Hi all I‘ve got some issues with load ftb to work with my board (mpc8313erdb) My serial print errors as follow: ERROR: /chosen node create failed I used the following command to generate my dtb。 dtc -f -b 0 -O dtb -I dts -R 8 -S 0x3000 -o my.dtb my.dts
thanks
Dear =?UTF-8?B?5byg5oms?=,
In message AANLkTikg4SH-5HNx3ZWdgtQc-3SAcq6vyqmu36btnKFg@mail.gmail.com you wrote:
I`ve got some issues with load ftb to work with my board (mpc8313erdb) My serial print errors as follow: ERROR: /chosen node create failed
Is this the only message? Isn't there also some WARNING ?
I used the following command to generate my dtb# dtc -f -b 0 -O dtb -I dts -R 8 -S 0x3000 -o my.dtb my.dts
Why don't you use the kernel's Makefile rule? Just run
make my.dtb
in your kernel tree.
Dear Wolfgang
2011/1/12 Wolfgang Denk wd@denx.de:
make my.dtb
in your kernel tree. i trying to sue the kernel's Makefile rule, but the issue is not solved.
WARNING: could not set linux,stdout-path FDT_ERR_NOTFOUND. ERROR: /chosen node create failed - must RESET the board to recover.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Is there a way to determine Yesterday's date using Unix utilities?
echo "what is yesterday's date?" | /bin/mail root -- Randal L. Schwartz in ukbuh2y982.fsf@julie.teleport.com
In message AANLkTinUx-NmpundBm=scYeahCkBAd9=dx8B3rO7G9GN@mail.gmail.com you wrote:
Well, seems your device tree has some problem.
My guess is it's an old U-Boot that can't create properties in /chosen if /chosen doesn't already exist.
-Scott
Dear Scott Wood
2011/1/13 Scott Wood scottwood@freescale.com:
My guess is it's an old U-Boot that can't create properties in /chosen if /chosen doesn't already exist. i use lastest version of u-boot, booting process gives the error. but i use u-boot-1.3.0 that's ok. -Scott
On Fri, 14 Jan 2011 09:44:44 +0800 张扬 w90p710@gmail.com wrote:
Dear Scott Wood
OK, check whether you have a "serial0" alias (or "serial1" if using what U-Boot thinks of as the second serial port, etc) in your device tree.
-Scott
Scott Wood
张扬
