[PATCH v5 00/23] Migration to using binman for bootloader
This series aims to eliminate the use of additional custom repositories such as k3-image-gen (K3 Image Generation) repo and core-secdev-k3 (K3 Security Development Tools) that was plumbed into the U-Boot build flow to generate boot images for TI K3 platform devices. And instead, we move towards using binman that aligns better with the community standard build flow.
This series uses binman for all K3 platforms supported on U-Boot currently; both HS (High Security, both SE and FS) and GP (General Purpose) devices.
Background on using k3-image-gen: * TI K3 devices require a SYSFW (System Firmware) image consisting of a signed system firmware image and board configuration binaries, this is needed to bring up system firmware during U-Boot R5 SPL startup. * Board configuration data contain board-specific information such as resource management, power management and security.
Background on using core-secdev-k3: * Contains resources to sign x509 certificates for HS devices
Series intends to use binman to take over the packaging and signing for the R5 bootloader images tiboot3.bin (and sysfw.itb, for non-combined boot flow) instead of k3-image-gen.
Series also packages the A72/A53 bootloader images (tispl.bin and u-boot.img) using ATF, OPTEE and DM (Device Manager)
Changes in v5: - updated all board configurations to latest - changed output binary filenames - fixed multiple certificate generation leading to packaging inconsistency in ti-secure*.py - added patch to overwrite symlink if exists, patch 21/23 ("binman: Overwrite symlink if it already exists")
Changes in v4: - added support for iot2050 - documentation fixes - move to using self.Raise in ti-board-config etype - introduced common k3-binman.dtsi (further reduction in code duplication can be targeted, this as first step)
Changes in v3: - added support for HS-FS devices - added support for AM68-sk - added back dropped documentation patch - changed prefix for SYSFW and DM files to expected directory name - extended test coverage to 100% - documentation fixes - corrected formatting changes
Changes in v2: - removed all external scripts - created ti-board-config etype to support generation of board config binaries - created ti-secure and ti-secure-rom etypes to handle signing instead of using external TI_SECURE_DEV_PKG - updated openssl btool to support x509 certificate generation - dropped Makefile changes to obtain external binary components, moving to using BINMAN_INDIRS to achieve the same
CI/CD passes 100% (with series rebased on -master, current series based on -next) [1]
v1: https://patchwork.ozlabs.org/project/uboot/cover/20230120101903.179959-1-n-f... v2: https://patchwork.ozlabs.org/project/uboot/cover/20230404121342.446935-1-n-f... v3: https://patchwork.ozlabs.org/project/uboot/cover/20230421123203.1315330-1-n-... v4: https://patchwork.ozlabs.org/project/uboot/cover/20230518142713.184164-1-n-f...
[1] https://github.com/u-boot/u-boot/pull/341
Andrew Davis (1): binman: Overwrite symlink if it already exists
Neha Malcom Francis (20): binman: ti-board-config: Add support for TI board config binaries binman: ti-secure: Add support for TI signing arm: dts: k3: Add support for packaging sysfw.itb and tiboot3.bin j721e: schema: yaml: Add general schema and J721E board config files j721e: dts: binman: Package tiboot3.bin, sysfw.itb, tispl.bin, u-boot.img j7200: yaml: Add J7200 board config files j7200: dts: binman: Package tiboot3.bin, tispl.bin, u-boot.img am65x: yaml: Add AM65x board config files am65: dts: binman: Package tiboot3.bin, sysfw.itb, tispl.bin, u-boot.img am64x: yaml: Add board configs for AM64x am64x: dts: binman: Package tiboot3.bin, tispl.bin u-boot.img j721s2: yaml: Add board configs for J721S2 j721s2: dts: binman: Package tiboot3.bin, tispl.bin and u-boot.img am62: yaml: Add board configs for AM62 am625: dts: binman: Package tiboot3.bin, tispl.bin and u-boot.img am62a: yaml: Add board configs for AM62ax am62a: dts: binman: Package tiboot3.bin, tispl.bin, u-boot.img arm: k3-am65x-iot2050: Use binman for tispl.bin for iot2050 k3: tools: config.mk: Update makefile and remove scripts doc: board: ti: Update documentation for binman flow
Tom Rini (2): buildman: Create a requirements.txt file CI: Make use of buildman requirements.txt
.azure-pipelines.yml | 4 + .gitlab-ci.yml | 4 + arch/arm/dts/k3-am625-r5-sk.dts | 1 + arch/arm/dts/k3-am625-sk-binman.dtsi | 463 +++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 2 + arch/arm/dts/k3-am62a-sk-binman.dtsi | 466 +++ arch/arm/dts/k3-am62a7-r5-sk.dts | 1 + arch/arm/dts/k3-am62a7-sk.dts | 1 + arch/arm/dts/k3-am642-evm-u-boot.dtsi | 2 + arch/arm/dts/k3-am642-r5-evm.dts | 1 + arch/arm/dts/k3-am642-sk-u-boot.dtsi | 2 + arch/arm/dts/k3-am64x-binman.dtsi | 515 +++ arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 76 +- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 1 + .../dts/k3-am654-r5-base-board-u-boot.dtsi | 1 + arch/arm/dts/k3-am65x-binman.dtsi | 518 +++ .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 2 + arch/arm/dts/k3-binman.dtsi | 116 + arch/arm/dts/k3-j7200-binman.dtsi | 502 +++ .../k3-j7200-common-proc-board-u-boot.dtsi | 2 + arch/arm/dts/k3-j721e-binman.dtsi | 701 ++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + .../arm/dts/k3-j721e-r5-common-proc-board.dts | 1 + arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 1 + arch/arm/dts/k3-j721s2-binman.dtsi | 546 +++ .../k3-j721s2-common-proc-board-u-boot.dtsi | 2 + .../dts/k3-j721s2-r5-common-proc-board.dts | 1 + arch/arm/mach-k3/config.mk | 103 - board/ti/am62ax/Kconfig | 2 + board/ti/am62ax/board-cfg.yaml | 36 + board/ti/am62ax/pm-cfg.yaml | 12 + board/ti/am62ax/rm-cfg.yaml | 1151 ++++++ board/ti/am62ax/sec-cfg.yaml | 379 ++ board/ti/am62ax/tifs-rm-cfg.yaml | 1011 ++++++ board/ti/am62x/Kconfig | 2 + board/ti/am62x/board-cfg.yaml | 36 + board/ti/am62x/pm-cfg.yaml | 12 + board/ti/am62x/rm-cfg.yaml | 1088 ++++++ board/ti/am62x/sec-cfg.yaml | 379 ++ board/ti/am64x/Kconfig | 2 + board/ti/am64x/board-cfg.yaml | 37 + board/ti/am64x/pm-cfg.yaml | 12 + board/ti/am64x/rm-cfg.yaml | 1400 ++++++++ board/ti/am64x/sec-cfg.yaml | 380 ++ board/ti/am65x/Kconfig | 2 + board/ti/am65x/board-cfg.yaml | 36 + board/ti/am65x/pm-cfg.yaml | 12 + board/ti/am65x/rm-cfg.yaml | 2068 +++++++++++ board/ti/am65x/sec-cfg.yaml | 379 ++ board/ti/common/schema.yaml | 436 +++ board/ti/j721e/Kconfig | 4 + board/ti/j721e/board-cfg.yaml | 37 + board/ti/j721e/board-cfg_j7200.yaml | 36 + board/ti/j721e/pm-cfg.yaml | 13 + board/ti/j721e/pm-cfg_j7200.yaml | 12 + board/ti/j721e/rm-cfg.yaml | 3174 +++++++++++++++++ board/ti/j721e/rm-cfg_j7200.yaml | 2065 +++++++++++ board/ti/j721e/sec-cfg.yaml | 381 ++ board/ti/j721e/sec-cfg_j7200.yaml | 380 ++ board/ti/j721s2/Kconfig | 2 + board/ti/j721s2/board-cfg.yaml | 37 + board/ti/j721s2/pm-cfg.yaml | 12 + board/ti/j721s2/rm-cfg.yaml | 2901 +++++++++++++++ board/ti/j721s2/sec-cfg.yaml | 379 ++ board/ti/keys/custMpk.pem | 51 + board/ti/keys/ti-degenerate-key.pem | 10 + doc/board/ti/am62x_sk.rst | 42 +- doc/board/ti/j721e_evm.rst | 50 +- doc/board/ti/k3.rst | 95 +- tools/binman/btool/openssl.py | 244 ++ tools/binman/entries.rst | 113 + tools/binman/etype/ti_board_config.py | 259 ++ tools/binman/etype/ti_secure.py | 78 + tools/binman/etype/ti_secure_rom.py | 249 ++ tools/binman/etype/x509_cert.py | 87 +- tools/binman/ftest.py | 72 + tools/binman/image.py | 2 + tools/binman/test/277_ti_board_cfg.dts | 14 + .../binman/test/278_ti_board_cfg_combined.dts | 25 + .../binman/test/279_ti_board_cfg_no_type.dts | 11 + tools/binman/test/279_ti_secure.dts | 17 + tools/binman/test/280_ti_secure_rom.dts | 17 + .../test/281_ti_secure_rom_combined.dts | 25 + tools/binman/test/288_ti_secure_rom_a.dts | 19 + tools/binman/test/289_ti_secure_rom_b.dts | 18 + tools/binman/test/yaml/config.yaml | 19 + tools/binman/test/yaml/schema.yaml | 51 + tools/binman/test/yaml/schema_notype.yaml | 40 + tools/buildman/requirements.txt | 2 + tools/k3_fit_atf.sh | 123 - tools/k3_gen_x509_cert.sh | 262 -- 91 files changed, 23724 insertions(+), 612 deletions(-) create mode 100644 arch/arm/dts/k3-am625-sk-binman.dtsi create mode 100644 arch/arm/dts/k3-am62a-sk-binman.dtsi create mode 100644 arch/arm/dts/k3-am64x-binman.dtsi create mode 100644 arch/arm/dts/k3-am65x-binman.dtsi create mode 100644 arch/arm/dts/k3-binman.dtsi create mode 100644 arch/arm/dts/k3-j7200-binman.dtsi create mode 100644 arch/arm/dts/k3-j721e-binman.dtsi create mode 100644 arch/arm/dts/k3-j721s2-binman.dtsi delete mode 100644 arch/arm/mach-k3/config.mk create mode 100644 board/ti/am62ax/board-cfg.yaml create mode 100644 board/ti/am62ax/pm-cfg.yaml create mode 100644 board/ti/am62ax/rm-cfg.yaml create mode 100644 board/ti/am62ax/sec-cfg.yaml create mode 100644 board/ti/am62ax/tifs-rm-cfg.yaml create mode 100644 board/ti/am62x/board-cfg.yaml create mode 100644 board/ti/am62x/pm-cfg.yaml create mode 100644 board/ti/am62x/rm-cfg.yaml create mode 100644 board/ti/am62x/sec-cfg.yaml create mode 100644 board/ti/am64x/board-cfg.yaml create mode 100644 board/ti/am64x/pm-cfg.yaml create mode 100644 board/ti/am64x/rm-cfg.yaml create mode 100644 board/ti/am64x/sec-cfg.yaml create mode 100644 board/ti/am65x/board-cfg.yaml create mode 100644 board/ti/am65x/pm-cfg.yaml create mode 100644 board/ti/am65x/rm-cfg.yaml create mode 100644 board/ti/am65x/sec-cfg.yaml create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/board-cfg.yaml create mode 100644 board/ti/j721e/board-cfg_j7200.yaml create mode 100644 board/ti/j721e/pm-cfg.yaml create mode 100644 board/ti/j721e/pm-cfg_j7200.yaml create mode 100644 board/ti/j721e/rm-cfg.yaml create mode 100644 board/ti/j721e/rm-cfg_j7200.yaml create mode 100644 board/ti/j721e/sec-cfg.yaml create mode 100644 board/ti/j721e/sec-cfg_j7200.yaml create mode 100644 board/ti/j721s2/board-cfg.yaml create mode 100644 board/ti/j721s2/pm-cfg.yaml create mode 100644 board/ti/j721s2/rm-cfg.yaml create mode 100644 board/ti/j721s2/sec-cfg.yaml create mode 100644 board/ti/keys/custMpk.pem create mode 100644 board/ti/keys/ti-degenerate-key.pem create mode 100644 tools/binman/etype/ti_board_config.py create mode 100644 tools/binman/etype/ti_secure.py create mode 100644 tools/binman/etype/ti_secure_rom.py create mode 100644 tools/binman/test/277_ti_board_cfg.dts create mode 100644 tools/binman/test/278_ti_board_cfg_combined.dts create mode 100644 tools/binman/test/279_ti_board_cfg_no_type.dts create mode 100644 tools/binman/test/279_ti_secure.dts create mode 100644 tools/binman/test/280_ti_secure_rom.dts create mode 100644 tools/binman/test/281_ti_secure_rom_combined.dts create mode 100644 tools/binman/test/288_ti_secure_rom_a.dts create mode 100644 tools/binman/test/289_ti_secure_rom_b.dts create mode 100644 tools/binman/test/yaml/config.yaml create mode 100644 tools/binman/test/yaml/schema.yaml create mode 100644 tools/binman/test/yaml/schema_notype.yaml create mode 100644 tools/buildman/requirements.txt delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh
The ti-board-config entry loads and validates a given YAML config file against a given schema, and generates the board config binary. K3 devices require these binaries to be packed into the final system firmware images.
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- tools/binman/entries.rst | 48 ++++ tools/binman/etype/ti_board_config.py | 259 ++++++++++++++++++ tools/binman/ftest.py | 20 ++ tools/binman/test/277_ti_board_cfg.dts | 14 + .../binman/test/278_ti_board_cfg_combined.dts | 25 ++ .../binman/test/279_ti_board_cfg_no_type.dts | 11 + tools/binman/test/yaml/config.yaml | 19 ++ tools/binman/test/yaml/schema.yaml | 51 ++++ tools/binman/test/yaml/schema_notype.yaml | 40 +++ 9 files changed, 487 insertions(+) create mode 100644 tools/binman/etype/ti_board_config.py create mode 100644 tools/binman/test/277_ti_board_cfg.dts create mode 100644 tools/binman/test/278_ti_board_cfg_combined.dts create mode 100644 tools/binman/test/279_ti_board_cfg_no_type.dts create mode 100644 tools/binman/test/yaml/config.yaml create mode 100644 tools/binman/test/yaml/schema.yaml create mode 100644 tools/binman/test/yaml/schema_notype.yaml
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index b71af801fd..14a2d03fad 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1658,6 +1658,54 @@ by setting the size of the entry to something larger than the text.
+.. _etype_ti_board_config: + +Entry: ti-board-config: An entry containing a TI schema validated board config binary +------------------------------------------------------------------------------------- + +This etype supports generation of two kinds of board configuration +binaries: singular board config binary as well as combined board config +binary. + +Properties / Entry arguments: + - config-file: File containing board configuration data in YAML + - schema-file: File containing board configuration YAML schema against + which the config file is validated + +Output files: + - board config binary: File containing board configuration binary + +These above parameters are used only when the generated binary is +intended to be a single board configuration binary. Example:: + + my-ti-board-config { + ti-board-config { + config = "board-config.yaml"; + schema = "schema.yaml"; + }; + }; + +To generate a combined board configuration binary, we pack the +needed individual binaries into a ti-board-config binary. In this case, +the available supported subnode names are board-cfg, pm-cfg, sec-cfg and +rm-cfg. The final binary is prepended with a header containing details about +the included board config binaries. Example:: + + my-combined-ti-board-config { + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + } + } + + + .. _etype_u_boot:
Entry: u-boot: U-Boot flat binary diff --git a/tools/binman/etype/ti_board_config.py b/tools/binman/etype/ti_board_config.py new file mode 100644 index 0000000000..0799e5dc59 --- /dev/null +++ b/tools/binman/etype/ti_board_config.py @@ -0,0 +1,259 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# Written by Neha Malcom Francis n-francis@ti.com +# +# Entry-type module for generating schema validated TI board +# configuration binary +# + +import os +import struct +import yaml + +from collections import OrderedDict +from jsonschema import validate +from shutil import copyfileobj + +from binman.entry import Entry +from binman.etype.section import Entry_section +from dtoc import fdt_util +from u_boot_pylib import tools + +BOARDCFG = 0xB +BOARDCFG_SEC = 0xD +BOARDCFG_PM = 0xE +BOARDCFG_RM = 0xC +BOARDCFG_NUM_ELEMS = 4 + +class Entry_ti_board_config(Entry_section): + """An entry containing a TI schema validated board config binary + + This etype supports generation of two kinds of board configuration + binaries: singular board config binary as well as combined board config + binary. + + Properties / Entry arguments: + - config-file: File containing board configuration data in YAML + - schema-file: File containing board configuration YAML schema against + which the config file is validated + + Output files: + - board config binary: File containing board configuration binary + + These above parameters are used only when the generated binary is + intended to be a single board configuration binary. Example:: + + my-ti-board-config { + ti-board-config { + config = "board-config.yaml"; + schema = "schema.yaml"; + }; + }; + + To generate a combined board configuration binary, we pack the + needed individual binaries into a ti-board-config binary. In this case, + the available supported subnode names are board-cfg, pm-cfg, sec-cfg and + rm-cfg. The final binary is prepended with a header containing details about + the included board config binaries. Example:: + + my-combined-ti-board-config { + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "schema.yaml"; + }; + } + } + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self._config = None + self._schema = None + self._entries = OrderedDict() + self._num_elems = BOARDCFG_NUM_ELEMS + self._fmt = '<HHHBB' + self._index = 0 + self._binary_offset = 0 + self._sw_rev = 1 + self._devgrp = 0 + + def ReadNode(self): + super().ReadNode() + self._config = fdt_util.GetString(self._node, 'config') + self._schema = fdt_util.GetString(self._node, 'schema') + # Depending on whether config file is present in node, we determine + # whether it is a combined board config binary or not + if self._config is None: + self.ReadEntries() + else: + self._config_file = tools.get_input_filename(self._config) + self._schema_file = tools.get_input_filename(self._schema) + + def ReadEntries(self): + """Read the subnodes to find out what should go in this image + """ + for node in self._node.subnodes: + if 'type' not in node.props: + entry = Entry.Create(self, node, 'ti-board-config') + entry.ReadNode() + cfg_data = entry.BuildSectionData(True) + entry._cfg_data = cfg_data + self._entries[entry.name] = entry + self._num_elems = len(self._node.subnodes) + + def _convert_to_byte_chunk(self, val, data_type): + """Convert value into byte array + + Args: + val: value to convert into byte array + data_type: data type used in schema, supported data types are u8, + u16 and u32 + + Returns: + array of bytes representing value + """ + size = 0 + if (data_type == '#/definitions/u8'): + size = 1 + elif (data_type == '#/definitions/u16'): + size = 2 + else: + size = 4 + if type(val) == int: + br = val.to_bytes(size, byteorder='little') + return br + + def _compile_yaml(self, schema_yaml, file_yaml): + """Convert YAML file into byte array based on YAML schema + + Args: + schema_yaml: file containing YAML schema + file_yaml: file containing config to compile + + Returns: + array of bytes repesenting YAML file against YAML schema + """ + br = bytearray() + for key, node in file_yaml.items(): + node_schema = schema_yaml['properties'][key] + node_type = node_schema.get('type') + if not 'type' in node_schema: + br += self._convert_to_byte_chunk(node, + node_schema.get('$ref')) + elif node_type == 'object': + br += self._compile_yaml(node_schema, node) + elif node_type == 'array': + for item in node: + if not isinstance(item, dict): + br += self._convert_to_byte_chunk( + item, schema_yaml['properties'][key]['items']['$ref']) + else: + br += self._compile_yaml(node_schema.get('items'), item) + return br + + def _generate_binaries(self): + """Generate config binary artifacts from the loaded YAML configuration file + + Returns: + byte array containing config binary artifacts + or None if generation fails + """ + cfg_binary = bytearray() + for key, node in self.file_yaml.items(): + node_schema = self.schema_yaml['properties'][key] + br = self._compile_yaml(node_schema, node) + cfg_binary += br + return cfg_binary + + def _add_boardcfg(self, bcfgtype, bcfgdata): + """Add board config to combined board config binary + + Args: + bcfgtype (int): board config type + bcfgdata (byte array): board config data + """ + size = len(bcfgdata) + desc = struct.pack(self._fmt, bcfgtype, + self._binary_offset, size, self._devgrp, 0) + with open(self.descfile, 'ab+') as desc_fh: + desc_fh.write(desc) + with open(self.bcfgfile, 'ab+') as bcfg_fh: + bcfg_fh.write(bcfgdata) + self._binary_offset += size + self._index += 1 + + def _finalize(self): + """Generate final combined board config binary + + Returns: + byte array containing combined board config data + or None if unable to generate + """ + with open(self.descfile, 'rb') as desc_fh: + with open(self.bcfgfile, 'rb') as bcfg_fh: + with open(self.fh_file, 'ab+') as fh: + copyfileobj(desc_fh, fh) + copyfileobj(bcfg_fh, fh) + data = tools.read_file(self.fh_file) + return data + + def BuildSectionData(self, required): + if self._config is None: + self._binary_offset = 0 + uniq = self.GetUniqueName() + self.fh_file = tools.get_output_filename('fh.%s' % uniq) + self.descfile = tools.get_output_filename('desc.%s' % uniq) + self.bcfgfile = tools.get_output_filename('bcfg.%s' % uniq) + + # when binman runs again make sure we start clean + if os.path.exists(self.fh_file): + os.remove(self.fh_file) + if os.path.exists(self.descfile): + os.remove(self.descfile) + if os.path.exists(self.bcfgfile): + os.remove(self.bcfgfile) + + with open(self.fh_file, 'wb') as f: + t_bytes = f.write(struct.pack( + '<BB', self._num_elems, self._sw_rev)) + self._binary_offset += t_bytes + self._binary_offset += self._num_elems * struct.calcsize(self._fmt) + + if 'board-cfg' in self._entries: + self._add_boardcfg(BOARDCFG, self._entries['board-cfg']._cfg_data) + + if 'sec-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_SEC, self._entries['sec-cfg']._cfg_data) + + if 'pm-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_PM, self._entries['pm-cfg']._cfg_data) + + if 'rm-cfg' in self._entries: + self._add_boardcfg(BOARDCFG_RM, self._entries['rm-cfg']._cfg_data) + + data = self._finalize() + return data + + else: + with open(self._config_file, 'r') as f: + self.file_yaml = yaml.safe_load(f) + with open(self._schema_file, 'r') as sch: + self.schema_yaml = yaml.safe_load(sch) + + try: + validate(self.file_yaml, self.schema_yaml) + except Exception as e: + self.Raise(f"Schema validation error: {e}") + + data = self._generate_binaries() + return data + + def SetImagePos(self, image_pos): + Entry.SetImagePos(self, image_pos) + + def CheckEntries(self): + Entry.CheckEntries(self) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 43b4f850a6..b9a490a5bd 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -97,6 +97,7 @@ ENV_DATA = b'var1=1\nvar2="2"' PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') +TI_BOARD_CONFIG_DATA = b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -199,6 +200,9 @@ class TestFunctional(unittest.TestCase): shutil.copytree(cls.TestFile('files'), os.path.join(cls._indir, 'files'))
