[U-Boot] [GIT PULL] Zynq changes
Hi Tom,
please pull these changes. It is moving GEM to DM and fixes problems with SPL. The last three patches are fixing MANUAL_RELOC and enabling SPL_SIMPLE_BUS by default.
Thanks, Michal
The following changes since commit 75507d5d5496a691aecb731f87d4d8d5cdf62b77:
am33xx: Update serial pdata (2015-12-06 16:38:05 -0500)
git://www.denx.de/git/u-boot-microblaze.git zynq
for you to fetch changes up to 8bebf03c73cd0830cb2cd234021004cde67c6412:
dm: core: Enable SPL_SIMPLE_BUS by default (2015-12-07 10:14:30 +0100)
---------------------------------------------------------------- Michal Simek (27): ARM: zynq: Remove PHYLIB from config to defconfig ARM: zynq: Remove CONFIG_API net: gem: Do not continue if phy is not found net: gem: Change mdio_wait prototype to pass regs net: gem: Change mii function not to use eth_device structure net: gem: Remove phydev variable net: gem: Extract phy init code net: gem: Check if priv->phydev is valid net: gem: Enable MDIO bus earlier net: gem: Remove zynq_gem_of_init() net: gem: Fix miiphy_read name net: gem: Move driver to DM net: gem: Read information about interface from DT net: gem: Move gem to Kconfig net: gem: Enable CTRL+C in wait_for_bit ARM64: zynqmp: Enable FIT config option via Kconfig ARM: zynq: Enable debug console for zc702 ARM: zynq: Fix location of stack and malloc areas ARM: zynq: Extend malloc size ARM: zynq: Remove unused SERIAL macros for serial_zynq zynq: sdhci: Remove zynq_sdhci_of_init() zynq: sdhci: Move driver to DM serial: zynq: Fix incorrect reference to s5p driver serial: zynq: Remove duplicated header i2c: cmd: Relocate subcommands when MANUAL_RELOC dm: cmd: Relocate subcommands when MANUAL_RELOC dm: core: Enable SPL_SIMPLE_BUS by default
Siva Durga Prasad Paladugu (1): zynq: sdhci: Calculate minimum frequency based on max frequency
arch/arm/Kconfig | 4 +++ arch/arm/dts/zynq-zc702.dts | 3 ++ arch/arm/include/asm/arch-zynqmp/hardware.h | 6 ---- arch/arm/include/asm/arch-zynqmp/sys_proto.h | 1 - arch/arm/mach-zynq/include/mach/hardware.h | 4 --- arch/arm/mach-zynq/include/mach/sys_proto.h | 3 -- board/xilinx/zynq/board.c | 30 ---------------- board/xilinx/zynqmp/zynqmp.c | 47 ------------------------ common/cmd_i2c.c | 16 ++++++--- configs/xilinx_zynqmp_ep_defconfig | 3 ++ configs/zynq_microzed_defconfig | 2 ++ configs/zynq_picozed_defconfig | 2 ++ configs/zynq_zc702_defconfig | 6 ++++ configs/zynq_zc706_defconfig | 2 ++ configs/zynq_zc770_xm010_defconfig | 2 ++ configs/zynq_zc770_xm011_defconfig | 2 ++ configs/zynq_zc770_xm012_defconfig | 2 ++ configs/zynq_zc770_xm013_defconfig | 2 ++ configs/zynq_zed_defconfig | 2 ++ configs/zynq_zybo_defconfig | 2 ++ drivers/core/Kconfig | 2 +- drivers/mmc/zynq_sdhci.c | 67 ++++++++++++++++------------------ drivers/net/Kconfig | 6 ++++ drivers/net/zynq_gem.c | 314 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------------------------- drivers/serial/Kconfig | 2 +- drivers/serial/serial_zynq.c | 5 +-- include/configs/xilinx_zynqmp.h | 7 +--- include/configs/xilinx_zynqmp_ep.h | 3 -- include/configs/zynq-common.h | 29 ++++++--------- include/configs/zynq_microzed.h | 3 -- include/configs/zynq_picozed.h | 3 -- include/configs/zynq_zc70x.h | 3 -- include/configs/zynq_zc770.h | 4 --- include/configs/zynq_zed.h | 3 -- include/configs/zynq_zybo.h | 3 -- include/netdev.h | 3 -- test/dm/cmd_dm.c | 14 ++++++++ 37 files changed, 285 insertions(+), 327 deletions(-)
Now that we may compile (but not link) code calling fixup_cmdtable when this is not set, we need to always have the declaration available. We should also make sure that anyone calling the function includes <command.h> as that's where the function declaration is.
Signed-off-by: Tom Rini trini@konsulko.com --- common/board_r.c | 1 + include/command.h | 2 -- test/dm/cmd_dm.c | 1 + 3 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 5af32dd..75ee43e 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -15,6 +15,7 @@ #if defined(CONFIG_CMD_BEDBUG) #include <bedbug/type.h> #endif +#include <command.h> #include <console.h> #ifdef CONFIG_HAS_DATAFLASH #include <dataflash.h> diff --git a/include/command.h b/include/command.h index 6c04cd9..07ae525 100644 --- a/include/command.h +++ b/include/command.h @@ -179,8 +179,6 @@ int cmd_process(int flag, int argc, char * const argv[], #define U_BOOT_CMD(_name, _maxargs, _rep, _cmd, _usage, _help) \ U_BOOT_CMD_COMPLETE(_name, _maxargs, _rep, _cmd, _usage, _help, NULL)
-#if defined(CONFIG_NEEDS_MANUAL_RELOC) void fixup_cmdtable(cmd_tbl_t *cmdtp, int size); -#endif
#endif /* __COMMAND_H */ diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index b6e7109..a3c5971 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -8,6 +8,7 @@ */
#include <common.h> +#include <command.h> #include <dm.h> #include <malloc.h> #include <mapmem.h>
--- Changes in v2: - Move declaration up to be under the current __ASSEMBLY__ test. --- common/board_r.c | 1 + include/command.h | 5 +---- test/dm/cmd_dm.c | 1 + 3 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 5af32dd..75ee43e 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -15,6 +15,7 @@ #if defined(CONFIG_CMD_BEDBUG) #include <bedbug/type.h> #endif +#include <command.h> #include <console.h> #ifdef CONFIG_HAS_DATAFLASH #include <dataflash.h> diff --git a/include/command.h b/include/command.h index 6c04cd9..2ae9b6c 100644 --- a/include/command.h +++ b/include/command.h @@ -142,6 +142,7 @@ enum command_ret_t { int cmd_process(int flag, int argc, char * const argv[], int *repeatable, unsigned long *ticks);
+void fixup_cmdtable(cmd_tbl_t *cmdtp, int size); #endif /* __ASSEMBLY__ */
/* @@ -179,8 +180,4 @@ int cmd_process(int flag, int argc, char * const argv[], #define U_BOOT_CMD(_name, _maxargs, _rep, _cmd, _usage, _help) \ U_BOOT_CMD_COMPLETE(_name, _maxargs, _rep, _cmd, _usage, _help, NULL)
-#if defined(CONFIG_NEEDS_MANUAL_RELOC) -void fixup_cmdtable(cmd_tbl_t *cmdtp, int size); -#endif - #endif /* __COMMAND_H */ diff --git a/test/dm/cmd_dm.c b/test/dm/cmd_dm.c index b6e7109..a3c5971 100644 --- a/test/dm/cmd_dm.c +++ b/test/dm/cmd_dm.c @@ -8,6 +8,7 @@ */
On Mon, Dec 07, 2015 at 10:19:31AM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
