[U-Boot] [PATCH 1/4] imx: iomux-v3: Fix common pad control definitions
Commit dc88403 "iomux-v3: Place pad control definitions into common file" broke mx51_efikamx because it made i.MX6's pad control definitions conflict with i.MX51's.
i.MX51's pad control definitions are actually common to some other i.MX (25/35/53), so move them to the common iomux-v3.h (just like what is done in Linux's), and select the correct definitions depending on whether CONFIG_MX6 is defined or not.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/include/asm/arch-mx5/iomux-mx51.h | 23 ----------------------- arch/arm/include/asm/imx-common/iomux-v3.h | 28 ++++++++++++++++++++++++++++ 2 files changed, 28 insertions(+), 23 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/iomux-mx51.h b/arch/arm/include/asm/arch-mx5/iomux-mx51.h index 4f37295..5f96dc4 100644 --- a/arch/arm/include/asm/arch-mx5/iomux-mx51.h +++ b/arch/arm/include/asm/arch-mx5/iomux-mx51.h @@ -21,27 +21,6 @@
#include <asm/imx-common/iomux-v3.h>
-#define PAD_CTL_DVS (1 << 13) -#define PAD_CTL_INPUT_DDR (1 << 9) -#define PAD_CTL_HYS (1 << 8) - -#define PAD_CTL_PKE (1 << 7) -#define PAD_CTL_PUE (1 << 6 | PAD_CTL_PKE) -#define PAD_CTL_PUS_100K_DOWN (0 << 4 | PAD_CTL_PUE) -#define PAD_CTL_PUS_47K_UP (1 << 4 | PAD_CTL_PUE) -#define PAD_CTL_PUS_100K_UP (2 << 4 | PAD_CTL_PUE) -#define PAD_CTL_PUS_22K_UP (3 << 4 | PAD_CTL_PUE) - -#define PAD_CTL_ODE (1 << 3) - -#define PAD_CTL_DSE_LOW (0 << 1) -#define PAD_CTL_DSE_MED (1 << 1) -#define PAD_CTL_DSE_HIGH (2 << 1) -#define PAD_CTL_DSE_MAX (3 << 1) - -#define PAD_CTL_SRE_FAST (1 << 0) -#define PAD_CTL_SRE_SLOW (0 << 0) - /* Pad control groupings */ #define MX51_UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_DSE_HIGH | \ PAD_CTL_HYS | PAD_CTL_SRE_FAST) @@ -61,8 +40,6 @@ PAD_CTL_SRE_FAST | PAD_CTL_DVS) #define MX51_GPIO_PAD_CTRL (PAD_CTL_DSE_HIGH | PAD_CTL_PKE | PAD_CTL_SRE_FAST)
-#define __NA_ 0x000 - /* * The naming convention for the pad modes is MX51_PAD_<padname>__<padmode> * If <padname> or <padmode> refers to a GPIO, it is named GPIO<unit>_<num> diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 7b1580d..87d849a 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -23,6 +23,8 @@ #ifndef __MACH_IOMUX_V3_H__ #define __MACH_IOMUX_V3_H__
+#include <common.h> + /* * build IOMUX_PAD structure * @@ -95,6 +97,8 @@ typedef u64 iomux_v3_cfg_t; #define GPIO_PORTE (4 << GPIO_PORT_SHIFT) #define GPIO_PORTF (5 << GPIO_PORT_SHIFT)
+#ifdef CONFIG_MX6 + #define PAD_CTL_HYS (1 << 16) #define PAD_CTL_PUS_100K_DOWN (0 << 14) #define PAD_CTL_PUS_47K_UP (1 << 14) @@ -115,10 +119,34 @@ typedef u64 iomux_v3_cfg_t; #define PAD_CTL_DSE_48ohm (5 << 3) #define PAD_CTL_DSE_40ohm (6 << 3) #define PAD_CTL_DSE_34ohm (7 << 3) + +#else + +#define PAD_CTL_DVS (1 << 13) +#define PAD_CTL_INPUT_DDR (1 << 9) +#define PAD_CTL_HYS (1 << 8) + +#define PAD_CTL_PKE (1 << 7) +#define PAD_CTL_PUE (1 << 6 | PAD_CTL_PKE) +#define PAD_CTL_PUS_100K_DOWN (0 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_47K_UP (1 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_100K_UP (2 << 4 | PAD_CTL_PUE) +#define PAD_CTL_PUS_22K_UP (3 << 4 | PAD_CTL_PUE) + +#define PAD_CTL_ODE (1 << 3) + +#define PAD_CTL_DSE_LOW (0 << 1) +#define PAD_CTL_DSE_MED (1 << 1) +#define PAD_CTL_DSE_HIGH (2 << 1) +#define PAD_CTL_DSE_MAX (3 << 1) + +#endif + #define PAD_CTL_SRE_FAST (1 << 0) #define PAD_CTL_SRE_SLOW (0 << 0)