+ shutil.copytree(cls.TestFile('yaml'), + os.path.join(cls._indir, 'yaml')) + TestFunctional._MakeInputFile('compress', COMPRESS_DATA) TestFunctional._MakeInputFile('compress_big', COMPRESS_DATA_BIG) TestFunctional._MakeInputFile('bl31.bin', ATF_BL31_DATA) @@ -6676,6 +6680,22 @@ fdt fdtmap Extract the devicetree blob from the fdtmap ['fit']) self.assertIn("Node '/fit': Missing tool: 'mkimage'", str(e.exception))
+ def testTIBoardConfig(self): + """Test that a schema validated board config file can be generated""" + data = self._DoReadFile('277_ti_board_cfg.dts') + self.assertEqual(TI_BOARD_CONFIG_DATA, data) + + def testTIBoardConfigCombined(self): + """Test that a schema validated combined board config file can be generated""" + data = self._DoReadFile('278_ti_board_cfg_combined.dts') + configlen_noheader = TI_BOARD_CONFIG_DATA * 4 + self.assertGreater(data, configlen_noheader) + + def testTIBoardConfigNoDataType(self): + """Test that error is thrown when data type is not supported""" + with self.assertRaises(ValueError) as e: + data = self._DoReadFile('279_ti_board_cfg_no_type.dts') + self.assertIn("Schema validation error", str(e.exception))
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/277_ti_board_cfg.dts b/tools/binman/test/277_ti_board_cfg.dts new file mode 100644 index 0000000000..cda024c1b8 --- /dev/null +++ b/tools/binman/test/277_ti_board_cfg.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-board-config { + config = "yaml/config.yaml"; + schema = "yaml/schema.yaml"; + }; + }; +}; diff --git a/tools/binman/test/278_ti_board_cfg_combined.dts b/tools/binman/test/278_ti_board_cfg_combined.dts new file mode 100644 index 0000000000..95ef449cbf --- /dev/null +++ b/tools/binman/test/278_ti_board_cfg_combined.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + ti-board-config { + board-cfg { + config = "yaml/config.yaml"; + schema = "yaml/schema.yaml"; + }; + sec-cfg { + config = "yaml/config.yaml"; + schema = "yaml/schema.yaml"; + }; + rm-cfg { + config = "yaml/config.yaml"; + schema = "yaml/schema.yaml"; + }; + pm-cfg { + config = "yaml/config.yaml"; + schema = "yaml/schema.yaml"; + }; + }; + }; +}; diff --git a/tools/binman/test/279_ti_board_cfg_no_type.dts b/tools/binman/test/279_ti_board_cfg_no_type.dts new file mode 100644 index 0000000000..584b7acc5a --- /dev/null +++ b/tools/binman/test/279_ti_board_cfg_no_type.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + ti-board-config { + config = "yaml/config.yaml"; + schema = "yaml/schema_notype.yaml"; + }; + }; +}; diff --git a/tools/binman/test/yaml/config.yaml b/tools/binman/test/yaml/config.yaml new file mode 100644 index 0000000000..79fd67c7f4 --- /dev/null +++ b/tools/binman/test/yaml/config.yaml @@ -0,0 +1,19 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Test config +# +--- + +main-branch: + obj: + a: 0x0 + b: 0 + arr: [0, 0, 0, 0] + another-arr: + - #1 + c: 0 + d: 0 + - #2 + c: 0 + d: 0 diff --git a/tools/binman/test/yaml/schema.yaml b/tools/binman/test/yaml/schema.yaml new file mode 100644 index 0000000000..60bf56f671 --- /dev/null +++ b/tools/binman/test/yaml/schema.yaml @@ -0,0 +1,51 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Test schema +# +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + +type: object +properties: + main-branch: + type: object + properties: + obj: + type: object + properties: + a: + $ref: "#/definitions/u32" + b: + $ref: "#/definitions/u16" + arr: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + another-arr: + type: array + minItems: 2 + maxItems: 2 + items: + type: object + properties: + c: + $ref: "#/definitions/u8" + d: + $ref: "#/definitions/u8" + diff --git a/tools/binman/test/yaml/schema_notype.yaml b/tools/binman/test/yaml/schema_notype.yaml new file mode 100644 index 0000000000..d45d6cdf7e --- /dev/null +++ b/tools/binman/test/yaml/schema_notype.yaml @@ -0,0 +1,40 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Test schema +# +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + +type: object +properties: + main-branch: + type: object + properties: + obj: + type: object + properties: + a: + $ref: "#/definitions/u4" + b: + $ref: "#/definitions/u16" + arr: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" +
+Output files:
- my-ti-board-config {
ti-board-config {
- my-combined-ti-board-config {
ti-board-config {
board-cfg {
sec-cfg {
.. _etype_u_boot:
- """An entry containing a TI schema validated board config binary
- This etype supports generation of two kinds of board configuration
- binaries: singular board config binary as well as combined board config
- binary.
- Properties / Entry arguments:
- Output files:
- These above parameters are used only when the generated binary is
- intended to be a single board configuration binary. Example::
ti-board-config {
- To generate a combined board configuration binary, we pack the
- needed individual binaries into a ti-board-config binary. In this case,
- the available supported subnode names are board-cfg, pm-cfg, sec-cfg and
- rm-cfg. The final binary is prepended with a header containing details about
- the included board config binaries. Example::
ti-board-config {
board-cfg {
sec-cfg {
- def __init__(self, section, etype, node):
self._config = None
self._schema = None
self._index = 0
self._sw_rev = 1
self._devgrp = 0
- def ReadNode(self):
super().ReadNode()
self.ReadEntries()
else:
- def ReadEntries(self):
entry.ReadNode()
- def _convert_to_byte_chunk(self, val, data_type):
Args:
u16 and u32
Returns:
size = 0
size = 1
size = 2
else:
size = 4
return br
- def _compile_yaml(self, schema_yaml, file_yaml):
Args:
Returns:
br = bytearray()
for item in node:
else:
return br
- def _generate_binaries(self):
Returns:
cfg_binary += br
return cfg_binary
- def _add_boardcfg(self, bcfgtype, bcfgdata):
Args:
desc_fh.write(desc)
self._index += 1
- def _finalize(self):
Returns:
return data
- def BuildSectionData(self, required):
return data
else:
try:
return data
- def SetImagePos(self, image_pos):
- def CheckEntries(self):
- def testTIBoardConfig(self):
- def testTIBoardConfigCombined(self):
- def testTIBoardConfigNoDataType(self):
- #address-cells = <1>;
- #size-cells = <1>;
- binman {
ti-board-config {
- binman {
ti-board-config {
board-cfg {
sec-cfg {
rm-cfg {
pm-cfg {
- binman {
ti-board-config {
+main-branch:
- obj:
- a: 0x0
- b: 0
- arr: [0, 0, 0, 0]
- another-arr:
- #1
c: 0
d: 0
- #2
c: 0
d: 0
+definitions:
- u8:
type: integer
minimum: 0
maximum: 0xff
- u16:
type: integer
minimum: 0
maximum: 0xffff
- u32:
type: integer
minimum: 0
maximum: 0xffffffff
- main-branch:
type: object
properties:
obj:
type: object
properties:
a:
b:
arr:
type: array
minItems: 4
maxItems: 4
items:
another-arr:
type: array
minItems: 2
maxItems: 2
items:
type: object
properties:
c:
d:
+definitions:
- u8:
type: integer
minimum: 0
maximum: 0xff
- u16:
type: integer
minimum: 0
maximum: 0xffff
- u32:
type: integer
minimum: 0
maximum: 0xffffffff
- main-branch:
type: object
properties:
obj:
type: object
properties:
a:
b:
arr:
type: array
minItems: 4
maxItems: 4
items:
... Applying: binman: ti-board-config: Add support for TI board config binaries .git/rebase-apply/patch:538: new blank line at EOF. + .git/rebase-apply/patch:584: new blank line at EOF. + warning: 2 lines add whitespace errors.
Jan
The ti-secure entry contains certificate for binaries that will be loaded or booted by system firmware whereas the ti-secure-rom entry contains certificate for binaries that will be booted by ROM. Support for both these types of certificates is necessary for booting of K3 devices.
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [vigneshr@ti.com: fixed inconsist cert generation by multiple packing] Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- board/ti/keys/custMpk.pem | 51 ++++ board/ti/keys/ti-degenerate-key.pem | 10 + tools/binman/btool/openssl.py | 244 +++++++++++++++++ tools/binman/entries.rst | 65 +++++ tools/binman/etype/ti_secure.py | 78 ++++++ tools/binman/etype/ti_secure_rom.py | 249 ++++++++++++++++++ tools/binman/etype/x509_cert.py | 87 +++++- tools/binman/ftest.py | 52 ++++ tools/binman/test/279_ti_secure.dts | 17 ++ tools/binman/test/280_ti_secure_rom.dts | 17 ++ .../test/281_ti_secure_rom_combined.dts | 25 ++ tools/binman/test/288_ti_secure_rom_a.dts | 19 ++ tools/binman/test/289_ti_secure_rom_b.dts | 18 ++ 13 files changed, 924 insertions(+), 8 deletions(-) create mode 100644 board/ti/keys/custMpk.pem create mode 100644 board/ti/keys/ti-degenerate-key.pem create mode 100644 tools/binman/etype/ti_secure.py create mode 100644 tools/binman/etype/ti_secure_rom.py create mode 100644 tools/binman/test/279_ti_secure.dts create mode 100644 tools/binman/test/280_ti_secure_rom.dts create mode 100644 tools/binman/test/281_ti_secure_rom_combined.dts create mode 100644 tools/binman/test/288_ti_secure_rom_a.dts create mode 100644 tools/binman/test/289_ti_secure_rom_b.dts
diff --git a/board/ti/keys/custMpk.pem b/board/ti/keys/custMpk.pem new file mode 100644 index 0000000000..adba378c80 --- /dev/null +++ b/board/ti/keys/custMpk.pem @@ -0,0 +1,51 @@ +-----BEGIN RSA PRIVATE KEY----- +MIIJKQIBAAKCAgEAvxSuSdh/ctNrI83rSA5l3CJN8g5PgvbttfLd23yR+m5Z/9X3 +tt4EHYrM0pXZ0eDEwfhQv/9IDJEiUJpMe4vzlgooJrOk2eCpVUEa+z5bJ2y/ysBx +ry9yIu5GASVirT7HBPaxGLYswBJuD+KbPuWmoKgGRQNBF04WH6l01oRO1nmnELgR +qQ6SHyXdf7Hy0bnyaNgzWUuCfXfM0Zz6I7T7WIjyzerVFvIsdS36YsPBCW7gBnDg +tQcJmWLZ1uTnbG3IggdQk/fi2O3RX+PQns+TVNlf3V3ON2DxqxSKBHtlp7p/30VF +fEuhW65OxpQ9jE6H0pQ8pPOf2vzyNnznDa1aQjfxKoHQbqGnZwMeh+0Au3NKaCgx +ooKaowTB6If/RX6qwZ/UOwXHg/0hcf69fzjJFhlSDuYDM40dHsk2HM1OnYIpiM2b +Kr5sX3uysjp5AGp99a0anR7NWCrPXvROgKs7T9341N40osQg2VkZLYUCXh9osUyN +uREG6S12tViMUKg3bmZ4b4MwRk00n7QYSrm7+nvFrtYyEISEbD+agDM1/E281W5g +VFDPfm2AlwT6jwsg/b2YK6E3vVn9SuxFoQmLF8lyFDO3BV4SXeJaHc4hVPbh6tVV +qifrTQnfGUCCLmaJF2XZbrPWOE6NYRbWdNTeFl9RGdVCuIPSyN5LqWmXto0CAwEA +AQKCAgAzkAwcJ0z1GnId/lJQZno8NhGckRoJuEKbR8dwlCP8VUz6Ca5H7Y9kvXDa +Hs/hn+rYgP6hYOz7XyrIX2rmJ/T6dxEwqGeC1+o59FConcIRWHpE5zuGT6JYJL5F +TuZa48bm4v8VMQvQZOjIZpkIFwao8c6HTwKAnHTB5IN/48I2hCt+Cn3RhfoOZ7Rm +4gkpaSkt+7GXlhXHb82YfujNO+hbktEamhUYlQ9EK70Wa8aqmf3gHxO0JgsEFjW8 +lJaSnultlTW8SDcx3LMUUjCYumECk4oX/VlJfmKYjPlVjkr3QQ+Cm3nNucb4K4hc +c+JL+2ERhSj8RjXL7VgbNgdPnIjvQDJuTNqecTU8xWPYrkOLQpNibbLjnutLkhJz +fMyRtmDtrsey8WiCDuCHkPJ8/f8RjL2zWI9fzTDDIzdlEKouUFGOovaHVnbua6pn +hymcu9d9FV3p2rcbj0ivCs7e8j+vhSxFJEJoAbcQdXCTi/n2uR7pLtoMNiUzsejy +d46Uz+KEU920NTwE2z6JJq8I2vegnxjc7PDDrV3/5rK04B93aXiqvwWseCpxelrI +xaMkRHbXrIXRO6MXQ3N+zNq8Dg3hjGTTvaBKuwgvqLwlXY8+Aa3ooFzEOInIOSsI +XcWqXxt/tgZgsj9RwpC42t8kbA+BkbNk9EIUa+P5kEr2P/fO7QKCAQEA4EtArnOX +D6tQF8uTw8USOZC2P9s/ez1z4jRq3oKP0Kv4tJiuIObJ/dUvGVD7aM5v2xaCfhm8 +xpk09VPUgghfG5jR5qVvQr75kCNToJQudWi4ngk1HwKJzzTO11giFEdybvTUA+Pj +fmxCM0dYYqRWZoj0hLqXlUCwxE74BFIhJVjeYbf+nTQrqpllTLoW7MTZHzGx5SXx +4dNzyVAUH49Yt2D8mgXXCkf5sGLh762wj34b/rR10Kr4O5utGMZrfTRIbuQ1pNjU +m66baPzq+mC0BzqZEW70TgEb7lOr8rcVXLOi3r36omfd9/MHx7iZD6o3K1axSO15 +grD4ZrN7Ac3QJwKCAQEA2heCoBdpvy6YUk8AO2k8qDygTdmPQRuwjjT+Z2fMslBt +D7DkpKwZ6Bl9OclcpiiLHmH+hv65KqYg+tR0RRb7PcogB9El9x7yKkGTPZEYWGky +n8P84rJpKwjnwWQvPQktI1cs3YGvZA9DQTFBavRrwuzgd1oSJq5aPQ2tme0kMvWp +l1/B/cPK+PKCi/Wfisaze1TjijP9qIeUwkdNN6WLrLU3QgsGppcg2I7RQtAIikT6 +GkuiOQAvWMsrJVV6PNrVKz4fJDJ59Rz6jbDHZNi1MEYNxQoB/Pl7QIakbfjWpHLv +8Ey7cB2JKxjQy8tmyl8WNQVbXbE6daPXcMTUmaRAKwKCAQBv1lYMJmq+T2eCVen6 +BbvOpE+bi5EdvEiaFBTtmiBnpjg+pJq+oRU60h/H+c9CNR0lGxY6Fk9An4f+g6xE +ojP6KLsQzJCrsVny+wpp2TlJJcxYULMCIVvhy60PR0zG29E9biqBPhJjKUvhEcQK +e3LxcXyq6fdHXphFajLUxLbuTl+kTgBRFoBnclFGbsubh5PTsA3J+p+fQLZNPPar +veg4l82cZykQYU8pGkUaI3sUMYd3+zd7sqRP5JHs9pMGPRmY4YW2CsAIWIn5UZNB +ARMDP76vKKn8cyUgMuxb+9pU/OVLN2NPs4bEaZQJjAwV+YPEwldny7F47xEM9JVz +EtKlAoIBAQDUt62u3GdGE/p5/ZgqWoDRTyDEDfmN9aYFbmbdEP80xQE7FrxMaZhz +K7laja6SWmUm40nQ/c45bQQp4uLtKHcxU15egX7YRBTLZl5o5IasZR79ebnEm2O8 +l9kEZeU1USf3mmWmP4GExOZCRfqaiYA6BbUCdJXTqKdXeWnkAssV8UrS3JFoJHpq +yo7OWGqefyQ8nRW6jO9SW7uaqtUD+7H6aF5XSk3YWvusfdBZrHNH+fM/hpnZovaL +Us7ogTDS/laA8PyK37jYfMVdQhmZoU1Iomt3zkUWK3gt/aWPpfAlQf4Jka4YspZB +tNiijefaZ1hPqsPs5Joyd/YAhdsfaHc1AoIBAQCn/9j6RRjRaw0ip756oad4AXHz +XBwVB2CrY96qT6Hj9Sq7tGgdskqGkOQkAivBLBizUdcWv0t1yenOsSgasQeMlvlh +B8md9cLvpKXPB3HM3rTDH/xNXe0TpVKLf7SXC8HfDyIweHwMW3QgO2DWrvI4BV/T +ckBatRNQ90HxkqGFhC/Mp529lQlyg3ifxPxJsvZOyPMUnrflAvsKQk5c2ZiQg3nZ +h7I2pjSYgCl+Ib52l8p9bf1kcrVGgPM+auzm496i0RPobFeDBoBvSoznJktHJ7+3 +NnZH+jLiZCODiQPGtQUi+T6eIZUIJF0YASpsCCtUzXCxwW3lYIDNy7UlMivF +-----END RSA PRIVATE KEY----- diff --git a/board/ti/keys/ti-degenerate-key.pem b/board/ti/keys/ti-degenerate-key.pem new file mode 100644 index 0000000000..bd7d3745ad --- /dev/null +++ b/board/ti/keys/ti-degenerate-key.pem @@ -0,0 +1,10 @@ +-----BEGIN RSA PRIVATE KEY----- +MIIBWwIBAAKBgQDRfrnXQaP0k6vRK/gZ+bDflSU6y1JagGeQ/b+QYuiDz14japog +8fRSu5WBsAxaSaySAUwS3L9Ppw+hGMecmyIJ494aMfZTtk1g49gU58joduiRnu7e +QSZHMnehhuNlfD7A2tAAKnxIYuabs8zHYM/SS9Ne7t3kIQMbKfUSzNy6qQIBAQIB +AQJBAOelUA376o6w3HkShXfN+shaOZYqFuTJ9exLMwsLp7DZKXB5F9I4JJ+Vkvho +k6QWs7vkhleLSYUZknXHYm26ZE0CQQDnhTtd4PTBoZPjPXOeYMJFtEdMNy0XP6ey +bcce389ugoY7BEkvASrd8PHgJQHziepgWOG4DGp33c64Hfq4zI3NAgEBAgEBAkA0 +RbK4uqoLciQluesTPU6lBy7Se3Dw0F9xBqlF5SR4KI6q+zQrHpBKyFOofMHZgizR +iCrL55cxEM146zMw3AnF +-----END RSA PRIVATE KEY----- diff --git a/tools/binman/btool/openssl.py b/tools/binman/btool/openssl.py index 3a4dbdd6d7..aad3b61ae2 100644 --- a/tools/binman/btool/openssl.py +++ b/tools/binman/btool/openssl.py @@ -15,6 +15,13 @@ import hashlib from binman import bintool from u_boot_pylib import tools
+ +VALID_SHAS = [256, 384, 512, 224] +SHA_OIDS = {256:'2.16.840.1.101.3.4.2.1', + 384:'2.16.840.1.101.3.4.2.2', + 512:'2.16.840.1.101.3.4.2.3', + 224:'2.16.840.1.101.3.4.2.4'} + class Bintoolopenssl(bintool.Bintool): """openssl tool
@@ -74,6 +81,243 @@ imageSize = INTEGER:{len(indata)} '-sha512'] return self.run_cmd(*args)
+ def x509_cert_sysfw(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict): + """Create a certificate to be booted by system firmware + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f'''[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +1.3.6.1.4.1.294.1.34 = ASN1:SEQUENCE:sysfw_image_integrity +1.3.6.1.4.1.294.1.35 = ASN1:SEQUENCE:sysfw_image_load + +[ swrv ] +swrv = INTEGER:{sw_rev} + +[ sysfw_image_integrity ] +shaType = OID:2.16.840.1.101.3.4.2.3 +shaValue = FORMAT:HEX,OCT:{hashval} +imageSize = INTEGER:{len(indata)} + +[ sysfw_image_load ] +destAddr = FORMAT:HEX,OCT:00000000 +authInPlace = INTEGER:2 +''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + + def x509_cert_rom(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict, cert_type, bootcore, + bootcore_opts, load_addr, sha): + """Create a certificate + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + cert_type (int): Certification type + bootcore (int): Booting core + load_addr (int): Load address of image + sha (int): Hash function + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f''' +[ req ] + distinguished_name = req_distinguished_name + x509_extensions = v3_ca + prompt = no + dirstring_type = nobmp + + [ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + + [ v3_ca ] + basicConstraints = CA:true + 1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq + 1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity + 1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption + 1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug + + [ boot_seq ] + certType = INTEGER:{cert_type} + bootCore = INTEGER:{bootcore} + bootCoreOpts = INTEGER:{bootcore_opts} + destAddr = FORMAT:HEX,OCT:{load_addr:08x} + imageSize = INTEGER:{len(indata)} + + [ image_integrity ] + shaType = OID:{SHA_OIDS[sha]} + shaValue = FORMAT:HEX,OCT:{hashval} + + [ swrv ] + swrv = INTEGER:{sw_rev} + +# [ encryption ] +# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV +# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS +# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX +# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT + + [ debug ] + debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 + debugType = INTEGER:4 + coreDbgEn = INTEGER:0 + coreDbgSecEn = INTEGER:0 +''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + + def x509_cert_rom_combined(self, cert_fname, input_fname, key_fname, sw_rev, + config_fname, req_dist_name_dict, load_addr, sha, total_size, num_comps, + sysfw_inner_cert_ext_boot_sequence_string, dm_data_ext_boot_sequence_string, + imagesize_sbl, hashval_sbl, load_addr_sysfw, imagesize_sysfw, + hashval_sysfw, load_addr_sysfw_data, imagesize_sysfw_data, + hashval_sysfw_data, sysfw_inner_cert_ext_boot_block, + dm_data_ext_boot_block): + """Create a certificate + + Args: + cert_fname (str): Filename of certificate to create + input_fname (str): Filename containing data to sign + key_fname (str): Filename of .pem file + sw_rev (int): Software revision + config_fname (str): Filename to write fconfig into + req_dist_name_dict (dict): Dictionary containing key-value pairs of + req_distinguished_name section extensions, must contain extensions for + C, ST, L, O, OU, CN and emailAddress + cert_type (int): Certification type + bootcore (int): Booting core + load_addr (int): Load address of image + sha (int): Hash function + + Returns: + str: Tool output + """ + indata = tools.read_file(input_fname) + hashval = hashlib.sha512(indata).hexdigest() + sha_type = SHA_OIDS[sha] + with open(config_fname, 'w', encoding='utf-8') as outf: + print(f''' +[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +C = {req_dist_name_dict['C']} +ST = {req_dist_name_dict['ST']} +L = {req_dist_name_dict['L']} +O = {req_dist_name_dict['O']} +OU = {req_dist_name_dict['OU']} +CN = {req_dist_name_dict['CN']} +emailAddress = {req_dist_name_dict['emailAddress']} + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.3=ASN1:SEQUENCE:swrv +1.3.6.1.4.1.294.1.9=ASN1:SEQUENCE:ext_boot_info + +[swrv] +swrv=INTEGER:{sw_rev} + +[ext_boot_info] +extImgSize=INTEGER:{total_size} +numComp=INTEGER:{num_comps} +sbl=SEQUENCE:sbl +sysfw=SEQUENCE:sysfw +sysfw_data=SEQUENCE:sysfw_data +{sysfw_inner_cert_ext_boot_sequence_string} +{dm_data_ext_boot_sequence_string} + +[sbl] +compType = INTEGER:1 +bootCore = INTEGER:16 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr:08x} +compSize = INTEGER:{imagesize_sbl} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sbl} + +[sysfw] +compType = INTEGER:2 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr_sysfw:08x} +compSize = INTEGER:{imagesize_sysfw} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw} + +[sysfw_data] +compType = INTEGER:18 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{load_addr_sysfw_data:08x} +compSize = INTEGER:{imagesize_sysfw_data} +shaType = OID:{sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw_data} + +{sysfw_inner_cert_ext_boot_block} + +{dm_data_ext_boot_block} + ''', file=outf) + args = ['req', '-new', '-x509', '-key', key_fname, '-nodes', + '-outform', 'DER', '-out', cert_fname, '-config', config_fname, + '-sha512'] + return self.run_cmd(*args) + def fetch(self, method): """Fetch handler for openssl
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index 14a2d03fad..a4c0223c84 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1706,6 +1706,71 @@ the included board config binaries. Example::
