[U-Boot] [PATCH] FSL PCI: Configure PCIe reference ratio
Most FSL PCIe controllers expects 333 MHz PCI reference clock. This clock is derived from the CCB but in many cases the ref. clock is not 333 MHz and a divisor needs to be configured.
This adds PEX_CCB_DIV #define which can be defined for each type of CPU/platform.
Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com --- drivers/pci/fsl_pci_init.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 52792dcd59..4d00b3f26c 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info)
pci_setup_indirect(hose, cfg_addr, cfg_data);
+#ifdef PEX_CCB_DIV + /* Configure the PCIE controller core clock ratio */ + pci_hose_write_config_dword(hose, dev, 0x440, + ((gd->bus_clk / 1000000) * + (16 / PEX_CCB_DIV)) / 333); +#endif block_rev = in_be32(&pci->block_rev1); if (PEX_IP_BLK_REV_2_2 <= block_rev) { pi = &pci->pit[2]; /* 0xDC0 */
+#ifdef PEX_CCB_DIV
- /* Configure the PCIE controller core clock ratio */
- pci_hose_write_config_dword(hose, dev, 0x440,
Mingkai,
Do you ack this change? This presumes the PCIe clock derives from CCB bus clock.
York
-----Original Message----- From: York Sun Sent: Friday, September 15, 2017 5:15 AM To: Joakim Tjernlund joakim.tjernlund@infinera.com; Mingkai Hu mingkai.hu@nxp.com; u-boot @ lists . denx . de u-boot@lists.denx.de; Roy Zang roy.zang@nxp.com Subject: Re: [PATCH] FSL PCI: Configure PCIe reference ratio
+#ifdef PEX_CCB_DIV
Mingkai,
gd->bus_clk indicates the platform clock while PCIe clock could be CCB or CCB/2. For example, it's CCB/2 for T1040/T1020, CCB for P2020.
I suggest to add the PCIe clock in gd to handle this difference, just like what we've done for other IP clocks.
Thanks, Mingkai
+#ifdef PEX_CCB_DIV
Ping?
Jocke
+#ifdef PEX_CCB_DIV
Ping?
Jocke
I believe Mingkai's last comment was "to add the PCIe clock in gd".
York
On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote:
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
+#ifdef PEX_CCB_DIV
Ping?
Jocke
Right, I seem to have forgotten to comment on that ... Why add that complexity/bloat? This is a constant defined by the CPU/SOC so it makes perfect sense to just #define it.
Jocke
+#ifdef PEX_CCB_DIV
Ping?
Jocke
I am leaning to agree with you. The clock is either CCB clock, or CCB/2. Would it be better if you use a Kconfig option and select the divisor by SoC?
York
+#ifdef PEX_CCB_DIV
Ping?
Jocke
No, this is not something that needs Kconfig, just add the PEX_CCB_DIV #define in relevant PPC CPU, like in config_mpc85xx.h
Jocke
+#ifdef PEX_CCB_DIV
Ping?
Jocke
So what should be in Kconfig, and what shouldn't? This is per SoC macro. Sounds like CONFIG_SYS_ in old days.
York
On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: > Most FSL PCIe controllers expects 333 MHz PCI reference clock. > This clock is derived from the CCB but in many cases the ref. > clock is not 333 MHz and a divisor needs to be configured. > > This adds PEX_CCB_DIV #define which can be defined for each > type of CPU/platform. > > Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com > --- > drivers/pci/fsl_pci_init.c | 6 ++++++ > 1 file changed, 6 insertions(+) > > diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c > index 52792dcd59..4d00b3f26c 100644 > --- a/drivers/pci/fsl_pci_init.c > +++ b/drivers/pci/fsl_pci_init.c > @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) > > pci_setup_indirect(hose, cfg_addr, cfg_data); > > +#ifdef PEX_CCB_DIV > + /* Configure the PCIE controller core clock ratio */ > + pci_hose_write_config_dword(hose, dev, 0x440, > + ((gd->bus_clk / 1000000) * > + (16 / PEX_CCB_DIV)) / 333); > +#endif > block_rev = in_be32(&pci->block_rev1); > if (PEX_IP_BLK_REV_2_2 <= block_rev) { > pi = &pci->pit[2]; /* 0xDC0 */
Ping?