#define IOMUX_CONFIG_SION 0x10 +#define __NA_ 0x000 #define NO_MUX_I 0 #define NO_PAD_I 0
Keep pad control definitions together, and organize definitions in a more legible way.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/include/asm/imx-common/iomux-v3.h | 33 ++++++++++++++++------------ 1 file changed, 19 insertions(+), 14 deletions(-)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 87d849a..6b58381 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -86,31 +86,29 @@ typedef u64 iomux_v3_cfg_t; ((iomux_v3_cfg_t)(sel_input_ofs) << MUX_SEL_INPUT_OFS_SHIFT)| \ ((iomux_v3_cfg_t)(sel_input) << MUX_SEL_INPUT_SHIFT))
+#define __NA_ 0x000 +#define NO_MUX_I 0 +#define NO_PAD_I 0 + #define NO_PAD_CTRL (1 << 17) -#define GPIO_PIN_MASK 0x1f -#define GPIO_PORT_SHIFT 5 -#define GPIO_PORT_MASK (0x7 << GPIO_PORT_SHIFT) -#define GPIO_PORTA (0 << GPIO_PORT_SHIFT) -#define GPIO_PORTB (1 << GPIO_PORT_SHIFT) -#define GPIO_PORTC (2 << GPIO_PORT_SHIFT) -#define GPIO_PORTD (3 << GPIO_PORT_SHIFT) -#define GPIO_PORTE (4 << GPIO_PORT_SHIFT) -#define GPIO_PORTF (5 << GPIO_PORT_SHIFT)
#ifdef CONFIG_MX6
#define PAD_CTL_HYS (1 << 16) + #define PAD_CTL_PUS_100K_DOWN (0 << 14) #define PAD_CTL_PUS_47K_UP (1 << 14) #define PAD_CTL_PUS_100K_UP (2 << 14) #define PAD_CTL_PUS_22K_UP (3 << 14) - #define PAD_CTL_PUE (1 << 13) #define PAD_CTL_PKE (1 << 12) + #define PAD_CTL_ODE (1 << 11) + #define PAD_CTL_SPEED_LOW (1 << 6) #define PAD_CTL_SPEED_MED (2 << 6) #define PAD_CTL_SPEED_HIGH (3 << 6) + #define PAD_CTL_DSE_DISABLE (0 << 3) #define PAD_CTL_DSE_240ohm (1 << 3) #define PAD_CTL_DSE_120ohm (2 << 3) @@ -142,13 +140,20 @@ typedef u64 iomux_v3_cfg_t;
#endif
-#define PAD_CTL_SRE_FAST (1 << 0) #define PAD_CTL_SRE_SLOW (0 << 0) +#define PAD_CTL_SRE_FAST (1 << 0)
#define IOMUX_CONFIG_SION 0x10 -#define __NA_ 0x000 -#define NO_MUX_I 0 -#define NO_PAD_I 0 + +#define GPIO_PIN_MASK 0x1f +#define GPIO_PORT_SHIFT 5 +#define GPIO_PORT_MASK (0x7 << GPIO_PORT_SHIFT) +#define GPIO_PORTA (0 << GPIO_PORT_SHIFT) +#define GPIO_PORTB (1 << GPIO_PORT_SHIFT) +#define GPIO_PORTC (2 << GPIO_PORT_SHIFT) +#define GPIO_PORTD (3 << GPIO_PORT_SHIFT) +#define GPIO_PORTE (4 << GPIO_PORT_SHIFT) +#define GPIO_PORTF (5 << GPIO_PORT_SHIFT)
void imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad); void imx_iomux_v3_setup_multiple_pads(iomux_v3_cfg_t const *pad_list,
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
This macro will be useful for future changes.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/include/asm/imx-common/iomux-v3.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 6b58381..2ba0a05 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -86,6 +86,9 @@ typedef u64 iomux_v3_cfg_t; ((iomux_v3_cfg_t)(sel_input_ofs) << MUX_SEL_INPUT_OFS_SHIFT)| \ ((iomux_v3_cfg_t)(sel_input) << MUX_SEL_INPUT_SHIFT))
+#define NEW_PAD_CTRL(cfg, pad) (((cfg) & ~MUX_PAD_CTRL_MASK) | \ + MUX_PAD_CTRL(pad)) + #define __NA_ 0x000 #define NO_MUX_I 0 #define NO_PAD_I 0