+.. _etype_ti_secure: + +Entry: ti-secure: Entry containing a TI x509 certificate binary +--------------------------------------------------------------- + +Properties / Entry arguments: + - content: List of phandles to entries to sign + - keyfile: Filename of file containing key to sign binary with + - sha: Hash function to be used for signing + +Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + +openssl signs the provided data, using the TI templated config file and +writes the signature in this entry. This allows verification that the +data is genuine. + + + +.. _etype_ti_secure_rom: + +Entry: ti-secure-rom: Entry containing a TI x509 certificate binary for images booted by ROM +-------------------------------------------------------------------------------------------- + +Properties / Entry arguments: + - keyfile: Filename of file containing key to sign binary with + - combined: boolean if device follows combined boot flow + - countersign: boolean if device contains countersigned system firmware + - load: load address of SPL + - sw-rev: software revision + - sha: Hash function to be used for signing + - core: core on which bootloader runs, valid cores are 'secure' and 'public' + - content: phandle of SPL in case of legacy bootflow or phandles of component binaries + in case of combined bootflow + +The following properties are only for generating a combined bootflow binary: + - sysfw-inner-cert: boolean if binary contains sysfw inner certificate + - dm-data: boolean if binary contains dm-data binary + - content-sbl: phandle of SPL binary + - content-sysfw: phandle of sysfw binary + - content-sysfw-data: phandle of sysfw-data or tifs-data binary + - content-sysfw-inner-cert (optional): phandle of sysfw inner certificate binary + - content-dm-data (optional): phandle of dm-data binary + - load-sysfw: load address of sysfw binary + - load-sysfw-data: load address of sysfw-data or tifs-data binary + - load-sysfw-inner-cert (optional): load address of sysfw inner certificate binary + - load-dm-data (optional): load address of dm-data binary + +Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + +openssl signs the provided data, using the TI templated config file and +writes the signature in this entry. This allows verification that the +data is genuine. + + + .. _etype_u_boot:
Entry: u-boot: U-Boot flat binary diff --git a/tools/binman/etype/ti_secure.py b/tools/binman/etype/ti_secure.py new file mode 100644 index 0000000000..f83bffc896 --- /dev/null +++ b/tools/binman/etype/ti_secure.py @@ -0,0 +1,78 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# Written by Neha Malcom Francis n-francis@ti.com +# + +# Support for generation of TI secured binary blobs + +from binman.entry import EntryArg +from binman.etype.x509_cert import Entry_x509_cert + +from dtoc import fdt_util + +class Entry_ti_secure(Entry_x509_cert): + """Entry containing a TI x509 certificate binary + + Properties / Entry arguments: + - content: List of phandles to entries to sign + - keyfile: Filename of file containing key to sign binary with + - sha: Hash function to be used for signing + + Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + + openssl signs the provided data, using the TI templated config file and + writes the signature in this entry. This allows verification that the + data is genuine. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.openssl = None + + def ReadNode(self): + super().ReadNode() + self.key_fname = self.GetEntryArgsOrProps([ + EntryArg('keyfile', str)], required=True)[0] + self.sha = fdt_util.GetInt(self._node, 'sha', 512) + self.req_dist_name = {'C': 'US', + 'ST': 'TX', + 'L': 'Dallas', + 'O': 'Texas Instruments Incorporated', + 'OU': 'Processors', + 'CN': 'TI Support', + 'emailAddress': 'support@ti.com'} + + def GetCertificate(self, required): + """Get the contents of this entry + + Args: + required: True if the data must be present, False if it is OK to + return None + + Returns: + bytes content of the entry, which is the certificate binary for the + provided data + """ + return super().GetCertificate(required=required, type='sysfw') + + def ObtainContents(self): + data = self.data + if data is None: + data = self.GetCertificate(False) + if data is None: + return False + self.SetContents(data) + return True + + def ProcessContents(self): + # The blob may have changed due to WriteSymbols() + data = self.data + return self.ProcessContentsUpdate(data) + + def AddBintools(self, btools): + super().AddBintools(btools) + self.openssl = self.AddBintool(btools, 'openssl') diff --git a/tools/binman/etype/ti_secure_rom.py b/tools/binman/etype/ti_secure_rom.py new file mode 100644 index 0000000000..42456f3d18 --- /dev/null +++ b/tools/binman/etype/ti_secure_rom.py @@ -0,0 +1,249 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# Written by Neha Malcom Francis n-francis@ti.com +# + +# Support for generation of TI secured bootloaders booted by ROM + +from binman.entry import EntryArg +from binman.etype.x509_cert import Entry_x509_cert + +import hashlib + +from dtoc import fdt_util +from u_boot_pylib import tools + +VALID_SHAS = [256, 384, 512, 224] +SHA_OIDS = {256:'2.16.840.1.101.3.4.2.1', + 384:'2.16.840.1.101.3.4.2.2', + 512:'2.16.840.1.101.3.4.2.3', + 224:'2.16.840.1.101.3.4.2.4'} + +class Entry_ti_secure_rom(Entry_x509_cert): + """Entry containing a TI x509 certificate binary for images booted by ROM + + Properties / Entry arguments: + - keyfile: Filename of file containing key to sign binary with + - combined: boolean if device follows combined boot flow + - countersign: boolean if device contains countersigned system firmware + - load: load address of SPL + - sw-rev: software revision + - sha: Hash function to be used for signing + - core: core on which bootloader runs, valid cores are 'secure' and 'public' + - content: phandle of SPL in case of legacy bootflow or phandles of component binaries + in case of combined bootflow + + The following properties are only for generating a combined bootflow binary: + - sysfw-inner-cert: boolean if binary contains sysfw inner certificate + - dm-data: boolean if binary contains dm-data binary + - content-sbl: phandle of SPL binary + - content-sysfw: phandle of sysfw binary + - content-sysfw-data: phandle of sysfw-data or tifs-data binary + - content-sysfw-inner-cert (optional): phandle of sysfw inner certificate binary + - content-dm-data (optional): phandle of dm-data binary + - load-sysfw: load address of sysfw binary + - load-sysfw-data: load address of sysfw-data or tifs-data binary + - load-sysfw-inner-cert (optional): load address of sysfw inner certificate binary + - load-dm-data (optional): load address of dm-data binary + + Output files: + - input.<unique_name> - input file passed to openssl + - config.<unique_name> - input file generated for openssl (which is + used as the config file) + - cert.<unique_name> - output file generated by openssl (which is + used as the entry contents) + + openssl signs the provided data, using the TI templated config file and + writes the signature in this entry. This allows verification that the + data is genuine. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.openssl = None + + def ReadNode(self): + super().ReadNode() + self.combined = fdt_util.GetBool(self._node, 'combined', False) + self.countersign = fdt_util.GetBool(self._node, 'countersign', False) + self.load_addr = fdt_util.GetInt(self._node, 'load', 0x00000000) + self.sw_rev = fdt_util.GetInt(self._node, 'sw-rev', 1) + self.sha = fdt_util.GetInt(self._node, 'sha', 512) + self.core = fdt_util.GetString(self._node, 'core', 'secure') + self.key_fname = self.GetEntryArgsOrProps([ + EntryArg('keyfile', str)], required=True)[0] + if self.combined: + self.sysfw_inner_cert = fdt_util.GetBool(self._node, 'sysfw-inner-cert', False) + self.load_addr_sysfw = fdt_util.GetInt(self._node, 'load-sysfw', 0x00000000) + self.load_addr_sysfw_data = fdt_util.GetInt(self._node, 'load-sysfw-data', 0x00000000) + self.dm_data = fdt_util.GetBool(self._node, 'dm-data', False) + if self.dm_data: + self.load_addr_dm_data = fdt_util.GetInt(self._node, 'load-dm-data', 0x00000000) + self.req_dist_name = {'C': 'US', + 'ST': 'TX', + 'L': 'Dallas', + 'O': 'Texas Instruments Incorporated', + 'OU': 'Processors', + 'CN': 'TI Support', + 'emailAddress': 'support@ti.com'} + + def NonCombinedGetCertificate(self, required): + """Generate certificate for legacy boot flow + + Args: + required: True if the data must be present, False if it is OK to + return None + + Returns: + bytes content of the entry, which is the certificate binary for the + provided data + """ + if self.core == 'secure': + if self.countersign: + self.cert_type = 3 + else: + self.cert_type = 2 + self.bootcore = 0 + self.bootcore_opts = 32 + else: + self.cert_type = 1 + self.bootcore = 16 + self.bootcore_opts = 0 + return super().GetCertificate(required=required, type='rom') + + def CombinedGetCertificate(self, required): + """Generate certificate for combined boot flow + + Args: + required: True if the data must be present, False if it is OK to + return None + + Returns: + bytes content of the entry, which is the certificate binary for the + provided data + """ + uniq = self.GetUniqueName() + + self.num_comps = 3 + self.sha_type = SHA_OIDS[self.sha] + + # sbl + self.content = fdt_util.GetPhandleList(self._node, 'content-sbl') + input_data_sbl = self.GetContents(required) + if input_data_sbl is None: + return None + + input_fname_sbl = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sbl, input_data_sbl) + + indata_sbl = tools.read_file(input_fname_sbl) + self.hashval_sbl = hashlib.sha512(indata_sbl).hexdigest() + self.imagesize_sbl = len(indata_sbl) + + # sysfw + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw') + input_data_sysfw = self.GetContents(required) + + input_fname_sysfw = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw, input_data_sysfw) + + indata_sysfw = tools.read_file(input_fname_sysfw) + self.hashval_sysfw = hashlib.sha512(indata_sysfw).hexdigest() + self.imagesize_sysfw = len(indata_sysfw) + + # sysfw data + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw-data') + input_data_sysfw_data = self.GetContents(required) + + input_fname_sysfw_data = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw_data, input_data_sysfw_data) + + indata_sysfw_data = tools.read_file(input_fname_sysfw_data) + self.hashval_sysfw_data = hashlib.sha512(indata_sysfw_data).hexdigest() + self.imagesize_sysfw_data = len(indata_sysfw_data) + + # sysfw inner cert + self.sysfw_inner_cert_ext_boot_block = "" + self.sysfw_inner_cert_ext_boot_sequence_string = "" + imagesize_sysfw_inner_cert = 0 + if self.sysfw_inner_cert: + self.content = fdt_util.GetPhandleList(self._node, 'content-sysfw-inner-cert') + input_data_sysfw_inner_cert = self.GetContents(required) + + input_fname_sysfw_inner_cert = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_sysfw_inner_cert, input_data_sysfw_inner_cert) + + indata_sysfw_inner_cert = tools.read_file(input_fname_sysfw_inner_cert) + hashval_sysfw_inner_cert = hashlib.sha512(indata_sysfw_inner_cert).hexdigest() + imagesize_sysfw_inner_cert = len(indata_sysfw_inner_cert) + self.num_comps += 1 + self.sysfw_inner_cert_ext_boot_sequence_string = "sysfw_inner_cert=SEQUENCE:sysfw_inner_cert" + self.sysfw_inner_cert_ext_boot_block = f"""[sysfw_inner_cert] +compType = INTEGER:3 +bootCore = INTEGER:0 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:00000000 +compSize = INTEGER:{imagesize_sysfw_inner_cert} +shaType = OID:{self.sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_sysfw_inner_cert}""" + + # dm data + self.dm_data_ext_boot_sequence_string = "" + self.dm_data_ext_boot_block = "" + imagesize_dm_data = 0 + if self.dm_data: + self.content = fdt_util.GetPhandleList(self._node, 'content-dm-data') + input_data_dm_data = self.GetContents(required) + + input_fname_dm_data = tools.get_output_filename('input.%s' % uniq) + tools.write_file(input_fname_dm_data, input_data_dm_data) + + indata_dm_data = tools.read_file(input_fname_dm_data) + hashval_dm_data = hashlib.sha512(indata_dm_data).hexdigest() + imagesize_dm_data = len(indata_dm_data) + self.num_comps += 1 + self.dm_data_ext_boot_sequence_string = "dm_data=SEQUENCE:dm_data" + self.dm_data_ext_boot_block = f"""[dm_data] +compType = INTEGER:17 +bootCore = INTEGER:16 +compOpts = INTEGER:0 +destAddr = FORMAT:HEX,OCT:{self.load_addr_dm_data:08x} +compSize = INTEGER:{imagesize_dm_data} +shaType = OID:{self.sha_type} +shaValue = FORMAT:HEX,OCT:{hashval_dm_data}""" + + self.total_size = self.imagesize_sbl + self.imagesize_sysfw + self.imagesize_sysfw_data + imagesize_sysfw_inner_cert + imagesize_dm_data + return super().GetCertificate(required=required, type='rom-combined') + + def GetCertificate(self, required): + """Get the contents of this entry + + Args: + required: True if the data must be present, False if it is OK to + return None + + Returns: + bytes content of the entry, which is the certificate binary for the + provided data + """ + if self.combined: + return self.CombinedGetCertificate(required) + else: + return self.NonCombinedGetCertificate(required) + + def ObtainContents(self): + data = self.data + if data is None: + data = self.GetCertificate(False) + if data is None: + return False + self.SetContents(data) + return True + + def ProcessContents(self): + # The blob may have changed due to WriteSymbols() + data = self.data + return self.ProcessContentsUpdate(data) + + def AddBintools(self, btools): + super().AddBintools(btools) + self.openssl = self.AddBintool(btools, 'openssl') diff --git a/tools/binman/etype/x509_cert.py b/tools/binman/etype/x509_cert.py index f80a6ec2d1..d028cfe38c 100644 --- a/tools/binman/etype/x509_cert.py +++ b/tools/binman/etype/x509_cert.py @@ -31,6 +31,26 @@ class Entry_x509_cert(Entry_collection): def __init__(self, section, etype, node): super().__init__(section, etype, node) self.openssl = None + self.req_dist_name = None + self.cert_type = None + self.bootcore = None + self.bootcore_opts = None + self.load_addr = None + self.sha = None + self.total_size = None + self.num_comps = None + self.sysfw_inner_cert_ext_boot_sequence_string = None + self.dm_data_ext_boot_sequence_string = None + self.imagesize_sbl = None + self.hashval_sbl = None + self.load_addr_sysfw = None + self.imagesize_sysfw = None + self.hashval_sysfw = None + self.load_addr_sysfw_data = None + self.imagesize_sysfw_data = None + self.hashval_sysfw_data = None + self.sysfw_inner_cert_ext_boot_block = None + self.dm_data_ext_boot_block = None
def ReadNode(self): super().ReadNode() @@ -38,13 +58,16 @@ class Entry_x509_cert(Entry_collection): self._cert_rev = fdt_util.GetInt(self._node, 'cert-revision-int', 0) self.key_fname = self.GetEntryArgsOrProps([ EntryArg('keyfile', str)], required=True)[0] + self.sw_rev = fdt_util.GetInt(self._node, 'sw-rev', 1)
- def GetCertificate(self, required): + def GetCertificate(self, required, type='generic'): """Get the contents of this entry
Args: required: True if the data must be present, False if it is OK to return None + type: Type of x509 certificate to generate, current supported ones are + 'generic', 'sysfw', 'rom'
Returns: bytes content of the entry, which is the signed vblock for the @@ -60,13 +83,61 @@ class Entry_x509_cert(Entry_collection): input_fname = tools.get_output_filename('input.%s' % uniq) config_fname = tools.get_output_filename('config.%s' % uniq) tools.write_file(input_fname, input_data) - stdout = self.openssl.x509_cert( - cert_fname=output_fname, - input_fname=input_fname, - key_fname=self.key_fname, - cn=self._cert_ca, - revision=self._cert_rev, - config_fname=config_fname) + if type == 'generic': + stdout = self.openssl.x509_cert( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + cn=self._cert_ca, + revision=self._cert_rev, + config_fname=config_fname) + elif type == 'sysfw': + stdout = self.openssl.x509_cert_sysfw( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name) + elif type == 'rom': + stdout = self.openssl.x509_cert_rom( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name, + cert_type=self.cert_type, + bootcore=self.bootcore, + bootcore_opts=self.bootcore_opts, + load_addr=self.load_addr, + sha=self.sha + ) + elif type == 'rom-combined': + stdout = self.openssl.x509_cert_rom_combined( + cert_fname=output_fname, + input_fname=input_fname, + key_fname=self.key_fname, + config_fname=config_fname, + sw_rev=self.sw_rev, + req_dist_name_dict=self.req_dist_name, + load_addr=self.load_addr, + sha=self.sha, + total_size=self.total_size, + num_comps=self.num_comps, + sysfw_inner_cert_ext_boot_sequence_string=self.sysfw_inner_cert_ext_boot_sequence_string, + dm_data_ext_boot_sequence_string=self.dm_data_ext_boot_sequence_string, + imagesize_sbl=self.imagesize_sbl, + hashval_sbl=self.hashval_sbl, + load_addr_sysfw=self.load_addr_sysfw, + imagesize_sysfw=self.imagesize_sysfw, + hashval_sysfw=self.hashval_sysfw, + load_addr_sysfw_data=self.load_addr_sysfw_data, + imagesize_sysfw_data=self.imagesize_sysfw_data, + hashval_sysfw_data=self.hashval_sysfw_data, + sysfw_inner_cert_ext_boot_block=self.sysfw_inner_cert_ext_boot_block, + dm_data_ext_boot_block=self.dm_data_ext_boot_block + ) if stdout is not None: data = tools.read_file(output_fname) else: diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index b9a490a5bd..f4bff50aaf 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -98,6 +98,7 @@ PRE_LOAD_MAGIC = b'UBSH' PRE_LOAD_VERSION = 0x11223344.to_bytes(4, 'big') PRE_LOAD_HDR_SIZE = 0x00001000.to_bytes(4, 'big') TI_BOARD_CONFIG_DATA = b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00' +TI_UNSECURE_DATA = b'unsecuredata'
# Subdirectory of the input dir to use to put test FDTs TEST_FDT_SUBDIR = 'fdts' @@ -211,6 +212,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('fw_dynamic.bin', OPENSBI_DATA) TestFunctional._MakeInputFile('scp.bin', SCP_DATA) TestFunctional._MakeInputFile('rockchip-tpl.bin', ROCKCHIP_TPL_DATA) + TestFunctional._MakeInputFile('ti_unsecure.bin', TI_UNSECURE_DATA)
# Add a few .dtb files for testing TestFunctional._MakeInputFile('%s/test-fdt1.dtb' % TEST_FDT_SUBDIR, @@ -6697,5 +6699,55 @@ fdt fdtmap Extract the devicetree blob from the fdtmap data = self._DoReadFile('279_ti_board_cfg_no_type.dts') self.assertIn("Schema validation error", str(e.exception))
+ def testPackTiSecure(self): + """Test that an image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('279_ti_secure.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + + def testPackTiSecureMissingTool(self): + """Test that an image with a TI secured binary (non-functional) can be created + when openssl is missing""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + with test_util.capture_sys_output() as (_, stderr): + self._DoTestFile('279_ti_secure.dts', + force_missing_bintools='openssl', + entry_args=entry_args) + err = stderr.getvalue() + self.assertRegex(err, "Image 'image'.*missing bintools.*: openssl") + + def testPackTiSecureROM(self): + """Test that a ROM image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('280_ti_secure_rom.dts', + entry_args=entry_args)[0] + data_a = self._DoReadFileDtb('288_ti_secure_rom_a.dts', + entry_args=entry_args)[0] + data_b = self._DoReadFileDtb('289_ti_secure_rom_b.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + self.assertGreater(len(data_a), len(TI_UNSECURE_DATA)) + self.assertGreater(len(data_b), len(TI_UNSECURE_DATA)) + + def testPackTiSecureROMCombined(self): + """Test that a ROM image with a TI secured binary can be created""" + keyfile = self.TestFile('key.key') + entry_args = { + 'keyfile': keyfile, + } + data = self._DoReadFileDtb('281_ti_secure_rom_combined.dts', + entry_args=entry_args)[0] + self.assertGreater(len(data), len(TI_UNSECURE_DATA)) + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/test/279_ti_secure.dts b/tools/binman/test/279_ti_secure.dts new file mode 100644 index 0000000000..941d0ab4ca --- /dev/null +++ b/tools/binman/test/279_ti_secure.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure { + content = <&unsecure_binary>; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/280_ti_secure_rom.dts b/tools/binman/test/280_ti_secure_rom.dts new file mode 100644 index 0000000000..d1313769f4 --- /dev/null +++ b/tools/binman/test/280_ti_secure_rom.dts @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/281_ti_secure_rom_combined.dts b/tools/binman/test/281_ti_secure_rom_combined.dts new file mode 100644 index 0000000000..bf872739bc --- /dev/null +++ b/tools/binman/test/281_ti_secure_rom_combined.dts @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + content-sbl = <&unsecure_binary>; + content-sysfw = <&unsecure_binary>; + content-sysfw-data = <&unsecure_binary>; + content-sysfw-inner-cert = <&unsecure_binary>; + content-dm-data = <&unsecure_binary>; + combined; + sysfw-inner-cert; + dm-data; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/288_ti_secure_rom_a.dts b/tools/binman/test/288_ti_secure_rom_a.dts new file mode 100644 index 0000000000..887138f0e4 --- /dev/null +++ b/tools/binman/test/288_ti_secure_rom_a.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + core = "secure"; + countersign; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +}; diff --git a/tools/binman/test/289_ti_secure_rom_b.dts b/tools/binman/test/289_ti_secure_rom_b.dts new file mode 100644 index 0000000000..c6d6182158 --- /dev/null +++ b/tools/binman/test/289_ti_secure_rom_b.dts @@ -0,0 +1,18 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + ti-secure-rom { + content = <&unsecure_binary>; + core = "public"; + }; + unsecure_binary: blob-ext { + filename = "ti_unsecure.bin"; + }; + }; +};
Board config binary artifacts must be generated to be used by binman to package sysfw.itb and tiboot3.bin for all K3 devices.