Jocke
I must confess, I am not up to date with Kconfig stuff. I based my suggestion on what already exists in config_mpc85xx.h: #elif defined(CONFIG_PPC_T1040) || defined(CONFIG_PPC_T1042) ||\ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_E5500 #define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS2 /* Freescale Chassis generation 2 */ #define CONFIG_SYS_FSL_CORES_PER_CLUSTER 1 #define CONFIG_SYS_FSL_QMAN_V3 /* QMAN version 3 */ #ifdef CONFIG_SYS_FSL_DDR4 #define CONFIG_SYS_FSL_DDRC_GEN4 #endif #if defined(CONFIG_PPC_T1040) || defined(CONFIG_PPC_T1042) #define CONFIG_MAX_CPUS 4 #elif defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_MAX_CPUS 2 #endif #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 1, 1 } #define CONFIG_SYS_FSL_NUM_LAWS 16 #define CONFIG_SYS_FSL_SRDS_1 #define CONFIG_SYS_FSL_SEC_COMPAT 5 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 5 .... etc.
Seems like a good place to put another CPU constant.
Anyhow, that patch stands of its own I think. Where to put all constants is another patch for NXP.
Jocke
On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: > On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: >> Most FSL PCIe controllers expects 333 MHz PCI reference clock. >> This clock is derived from the CCB but in many cases the ref. >> clock is not 333 MHz and a divisor needs to be configured. >> >> This adds PEX_CCB_DIV #define which can be defined for each >> type of CPU/platform. >> >> Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com >> --- >> drivers/pci/fsl_pci_init.c | 6 ++++++ >> 1 file changed, 6 insertions(+) >> >> diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c >> index 52792dcd59..4d00b3f26c 100644 >> --- a/drivers/pci/fsl_pci_init.c >> +++ b/drivers/pci/fsl_pci_init.c >> @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) >> >> pci_setup_indirect(hose, cfg_addr, cfg_data); >> >> +#ifdef PEX_CCB_DIV >> + /* Configure the PCIE controller core clock ratio */ >> + pci_hose_write_config_dword(hose, dev, 0x440, >> + ((gd->bus_clk / 1000000) * >> + (16 / PEX_CCB_DIV)) / 333); >> +#endif
I took another look at this patch. Would it be appropriate to alway write to this register with correct clock?
>> block_rev = in_be32(&pci->block_rev1); >> if (PEX_IP_BLK_REV_2_2 <= block_rev) { >> pi = &pci->pit[2]; /* 0xDC0 */ > > Ping? > > Jocke >
Yeah. We have been moving things out of header files and into Kconfig. I would avoid adding new macro to header files.
Yes, we can add another patch to define this option for SoCs.
York
On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote: > CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. > > > On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: > > On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: > > > Most FSL PCIe controllers expects 333 MHz PCI reference clock. > > > This clock is derived from the CCB but in many cases the ref. > > > clock is not 333 MHz and a divisor needs to be configured. > > > > > > This adds PEX_CCB_DIV #define which can be defined for each > > > type of CPU/platform. > > > > > > Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com > > > --- > > > drivers/pci/fsl_pci_init.c | 6 ++++++ > > > 1 file changed, 6 insertions(+) > > > > > > diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c > > > index 52792dcd59..4d00b3f26c 100644 > > > --- a/drivers/pci/fsl_pci_init.c > > > +++ b/drivers/pci/fsl_pci_init.c > > > @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) > > > > > > pci_setup_indirect(hose, cfg_addr, cfg_data); > > > > > > +#ifdef PEX_CCB_DIV > > > + /* Configure the PCIE controller core clock ratio */ > > > + pci_hose_write_config_dword(hose, dev, 0x440, > > > + ((gd->bus_clk / 1000000) * > > > + (16 / PEX_CCB_DIV)) / 333); > > > +#endif
I sure hope so, the docs I have only mentions this reg having a default value which needs to be changed in most cases I guess.