PUE requires PKE to mean something, as do pull values with PUE, so do not compell users to explicitly use PKE and PUE everywhere. This is also what is done on Linux and what has already been done for i.MX51.
By the way, remove some unused pad control definitions.
There is no change of behavior.
Note that SPI_PAD_CTRL was defined by several boards with a pull value, but without PKE or PUE, which means that no pull was actually enabled in the pad. This might be a bug in those boards, but this patch does not change the behavior, so it just removes the meaningless pull value from those definitions.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com --- arch/arm/include/asm/arch-mx5/iomux-mx51.h | 10 +++--- arch/arm/include/asm/imx-common/iomux-v3.h | 10 +++--- board/boundary/nitrogen6x/nitrogen6x.c | 42 +++++++++++-------------- board/freescale/mx6qarm2/mx6qarm2.c | 17 +++++----- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 17 +++++----- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 30 ++++++++---------- board/freescale/mx6qsabresd/mx6qsabresd.c | 17 +++++----- board/freescale/mx6slevk/mx6slevk.c | 12 +++---- board/freescale/titanium/titanium.c | 20 +++--------- board/wandboard/wandboard.c | 17 +++++----- 10 files changed, 82 insertions(+), 110 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/iomux-mx51.h b/arch/arm/include/asm/arch-mx5/iomux-mx51.h index 5f96dc4..328c188 100644 --- a/arch/arm/include/asm/arch-mx5/iomux-mx51.h +++ b/arch/arm/include/asm/arch-mx5/iomux-mx51.h @@ -22,7 +22,7 @@ #include <asm/imx-common/iomux-v3.h>
/* Pad control groupings */ -#define MX51_UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_DSE_HIGH | \ +#define MX51_UART_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE_HIGH | \ PAD_CTL_HYS | PAD_CTL_SRE_FAST) #define MX51_I2C_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_ODE | \ PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ @@ -30,13 +30,11 @@ #define MX51_ESDHC_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_ODE | \ PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ PAD_CTL_HYS) -#define MX51_USBH1_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_SRE_FAST | \ - PAD_CTL_DSE_HIGH | PAD_CTL_PUS_100K_UP | \ - PAD_CTL_HYS | PAD_CTL_PUE) +#define MX51_USBH1_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_DSE_HIGH | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_HYS) #define MX51_ECSPI_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_HYS | \ PAD_CTL_DSE_HIGH | PAD_CTL_SRE_FAST) -#define MX51_SDHCI_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_DSE_HIGH | \ - PAD_CTL_PUS_47K_UP | PAD_CTL_PUE | \ +#define MX51_SDHCI_PAD_CTRL (PAD_CTL_DSE_HIGH | PAD_CTL_PUS_47K_UP | \ PAD_CTL_SRE_FAST | PAD_CTL_DVS) #define MX51_GPIO_PAD_CTRL (PAD_CTL_DSE_HIGH | PAD_CTL_PKE | PAD_CTL_SRE_FAST)
diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index 2ba0a05..0b4e763 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -99,11 +99,11 @@ typedef u64 iomux_v3_cfg_t;
-#define PAD_CTL_PUS_100K_DOWN (0 << 14) -#define PAD_CTL_PUS_47K_UP (1 << 14) -#define PAD_CTL_PUS_100K_UP (2 << 14) -#define PAD_CTL_PUS_22K_UP (3 << 14) -#define PAD_CTL_PUE (1 << 13) +#define PAD_CTL_PUS_100K_DOWN (0 << 14 | PAD_CTL_PUE) +#define PAD_CTL_PUS_47K_UP (1 << 14 | PAD_CTL_PUE) +#define PAD_CTL_PUS_100K_UP (2 << 14 | PAD_CTL_PUE) +#define PAD_CTL_PUS_22K_UP (3 << 14 | PAD_CTL_PUE) +#define PAD_CTL_PUE (1 << 13 | PAD_CTL_PKE) #define PAD_CTL_PKE (1 << 12)