For devices that follow combined flow, these board configuration binaries must again be packaged into a combined board configuration blobs to be used by binman to package tiboot3.bin.
Add common k3-binman.dtsi to generate all the board configuration binaries needed.
Also add custMpk.pem and ti-degenerate-key.pem needed for signing GP and HS bootloader images common to all K3 devices.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-binman.dtsi | 116 ++++++++++++++++++++++++++++++++++++ 1 file changed, 116 insertions(+) create mode 100644 arch/arm/dts/k3-binman.dtsi
diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi new file mode 100644 index 0000000000..97a3573bdb --- /dev/null +++ b/arch/arm/dts/k3-binman.dtsi @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + custMpk { + filename = "custMpk.pem"; + blob-ext { + filename = "../keys/custMpk.pem"; + }; + }; + + ti-degenerate-key { + filename = "ti-degenerate-key.pem"; + blob-ext { + filename = "../keys/ti-degenerate-key.pem"; + }; + }; +}; + +#ifndef CONFIG_ARM64 + +&binman { + board-cfg { + filename = "board-cfg.bin"; + bcfg_yaml: ti-board-config { + config = "board-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + pm-cfg { + filename = "pm-cfg.bin"; + rcfg_yaml: ti-board-config { + config = "pm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + rm-cfg { + filename = "rm-cfg.bin"; + pcfg_yaml: ti-board-config { + config = "rm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + sec-cfg { + filename = "sec-cfg.bin"; + scfg_yaml: ti-board-config { + config = "sec-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + combined-tifs-cfg { + filename = "combined-tifs-cfg.bin"; + ti-board-config { + bcfg_yaml_tifs: board-cfg { + config = "board-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + scfg_yaml_tifs: sec-cfg { + config = "sec-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + pcfg_yaml_tifs: pm-cfg { + config = "pm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + rcfg_yaml_tifs: rm-cfg { + config = "rm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + }; + combined-dm-cfg { + filename = "combined-dm-cfg.bin"; + ti-board-config { + pcfg_yaml_dm: pm-cfg { + config = "pm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + rcfg_yaml_dm: rm-cfg { + config = "rm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + }; + combined-sysfw-cfg { + filename = "combined-sysfw-cfg.bin"; + ti-board-config { + board-cfg { + config = "board-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + sec-cfg { + config = "sec-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + pm-cfg { + config = "pm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + rm-cfg { + config = "rm-cfg.yaml"; + schema = "../common/schema.yaml"; + }; + }; + }; +}; + +#endif
Schema file in YAML must be provided in board/ti/common for validating input config files and packaging system firmware. The schema includes entries for rm-cfg, board-cfg, pm-cfg and sec-cfg.
Board config files must be provided in board/ti/<devicename> in YAML. These can then be consumed for generation of binaries to package system firmware. Added YAML configs for J721E in particular.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/common/schema.yaml | 436 +++++ board/ti/j721e/board-cfg.yaml | 37 + board/ti/j721e/pm-cfg.yaml | 13 + board/ti/j721e/rm-cfg.yaml | 3174 +++++++++++++++++++++++++++++++++ board/ti/j721e/sec-cfg.yaml | 381 ++++ 5 files changed, 4041 insertions(+) create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/board-cfg.yaml create mode 100644 board/ti/j721e/pm-cfg.yaml create mode 100644 board/ti/j721e/rm-cfg.yaml create mode 100644 board/ti/j721e/sec-cfg.yaml
diff --git a/board/ti/common/schema.yaml b/board/ti/common/schema.yaml new file mode 100644 index 0000000000..8023ecb0e0 --- /dev/null +++ b/board/ti/common/schema.yaml @@ -0,0 +1,436 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Config schema for TI K3 devices +# + +--- + +definitions: + u8: + type: integer + minimum: 0 + maximum: 0xff + u16: + type: integer + minimum: 0 + maximum: 0xffff + u32: + type: integer + minimum: 0 + maximum: 0xffffffff + + + +type: object +properties: + pm-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + board-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + control: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + main_isolation_enable: + $ref: "#/definitions/u8" + main_isolation_hostid: + $ref: "#/definitions/u16" + + + secproxy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + scaling_factor: + $ref: "#/definitions/u8" + scaling_profile: + $ref: "#/definitions/u8" + disable_main_nav_secure_proxy: + $ref: "#/definitions/u8" + + msmc: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + msmc_cache_size: + $ref: "#/definitions/u8" + debug_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + trace_dst_enables: + $ref: "#/definitions/u16" + trace_src_enables: + $ref: "#/definitions/u16" + + sec-cfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + processor_acl_list: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + proc_acl_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + processor_id: + $ref: "#/definitions/u8" + proc_access_master: + $ref: "#/definitions/u8" + proc_access_secondary: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + host_hierarchy: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_hierarchy_entries: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + supervisor_host_id: + $ref: "#/definitions/u8" + + otp_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + otp_entry: + type: array + minItems: 32 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + host_perms: + $ref: "#/definitions/u8" + write_host_id: + $ref: "#/definitions/u8" + + dkek_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allowed_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + allow_dkek_export_tisci: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 3 + maxItems: 3 + items: + $ref: "#/definitions/u8" + + sa2ul_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + rsvd: + type: array + minItems: 2 + maxItems: 4 + items: + $ref: "#/definitions/u8" + enable_saul_psil_global_config_writes: + $ref: "#/definitions/u8" + auth_resource_owner: + $ref: "#/definitions/u8" + + sec_dbg_config: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + allow_jtag_unlock: + $ref: "#/definitions/u8" + allow_wildcard_unlock: + $ref: "#/definitions/u8" + allowed_debug_level_rsvd: + $ref: "#/definitions/u8" + rsvd: + $ref: "#/definitions/u8" + min_cert_rev: + $ref: "#/definitions/u32" + jtag_unlock_hosts: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + + sec_handover_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + handover_msg_sender: + $ref: "#/definitions/u8" + handover_to_host_id: + $ref: "#/definitions/u8" + rsvd: + type: array + minItems: 4 + maxItems: 4 + items: + $ref: "#/definitions/u8" + + rm-cfg: + type: object + properties: + rm_boardcfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + host_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_cfg_entries: + type: array + minItems: 0 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + allowed_atype: + $ref: "#/definitions/u8" + allowed_qos: + $ref: "#/definitions/u16" + allowed_orderid: + $ref: "#/definitions/u32" + allowed_priority: + $ref: "#/definitions/u16" + allowed_sched_priority: + $ref: "#/definitions/u8" + resasg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + resasg_entries_size: + $ref: "#/definitions/u16" + reserved: + $ref: "#/definitions/u16" + + resasg_entries: + type: array + minItems: 0 + maxItems: 468 + items: + type: object + properties: + start_resource: + $ref: "#/definitions/u16" + num_resource: + $ref: "#/definitions/u16" + type: + $ref: "#/definitions/u16" + host_id: + $ref: "#/definitions/u8" + reserved: + $ref: "#/definitions/u8" + + tifs-rm-cfg: + type: object + properties: + rm_boardcfg: + type: object + properties: + rev: + type: object + properties: + boardcfg_abi_maj: + $ref: "#/definitions/u8" + boardcfg_abi_min: + $ref: "#/definitions/u8" + + host_cfg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + host_cfg_entries: + type: array + minItems: 0 + maxItems: 32 + items: + type: object + properties: + host_id: + $ref: "#/definitions/u8" + allowed_atype: + $ref: "#/definitions/u8" + allowed_qos: + $ref: "#/definitions/u16" + allowed_orderid: + $ref: "#/definitions/u32" + allowed_priority: + $ref: "#/definitions/u16" + allowed_sched_priority: + $ref: "#/definitions/u8" + resasg: + type: object + properties: + subhdr: + type: object + properties: + magic: + $ref: "#/definitions/u16" + size: + $ref: "#/definitions/u16" + resasg_entries_size: + $ref: "#/definitions/u16" + reserved: + $ref: "#/definitions/u16" + + resasg_entries: + type: array + minItems: 0 + maxItems: 468 + items: + type: object + properties: + start_resource: + $ref: "#/definitions/u16" + num_resource: + $ref: "#/definitions/u16" + type: + $ref: "#/definitions/u16" + host_id: + $ref: "#/definitions/u8" + reserved: + $ref: "#/definitions/u8" diff --git a/board/ti/j721e/board-cfg.yaml b/board/ti/j721e/board-cfg.yaml new file mode 100644 index 0000000000..9f5e00b3dc --- /dev/null +++ b/board/ti/j721e/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721E +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable: 0x5A + main_isolation_hostid: 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor: 0x1 + scaling_profile: 0x1 + disable_main_nav_secure_proxy: 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size: 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables: 0x00 + trace_src_enables: 0x00 + diff --git a/board/ti/j721e/pm-cfg.yaml b/board/ti/j721e/pm-cfg.yaml new file mode 100644 index 0000000000..40a8dfb7af --- /dev/null +++ b/board/ti/j721e/pm-cfg.yaml @@ -0,0 +1,13 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J721E +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + diff --git a/board/ti/j721e/rm-cfg.yaml b/board/ti/j721e/rm-cfg.yaml new file mode 100644 index 0000000000..39d276d9d5 --- /dev/null +++ b/board/ti/j721e/rm-cfg.yaml @@ -0,0 +1,3174 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J721E +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size: 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #2 + host_id: 5 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #3 + host_id: 12 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #4 + host_id: 13 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #5 + host_id: 21 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #6 + host_id: 26 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #7 + host_id: 28 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #8 + host_id: 35 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #9 + host_id: 37 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #10 + host_id: 40 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #11 + host_id: 42 + allowed_atype: 0x2A + allowed_qos: 0xAAAA + allowed_orderid: 0xAAAAAAAA + allowed_priority: 0xAAAA + allowed_sched_priority: 0xAA + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size: 8 + resasg_entries_size: 3344 + reserved: 0 + resasg_entries: + - + start_resource: 4 + num_resource: 93 + type: 7744 + host_id: 26 + reserved: 0 + + - + start_resource: 4 + num_resource: 93 + type: 7808 + host_id: 28 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 7872 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 8384 + host_id: 40 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 8384 + host_id: 42 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 8384 + host_id: 35 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 8384 + host_id: 37 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 8384 + host_id: 26 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 8384 + host_id: 28 + reserved: 0 + + - + start_resource: 40 + num_resource: 12 + type: 8384 + host_id: 12 + reserved: 0 + + - + start_resource: 52 + num_resource: 12 + type: 8384 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 128 + type: 8576 + host_id: 35 + reserved: 0 + + - + start_resource: 128 + num_resource: 128 + type: 8576 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 128 + type: 8640 + host_id: 40 + reserved: 0 + + - + start_resource: 128 + num_resource: 128 + type: 8640 + host_id: 42 + reserved: 0 + + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 6 + type: 8768 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 6 + type: 8768 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 8768 + host_id: 35 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 8768 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + + - + start_resource: 38 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + + - + start_resource: 124 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + + - + start_resource: 156 + num_resource: 12 + type: 13386 + host_id: 40 + reserved: 0 + + - + start_resource: 168 + num_resource: 12 + type: 13386 + host_id: 42 + reserved: 0 + + - + start_resource: 180 + num_resource: 12 + type: 13386 + host_id: 21 + reserved: 0 + + - + start_resource: 192 + num_resource: 12 + type: 13386 + host_id: 26 + reserved: 0 + + - + start_resource: 204 + num_resource: 12 + type: 13386 + host_id: 28 + reserved: 0 + + - + start_resource: 216 + num_resource: 28 + type: 13386 + host_id: 35 + reserved: 0 + + - + start_resource: 244 + num_resource: 8 + type: 13386 + host_id: 37 + reserved: 0 + + - + start_resource: 252 + num_resource: 4 + type: 13386 + host_id: 128 + reserved: 0 + + - + start_resource: 38 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + + - + start_resource: 1062 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + + - + start_resource: 1574 + num_resource: 32 + type: 13389 + host_id: 3 + reserved: 0 + + - + start_resource: 1606 + num_resource: 32 + type: 13389 + host_id: 5 + reserved: 0 + + - + start_resource: 1638 + num_resource: 256 + type: 13389 + host_id: 40 + reserved: 0 + + - + start_resource: 1894 + num_resource: 256 + type: 13389 + host_id: 42 + reserved: 0 + + - + start_resource: 2150 + num_resource: 256 + type: 13389 + host_id: 21 + reserved: 0 + + - + start_resource: 2406 + num_resource: 256 + type: 13389 + host_id: 26 + reserved: 0 + + - + start_resource: 2662 + num_resource: 256 + type: 13389 + host_id: 28 + reserved: 0 + + - + start_resource: 2918 + num_resource: 512 + type: 13389 + host_id: 35 + reserved: 0 + + - + start_resource: 3430 + num_resource: 256 + type: 13389 + host_id: 37 + reserved: 0 + + - + start_resource: 3686 + num_resource: 922 + type: 13389 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 13440 + host_id: 40 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 13440 + host_id: 42 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 13440 + host_id: 21 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 13440 + host_id: 26 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 13440 + host_id: 28 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 13440 + host_id: 35 + reserved: 0 + + - + start_resource: 48 + num_resource: 4 + type: 13440 + host_id: 37 + reserved: 0 + + - + start_resource: 52 + num_resource: 12 + type: 13440 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + + - + start_resource: 440 + num_resource: 150 + type: 13505 + host_id: 12 + reserved: 0 + + - + start_resource: 590 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + + - + start_resource: 630 + num_resource: 6 + type: 13505 + host_id: 3 + reserved: 0 + + - + start_resource: 636 + num_resource: 6 + type: 13505 + host_id: 5 + reserved: 0 + + - + start_resource: 642 + num_resource: 10 + type: 13505 + host_id: 40 + reserved: 0 + + - + start_resource: 652 + num_resource: 10 + type: 13505 + host_id: 42 + reserved: 0 + + - + start_resource: 662 + num_resource: 32 + type: 13505 + host_id: 21 + reserved: 0 + + - + start_resource: 694 + num_resource: 38 + type: 13505 + host_id: 26 + reserved: 0 + + - + start_resource: 732 + num_resource: 12 + type: 13505 + host_id: 28 + reserved: 0 + + - + start_resource: 744 + num_resource: 182 + type: 13505 + host_id: 35 + reserved: 0 + + - + start_resource: 926 + num_resource: 40 + type: 13505 + host_id: 37 + reserved: 0 + + - + start_resource: 966 + num_resource: 8 + type: 13505 + host_id: 128 + reserved: 0 + + - + start_resource: 316 + num_resource: 8 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 324 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + + - + start_resource: 324 + num_resource: 0 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 326 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + + - + start_resource: 328 + num_resource: 2 + type: 13506 + host_id: 40 + reserved: 0 + + - + start_resource: 330 + num_resource: 2 + type: 13506 + host_id: 42 + reserved: 0 + + - + start_resource: 332 + num_resource: 2 + type: 13506 + host_id: 21 + reserved: 0 + + - + start_resource: 334 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + + - + start_resource: 342 + num_resource: 2 + type: 13506 + host_id: 28 + reserved: 0 + + - + start_resource: 344 + num_resource: 4 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 348 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 349 + num_resource: 47 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 396 + num_resource: 1 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 397 + num_resource: 4 + type: 13506 + host_id: 40 + reserved: 0 + + - + start_resource: 401 + num_resource: 4 + type: 13506 + host_id: 42 + reserved: 0 + + - + start_resource: 405 + num_resource: 4 + type: 13506 + host_id: 21 + reserved: 0 + + - + start_resource: 409 + num_resource: 8 + type: 13506 + host_id: 26 + reserved: 0 + + - + start_resource: 417 + num_resource: 6 + type: 13506 + host_id: 28 + reserved: 0 + + - + start_resource: 423 + num_resource: 16 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 439 + num_resource: 1 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 0 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 13507 + host_id: 40 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 13507 + host_id: 42 + reserved: 0 + + - + start_resource: 32 + num_resource: 2 + type: 13507 + host_id: 21 + reserved: 0 + + - + start_resource: 34 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + + - + start_resource: 42 + num_resource: 2 + type: 13507 + host_id: 28 + reserved: 0 + + - + start_resource: 44 + num_resource: 4 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 48 + num_resource: 1 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 49 + num_resource: 47 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 1 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 97 + num_resource: 4 + type: 13507 + host_id: 40 + reserved: 0 + + - + start_resource: 101 + num_resource: 4 + type: 13507 + host_id: 42 + reserved: 0 + + - + start_resource: 105 + num_resource: 4 + type: 13507 + host_id: 21 + reserved: 0 + + - + start_resource: 109 + num_resource: 8 + type: 13507 + host_id: 26 + reserved: 0 + + - + start_resource: 117 + num_resource: 6 + type: 13507 + host_id: 28 + reserved: 0 + + - + start_resource: 123 + num_resource: 10 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 133 + num_resource: 6 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 139 + num_resource: 1 + type: 13507 + host_id: 128 + reserved: 0 + + - + start_resource: 140 + num_resource: 16 + type: 13508 + host_id: 21 + reserved: 0 + + - + start_resource: 156 + num_resource: 6 + type: 13508 + host_id: 26 + reserved: 0 + + - + start_resource: 162 + num_resource: 6 + type: 13508 + host_id: 28 + reserved: 0 + + - + start_resource: 168 + num_resource: 2 + type: 13508 + host_id: 35 + reserved: 0 + + - + start_resource: 170 + num_resource: 2 + type: 13508 + host_id: 37 + reserved: 0 + + - + start_resource: 172 + num_resource: 96 + type: 13508 + host_id: 35 + reserved: 0 + + - + start_resource: 268 + num_resource: 32 + type: 13508 + host_id: 37 + reserved: 0 + + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 304 + num_resource: 4 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 304 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 308 + num_resource: 6 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 314 + num_resource: 2 + type: 13509 + host_id: 128 + reserved: 0 + + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 12 + reserved: 0 + + - + start_resource: 300 + num_resource: 2 + type: 13510 + host_id: 12 + reserved: 0 + + - + start_resource: 300 + num_resource: 0 + type: 13510 + host_id: 35 + reserved: 0 + + - + start_resource: 302 + num_resource: 2 + type: 13510 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 8 + num_resource: 6 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13511 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 13512 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 13514 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + + - + start_resource: 7 + num_resource: 3 + type: 13515 + host_id: 40 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 13515 + host_id: 42 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 13515 + host_id: 21 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 13515 + host_id: 26 + reserved: 0 + + - + start_resource: 19 + num_resource: 3 + type: 13515 + host_id: 28 + reserved: 0 + + - + start_resource: 22 + num_resource: 6 + type: 13515 + host_id: 35 + reserved: 0 + + - + start_resource: 28 + num_resource: 3 + type: 13515 + host_id: 37 + reserved: 0 + + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + + - + start_resource: 140 + num_resource: 16 + type: 13568 + host_id: 12 + reserved: 0 + + - + start_resource: 156 + num_resource: 16 + type: 13568 + host_id: 13 + reserved: 0 + + - + start_resource: 172 + num_resource: 128 + type: 13568 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 0 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 13578 + host_id: 40 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 13578 + host_id: 42 + reserved: 0 + + - + start_resource: 32 + num_resource: 2 + type: 13578 + host_id: 21 + reserved: 0 + + - + start_resource: 34 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + + - + start_resource: 42 + num_resource: 2 + type: 13578 + host_id: 28 + reserved: 0 + + - + start_resource: 44 + num_resource: 4 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 48 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 49 + num_resource: 47 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 1 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 97 + num_resource: 4 + type: 13578 + host_id: 40 + reserved: 0 + + - + start_resource: 101 + num_resource: 4 + type: 13578 + host_id: 42 + reserved: 0 + + - + start_resource: 105 + num_resource: 4 + type: 13578 + host_id: 21 + reserved: 0 + + - + start_resource: 109 + num_resource: 8 + type: 13578 + host_id: 26 + reserved: 0 + + - + start_resource: 117 + num_resource: 6 + type: 13578 + host_id: 28 + reserved: 0 + + - + start_resource: 123 + num_resource: 16 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 139 + num_resource: 1 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 8 + num_resource: 6 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13579 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 13580 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 0 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 13581 + host_id: 40 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 13581 + host_id: 42 + reserved: 0 + + - + start_resource: 32 + num_resource: 2 + type: 13581 + host_id: 21 + reserved: 0 + + - + start_resource: 34 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + + - + start_resource: 42 + num_resource: 2 + type: 13581 + host_id: 28 + reserved: 0 + + - + start_resource: 44 + num_resource: 4 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 48 + num_resource: 1 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 49 + num_resource: 47 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 1 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 