Re: [U-Boot] [PATCH2/2] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
-----Original Message----- From: Dieter Kiermaier [mailto:dk-arm-linux@gmx.de] Sent: Thursday, July 09, 2009 12:50 PM To: Prafulla Wadaskar Subject: Re: [U-Boot] [PATCH2/2] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
Hi Prafulla,
-----Original Message----- From: Dieter Kiermaier [mailto:dk-arm-linux@gmx.de] Sent: Thursday, July 09, 2009 12:25 PM To: Jean-Christophe PLAGNIOL-VILLARD Cc: u-boot@lists.denx.de; Prafulla Wadaskar Subject: Re: [U-Boot] [PATCH2/2] Sheevaplug: Add Kirkwood gpio support to Sheevaplug
Hi Jean, hi Prafulla,
here the corrected version.
Many thanks, Dieter
On 14:45 Mon 29 Jun , Dieter Kiermaier wrote:
patch 2 of 2 which adds Kirkwood GPIO support to Sheevaplug. Any comments are welcome!
Hi Dieter Thanks for your efforts That's good, gpio driver is supported for Kirkwood but,
Again question
remains the same- Why do you need gpio support on
Sheevaplug? Whereas you have no evidence to use it.
That's a good question :) I need gpio support for my own board which will come up the next 2 months. So maybe you're right. There is no need for GPIO support on SheevaPlug.
Well.. you better post separate patch for your board that needs to use gpio support.
On the other hand there are maybe some hackers out there using sheevaplug not only as it is. So maybe there is a need for some GPIO bitbanging? At least if you open the case :)
I will post this information on plug forum (http://plugcomputer.org/plugforum/index.php). Also a small how-to doc to uses gpio support for bit bang interface.
Also many thanks to all of you out there for such a nice boot loader :) Dieter
Thanks to yourself too :-) let's make it further better.
Regards. Prafulla . .
Hi Prafulla,
Many thanks, Dieter
Again question
Would be the best solution. Is there anything I have to know if I want u-boot to support my own board?
Good idea.
Yep.
Dieter
Dieter Kiermaier
Prafulla Wadaskar
