/null +++ b/board/freescale/imxrt1050-evk/imximage.cfg @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* Set all FlexRAM as OCRAM(01b) */ +DATA 4 0x400AC044 0x55555555 +/* Use FLEXRAM_BANK_CFG to config FlexRAM */ +SET_BIT 4 0x400AC040 0x4 diff --git a/board/freescale/imxrt1050-evk/imxrt1050-evk.c b/board/freescale/imxrt1050-evk/imxrt1050-evk.c new file mode 100644 index 0000000000..bda03b5ea5 --- /dev/null +++ b/board/freescale/imxrt1050-evk/imxrt1050-evk.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/armv7m.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ +#ifndef CONFIG_SUPPORT_SPL + int rv; + struct udevice *dev; + + rv = uclass_get_device(UCLASS_RAM, 0, &dev); + if (rv) { + debug("DRAM init failed: %d\n", rv); + return rv; + } + +#endif + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +#ifdef CONFIG_SPL_BUILD +#ifdef CONFIG_SPL_OS_BOOT +int spl_start_uboot(void) +{ + debug("SPL: booting kernel\n"); + /* break into full u-boot on 'c' */ + return serial_tstc() && serial_getc() == 'c'; +} +#endif + +int spl_dram_init(void) +{ + struct udevice *dev; + int rv; + + rv = uclass_get_device(UCLASS_RAM, 0, &dev); + if (rv) + debug("DRAM init failed: %d\n", rv); + return rv; +} + +void spl_board_init(void) +{ + spl_dram_init(); + preloader_console_init(); + arch_cpu_init(); /* to configure mpu for sdram rw permissions */ +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} +#endif + +u32 get_board_rev(void) +{ + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + + return 0; +} diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig new file mode 100644 index 0000000000..e8487d142a --- /dev/null +++ b/configs/imxrt1050-evk_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SYS_ICACHE_OFF=y +CONFIG_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMXRT=y +CONFIG_SYS_TEXT_BASE=0x80002000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_TARGET_IMXRT1050_EVK=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_ENV_OFFSET=0x80000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL_SIZE_LIMIT=131072 +CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x20209000 +# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SD_BOOT=y +# CONFIG_USE_BOOTCOMMAND is not set +# CONFIG_CONSOLE_MUX is not set +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_BOARD_INIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x100 +# CONFIG_SPL_CRC32_SUPPORT is not set +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_MII is not set +CONFIG_CMD_BMP=y +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imxrt1050-evk" +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_OF_TRANSLATE is not set +CONFIG_SPL_CLK_COMPOSITE_CCF=y +CONFIG_CLK_COMPOSITE_CCF=y +CONFIG_SPL_CLK_IMXRT1050=y +CONFIG_CLK_IMXRT1050=y +CONFIG_DM_GPIO=y +CONFIG_MXC_GPIO=y +# CONFIG_INPUT is not set +CONFIG_DM_MMC=y +CONFIG_FSL_USDHC=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMXRT=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_IMXRT_SDRAM=y +CONFIG_FSL_LPUART=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP32 is not set +CONFIG_SHA1=y +CONFIG_SHA256=y +CONFIG_HEXDUMP=y diff --git a/include/configs/imxrt1050-evk.h b/include/configs/imxrt1050-evk.h new file mode 100644 index 0000000000..f15b4f723e --- /dev/null +++ b/include/configs/imxrt1050-evk.h @@ -0,0 +1,59 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#ifndef __IMXRT1050_EVK_H +#define __IMXRT1050_EVK_H + +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_INIT_SP_ADDR 0x20280000 + +#ifdef CONFIG_SUPPORT_SPL +#define CONFIG_SYS_LOAD_ADDR 0x20209000 +#else +#define CONFIG_SYS_LOAD_ADDR 0x80000000 +#define CONFIG_LOADADDR 0x80000000 +#endif + +#define CONFIG_SYS_FSL_ERRATUM_ESDHC135 1 +#define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE 1 + +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE (32 * 1024 * 1024) + +#define DMAMEM_SZ_ALL (1 * 1024 * 1024) +#define DMAMEM_BASE (PHYS_SDRAM + PHYS_SDRAM_SIZE - \ + DMAMEM_SZ_ALL) + +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ + +/* + * Configuration of the external SDRAM memory + */ +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) + +/* For SPL */ +#ifdef CONFIG_SUPPORT_SPL +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR +#define CONFIG_SYS_SPL_LEN 0x00008000 +#define CONFIG_SYS_UBOOT_START 0x800023FD +#endif +/* For SPL ends */ + +/* LCD */ +#ifndef CONFIG_SPL_BUILD +#ifdef CONFIG_DM_VIDEO +#define CONFIG_VIDEO_MXS +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_VIDEO_BMP_LOGO +#endif +#endif + +#endif /* __IMXRT1050_EVK_H */
Giulio Benetti