97 + num_resource: 4 + type: 13581 + host_id: 40 + reserved: 0 + + - + start_resource: 101 + num_resource: 4 + type: 13581 + host_id: 42 + reserved: 0 + + - + start_resource: 105 + num_resource: 4 + type: 13581 + host_id: 21 + reserved: 0 + + - + start_resource: 109 + num_resource: 8 + type: 13581 + host_id: 26 + reserved: 0 + + - + start_resource: 117 + num_resource: 6 + type: 13581 + host_id: 28 + reserved: 0 + + - + start_resource: 123 + num_resource: 10 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 133 + num_resource: 6 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 139 + num_resource: 1 + type: 13581 + host_id: 128 + reserved: 0 + + - + start_resource: 140 + num_resource: 16 + type: 13582 + host_id: 21 + reserved: 0 + + - + start_resource: 156 + num_resource: 6 + type: 13582 + host_id: 26 + reserved: 0 + + - + start_resource: 162 + num_resource: 6 + type: 13582 + host_id: 28 + reserved: 0 + + - + start_resource: 168 + num_resource: 2 + type: 13582 + host_id: 35 + reserved: 0 + + - + start_resource: 170 + num_resource: 2 + type: 13582 + host_id: 37 + reserved: 0 + + - + start_resource: 172 + num_resource: 96 + type: 13582 + host_id: 35 + reserved: 0 + + - + start_resource: 268 + num_resource: 32 + type: 13582 + host_id: 37 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 8 + num_resource: 6 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13583 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 13584 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 100 + type: 13632 + host_id: 12 + reserved: 0 + + - + start_resource: 110 + num_resource: 32 + type: 13632 + host_id: 13 + reserved: 0 + + - + start_resource: 142 + num_resource: 46 + type: 13632 + host_id: 21 + reserved: 0 + + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + + - + start_resource: 260 + num_resource: 28 + type: 13632 + host_id: 40 + reserved: 0 + + - + start_resource: 292 + num_resource: 28 + type: 13632 + host_id: 42 + reserved: 0 + + - + start_resource: 320 + num_resource: 24 + type: 13632 + host_id: 26 + reserved: 0 + + - + start_resource: 352 + num_resource: 24 + type: 13632 + host_id: 28 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + + - + start_resource: 64 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + + - + start_resource: 128 + num_resource: 4 + type: 14922 + host_id: 5 + reserved: 0 + + - + start_resource: 132 + num_resource: 16 + type: 14922 + host_id: 40 + reserved: 0 + + - + start_resource: 148 + num_resource: 16 + type: 14922 + host_id: 42 + reserved: 0 + + - + start_resource: 164 + num_resource: 8 + type: 14922 + host_id: 21 + reserved: 0 + + - + start_resource: 172 + num_resource: 8 + type: 14922 + host_id: 26 + reserved: 0 + + - + start_resource: 180 + num_resource: 8 + type: 14922 + host_id: 28 + reserved: 0 + + - + start_resource: 188 + num_resource: 24 + type: 14922 + host_id: 35 + reserved: 0 + + - + start_resource: 212 + num_resource: 8 + type: 14922 + host_id: 37 + reserved: 0 + + - + start_resource: 220 + num_resource: 36 + type: 14922 + host_id: 128 + reserved: 0 + + - + start_resource: 16400 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + + - + start_resource: 16528 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + + - + start_resource: 16656 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + + - + start_resource: 16912 + num_resource: 64 + type: 14925 + host_id: 5 + reserved: 0 + + - + start_resource: 16976 + num_resource: 128 + type: 14925 + host_id: 40 + reserved: 0 + + - + start_resource: 17104 + num_resource: 128 + type: 14925 + host_id: 42 + reserved: 0 + + - + start_resource: 17232 + num_resource: 64 + type: 14925 + host_id: 21 + reserved: 0 + + - + start_resource: 17296 + num_resource: 64 + type: 14925 + host_id: 26 + reserved: 0 + + - + start_resource: 17360 + num_resource: 64 + type: 14925 + host_id: 28 + reserved: 0 + + - + start_resource: 17424 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + + - + start_resource: 17552 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + + - + start_resource: 17680 + num_resource: 240 + type: 14925 + host_id: 128 + reserved: 0 + + - + start_resource: 1 + num_resource: 4 + type: 14976 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 3 + reserved: 0 + + - + start_resource: 13 + num_resource: 4 + type: 14976 + host_id: 5 + reserved: 0 + + - + start_resource: 17 + num_resource: 4 + type: 14976 + host_id: 40 + reserved: 0 + + - + start_resource: 21 + num_resource: 4 + type: 14976 + host_id: 42 + reserved: 0 + + - + start_resource: 25 + num_resource: 4 + type: 14976 + host_id: 21 + reserved: 0 + + - + start_resource: 29 + num_resource: 4 + type: 14976 + host_id: 26 + reserved: 0 + + - + start_resource: 33 + num_resource: 4 + type: 14976 + host_id: 28 + reserved: 0 + + - + start_resource: 37 + num_resource: 16 + type: 14976 + host_id: 35 + reserved: 0 + + - + start_resource: 53 + num_resource: 4 + type: 14976 + host_id: 37 + reserved: 0 + + - + start_resource: 57 + num_resource: 7 + type: 14976 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 20 + type: 15041 + host_id: 12 + reserved: 0 + + - + start_resource: 116 + num_resource: 8 + type: 15041 + host_id: 13 + reserved: 0 + + - + start_resource: 124 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + + - + start_resource: 156 + num_resource: 12 + type: 15041 + host_id: 5 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 15041 + host_id: 40 + reserved: 0 + + - + start_resource: 176 + num_resource: 8 + type: 15041 + host_id: 42 + reserved: 0 + + - + start_resource: 184 + num_resource: 8 + type: 15041 + host_id: 21 + reserved: 0 + + - + start_resource: 192 + num_resource: 8 + type: 15041 + host_id: 26 + reserved: 0 + + - + start_resource: 200 + num_resource: 8 + type: 15041 + host_id: 28 + reserved: 0 + + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + + - + start_resource: 224 + num_resource: 8 + type: 15041 + host_id: 37 + reserved: 0 + + - + start_resource: 232 + num_resource: 20 + type: 15041 + host_id: 128 + reserved: 0 + + - + start_resource: 50 + num_resource: 4 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 54 + num_resource: 0 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 56 + num_resource: 0 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 56 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + + - + start_resource: 57 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + + - + start_resource: 58 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + + - + start_resource: 60 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + + - + start_resource: 61 + num_resource: 1 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 62 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 78 + num_resource: 3 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 81 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 83 + num_resource: 1 + type: 15042 + host_id: 40 + reserved: 0 + + - + start_resource: 84 + num_resource: 1 + type: 15042 + host_id: 42 + reserved: 0 + + - + start_resource: 85 + num_resource: 1 + type: 15042 + host_id: 21 + reserved: 0 + + - + start_resource: 86 + num_resource: 1 + type: 15042 + host_id: 26 + reserved: 0 + + - + start_resource: 87 + num_resource: 1 + type: 15042 + host_id: 28 + reserved: 0 + + - + start_resource: 88 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 90 + num_resource: 1 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 91 + num_resource: 2 + type: 15042 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 0 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + + - + start_resource: 12 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + + - + start_resource: 13 + num_resource: 1 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 6 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 30 + num_resource: 3 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 33 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 15043 + host_id: 40 + reserved: 0 + + - + start_resource: 36 + num_resource: 1 + type: 15043 + host_id: 42 + reserved: 0 + + - + start_resource: 37 + num_resource: 1 + type: 15043 + host_id: 21 + reserved: 0 + + - + start_resource: 38 + num_resource: 1 + type: 15043 + host_id: 26 + reserved: 0 + + - + start_resource: 39 + num_resource: 1 + type: 15043 + host_id: 28 + reserved: 0 + + - + start_resource: 40 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 42 + num_resource: 1 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 43 + num_resource: 3 + type: 15043 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 15050 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 3 + type: 15051 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 3 + type: 15051 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 3 + type: 15051 + host_id: 40 + reserved: 0 + + - + start_resource: 14 + num_resource: 3 + type: 15051 + host_id: 42 + reserved: 0 + + - + start_resource: 17 + num_resource: 3 + type: 15051 + host_id: 21 + reserved: 0 + + - + start_resource: 20 + num_resource: 3 + type: 15051 + host_id: 26 + reserved: 0 + + - + start_resource: 23 + num_resource: 3 + type: 15051 + host_id: 28 + reserved: 0 + + - + start_resource: 26 + num_resource: 3 + type: 15051 + host_id: 35 + reserved: 0 + + - + start_resource: 29 + num_resource: 3 + type: 15051 + host_id: 37 + reserved: 0 + + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + + - + start_resource: 72 + num_resource: 4 + type: 15104 + host_id: 40 + reserved: 0 + + - + start_resource: 76 + num_resource: 4 + type: 15104 + host_id: 42 + reserved: 0 + + - + start_resource: 80 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + + - + start_resource: 88 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + + - + start_resource: 92 + num_resource: 4 + type: 15104 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 0 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + + - + start_resource: 12 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + + - + start_resource: 13 + num_resource: 1 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 6 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 30 + num_resource: 3 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 33 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 15114 + host_id: 40 + reserved: 0 + + - + start_resource: 36 + num_resource: 1 + type: 15114 + host_id: 42 + reserved: 0 + + - + start_resource: 37 + num_resource: 1 + type: 15114 + host_id: 21 + reserved: 0 + + - + start_resource: 38 + num_resource: 1 + type: 15114 + host_id: 26 + reserved: 0 + + - + start_resource: 39 + num_resource: 1 + type: 15114 + host_id: 28 + reserved: 0 + + - + start_resource: 40 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 42 + num_resource: 1 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 43 + num_resource: 2 + type: 15114 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 0 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + + - + start_resource: 12 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + + - + start_resource: 13 + num_resource: 1 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 6 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 30 + num_resource: 3 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 33 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 15117 + host_id: 40 + reserved: 0 + + - + start_resource: 36 + num_resource: 1 + type: 15117 + host_id: 42 + reserved: 0 + + - + start_resource: 37 + num_resource: 1 + type: 15117 + host_id: 21 + reserved: 0 + + - + start_resource: 38 + num_resource: 1 + type: 15117 + host_id: 26 + reserved: 0 + + - + start_resource: 39 + num_resource: 1 + type: 15117 + host_id: 28 + reserved: 0 + + - + start_resource: 40 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 42 + num_resource: 1 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 43 + num_resource: 3 + type: 15117 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0 diff --git a/board/ti/j721e/sec-cfg.yaml b/board/ti/j721e/sec-cfg.yaml new file mode 100644 index 0000000000..dbaae99033 --- /dev/null +++ b/board/ti/j721e/sec-cfg.yaml @@ -0,0 +1,381 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for J721E +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj: 0x0 + boardcfg_abi_min: 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + write_host_id: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci: 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size: 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0 + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock: 0x5A + allow_wildcard_unlock: 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev: 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender: 0 + handover_to_host_id: 0 + rsvd: [0, 0, 0, 0] +
+definitions:
- u8:
type: integer
minimum: 0
maximum: 0xff
- u16:
type: integer
minimum: 0
maximum: 0xffff
- u32:
type: integer
minimum: 0
maximum: 0xffffffff
- pm-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
- board-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
control:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
secproxy:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
scaling_factor:
scaling_profile:
msmc:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
msmc_cache_size:
debug_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
trace_dst_enables:
trace_src_enables:
- sec-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
processor_acl_list:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
proc_acl_entries:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
processor_id:
proc_access_master:
type: array
minItems: 3
maxItems: 3
items:
host_hierarchy:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
host_id:
supervisor_host_id:
otp_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
otp_entry:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
host_id:
host_perms:
write_host_id:
dkek_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
allowed_hosts:
type: array
minItems: 4
maxItems: 4
items:
rsvd:
type: array
minItems: 3
maxItems: 3
items:
sa2ul_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
rsvd:
type: array
minItems: 2
maxItems: 4
items:
sec_dbg_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
allow_jtag_unlock:
rsvd:
min_cert_rev:
jtag_unlock_hosts:
type: array
minItems: 4
maxItems: 4
items:
sec_handover_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
rsvd:
type: array
minItems: 4
maxItems: 4
items:
- rm-cfg:
type: object
properties:
rm_boardcfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
host_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
host_cfg_entries:
type: array
minItems: 0
maxItems: 32
items:
type: object
properties:
host_id:
allowed_atype:
allowed_qos:
allowed_orderid:
allowed_priority:
resasg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
reserved:
resasg_entries:
type: array
minItems: 0
maxItems: 468
items:
type: object
properties:
start_resource:
num_resource:
type:
host_id:
reserved:
- tifs-rm-cfg:
type: object
properties:
rm_boardcfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
host_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
host_cfg_entries:
type: array
minItems: 0
maxItems: 32
items:
type: object
properties:
host_id:
allowed_atype:
allowed_qos:
allowed_orderid:
allowed_priority:
resasg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
reserved:
resasg_entries:
type: array
minItems: 0
maxItems: 468
items:
type: object
properties:
start_resource:
num_resource:
type:
host_id:
reserved:
+board-cfg:
rev:
control:
subhdr:
magic: 0xC1D3
secproxy:
subhdr:
magic: 0x1207
scaling_factor: 0x1
msmc:
subhdr:
magic: 0xA5C3
debug_cfg:
subhdr:
magic: 0x020C
+pm-cfg:
rev:
+rm-cfg:
rm_boardcfg:
rev:
host_cfg:
subhdr:
magic: 0x4C41
host_cfg_entries:
- #1
host_id: 3
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #2
host_id: 5
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #3
host_id: 12
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #4
host_id: 13
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #5
host_id: 21
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #6
host_id: 26
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #7
host_id: 28
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #8
host_id: 35
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #9
host_id: 37
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #10
host_id: 40
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #11
host_id: 42
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #12
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #13
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #14
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #15
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #16
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #17
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #18
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #19
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #20
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #21
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #22
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #23
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #24
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #25
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #26
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #27
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #28
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #29
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #30
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #31
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #32
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
resasg:
subhdr:
magic: 0x7B25
reserved: 0
resasg_entries:
start_resource: 4
num_resource: 93
type: 7744
host_id: 26
reserved: 0
start_resource: 4
num_resource: 93
type: 7808
host_id: 28
reserved: 0
start_resource: 0
num_resource: 32
type: 7872
host_id: 128
reserved: 0
start_resource: 0
num_resource: 32
type: 8192
host_id: 3
reserved: 0
start_resource: 32
num_resource: 32
type: 8192
host_id: 5
reserved: 0
start_resource: 0
num_resource: 24
type: 8320
host_id: 3
reserved: 0
start_resource: 24
num_resource: 24
type: 8320
host_id: 5
reserved: 0
start_resource: 0
num_resource: 8
type: 8384
host_id: 3
reserved: 0
start_resource: 8
num_resource: 8
type: 8384
host_id: 5
reserved: 0
start_resource: 16
num_resource: 4
type: 8384
host_id: 40
reserved: 0
start_resource: 20
num_resource: 4
type: 8384
host_id: 42
reserved: 0
start_resource: 24
num_resource: 4
type: 8384
host_id: 35
reserved: 0
start_resource: 28
num_resource: 4
type: 8384
host_id: 37
reserved: 0
start_resource: 32
num_resource: 4
type: 8384
host_id: 26
reserved: 0
start_resource: 36
num_resource: 4
type: 8384
host_id: 28
reserved: 0
start_resource: 40
num_resource: 12
type: 8384
host_id: 12
reserved: 0
start_resource: 52
num_resource: 12
type: 8384
host_id: 13
reserved: 0
start_resource: 0
num_resource: 128
type: 8576
host_id: 35
reserved: 0
start_resource: 128
num_resource: 128
type: 8576
host_id: 37
reserved: 0
start_resource: 0
num_resource: 128
type: 8640
host_id: 40
reserved: 0
start_resource: 128
num_resource: 128
type: 8640
host_id: 42
reserved: 0
start_resource: 0
num_resource: 48
type: 8704
host_id: 128
reserved: 0
start_resource: 0
num_resource: 8
type: 8768
host_id: 3
reserved: 0
start_resource: 8
num_resource: 8
type: 8768
host_id: 5
reserved: 0
start_resource: 16
num_resource: 6
type: 8768
host_id: 12
reserved: 0
start_resource: 22
num_resource: 6
type: 8768
host_id: 13
reserved: 0
start_resource: 28
num_resource: 2
type: 8768
host_id: 35
reserved: 0
start_resource: 30
num_resource: 2
type: 8768
host_id: 37
reserved: 0
start_resource: 0
num_resource: 64
type: 13258
host_id: 128
reserved: 0
num_resource: 1024
type: 13261
host_id: 128
reserved: 0
start_resource: 0
num_resource: 64
type: 13322
host_id: 128
reserved: 0
num_resource: 1024
type: 13325
host_id: 128
reserved: 0
start_resource: 38
num_resource: 86
type: 13386
host_id: 12
reserved: 0
start_resource: 124
num_resource: 32
type: 13386
host_id: 13
reserved: 0
start_resource: 156
num_resource: 12
type: 13386
host_id: 40
reserved: 0
start_resource: 168
num_resource: 12
type: 13386
host_id: 42
reserved: 0
start_resource: 180
num_resource: 12
type: 13386
host_id: 21
reserved: 0
start_resource: 192
num_resource: 12
type: 13386
host_id: 26
reserved: 0
start_resource: 204
num_resource: 12
type: 13386
host_id: 28
reserved: 0
start_resource: 216
num_resource: 28
type: 13386
host_id: 35
reserved: 0
start_resource: 244
num_resource: 8
type: 13386
host_id: 37
reserved: 0
start_resource: 252
num_resource: 4
type: 13386
host_id: 128
reserved: 0
start_resource: 38
num_resource: 1024
type: 13389
host_id: 12
reserved: 0
num_resource: 512
type: 13389
host_id: 13
reserved: 0
num_resource: 32
type: 13389
host_id: 3
reserved: 0
num_resource: 32
type: 13389
host_id: 5
reserved: 0
num_resource: 256
type: 13389
host_id: 40
reserved: 0
num_resource: 256
type: 13389
host_id: 42
reserved: 0
num_resource: 256
type: 13389
host_id: 21
reserved: 0
num_resource: 256
type: 13389
host_id: 26
reserved: 0
num_resource: 256
type: 13389
host_id: 28
reserved: 0
num_resource: 512
type: 13389
host_id: 35
reserved: 0
num_resource: 256
type: 13389
host_id: 37
reserved: 0
num_resource: 922
type: 13389
host_id: 128
reserved: 0
start_resource: 0
num_resource: 4
type: 13440
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13440
host_id: 13
reserved: 0
start_resource: 8
num_resource: 4
type: 13440
host_id: 3
reserved: 0
start_resource: 12
num_resource: 4
type: 13440
host_id: 5
reserved: 0
start_resource: 16
num_resource: 4
type: 13440
host_id: 40
reserved: 0
start_resource: 20
num_resource: 4
type: 13440
host_id: 42
reserved: 0
start_resource: 24
num_resource: 4
type: 13440
host_id: 21
reserved: 0
start_resource: 28
num_resource: 4
type: 13440
host_id: 26
reserved: 0
start_resource: 32
num_resource: 4
type: 13440
host_id: 28
reserved: 0
start_resource: 36
num_resource: 12
type: 13440
host_id: 35
reserved: 0
start_resource: 48
num_resource: 4
type: 13440
host_id: 37
reserved: 0
start_resource: 52
num_resource: 12
type: 13440
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13504
host_id: 128
reserved: 0
start_resource: 440
num_resource: 150
type: 13505
host_id: 12
reserved: 0
start_resource: 590
num_resource: 40
type: 13505
host_id: 13
reserved: 0
start_resource: 630
num_resource: 6
type: 13505
host_id: 3
reserved: 0
start_resource: 636
num_resource: 6
type: 13505
host_id: 5
reserved: 0
start_resource: 642
num_resource: 10
type: 13505
host_id: 40
reserved: 0
start_resource: 652
num_resource: 10
type: 13505
host_id: 42
reserved: 0
start_resource: 662
num_resource: 32
type: 13505
host_id: 21
reserved: 0
start_resource: 694
num_resource: 38
type: 13505
host_id: 26
reserved: 0
start_resource: 732
num_resource: 12
type: 13505
host_id: 28
reserved: 0
start_resource: 744
num_resource: 182
type: 13505
host_id: 35
reserved: 0
start_resource: 926
num_resource: 40
type: 13505
host_id: 37
reserved: 0
start_resource: 966
num_resource: 8
type: 13505
host_id: 128
reserved: 0
start_resource: 316
num_resource: 8
type: 13506
host_id: 12
reserved: 0
start_resource: 324
num_resource: 2
type: 13506
host_id: 3
reserved: 0
start_resource: 324
num_resource: 0
type: 13506
host_id: 13
reserved: 0
start_resource: 326
num_resource: 2
type: 13506
host_id: 5
reserved: 0
start_resource: 328
num_resource: 2
type: 13506
host_id: 40
reserved: 0
start_resource: 330
num_resource: 2
type: 13506
host_id: 42
reserved: 0
start_resource: 332
num_resource: 2
type: 13506
host_id: 21
reserved: 0
start_resource: 334
num_resource: 8
type: 13506
host_id: 26
reserved: 0
start_resource: 342
num_resource: 2
type: 13506
host_id: 28
reserved: 0
start_resource: 344
num_resource: 4
type: 13506
host_id: 35
reserved: 0
start_resource: 348
num_resource: 1
type: 13506
host_id: 37
reserved: 0
start_resource: 349
num_resource: 47
type: 13506
host_id: 12
reserved: 0
start_resource: 396