#define PAD_CTL_ODE (1 << 11) diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index cc071d6..e155556 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -47,40 +47,34 @@
DECLARE_GLOBAL_DATA_PTR;
-#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ - PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS) +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define SPI_PAD_CTRL (PAD_CTL_HYS | \ - PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
-#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS) +#define BUTTON_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE | PAD_CTL_SRE_FAST)
-#define WEAK_PULLUP (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ +#define WEAK_PULLUP (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_SRE_SLOW)
-#define WEAK_PULLDOWN (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_SRE_SLOW) +#define WEAK_PULLDOWN (PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_HYS | PAD_CTL_SRE_SLOW)
#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm)
diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index ff7f5e8..e336746 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -35,17 +35,16 @@
int dram_init(void) { diff --git a/board/freescale/mx6qsabreauto/mx6qsabreauto.c b/board/freescale/mx6qsabreauto/mx6qsabreauto.c index aec3286..54538af 100644 --- a/board/freescale/mx6qsabreauto/mx6qsabreauto.c +++ b/board/freescale/mx6qsabreauto/mx6qsabreauto.c @@ -35,17 +35,16 @@
int dram_init(void) { diff --git a/board/freescale/mx6qsabrelite/mx6qsabrelite.c b/board/freescale/mx6qsabrelite/mx6qsabrelite.c index 9f9cac8..8ce054e 100644 --- a/board/freescale/mx6qsabrelite/mx6qsabrelite.c +++ b/board/freescale/mx6qsabrelite/mx6qsabrelite.c @@ -45,29 +45,25 @@
int dram_init(void) diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6qsabresd/mx6qsabresd.c index bf9beef..2529826 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6qsabresd/mx6qsabresd.c @@ -34,17 +34,16 @@
int dram_init(void) { diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index fc6353e..69fe8fc 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -24,13 +24,13 @@
-#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ - PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) +#define USDHC_PAD_CTRL (PAD_CTL_PUS_22K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS)
int dram_init(void) { diff --git a/board/freescale/titanium/titanium.c b/board/freescale/titanium/titanium.c index 894ebae..5250522 100644 --- a/board/freescale/titanium/titanium.c +++ b/board/freescale/titanium/titanium.c @@ -35,28 +35,16 @@
-#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define SPI_PAD_CTRL (PAD_CTL_HYS | \ - PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_ODE | PAD_CTL_SRE_FAST)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index c71c90d..bb98352 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -27,17 +27,16 @@
#define USDHC1_CD_GPIO IMX_GPIO_NR(1, 2) #define USDHC3_CD_GPIO IMX_GPIO_NR(3, 9)
Benoît Thébaudeau
Stefano Babic
