[PATCH] ARM: imx: Set stdio to serial on DH i.MX8M Plus DHCOM
In case CONSOLE_MUX and SYS_CONSOLE_IS_IN_ENV are enabled, the console stdin, stdout, stderr must be defined in environment. Define the default settings to fix the following warning on boot:
" In: No input devices available! Out: No output devices available! Err: No error devices available! "
Sort the default environment as well.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@dh-electronics.com --- include/configs/imx8mp_dhcom_pdk2.h | 17 ++++++++++------- 1 file changed, 10 insertions(+), 7 deletions(-)
diff --git a/include/configs/imx8mp_dhcom_pdk2.h b/include/configs/imx8mp_dhcom_pdk2.h index d022faaa91a..ea32fe11a52 100644 --- a/include/configs/imx8mp_dhcom_pdk2.h +++ b/include/configs/imx8mp_dhcom_pdk2.h @@ -28,15 +28,9 @@ #define CFG_SYS_FSL_USDHC_NUM 2 #define CFG_SYS_FSL_ESDHC_ADDR 0
-#define CFG_EXTRA_ENV_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ "altbootcmd=run bootcmd ; reset\0" \ "bootlimit=3\0" \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "pxefile_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramdisk_addr_r=0x58000000\0" \ - "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - /* Give slow devices beyond USB HUB chance to come up. */ \ - "usb_pgood_delay=2000\0" \ "dfu_alt_info=" \ /* RAM block at DRAM offset 256..768 MiB */ \ "ram ram0=ram ram 0x50000000 0x20000000&" \ @@ -68,6 +62,15 @@ "dh_update_emmc_to_sf=" \ "load mmc 1:1 ${loadaddr} boot/flash.bin && " \ "run dh_update_sf_gen_fcfb dh_update_sf_write_data\0" \ + "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "ramdisk_addr_r=0x58000000\0" \ + "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" \ + /* Give slow devices beyond USB HUB chance to come up. */ \ + "usb_pgood_delay=2000\0" \ BOOTENV
#define BOOT_TARGET_DEVICES(func) \
Applied, thanks.
Fabio Estevam