num_resource: 1
type: 13506
host_id: 13
reserved: 0
start_resource: 397
num_resource: 4
type: 13506
host_id: 40
reserved: 0
start_resource: 401
num_resource: 4
type: 13506
host_id: 42
reserved: 0
start_resource: 405
num_resource: 4
type: 13506
host_id: 21
reserved: 0
start_resource: 409
num_resource: 8
type: 13506
host_id: 26
reserved: 0
start_resource: 417
num_resource: 6
type: 13506
host_id: 28
reserved: 0
start_resource: 423
num_resource: 16
type: 13506
host_id: 35
reserved: 0
start_resource: 439
num_resource: 1
type: 13506
host_id: 37
reserved: 0
start_resource: 16
num_resource: 8
type: 13507
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13507
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13507
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13507
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13507
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13507
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13507
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13507
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13507
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13507
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13507
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13507
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13507
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13507
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13507
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13507
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13507
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13507
host_id: 28
reserved: 0
start_resource: 123
num_resource: 10
type: 13507
host_id: 35
reserved: 0
start_resource: 133
num_resource: 6
type: 13507
host_id: 37
reserved: 0
start_resource: 139
num_resource: 1
type: 13507
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13508
host_id: 21
reserved: 0
start_resource: 156
num_resource: 6
type: 13508
host_id: 26
reserved: 0
start_resource: 162
num_resource: 6
type: 13508
host_id: 28
reserved: 0
start_resource: 168
num_resource: 2
type: 13508
host_id: 35
reserved: 0
start_resource: 170
num_resource: 2
type: 13508
host_id: 37
reserved: 0
start_resource: 172
num_resource: 96
type: 13508
host_id: 35
reserved: 0
start_resource: 268
num_resource: 32
type: 13508
host_id: 37
reserved: 0
start_resource: 304
num_resource: 0
type: 13509
host_id: 12
reserved: 0
start_resource: 304
num_resource: 4
type: 13509
host_id: 12
reserved: 0
start_resource: 304
num_resource: 0
type: 13509
host_id: 35
reserved: 0
start_resource: 308
num_resource: 6
type: 13509
host_id: 35
reserved: 0
start_resource: 314
num_resource: 2
type: 13509
host_id: 128
reserved: 0
start_resource: 300
num_resource: 0
type: 13510
host_id: 12
reserved: 0
start_resource: 300
num_resource: 2
type: 13510
host_id: 12
reserved: 0
start_resource: 300
num_resource: 0
type: 13510
host_id: 35
reserved: 0
start_resource: 302
num_resource: 2
type: 13510
host_id: 35
reserved: 0
start_resource: 4
num_resource: 0
type: 13511
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13511
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13511
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13511
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13511
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13512
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13512
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13512
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13512
host_id: 35
reserved: 0
start_resource: 2
num_resource: 5
type: 13514
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 13514
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 13515
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 13515
host_id: 13
reserved: 0
start_resource: 5
num_resource: 1
type: 13515
host_id: 3
reserved: 0
start_resource: 6
num_resource: 1
type: 13515
host_id: 5
reserved: 0
start_resource: 7
num_resource: 3
type: 13515
host_id: 40
reserved: 0
start_resource: 10
num_resource: 3
type: 13515
host_id: 42
reserved: 0
start_resource: 13
num_resource: 3
type: 13515
host_id: 21
reserved: 0
start_resource: 16
num_resource: 3
type: 13515
host_id: 26
reserved: 0
start_resource: 19
num_resource: 3
type: 13515
host_id: 28
reserved: 0
start_resource: 22
num_resource: 6
type: 13515
host_id: 35
reserved: 0
start_resource: 28
num_resource: 3
type: 13515
host_id: 37
reserved: 0
start_resource: 31
num_resource: 1
type: 13515
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13568
host_id: 12
reserved: 0
start_resource: 156
num_resource: 16
type: 13568
host_id: 13
reserved: 0
start_resource: 172
num_resource: 128
type: 13568
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13569
host_id: 128
reserved: 0
num_resource: 1024
type: 13570
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13571
host_id: 128
reserved: 0
start_resource: 16
num_resource: 8
type: 13578
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13578
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13578
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13578
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13578
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13578
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13578
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13578
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13578
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13578
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13578
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13578
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13578
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13578
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13578
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13578
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13578
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13578
host_id: 28
reserved: 0
start_resource: 123
num_resource: 16
type: 13578
host_id: 35
reserved: 0
start_resource: 139
num_resource: 1
type: 13578
host_id: 37
reserved: 0
start_resource: 4
num_resource: 0
type: 13579
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13579
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13579
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13579
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13579
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13580
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13580
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13580
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13580
host_id: 35
reserved: 0
start_resource: 16
num_resource: 8
type: 13581
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13581
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13581
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13581
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13581
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13581
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13581
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13581
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13581
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13581
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13581
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13581
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13581
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13581
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13581
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13581
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13581
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13581
host_id: 28
reserved: 0
start_resource: 123
num_resource: 10
type: 13581
host_id: 35
reserved: 0
start_resource: 133
num_resource: 6
type: 13581
host_id: 37
reserved: 0
start_resource: 139
num_resource: 1
type: 13581
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13582
host_id: 21
reserved: 0
start_resource: 156
num_resource: 6
type: 13582
host_id: 26
reserved: 0
start_resource: 162
num_resource: 6
type: 13582
host_id: 28
reserved: 0
start_resource: 168
num_resource: 2
type: 13582
host_id: 35
reserved: 0
start_resource: 170
num_resource: 2
type: 13582
host_id: 37
reserved: 0
start_resource: 172
num_resource: 96
type: 13582
host_id: 35
reserved: 0
start_resource: 268
num_resource: 32
type: 13582
host_id: 37
reserved: 0
start_resource: 4
num_resource: 0
type: 13583
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13583
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13583
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13583
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13583
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13584
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13584
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13584
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13584
host_id: 35
reserved: 0
start_resource: 10
num_resource: 100
type: 13632
host_id: 12
reserved: 0
start_resource: 110
num_resource: 32
type: 13632
host_id: 13
reserved: 0
start_resource: 142
num_resource: 46
type: 13632
host_id: 21
reserved: 0
start_resource: 196
num_resource: 28
type: 13632
host_id: 35
reserved: 0
start_resource: 228
num_resource: 28
type: 13632
host_id: 37
reserved: 0
start_resource: 260
num_resource: 28
type: 13632
host_id: 40
reserved: 0
start_resource: 292
num_resource: 28
type: 13632
host_id: 42
reserved: 0
start_resource: 320
num_resource: 24
type: 13632
host_id: 26
reserved: 0
start_resource: 352
num_resource: 24
type: 13632
host_id: 28
reserved: 0
start_resource: 400
num_resource: 4
type: 13632
host_id: 3
reserved: 0
start_resource: 404
num_resource: 4
type: 13632
host_id: 5
reserved: 0
start_resource: 16
num_resource: 32
type: 14922
host_id: 12
reserved: 0
start_resource: 48
num_resource: 16
type: 14922
host_id: 13
reserved: 0
start_resource: 64
num_resource: 64
type: 14922
host_id: 3
reserved: 0
start_resource: 128
num_resource: 4
type: 14922
host_id: 5
reserved: 0
start_resource: 132
num_resource: 16
type: 14922
host_id: 40
reserved: 0
start_resource: 148
num_resource: 16
type: 14922
host_id: 42
reserved: 0
start_resource: 164
num_resource: 8
type: 14922
host_id: 21
reserved: 0
start_resource: 172
num_resource: 8
type: 14922
host_id: 26
reserved: 0
start_resource: 180
num_resource: 8
type: 14922
host_id: 28
reserved: 0
start_resource: 188
num_resource: 24
type: 14922
host_id: 35
reserved: 0
start_resource: 212
num_resource: 8
type: 14922
host_id: 37
reserved: 0
start_resource: 220
num_resource: 36
type: 14922
host_id: 128
reserved: 0
num_resource: 128
type: 14925
host_id: 12
reserved: 0
num_resource: 128
type: 14925
host_id: 13
reserved: 0
num_resource: 256
type: 14925
host_id: 3
reserved: 0
num_resource: 64
type: 14925
host_id: 5
reserved: 0
num_resource: 128
type: 14925
host_id: 40
reserved: 0
num_resource: 128
type: 14925
host_id: 42
reserved: 0
num_resource: 64
type: 14925
host_id: 21
reserved: 0
num_resource: 64
type: 14925
host_id: 26
reserved: 0
num_resource: 64
type: 14925
host_id: 28
reserved: 0
num_resource: 128
type: 14925
host_id: 35
reserved: 0
num_resource: 128
type: 14925
host_id: 37
reserved: 0
num_resource: 240
type: 14925
host_id: 128
reserved: 0
start_resource: 1
num_resource: 4
type: 14976
host_id: 12
reserved: 0
start_resource: 5
num_resource: 4
type: 14976
host_id: 13
reserved: 0
start_resource: 9
num_resource: 4
type: 14976
host_id: 3
reserved: 0
start_resource: 13
num_resource: 4
type: 14976
host_id: 5
reserved: 0
start_resource: 17
num_resource: 4
type: 14976
host_id: 40
reserved: 0
start_resource: 21
num_resource: 4
type: 14976
host_id: 42
reserved: 0
start_resource: 25
num_resource: 4
type: 14976
host_id: 21
reserved: 0
start_resource: 29
num_resource: 4
type: 14976
host_id: 26
reserved: 0
start_resource: 33
num_resource: 4
type: 14976
host_id: 28
reserved: 0
start_resource: 37
num_resource: 16
type: 14976
host_id: 35
reserved: 0
start_resource: 53
num_resource: 4
type: 14976
host_id: 37
reserved: 0
start_resource: 57
num_resource: 7
type: 14976
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15040
host_id: 128
reserved: 0
start_resource: 96
num_resource: 20
type: 15041
host_id: 12
reserved: 0
start_resource: 116
num_resource: 8
type: 15041
host_id: 13
reserved: 0
start_resource: 124
num_resource: 32
type: 15041
host_id: 3
reserved: 0
start_resource: 156
num_resource: 12
type: 15041
host_id: 5
reserved: 0
start_resource: 168
num_resource: 8
type: 15041
host_id: 40
reserved: 0
start_resource: 176
num_resource: 8
type: 15041
host_id: 42
reserved: 0
start_resource: 184
num_resource: 8
type: 15041
host_id: 21
reserved: 0
start_resource: 192
num_resource: 8
type: 15041
host_id: 26
reserved: 0
start_resource: 200
num_resource: 8
type: 15041
host_id: 28
reserved: 0
start_resource: 208
num_resource: 16
type: 15041
host_id: 35
reserved: 0
start_resource: 224
num_resource: 8
type: 15041
host_id: 37
reserved: 0
start_resource: 232
num_resource: 20
type: 15041
host_id: 128
reserved: 0
start_resource: 50
num_resource: 4
type: 15042
host_id: 12
reserved: 0
start_resource: 54
num_resource: 2
type: 15042
host_id: 3
reserved: 0
start_resource: 54
num_resource: 0
type: 15042
host_id: 13
reserved: 0
start_resource: 56
num_resource: 0
type: 15042
host_id: 5
reserved: 0
start_resource: 56
num_resource: 1
type: 15042
host_id: 40
reserved: 0
start_resource: 57
num_resource: 1
type: 15042
host_id: 42
reserved: 0
start_resource: 58
num_resource: 1
type: 15042
host_id: 21
reserved: 0
start_resource: 59
num_resource: 1
type: 15042
host_id: 26
reserved: 0
start_resource: 60
num_resource: 1
type: 15042
host_id: 28
reserved: 0
start_resource: 61
num_resource: 1
type: 15042
host_id: 35
reserved: 0
start_resource: 62
num_resource: 1
type: 15042
host_id: 37
reserved: 0
start_resource: 63
num_resource: 9
type: 15042
host_id: 12
reserved: 0
start_resource: 72
num_resource: 6
type: 15042
host_id: 13
reserved: 0
start_resource: 78
num_resource: 3
type: 15042
host_id: 3
reserved: 0
start_resource: 81
num_resource: 2
type: 15042
host_id: 5
reserved: 0
start_resource: 83
num_resource: 1
type: 15042
host_id: 40
reserved: 0
start_resource: 84
num_resource: 1
type: 15042
host_id: 42
reserved: 0
start_resource: 85
num_resource: 1
type: 15042
host_id: 21
reserved: 0
start_resource: 86
num_resource: 1
type: 15042
host_id: 26
reserved: 0
start_resource: 87
num_resource: 1
type: 15042
host_id: 28
reserved: 0
start_resource: 88
num_resource: 2
type: 15042
host_id: 35
reserved: 0
start_resource: 90
num_resource: 1
type: 15042
host_id: 37
reserved: 0
start_resource: 91
num_resource: 2
type: 15042
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 15043
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15043
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15043
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15043
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15043
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15043
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15043
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15043
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15043
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15043
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15043
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15043
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15043
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15043
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15043
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15043
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15043
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15043
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15043
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15043
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15043
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15043
host_id: 37
reserved: 0
start_resource: 43
num_resource: 3
type: 15043
host_id: 128
reserved: 0
start_resource: 48
num_resource: 0
type: 15045
host_id: 3
reserved: 0
start_resource: 48
num_resource: 2
type: 15045
host_id: 3
reserved: 0
start_resource: 0
num_resource: 0
type: 15047
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15047
host_id: 3
reserved: 0
start_resource: 2
num_resource: 5
type: 15050
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 15050
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 15051
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 15051
host_id: 13
reserved: 0
start_resource: 5
num_resource: 3
type: 15051
host_id: 3
reserved: 0
start_resource: 8
num_resource: 3
type: 15051
host_id: 5
reserved: 0
start_resource: 11
num_resource: 3
type: 15051
host_id: 40
reserved: 0
start_resource: 14
num_resource: 3
type: 15051
host_id: 42
reserved: 0
start_resource: 17
num_resource: 3
type: 15051
host_id: 21
reserved: 0
start_resource: 20
num_resource: 3
type: 15051
host_id: 26
reserved: 0
start_resource: 23
num_resource: 3
type: 15051
host_id: 28
reserved: 0
start_resource: 26
num_resource: 3
type: 15051
host_id: 35
reserved: 0
start_resource: 29
num_resource: 3
type: 15051
host_id: 37
reserved: 0
start_resource: 48
num_resource: 8
type: 15104
host_id: 12
reserved: 0
start_resource: 56
num_resource: 4
type: 15104
host_id: 13
reserved: 0
start_resource: 60
num_resource: 8
type: 15104
host_id: 3
reserved: 0
start_resource: 68
num_resource: 4
type: 15104
host_id: 5
reserved: 0
start_resource: 72
num_resource: 4
type: 15104
host_id: 40
reserved: 0
start_resource: 76
num_resource: 4
type: 15104
host_id: 42
reserved: 0
start_resource: 80
num_resource: 8
type: 15104
host_id: 35
reserved: 0
start_resource: 88
num_resource: 4
type: 15104
host_id: 37
reserved: 0
start_resource: 92
num_resource: 4
type: 15104
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15105
host_id: 128
reserved: 0
num_resource: 256
type: 15106
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15107
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 15114
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15114
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15114
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15114
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15114
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15114
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15114
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15114
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15114
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15114
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15114
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15114
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15114
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15114
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15114
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15114
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15114
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15114
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15114
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15114
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15114
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15114
host_id: 37
reserved: 0
start_resource: 43
num_resource: 2
type: 15114
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 15115
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15115
host_id: 3
reserved: 0
start_resource: 2
num_resource: 4
type: 15117
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15117
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15117
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15117
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15117
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15117
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15117
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15117
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15117
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15117
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15117
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15117
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15117
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15117
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15117
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15117
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15117
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15117
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15117
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15117
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15117
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15117
host_id: 37
reserved: 0
start_resource: 43
num_resource: 3
type: 15117
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 15119
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15119
host_id: 3
reserved: 0
start_resource: 12
num_resource: 20
type: 15168
host_id: 3
reserved: 0
start_resource: 36
num_resource: 28
type: 15168
host_id: 5
reserved: 0
+sec-cfg:
rev:
processor_acl_list:
subhdr:
magic: 0xF1EA
proc_acl_entries:
- #1
processor_id: 0
- #2
processor_id: 0
- #3
processor_id: 0
- #4
processor_id: 0
- #5
processor_id: 0
- #6
processor_id: 0
- #7
processor_id: 0
- #8
processor_id: 0
- #9
processor_id: 0
- #10
processor_id: 0
- #11
processor_id: 0
- #12
processor_id: 0
- #13
processor_id: 0
- #14
processor_id: 0
- #15
processor_id: 0
- #16
processor_id: 0
- #17
processor_id: 0
- #18
processor_id: 0
- #19
processor_id: 0
- #20
processor_id: 0
- #21
processor_id: 0
- #22
processor_id: 0
- #23
processor_id: 0
- #24
processor_id: 0
- #25
processor_id: 0
- #26
processor_id: 0
- #27
processor_id: 0
- #28
processor_id: 0
- #29
processor_id: 0
- #30
processor_id: 0
- #31
processor_id: 0
- #32
processor_id: 0
host_hierarchy:
subhdr:
magic: 0x8D27
- #1
host_id: 0
- #2
host_id: 0
- #3
host_id: 0
- #4
host_id: 0
- #5
host_id: 0
- #6
host_id: 0
- #7
host_id: 0
- #8
host_id: 0
- #9
host_id: 0
- #10
host_id: 0
- #11
host_id: 0
- #12
host_id: 0
- #13
host_id: 0
- #14
host_id: 0
- #15
host_id: 0
- #16
host_id: 0
- #17
host_id: 0
- #18
host_id: 0
- #19
host_id: 0
- #20
host_id: 0
- #21
host_id: 0
- #22
host_id: 0
- #23
host_id: 0
- #24
host_id: 0
- #25
host_id: 0
- #26
host_id: 0
- #27
host_id: 0
- #28
host_id: 0
- #29
host_id: 0
- #30
host_id: 0
- #31
host_id: 0
- #32
host_id: 0
otp_config:
subhdr:
magic: 0x4081
otp_entry:
- #1
host_id: 0
host_perms: 0
- #2
host_id: 0
host_perms: 0
- #3
host_id: 0
host_perms: 0
- #4
host_id: 0
host_perms: 0
- #5
host_id: 0
host_perms: 0
- #6
host_id: 0
host_perms: 0
- #7
host_id: 0
host_perms: 0
- #8
host_id: 0
host_perms: 0
- #9
host_id: 0
host_perms: 0
- #10
host_id: 0
host_perms: 0
- #11
host_id: 0
host_perms: 0
- #12
host_id: 0
host_perms: 0
- #13
host_id: 0
host_perms: 0
- #14
host_id: 0
host_perms: 0
- #15
host_id: 0
host_perms: 0
- #16
host_id: 0
host_perms: 0
- #17
host_id: 0
host_perms: 0
- #18
host_id: 0
host_perms: 0
- #19
host_id: 0
host_perms: 0
- #20
host_id: 0
host_perms: 0
- #21
host_id: 0
host_perms: 0
- #22
host_id: 0
host_perms: 0
- #23
host_id: 0
host_perms: 0
- #24
host_id: 0
host_perms: 0
- #25
host_id: 0
host_perms: 0
- #26
host_id: 0
host_perms: 0
- #27
host_id: 0
host_perms: 0
- #28
host_id: 0
host_perms: 0
- #29
host_id: 0
host_perms: 0
- #30
host_id: 0
host_perms: 0
- #31
host_id: 0
host_perms: 0
- #32
host_id: 0
host_perms: 0
write_host_id: 0
dkek_config:
subhdr:
magic: 0x5170
rsvd: [0, 0, 0]
sa2ul_cfg:
subhdr:
magic: 0x23BE
rsvd: [0, 0]
sec_dbg_config:
subhdr:
magic: 0x42AF
rsvd: 0
min_cert_rev: 0x0
sec_handover_cfg:
subhdr:
magic: 0x608F
rsvd: [0, 0, 0, 0]
... Applying: j721e: schema: yaml: Add general schema and J721E board config files .git/rebase-apply/patch:498: new blank line at EOF. + .git/rebase-apply/patch:517: new blank line at EOF. + .git/rebase-apply/patch:4084: new blank line at EOF. + warning: 3 lines add whitespace errors.
