[RFC] mx6cuboxi: Enable OF_CONTROL and DM in SPL
Make an additional step to add full DM support to mx6cuboxi, including its support for SPL
With this new configuration SPL image is 50 KB, higher than the 38 KB from the previous version, but it still under the 68 KB limit.
Signed-off-by: Walter Lozano walter.lozano@collabora.com --- arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 4 ++++ configs/mx6cuboxi_defconfig | 3 +++ 2 files changed, 7 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi index d302b2e275..b1364a0bbf 100644 --- a/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi @@ -34,3 +34,7 @@ &usdhc1 { status = "disabled"; }; + +&usdhc2 { + u-boot,dm-pre-reloc; +}; diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 23ce485f43..ae8d920260 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -24,6 +24,7 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="if hdmidet; then usb start; setenv stdin serial,usbkbd; setenv stdout serial,vga; setenv stderr serial,vga; else setenv stdin serial; setenv stdout serial; setenv stderr serial; fi;" CONFIG_BOUNCE_BUFFER=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y @@ -36,6 +37,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-hummingboard2-emmc-som-v15" CONFIG_OF_LIST="imx6dl-hummingboard2-emmc-som-v15 imx6q-hummingboard2-emmc-som-v15" CONFIG_MULTI_DTB_FIT=y @@ -44,6 +46,7 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y
Hi Walter,
Thanks for the patch.
One comment below.
+&usdhc2 {
- u-boot,dm-pre-reloc;
Have you tested boot from eMMC?
You would most likely need to add &usdhc3 to SPL DT for that.
baruch
Hi Baruch,
Thanks for your comments. My replay below.
On 4/2/20 10:41, Baruch Siach wrote:
Hi Walter,
One comment below.
+&usdhc2 {
Good point. I haven't tested booting from eMMC as I can only boot from SD because of eFuse settings. However after re thinking it should be still possible to test it by keeping SPL on SD and placing U-Boot on eMMC.
Regards,
Walter
baruch
Baruch Siach
Walter Lozano
