[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit a747cc0a8c55d69a56a6db80a35cdb48c853447d:
tegra2: Optimize out-of-tree build for Ventana. (2011-12-24 10:23:32 +0100)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Eric Nelson (1): i.mx6q: mx6qarm2: Enable the usboh3 clock
Fabio Estevam (6): net: imx: Add multi-FEC support for imx_get_mac_from_fuse mx28: Let imx_get_mac_from_fuse be common for mx28 mx28: Let dram_init be common for mx28 mx28evk: Add initial support for MX28EVK board mx28evk: Remove 'all' target from Makefile m28evk: Use GENERATED_GBL_DATA_SIZE
Jason Liu (4): i.mx: i.mx6q: Add the enet clock function fec: add the i.mx6q enet driver support i.mx6q: arm2: Add the enet function support i.mx6:imx6q: allign MAC address with burned-in ordering
Marek Vasut (1): MX28: Fix MXSBOOT segfault if no params specified
Veli-Pekka Peltola (1): mx28: remove omap specific config options
MAINTAINERS | 1 + arch/arm/cpu/arm1136/mx35/generic.c | 2 +- arch/arm/cpu/arm926ejs/mx25/generic.c | 2 +- arch/arm/cpu/arm926ejs/mx27/generic.c | 2 +- arch/arm/cpu/arm926ejs/mx28/mx28.c | 67 +++++++++++ arch/arm/cpu/arm926ejs/mx28/start.S | 6 - arch/arm/cpu/armv7/mx6/clock.c | 5 + arch/arm/cpu/armv7/mx6/soc.c | 16 ++- arch/arm/include/asm/arch-mx28/sys_proto.h | 2 + arch/arm/include/asm/arch-mx6/imx-regs.h | 4 +- board/denx/m28evk/m28evk.c | 53 +-------- board/freescale/mx28evk/Makefile | 47 ++++++++ board/freescale/mx28evk/iomux.c | 138 ++++++++++++++++++++++ board/freescale/mx28evk/mx28evk.c | 169 ++++++++++++++++++++++++++ board/freescale/mx28evk/u-boot.bd | 14 +++ board/freescale/mx6qarm2/imximage.cfg | 2 +- board/freescale/mx6qarm2/mx6qarm2.c | 90 ++++++++++++++ boards.cfg | 1 + drivers/net/fec_mxc.c | 19 +++- drivers/net/fec_mxc.h | 9 +- include/configs/m28evk.h | 9 ++- include/configs/mx28evk.h | 176 ++++++++++++++++++++++++++++ include/configs/mx6qarm2.h | 12 ++- tools/mxsboot.c | 3 + 24 files changed, 769 insertions(+), 80 deletions(-) create mode 100644 board/freescale/mx28evk/Makefile create mode 100644 board/freescale/mx28evk/iomux.c create mode 100644 board/freescale/mx28evk/mx28evk.c create mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 include/configs/mx28evk.h
Hi Stefano,
Looks like the similar patch for m28evk is missing.
Please find it here: http://patchwork.ozlabs.org/patch/133542/
Regards,
Fabio Estevam
On 04/01/2012 18:41, Fabio Estevam wrote:
Hi Stefano,
That's right, thanks, I did not merge it.
There is no drawbacks for the current pull request if the patch is missing, and I merge the patch into my next branch for the next time.
Thanks,
Stefano Babic
Hi Stefano,
Le 04/01/2012 17:57, Stefano Babic a écrit :
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Fabio Estevam
Stefano Babic