Jan
Hi Jan
Schema file in YAML must be provided in board/ti/common for validating input config files and packaging system firmware. The schema includes entries for rm-cfg, board-cfg, pm-cfg and sec-cfg.
Board config files must be provided in board/ti/<devicename> in YAML. These can then be consumed for generation of binaries to package system firmware. Added YAML configs for J721E in particular.
Signed-off-by: Tarun Sahu t-sahu@ti.com [n-francis@ti.com: prepared patch for upstreaming] Signed-off-by: Neha Malcom Francis n-francis@ti.com
board/ti/common/schema.yaml | 436 +++++ board/ti/j721e/board-cfg.yaml | 37 + board/ti/j721e/pm-cfg.yaml | 13 + board/ti/j721e/rm-cfg.yaml | 3174 +++++++++++++++++++++++++++++++++ board/ti/j721e/sec-cfg.yaml | 381 ++++ 5 files changed, 4041 insertions(+) create mode 100644 board/ti/common/schema.yaml create mode 100644 board/ti/j721e/board-cfg.yaml create mode 100644 board/ti/j721e/pm-cfg.yaml create mode 100644 board/ti/j721e/rm-cfg.yaml create mode 100644 board/ti/j721e/sec-cfg.yaml
diff --git a/board/ti/common/schema.yaml b/board/ti/common/schema.yaml new file mode 100644 index 0000000000..8023ecb0e0 --- /dev/null +++ b/board/ti/common/schema.yaml @@ -0,0 +1,436 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Config schema for TI K3 devices +#
+definitions:
- u8:
type: integer
minimum: 0
maximum: 0xff
- u16:
type: integer
minimum: 0
maximum: 0xffff
- u32:
type: integer
minimum: 0
maximum: 0xffffffff
+type: object +properties:
- pm-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
$ref: "#/definitions/u8"
boardcfg_abi_min:
- board-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
control:
type: object
properties:
subhdr:
type: object
properties:
magic:
$ref: "#/definitions/u16"
size:
main_isolation_enable:
main_isolation_hostid:
secproxy:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
scaling_factor:
scaling_profile:
disable_main_nav_secure_proxy:
msmc:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
msmc_cache_size:
debug_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
trace_dst_enables:
trace_src_enables:
- sec-cfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
processor_acl_list:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
proc_acl_entries:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
processor_id:
proc_access_master:
type: array
minItems: 3
maxItems: 3
items:
host_hierarchy:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
host_id:
supervisor_host_id:
otp_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
otp_entry:
type: array
minItems: 32
maxItems: 32
items:
type: object
properties:
host_id:
host_perms:
write_host_id:
dkek_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
allowed_hosts:
type: array
minItems: 4
maxItems: 4
items:
rsvd:
type: array
minItems: 3
maxItems: 3
items:
sa2ul_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
rsvd:
type: array
minItems: 2
maxItems: 4
items:
sec_dbg_config:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
allow_jtag_unlock:
rsvd:
min_cert_rev:
$ref: "#/definitions/u32"
jtag_unlock_hosts:
type: array
minItems: 4
maxItems: 4
items:
sec_handover_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
rsvd:
type: array
minItems: 4
maxItems: 4
items:
- rm-cfg:
type: object
properties:
rm_boardcfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
host_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
host_cfg_entries:
type: array
minItems: 0
maxItems: 32
items:
type: object
properties:
host_id:
allowed_atype:
allowed_qos:
allowed_orderid:
allowed_priority:
allowed_sched_priority:
resasg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
resasg_entries_size:
reserved:
resasg_entries:
type: array
minItems: 0
maxItems: 468
items:
type: object
properties:
start_resource:
num_resource:
type:
host_id:
reserved:
- tifs-rm-cfg:
type: object
properties:
rm_boardcfg:
type: object
properties:
rev:
type: object
properties:
boardcfg_abi_maj:
boardcfg_abi_min:
host_cfg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
host_cfg_entries:
type: array
minItems: 0
maxItems: 32
items:
type: object
properties:
host_id:
allowed_atype:
allowed_qos:
allowed_orderid:
allowed_priority:
resasg:
type: object
properties:
subhdr:
type: object
properties:
magic:
size:
reserved:
resasg_entries:
type: array
minItems: 0
maxItems: 468
items:
type: object
properties:
start_resource:
num_resource:
type:
host_id:
reserved:
diff --git a/board/ti/j721e/board-cfg.yaml b/board/ti/j721e/board-cfg.yaml new file mode 100644 index 0000000000..9f5e00b3dc --- /dev/null +++ b/board/ti/j721e/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721E +#
+board-cfg:
rev:
control:
subhdr:
magic: 0xC1D3
main_isolation_enable: 0x5A
main_isolation_hostid: 0x2
secproxy:
subhdr:
magic: 0x1207
scaling_factor: 0x1
scaling_profile: 0x1
disable_main_nav_secure_proxy: 0
msmc:
subhdr:
magic: 0xA5C3
msmc_cache_size: 0x0
debug_cfg:
subhdr:
magic: 0x020C
trace_dst_enables: 0x00
trace_src_enables: 0x00
diff --git a/board/ti/j721e/pm-cfg.yaml b/board/ti/j721e/pm-cfg.yaml new file mode 100644 index 0000000000..40a8dfb7af --- /dev/null +++ b/board/ti/j721e/pm-cfg.yaml @@ -0,0 +1,13 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J721E +#
+pm-cfg:
rev:
diff --git a/board/ti/j721e/rm-cfg.yaml b/board/ti/j721e/rm-cfg.yaml new file mode 100644 index 0000000000..39d276d9d5 --- /dev/null +++ b/board/ti/j721e/rm-cfg.yaml @@ -0,0 +1,3174 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J721E +#
+rm-cfg:
rm_boardcfg:
rev:
host_cfg:
subhdr:
magic: 0x4C41
host_cfg_entries:
- #1
host_id: 3
allowed_atype: 0x2A
allowed_qos: 0xAAAA
allowed_orderid: 0xAAAAAAAA
allowed_priority: 0xAAAA
allowed_sched_priority: 0xAA
- #2
host_id: 5
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #3
host_id: 12
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #4
host_id: 13
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #5
host_id: 21
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #6
host_id: 26
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #7
host_id: 28
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #8
host_id: 35
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #9
host_id: 37
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #10
host_id: 40
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #11
host_id: 42
allowed_atype: 0x2A
allowed_qos: 0xAAAA
- #12
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #13
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #14
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #15
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #16
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #17
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #18
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #19
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #20
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #21
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #22
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #23
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #24
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #25
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #26
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #27
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #28
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #29
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #30
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #31
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #32
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
resasg:
subhdr:
magic: 0x7B25
resasg_entries_size: 3344
reserved: 0
resasg_entries:
start_resource: 4
num_resource: 93
type: 7744
host_id: 26
reserved: 0
start_resource: 4
num_resource: 93
type: 7808
host_id: 28
reserved: 0
start_resource: 0
num_resource: 32
type: 7872
host_id: 128
reserved: 0
start_resource: 0
num_resource: 32
type: 8192
host_id: 3
reserved: 0
start_resource: 32
num_resource: 32
type: 8192
host_id: 5
reserved: 0
start_resource: 0
num_resource: 24
type: 8320
host_id: 3
reserved: 0
start_resource: 24
num_resource: 24
type: 8320
host_id: 5
reserved: 0
start_resource: 0
num_resource: 8
type: 8384
host_id: 3
reserved: 0
start_resource: 8
num_resource: 8
type: 8384
host_id: 5
reserved: 0
start_resource: 16
num_resource: 4
type: 8384
host_id: 40
reserved: 0
start_resource: 20
num_resource: 4
type: 8384
host_id: 42
reserved: 0
start_resource: 24
num_resource: 4
type: 8384
host_id: 35
reserved: 0
start_resource: 28
num_resource: 4
type: 8384
host_id: 37
reserved: 0
start_resource: 32
num_resource: 4
type: 8384
host_id: 26
reserved: 0
start_resource: 36
num_resource: 4
type: 8384
host_id: 28
reserved: 0
start_resource: 40
num_resource: 12
type: 8384
host_id: 12
reserved: 0
start_resource: 52
num_resource: 12
type: 8384
host_id: 13
reserved: 0
start_resource: 0
num_resource: 128
type: 8576
host_id: 35
reserved: 0
start_resource: 128
num_resource: 128
type: 8576
host_id: 37
reserved: 0
start_resource: 0
num_resource: 128
type: 8640
host_id: 40
reserved: 0
start_resource: 128
num_resource: 128
type: 8640
host_id: 42
reserved: 0
start_resource: 0
num_resource: 48
type: 8704
host_id: 128
reserved: 0
start_resource: 0
num_resource: 8
type: 8768
host_id: 3
reserved: 0
start_resource: 8
num_resource: 8
type: 8768
host_id: 5
reserved: 0
start_resource: 16
num_resource: 6
type: 8768
host_id: 12
reserved: 0
start_resource: 22
num_resource: 6
type: 8768
host_id: 13
reserved: 0
start_resource: 28
num_resource: 2
type: 8768
host_id: 35
reserved: 0
start_resource: 30
num_resource: 2
type: 8768
host_id: 37
reserved: 0
start_resource: 0
num_resource: 64
type: 13258
host_id: 128
reserved: 0
start_resource: 20480
num_resource: 1024
type: 13261
host_id: 128
reserved: 0
start_resource: 0
num_resource: 64
type: 13322
host_id: 128
reserved: 0
start_resource: 22528
num_resource: 1024
type: 13325
host_id: 128
reserved: 0
start_resource: 38
num_resource: 86
type: 13386
host_id: 12
reserved: 0
start_resource: 124
num_resource: 32
type: 13386
host_id: 13
reserved: 0
start_resource: 156
num_resource: 12
type: 13386
host_id: 40
reserved: 0
start_resource: 168
num_resource: 12
type: 13386
host_id: 42
reserved: 0
start_resource: 180
num_resource: 12
type: 13386
host_id: 21
reserved: 0
start_resource: 192
num_resource: 12
type: 13386
host_id: 26
reserved: 0
start_resource: 204
num_resource: 12
type: 13386
host_id: 28
reserved: 0
start_resource: 216
num_resource: 28
type: 13386
host_id: 35
reserved: 0
start_resource: 244
num_resource: 8
type: 13386
host_id: 37
reserved: 0
start_resource: 252
num_resource: 4
type: 13386
host_id: 128
reserved: 0
start_resource: 38
num_resource: 1024
type: 13389
host_id: 12
reserved: 0
start_resource: 1062
num_resource: 512
type: 13389
host_id: 13
reserved: 0
start_resource: 1574
num_resource: 32
type: 13389
host_id: 3
reserved: 0
start_resource: 1606
num_resource: 32
type: 13389
host_id: 5
reserved: 0
start_resource: 1638
num_resource: 256
type: 13389
host_id: 40
reserved: 0
start_resource: 1894
num_resource: 256
type: 13389
host_id: 42
reserved: 0
start_resource: 2150
num_resource: 256
type: 13389
host_id: 21
reserved: 0
start_resource: 2406
num_resource: 256
type: 13389
host_id: 26
reserved: 0
start_resource: 2662
num_resource: 256
type: 13389
host_id: 28
reserved: 0
start_resource: 2918
num_resource: 512
type: 13389
host_id: 35
reserved: 0
start_resource: 3430
num_resource: 256
type: 13389
host_id: 37
reserved: 0
start_resource: 3686
num_resource: 922
type: 13389
host_id: 128
reserved: 0
start_resource: 0
num_resource: 4
type: 13440
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13440
host_id: 13
reserved: 0
start_resource: 8
num_resource: 4
type: 13440
host_id: 3
reserved: 0
start_resource: 12
num_resource: 4
type: 13440
host_id: 5
reserved: 0
start_resource: 16
num_resource: 4
type: 13440
host_id: 40
reserved: 0
start_resource: 20
num_resource: 4
type: 13440
host_id: 42
reserved: 0
start_resource: 24
num_resource: 4
type: 13440
host_id: 21
reserved: 0
start_resource: 28
num_resource: 4
type: 13440
host_id: 26
reserved: 0
start_resource: 32
num_resource: 4
type: 13440
host_id: 28
reserved: 0
start_resource: 36
num_resource: 12
type: 13440
host_id: 35
reserved: 0
start_resource: 48
num_resource: 4
type: 13440
host_id: 37
reserved: 0
start_resource: 52
num_resource: 12
type: 13440
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13504
host_id: 128
reserved: 0
start_resource: 440
num_resource: 150
type: 13505
host_id: 12
reserved: 0
start_resource: 590
num_resource: 40
type: 13505
host_id: 13
reserved: 0
start_resource: 630
num_resource: 6
type: 13505
host_id: 3
reserved: 0
start_resource: 636
num_resource: 6
type: 13505
host_id: 5
reserved: 0
start_resource: 642
num_resource: 10
type: 13505
host_id: 40
reserved: 0
start_resource: 652
num_resource: 10
type: 13505
host_id: 42
reserved: 0
start_resource: 662
num_resource: 32
type: 13505
host_id: 21
reserved: 0
start_resource: 694
num_resource: 38
type: 13505
host_id: 26
reserved: 0
start_resource: 732
num_resource: 12
type: 13505
host_id: 28
reserved: 0
start_resource: 744
num_resource: 182
type: 13505
host_id: 35
reserved: 0
start_resource: 926
num_resource: 40
type: 13505
host_id: 37
reserved: 0
start_resource: 966
num_resource: 8
type: 13505
host_id: 128
reserved: 0
start_resource: 316
num_resource: 8
type: 13506
host_id: 12
reserved: 0
start_resource: 324
num_resource: 2
type: 13506
host_id: 3
reserved: 0
start_resource: 324
num_resource: 0
type: 13506
host_id: 13
reserved: 0
start_resource: 326
num_resource: 2
type: 13506
host_id: 5
reserved: 0
start_resource: 328
num_resource: 2
type: 13506
host_id: 40
reserved: 0
start_resource: 330
num_resource: 2
type: 13506
host_id: 42
reserved: 0
start_resource: 332
num_resource: 2
type: 13506
host_id: 21
reserved: 0
start_resource: 334
num_resource: 8
type: 13506
host_id: 26
reserved: 0
start_resource: 342
num_resource: 2
type: 13506
host_id: 28
reserved: 0
start_resource: 344
num_resource: 4
type: 13506
host_id: 35
reserved: 0
start_resource: 348
num_resource: 1
type: 13506
host_id: 37
reserved: 0
start_resource: 349
num_resource: 47
type: 13506
host_id: 12
reserved: 0
start_resource: 396
num_resource: 1
type: 13506
host_id: 13
reserved: 0
start_resource: 397
num_resource: 4
type: 13506
host_id: 40
reserved: 0
start_resource: 401
num_resource: 4
type: 13506
host_id: 42
reserved: 0
start_resource: 405
num_resource: 4
type: 13506
host_id: 21
reserved: 0
start_resource: 409
num_resource: 8
type: 13506
host_id: 26
reserved: 0
start_resource: 417
num_resource: 6
type: 13506
host_id: 28
reserved: 0
start_resource: 423
num_resource: 16
type: 13506
host_id: 35
reserved: 0
start_resource: 439
num_resource: 1
type: 13506
host_id: 37
reserved: 0
start_resource: 16
num_resource: 8
type: 13507
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13507
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13507
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13507
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13507
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13507
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13507
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13507
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13507
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13507
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13507
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13507
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13507
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13507
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13507
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13507
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13507
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13507
host_id: 28
reserved: 0
start_resource: 123
num_resource: 10
type: 13507
host_id: 35
reserved: 0
start_resource: 133
num_resource: 6
type: 13507
host_id: 37
reserved: 0
start_resource: 139
num_resource: 1
type: 13507
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13508
host_id: 21
reserved: 0
start_resource: 156
num_resource: 6
type: 13508
host_id: 26
reserved: 0
start_resource: 162
num_resource: 6
type: 13508
host_id: 28
reserved: 0
start_resource: 168
num_resource: 2
type: 13508
host_id: 35
reserved: 0
start_resource: 170
num_resource: 2
type: 13508
host_id: 37
reserved: 0
start_resource: 172
num_resource: 96
type: 13508
host_id: 35
reserved: 0
start_resource: 268
num_resource: 32
type: 13508
host_id: 37
reserved: 0
start_resource: 304
num_resource: 0
type: 13509
host_id: 12
reserved: 0
start_resource: 304
num_resource: 4
type: 13509
host_id: 12
reserved: 0
start_resource: 304
num_resource: 0
type: 13509
host_id: 35
reserved: 0
start_resource: 308
num_resource: 6
type: 13509
host_id: 35
reserved: 0
start_resource: 314
num_resource: 2
type: 13509
host_id: 128
reserved: 0
start_resource: 300
num_resource: 0
type: 13510
host_id: 12
reserved: 0
start_resource: 300
num_resource: 2
type: 13510
host_id: 12
reserved: 0
start_resource: 300
num_resource: 0
type: 13510
host_id: 35
reserved: 0
start_resource: 302
num_resource: 2
type: 13510
host_id: 35
reserved: 0
start_resource: 4
num_resource: 0
type: 13511
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13511
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13511
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13511
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13511
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13512
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13512
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13512
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13512
host_id: 35
reserved: 0
start_resource: 2
num_resource: 5
type: 13514
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 13514
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 13515
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 13515
host_id: 13
reserved: 0
start_resource: 5
num_resource: 1
type: 13515
host_id: 3
reserved: 0
start_resource: 6
num_resource: 1
type: 13515
host_id: 5
reserved: 0
start_resource: 7
num_resource: 3
type: 13515
host_id: 40
reserved: 0
start_resource: 10
num_resource: 3
type: 13515
host_id: 42
reserved: 0
start_resource: 13
num_resource: 3
type: 13515
host_id: 21
reserved: 0
start_resource: 16
num_resource: 3
type: 13515
host_id: 26
reserved: 0
start_resource: 19
num_resource: 3
type: 13515
host_id: 28
reserved: 0
start_resource: 22
num_resource: 6
type: 13515
host_id: 35
reserved: 0
start_resource: 28
num_resource: 3
type: 13515
host_id: 37
reserved: 0
start_resource: 31
num_resource: 1
type: 13515
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13568
host_id: 12
reserved: 0
start_resource: 156
num_resource: 16
type: 13568
host_id: 13
reserved: 0
start_resource: 172
num_resource: 128
type: 13568
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13569
host_id: 128
reserved: 0
start_resource: 49152
num_resource: 1024
type: 13570
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 13571
host_id: 128
reserved: 0
start_resource: 16
num_resource: 8
type: 13578
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13578
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13578
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13578
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13578
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13578
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13578
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13578
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13578
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13578
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13578
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13578
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13578
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13578
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13578