> > > block_rev = in_be32(&pci->block_rev1); > > > if (PEX_IP_BLK_REV_2_2 <= block_rev) { > > > pi = &pci->pit[2]; /* 0xDC0 */ > > > > Ping? > > > > Jocke > > > > I believe Mingkai's last comment was "to add the PCIe clock in gd".
OK, I am happy if don't have to manually select the constant.
Jocke
On 11/21/2017 09:29 AM, Joakim Tjernlund wrote: > On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote: >> CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. >> >> >> On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: >>> On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: >>>> Most FSL PCIe controllers expects 333 MHz PCI reference clock. >>>> This clock is derived from the CCB but in many cases the ref. >>>> clock is not 333 MHz and a divisor needs to be configured. >>>> >>>> This adds PEX_CCB_DIV #define which can be defined for each >>>> type of CPU/platform. >>>> >>>> Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com >>>> --- >>>> drivers/pci/fsl_pci_init.c | 6 ++++++ >>>> 1 file changed, 6 insertions(+) >>>> >>>> diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c >>>> index 52792dcd59..4d00b3f26c 100644 >>>> --- a/drivers/pci/fsl_pci_init.c >>>> +++ b/drivers/pci/fsl_pci_init.c >>>> @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) >>>> >>>> pci_setup_indirect(hose, cfg_addr, cfg_data); >>>> >>>> +#ifdef PEX_CCB_DIV >>>> + /* Configure the PCIE controller core clock ratio */ >>>> + pci_hose_write_config_dword(hose, dev, 0x440, >>>> + ((gd->bus_clk / 1000000) * >>>> + (16 / PEX_CCB_DIV)) / 333); >>>> +#endif
The only case we don't need to set this register is when the actual clock is 333MHz. I wonder why we didn't have a problem so far. Maybe we just didn't realize it.
York
On Tue, 2017-11-21 at 17:32 +0000, York Sun wrote: > CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. > > > On 11/21/2017 09:29 AM, Joakim Tjernlund wrote: > > On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote: > > > CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. > > > > > > > > > On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: > > > > On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: > > > > > Most FSL PCIe controllers expects 333 MHz PCI reference clock. > > > > > This clock is derived from the CCB but in many cases the ref. > > > > > clock is not 333 MHz and a divisor needs to be configured. > > > > > > > > > > This adds PEX_CCB_DIV #define which can be defined for each > > > > > type of CPU/platform. > > > > > > > > > > Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com > > > > > --- > > > > > drivers/pci/fsl_pci_init.c | 6 ++++++ > > > > > 1 file changed, 6 insertions(+) > > > > > > > > > > diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c > > > > > index 52792dcd59..4d00b3f26c 100644 > > > > > --- a/drivers/pci/fsl_pci_init.c > > > > > +++ b/drivers/pci/fsl_pci_init.c > > > > > @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) > > > > > > > > > > pci_setup_indirect(hose, cfg_addr, cfg_data); > > > > > > > > > > +#ifdef PEX_CCB_DIV > > > > > + /* Configure the PCIE controller core clock ratio */ > > > > > + pci_hose_write_config_dword(hose, dev, 0x440, > > > > > + ((gd->bus_clk / 1000000) * > > > > > + (16 / PEX_CCB_DIV)) / 333); > > > > > +#endif
Have you tried higher PCI speeds? I remember a board we had didn't work with higher speeds so we settled for less than max. Don't hav the board handy now.
Jocke
On 11/21/2017 09:41 AM, Joakim Tjernlund wrote: > On Tue, 2017-11-21 at 17:32 +0000, York Sun wrote: >> CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. >> >> >> On 11/21/2017 09:29 AM, Joakim Tjernlund wrote: >>> On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote: >>>> CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. >>>> >>>> >>>> On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: >>>>> On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: >>>>>> Most FSL PCIe controllers expects 333 MHz PCI reference clock. >>>>>> This clock is derived from the CCB but in many cases the ref. >>>>>> clock is not 333 MHz and a divisor needs to be configured. >>>>>> >>>>>> This adds PEX_CCB_DIV #define which can be defined for each >>>>>> type of CPU/platform. >>>>>> >>>>>> Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com >>>>>> --- >>>>>> drivers/pci/fsl_pci_init.c | 6 ++++++ >>>>>> 1 file changed, 6 insertions(+) >>>>>> >>>>>> diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c >>>>>> index 52792dcd59..4d00b3f26c 100644 >>>>>> --- a/drivers/pci/fsl_pci_init.c >>>>>> +++ b/drivers/pci/fsl_pci_init.c >>>>>> @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) >>>>>> >>>>>> pci_setup_indirect(hose, cfg_addr, cfg_data); >>>>>> >>>>>> +#ifdef PEX_CCB_DIV >>>>>> + /* Configure the PCIE controller core clock ratio */ >>>>>> + pci_hose_write_config_dword(hose, dev, 0x440, >>>>>> + ((gd->bus_clk / 1000000) * >>>>>> + (16 / PEX_CCB_DIV)) / 333); >>>>>> +#endif
No, I haven't.
York
>>>> block_rev = in_be32(&pci->block_rev1); >>>> if (PEX_IP_BLK_REV_2_2 <= block_rev) { >>>> pi = &pci->pit[2]; /* 0xDC0 */ >>> >>> Ping? >>> >>> Jocke >>> >> >> I believe Mingkai's last comment was "to add the PCIe clock in gd". > > Right, I seem to have forgotten to comment on that ... > Why add that complexity/bloat? This is a constant defined by the CPU/SOC so > it makes perfect sense to just #define it. >
Jocke,
Where are we on this patch? Do we have any patch to define PEX_CCB_DIV to activate this new code?
York
> > > > > block_rev = in_be32(&pci->block_rev1); > > > > > if (PEX_IP_BLK_REV_2_2 <= block_rev) { > > > > > pi = &pci->pit[2]; /* 0xDC0 */ > > > > > > > > Ping? > > > > > > > > Jocke > > > > > > > > > > I believe Mingkai's last comment was "to add the PCIe clock in gd". > > > > Right, I seem to have forgotten to comment on that ... > > Why add that complexity/bloat? This is a constant defined by the CPU/SOC so > > it makes perfect sense to just #define it. > > > > I am leaning to agree with you. The clock is either CCB clock, or CCB/2. > Would it be better if you use a Kconfig option and select the divisor by > SoC?
Jocke,
I think we are at me thinking we should add my simple patch: +#ifdef PEX_CCB_DIV + /* Configure the PCIE controller core clock ratio */ + pci_hose_write_config_dword(hose, dev, 0x440,> + ((gd->bus_clk / 1000000) * + (16 / PEX_CCB_DIV)) / 333); +#endif and then NXP find a suitable place to add PEX_CCB_DIV #define for each CPU/SOC. I am not working on such a patch anyhow.
Jocke
>>>>>> block_rev = in_be32(&pci->block_rev1); >>>>>> if (PEX_IP_BLK_REV_2_2 <= block_rev) { >>>>>> pi = &pci->pit[2]; /* 0xDC0 */ >>>>> >>>>> Ping? >>>>> >>>>> Jocke >>>>> >>>> >>>> I believe Mingkai's last comment was "to add the PCIe clock in gd". >>> >>> Right, I seem to have forgotten to comment on that ... >>> Why add that complexity/bloat? This is a constant defined by the CPU/SOC so >>> it makes perfect sense to just #define it. >>> >> >> I am leaning to agree with you. The clock is either CCB clock, or CCB/2. >> Would it be better if you use a Kconfig option and select the divisor by >> SoC? > > No, this is not something that needs Kconfig, just add the PEX_CCB_DIV #define > in relevant PPC CPU, like in config_mpc85xx.h >
Jocke,
- pci_hose_write_config_dword(hose, dev, 0x440,>
OK. I tend to accept this patch and have Mingkai to follow up on defining PEX_CCB_DIV for SoCs in need.
York
York, did this go anywhere?
Jocke
On Tue, 2017-11-21 at 17:45 +0000, York Sun wrote: > > On 11/21/2017 09:41 AM, Joakim Tjernlund wrote: > > On Tue, 2017-11-21 at 17:32 +0000, York Sun wrote: > > > CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. > > > > > > > > > On 11/21/2017 09:29 AM, Joakim Tjernlund wrote: > > > > On Tue, 2017-11-21 at 17:23 +0000, York Sun wrote: > > > > > CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe. > > > > > > > > > > > > > > > On 11/21/2017 09:18 AM, Joakim Tjernlund wrote: > > > > > > On Tue, 2017-09-12 at 19:56 +0200, Joakim Tjernlund wrote: > > > > > > > Most FSL PCIe controllers expects 333 MHz PCI reference clock. > > > > > > > This clock is derived from the CCB but in many cases the ref. > > > > > > > clock is not 333 MHz and a divisor needs to be configured. > > > > > > > > > > > > > > This adds PEX_CCB_DIV #define which can be defined for each > > > > > > > type of CPU/platform. > > > > > > > > > > > > > > Signed-off-by: Joakim Tjernlund joakim.tjernlund@infinera.com > > > > > > > --- > > > > > > > drivers/pci/fsl_pci_init.c | 6 ++++++ > > > > > > > 1 file changed, 6 insertions(+) > > > > > > > > > > > > > > diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c > > > > > > > index 52792dcd59..4d00b3f26c 100644 > > > > > > > --- a/drivers/pci/fsl_pci_init.c > > > > > > > +++ b/drivers/pci/fsl_pci_init.c > > > > > > > @@ -322,6 +322,12 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info) > > > > > > > > > > > > > > pci_setup_indirect(hose, cfg_addr, cfg_data); > > > > > > > > > > > > > > +#ifdef PEX_CCB_DIV > > > > > > > + /* Configure the PCIE controller core clock ratio */ > > > > > > > + pci_hose_write_config_dword(hose, dev, 0x440, > > > > > > > + ((gd->bus_clk / 1000000) * > > > > > > > + (16 / PEX_CCB_DIV)) / 333); > > > > > > > +#endif
> > > > > > > block_rev = in_be32(&pci->block_rev1); > > > > > > > if (PEX_IP_BLK_REV_2_2 <= block_rev) { > > > > > > > pi = &pci->pit[2]; /* 0xDC0 */ > > > > > > > > > > > > Ping? > > > > > > > > > > > > Jocke > > > > > > > > > > > > > > > > I believe Mingkai's last comment was "to add the PCIe clock in gd". > > > > > > > > Right, I seem to have forgotten to comment on that ... > > > > Why add that complexity/bloat? This is a constant defined by the CPU/SOC so > > > > it makes perfect sense to just #define it. > > > > > > > > > > I am leaning to agree with you. The clock is either CCB clock, or CCB/2. > > > Would it be better if you use a Kconfig option and select the divisor by > > > SoC? > > > > No, this is not something that needs Kconfig, just add the PEX_CCB_DIV #define > > in relevant PPC CPU, like in config_mpc85xx.h > > > > So what should be in Kconfig, and what shouldn't? This is per SoC macro. > Sounds like CONFIG_SYS_ in old days.
Jocke,
York
Applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Joakim Tjernlund
Joakim Tjernlund
Mingkai Hu
York Sun