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13578
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13578
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13578
host_id: 28
reserved: 0
start_resource: 123
num_resource: 16
type: 13578
host_id: 35
reserved: 0
start_resource: 139
num_resource: 1
type: 13578
host_id: 37
reserved: 0
start_resource: 4
num_resource: 0
type: 13579
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13579
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13579
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13579
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13579
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13580
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13580
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13580
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13580
host_id: 35
reserved: 0
start_resource: 16
num_resource: 8
type: 13581
host_id: 12
reserved: 0
start_resource: 24
num_resource: 2
type: 13581
host_id: 3
reserved: 0
start_resource: 24
num_resource: 0
type: 13581
host_id: 13
reserved: 0
start_resource: 26
num_resource: 2
type: 13581
host_id: 5
reserved: 0
start_resource: 28
num_resource: 2
type: 13581
host_id: 40
reserved: 0
start_resource: 30
num_resource: 2
type: 13581
host_id: 42
reserved: 0
start_resource: 32
num_resource: 2
type: 13581
host_id: 21
reserved: 0
start_resource: 34
num_resource: 8
type: 13581
host_id: 26
reserved: 0
start_resource: 42
num_resource: 2
type: 13581
host_id: 28
reserved: 0
start_resource: 44
num_resource: 4
type: 13581
host_id: 35
reserved: 0
start_resource: 48
num_resource: 1
type: 13581
host_id: 37
reserved: 0
start_resource: 49
num_resource: 47
type: 13581
host_id: 12
reserved: 0
start_resource: 96
num_resource: 1
type: 13581
host_id: 13
reserved: 0
start_resource: 97
num_resource: 4
type: 13581
host_id: 40
reserved: 0
start_resource: 101
num_resource: 4
type: 13581
host_id: 42
reserved: 0
start_resource: 105
num_resource: 4
type: 13581
host_id: 21
reserved: 0
start_resource: 109
num_resource: 8
type: 13581
host_id: 26
reserved: 0
start_resource: 117
num_resource: 6
type: 13581
host_id: 28
reserved: 0
start_resource: 123
num_resource: 10
type: 13581
host_id: 35
reserved: 0
start_resource: 133
num_resource: 6
type: 13581
host_id: 37
reserved: 0
start_resource: 139
num_resource: 1
type: 13581
host_id: 128
reserved: 0
start_resource: 140
num_resource: 16
type: 13582
host_id: 21
reserved: 0
start_resource: 156
num_resource: 6
type: 13582
host_id: 26
reserved: 0
start_resource: 162
num_resource: 6
type: 13582
host_id: 28
reserved: 0
start_resource: 168
num_resource: 2
type: 13582
host_id: 35
reserved: 0
start_resource: 170
num_resource: 2
type: 13582
host_id: 37
reserved: 0
start_resource: 172
num_resource: 96
type: 13582
host_id: 35
reserved: 0
start_resource: 268
num_resource: 32
type: 13582
host_id: 37
reserved: 0
start_resource: 4
num_resource: 0
type: 13583
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 13583
host_id: 12
reserved: 0
start_resource: 4
num_resource: 0
type: 13583
host_id: 35
reserved: 0
start_resource: 8
num_resource: 6
type: 13583
host_id: 35
reserved: 0
start_resource: 14
num_resource: 2
type: 13583
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 13584
host_id: 12
reserved: 0
start_resource: 0
num_resource: 2
type: 13584
host_id: 12
reserved: 0
start_resource: 0
num_resource: 0
type: 13584
host_id: 35
reserved: 0
start_resource: 2
num_resource: 2
type: 13584
host_id: 35
reserved: 0
start_resource: 10
num_resource: 100
type: 13632
host_id: 12
reserved: 0
start_resource: 110
num_resource: 32
type: 13632
host_id: 13
reserved: 0
start_resource: 142
num_resource: 46
type: 13632
host_id: 21
reserved: 0
start_resource: 196
num_resource: 28
type: 13632
host_id: 35
reserved: 0
start_resource: 228
num_resource: 28
type: 13632
host_id: 37
reserved: 0
start_resource: 260
num_resource: 28
type: 13632
host_id: 40
reserved: 0
start_resource: 292
num_resource: 28
type: 13632
host_id: 42
reserved: 0
start_resource: 320
num_resource: 24
type: 13632
host_id: 26
reserved: 0
start_resource: 352
num_resource: 24
type: 13632
host_id: 28
reserved: 0
start_resource: 400
num_resource: 4
type: 13632
host_id: 3
reserved: 0
start_resource: 404
num_resource: 4
type: 13632
host_id: 5
reserved: 0
start_resource: 16
num_resource: 32
type: 14922
host_id: 12
reserved: 0
start_resource: 48
num_resource: 16
type: 14922
host_id: 13
reserved: 0
start_resource: 64
num_resource: 64
type: 14922
host_id: 3
reserved: 0
start_resource: 128
num_resource: 4
type: 14922
host_id: 5
reserved: 0
start_resource: 132
num_resource: 16
type: 14922
host_id: 40
reserved: 0
start_resource: 148
num_resource: 16
type: 14922
host_id: 42
reserved: 0
start_resource: 164
num_resource: 8
type: 14922
host_id: 21
reserved: 0
start_resource: 172
num_resource: 8
type: 14922
host_id: 26
reserved: 0
start_resource: 180
num_resource: 8
type: 14922
host_id: 28
reserved: 0
start_resource: 188
num_resource: 24
type: 14922
host_id: 35
reserved: 0
start_resource: 212
num_resource: 8
type: 14922
host_id: 37
reserved: 0
start_resource: 220
num_resource: 36
type: 14922
host_id: 128
reserved: 0
start_resource: 16400
num_resource: 128
type: 14925
host_id: 12
reserved: 0
start_resource: 16528
num_resource: 128
type: 14925
host_id: 13
reserved: 0
start_resource: 16656
num_resource: 256
type: 14925
host_id: 3
reserved: 0
start_resource: 16912
num_resource: 64
type: 14925
host_id: 5
reserved: 0
start_resource: 16976
num_resource: 128
type: 14925
host_id: 40
reserved: 0
start_resource: 17104
num_resource: 128
type: 14925
host_id: 42
reserved: 0
start_resource: 17232
num_resource: 64
type: 14925
host_id: 21
reserved: 0
start_resource: 17296
num_resource: 64
type: 14925
host_id: 26
reserved: 0
start_resource: 17360
num_resource: 64
type: 14925
host_id: 28
reserved: 0
start_resource: 17424
num_resource: 128
type: 14925
host_id: 35
reserved: 0
start_resource: 17552
num_resource: 128
type: 14925
host_id: 37
reserved: 0
start_resource: 17680
num_resource: 240
type: 14925
host_id: 128
reserved: 0
start_resource: 1
num_resource: 4
type: 14976
host_id: 12
reserved: 0
start_resource: 5
num_resource: 4
type: 14976
host_id: 13
reserved: 0
start_resource: 9
num_resource: 4
type: 14976
host_id: 3
reserved: 0
start_resource: 13
num_resource: 4
type: 14976
host_id: 5
reserved: 0
start_resource: 17
num_resource: 4
type: 14976
host_id: 40
reserved: 0
start_resource: 21
num_resource: 4
type: 14976
host_id: 42
reserved: 0
start_resource: 25
num_resource: 4
type: 14976
host_id: 21
reserved: 0
start_resource: 29
num_resource: 4
type: 14976
host_id: 26
reserved: 0
start_resource: 33
num_resource: 4
type: 14976
host_id: 28
reserved: 0
start_resource: 37
num_resource: 16
type: 14976
host_id: 35
reserved: 0
start_resource: 53
num_resource: 4
type: 14976
host_id: 37
reserved: 0
start_resource: 57
num_resource: 7
type: 14976
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15040
host_id: 128
reserved: 0
start_resource: 96
num_resource: 20
type: 15041
host_id: 12
reserved: 0
start_resource: 116
num_resource: 8
type: 15041
host_id: 13
reserved: 0
start_resource: 124
num_resource: 32
type: 15041
host_id: 3
reserved: 0
start_resource: 156
num_resource: 12
type: 15041
host_id: 5
reserved: 0
start_resource: 168
num_resource: 8
type: 15041
host_id: 40
reserved: 0
start_resource: 176
num_resource: 8
type: 15041
host_id: 42
reserved: 0
start_resource: 184
num_resource: 8
type: 15041
host_id: 21
reserved: 0
start_resource: 192
num_resource: 8
type: 15041
host_id: 26
reserved: 0
start_resource: 200
num_resource: 8
type: 15041
host_id: 28
reserved: 0
start_resource: 208
num_resource: 16
type: 15041
host_id: 35
reserved: 0
start_resource: 224
num_resource: 8
type: 15041
host_id: 37
reserved: 0
start_resource: 232
num_resource: 20
type: 15041
host_id: 128
reserved: 0
start_resource: 50
num_resource: 4
type: 15042
host_id: 12
reserved: 0
start_resource: 54
num_resource: 2
type: 15042
host_id: 3
reserved: 0
start_resource: 54
num_resource: 0
type: 15042
host_id: 13
reserved: 0
start_resource: 56
num_resource: 0
type: 15042
host_id: 5
reserved: 0
start_resource: 56
num_resource: 1
type: 15042
host_id: 40
reserved: 0
start_resource: 57
num_resource: 1
type: 15042
host_id: 42
reserved: 0
start_resource: 58
num_resource: 1
type: 15042
host_id: 21
reserved: 0
start_resource: 59
num_resource: 1
type: 15042
host_id: 26
reserved: 0
start_resource: 60
num_resource: 1
type: 15042
host_id: 28
reserved: 0
start_resource: 61
num_resource: 1
type: 15042
host_id: 35
reserved: 0
start_resource: 62
num_resource: 1
type: 15042
host_id: 37
reserved: 0
start_resource: 63
num_resource: 9
type: 15042
host_id: 12
reserved: 0
start_resource: 72
num_resource: 6
type: 15042
host_id: 13
reserved: 0
start_resource: 78
num_resource: 3
type: 15042
host_id: 3
reserved: 0
start_resource: 81
num_resource: 2
type: 15042
host_id: 5
reserved: 0
start_resource: 83
num_resource: 1
type: 15042
host_id: 40
reserved: 0
start_resource: 84
num_resource: 1
type: 15042
host_id: 42
reserved: 0
start_resource: 85
num_resource: 1
type: 15042
host_id: 21
reserved: 0
start_resource: 86
num_resource: 1
type: 15042
host_id: 26
reserved: 0
start_resource: 87
num_resource: 1
type: 15042
host_id: 28
reserved: 0
start_resource: 88
num_resource: 2
type: 15042
host_id: 35
reserved: 0
start_resource: 90
num_resource: 1
type: 15042
host_id: 37
reserved: 0
start_resource: 91
num_resource: 2
type: 15042
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 15043
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15043
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15043
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15043
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15043
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15043
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15043
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15043
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15043
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15043
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15043
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15043
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15043
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15043
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15043
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15043
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15043
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15043
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15043
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15043
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15043
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15043
host_id: 37
reserved: 0
start_resource: 43
num_resource: 3
type: 15043
host_id: 128
reserved: 0
start_resource: 48
num_resource: 0
type: 15045
host_id: 3
reserved: 0
start_resource: 48
num_resource: 2
type: 15045
host_id: 3
reserved: 0
start_resource: 0
num_resource: 0
type: 15047
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15047
host_id: 3
reserved: 0
start_resource: 2
num_resource: 5
type: 15050
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 15050
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 15051
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 15051
host_id: 13
reserved: 0
start_resource: 5
num_resource: 3
type: 15051
host_id: 3
reserved: 0
start_resource: 8
num_resource: 3
type: 15051
host_id: 5
reserved: 0
start_resource: 11
num_resource: 3
type: 15051
host_id: 40
reserved: 0
start_resource: 14
num_resource: 3
type: 15051
host_id: 42
reserved: 0
start_resource: 17
num_resource: 3
type: 15051
host_id: 21
reserved: 0
start_resource: 20
num_resource: 3
type: 15051
host_id: 26
reserved: 0
start_resource: 23
num_resource: 3
type: 15051
host_id: 28
reserved: 0
start_resource: 26
num_resource: 3
type: 15051
host_id: 35
reserved: 0
start_resource: 29
num_resource: 3
type: 15051
host_id: 37
reserved: 0
start_resource: 48
num_resource: 8
type: 15104
host_id: 12
reserved: 0
start_resource: 56
num_resource: 4
type: 15104
host_id: 13
reserved: 0
start_resource: 60
num_resource: 8
type: 15104
host_id: 3
reserved: 0
start_resource: 68
num_resource: 4
type: 15104
host_id: 5
reserved: 0
start_resource: 72
num_resource: 4
type: 15104
host_id: 40
reserved: 0
start_resource: 76
num_resource: 4
type: 15104
host_id: 42
reserved: 0
start_resource: 80
num_resource: 8
type: 15104
host_id: 35
reserved: 0
start_resource: 88
num_resource: 4
type: 15104
host_id: 37
reserved: 0
start_resource: 92
num_resource: 4
type: 15104
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15105
host_id: 128
reserved: 0
start_resource: 56320
num_resource: 256
type: 15106
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 15107
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 15114
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15114
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15114
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15114
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15114
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15114
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15114
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15114
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15114
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15114
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15114
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15114
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15114
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15114
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15114
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15114
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15114
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15114
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15114
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15114
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15114
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15114
host_id: 37
reserved: 0
start_resource: 43
num_resource: 2
type: 15114
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 15115
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15115
host_id: 3
reserved: 0
start_resource: 2
num_resource: 4
type: 15117
host_id: 12
reserved: 0
start_resource: 6
num_resource: 2
type: 15117
host_id: 3
reserved: 0
start_resource: 6
num_resource: 0
type: 15117
host_id: 13
reserved: 0
start_resource: 8
num_resource: 0
type: 15117
host_id: 5
reserved: 0
start_resource: 8
num_resource: 1
type: 15117
host_id: 40
reserved: 0
start_resource: 9
num_resource: 1
type: 15117
host_id: 42
reserved: 0
start_resource: 10
num_resource: 1
type: 15117
host_id: 21
reserved: 0
start_resource: 11
num_resource: 1
type: 15117
host_id: 26
reserved: 0
start_resource: 12
num_resource: 1
type: 15117
host_id: 28
reserved: 0
start_resource: 13
num_resource: 1
type: 15117
host_id: 35
reserved: 0
start_resource: 14
num_resource: 1
type: 15117
host_id: 37
reserved: 0
start_resource: 15
num_resource: 9
type: 15117
host_id: 12
reserved: 0
start_resource: 24
num_resource: 6
type: 15117
host_id: 13
reserved: 0
start_resource: 30
num_resource: 3
type: 15117
host_id: 3
reserved: 0
start_resource: 33
num_resource: 2
type: 15117
host_id: 5
reserved: 0
start_resource: 35
num_resource: 1
type: 15117
host_id: 40
reserved: 0
start_resource: 36
num_resource: 1
type: 15117
host_id: 42
reserved: 0
start_resource: 37
num_resource: 1
type: 15117
host_id: 21
reserved: 0
start_resource: 38
num_resource: 1
type: 15117
host_id: 26
reserved: 0
start_resource: 39
num_resource: 1
type: 15117
host_id: 28
reserved: 0
start_resource: 40
num_resource: 2
type: 15117
host_id: 35
reserved: 0
start_resource: 42
num_resource: 1
type: 15117
host_id: 37
reserved: 0
start_resource: 43
num_resource: 3
type: 15117
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 15119
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 15119
host_id: 3
reserved: 0
start_resource: 12
num_resource: 20
type: 15168
host_id: 3
reserved: 0
start_resource: 36
num_resource: 28
type: 15168
host_id: 5
reserved: 0
diff --git a/board/ti/j721e/sec-cfg.yaml b/board/ti/j721e/sec-cfg.yaml new file mode 100644 index 0000000000..dbaae99033 --- /dev/null +++ b/board/ti/j721e/sec-cfg.yaml @@ -0,0 +1,381 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for J721E +#
+sec-cfg:
rev:
boardcfg_abi_maj: 0x0
boardcfg_abi_min: 0x1
processor_acl_list:
subhdr:
magic: 0xF1EA
proc_acl_entries:
- #1
processor_id: 0
proc_access_master: 0
proc_access_secondary: [0, 0, 0]
- #2
processor_id: 0
- #3
processor_id: 0
- #4
processor_id: 0
- #5
processor_id: 0
- #6
processor_id: 0
- #7
processor_id: 0
- #8
processor_id: 0
- #9
processor_id: 0
- #10
processor_id: 0
- #11
processor_id: 0
- #12
processor_id: 0
- #13
processor_id: 0
- #14
processor_id: 0
- #15
processor_id: 0
- #16
processor_id: 0
- #17
processor_id: 0
- #18
processor_id: 0
- #19
processor_id: 0
- #20
processor_id: 0
- #21
processor_id: 0
- #22
processor_id: 0
- #23
processor_id: 0
- #24
processor_id: 0
- #25
processor_id: 0
- #26
processor_id: 0
- #27
processor_id: 0
- #28
processor_id: 0
- #29
processor_id: 0
- #30
processor_id: 0
- #31
processor_id: 0
- #32
processor_id: 0
host_hierarchy:
subhdr:
magic: 0x8D27
host_hierarchy_entries:
- #1
host_id: 0
supervisor_host_id: 0
- #2
host_id: 0
- #3
host_id: 0
- #4
host_id: 0
- #5
host_id: 0
- #6
host_id: 0
- #7
host_id: 0
- #8
host_id: 0
- #9
host_id: 0
- #10
host_id: 0
- #11
host_id: 0
- #12
host_id: 0
- #13
host_id: 0
- #14
host_id: 0
- #15
host_id: 0
- #16
host_id: 0
- #17
host_id: 0
- #18
host_id: 0
- #19
host_id: 0
- #20
host_id: 0
- #21
host_id: 0
- #22
host_id: 0
- #23
host_id: 0
- #24
host_id: 0
- #25
host_id: 0
- #26
host_id: 0
- #27
host_id: 0
- #28
host_id: 0
- #29
host_id: 0
- #30
host_id: 0
- #31
host_id: 0
- #32
host_id: 0
otp_config:
subhdr:
magic: 0x4081
otp_entry:
- #1
host_id: 0
host_perms: 0
- #2
host_id: 0
host_perms: 0
- #3
host_id: 0
host_perms: 0
- #4
host_id: 0
host_perms: 0
- #5
host_id: 0
host_perms: 0
- #6
host_id: 0
host_perms: 0
- #7
host_id: 0
host_perms: 0
- #8
host_id: 0
host_perms: 0
- #9
host_id: 0
host_perms: 0
- #10
host_id: 0
host_perms: 0
- #11
host_id: 0
host_perms: 0
- #12
host_id: 0
host_perms: 0
- #13
host_id: 0
host_perms: 0
- #14
host_id: 0
host_perms: 0
- #15
host_id: 0
host_perms: 0
- #16
host_id: 0
host_perms: 0
- #17
host_id: 0
host_perms: 0
- #18
host_id: 0
host_perms: 0
- #19
host_id: 0
host_perms: 0
- #20
host_id: 0
host_perms: 0
- #21
host_id: 0
host_perms: 0
- #22
host_id: 0
host_perms: 0
- #23
host_id: 0
host_perms: 0
- #24
host_id: 0
host_perms: 0
- #25
host_id: 0
host_perms: 0
- #26
host_id: 0
host_perms: 0
- #27
host_id: 0
host_perms: 0
- #28
host_id: 0
host_perms: 0
- #29
host_id: 0
host_perms: 0
- #30
host_id: 0
host_perms: 0
- #31
host_id: 0
host_perms: 0
- #32
host_id: 0
host_perms: 0
write_host_id: 0
dkek_config:
subhdr:
magic: 0x5170
allowed_hosts: [128, 0, 0, 0]
allow_dkek_export_tisci: 0x5A
rsvd: [0, 0, 0]
sa2ul_cfg:
subhdr:
magic: 0x23BE
auth_resource_owner: 0
enable_saul_psil_global_config_writes: 0
rsvd: [0, 0]
sec_dbg_config:
subhdr:
magic: 0x42AF
allow_jtag_unlock: 0x5A
allow_wildcard_unlock: 0x5A
allowed_debug_level_rsvd: 0
rsvd: 0
min_cert_rev: 0x0
jtag_unlock_hosts: [0, 0, 0, 0]
sec_handover_cfg:
subhdr:
magic: 0x608F
handover_msg_sender: 0
handover_to_host_id: 0
rsvd: [0, 0, 0, 0]
Jan
I hadn't seen these warnings when applying locally, will check and update accordingly.
By providing entries in the binman node of the device tree, binman will be able to find and package board config artifacts generated by TIBoardConfig with sysfw.bin and generate the final image sysfw.itb. It will also pick out the R5 SPL and sign it with the help of TI signing entry and generate the final tiboot3.bin.
Entries for A72 build have been added to k3-j721e-binman.dtsi to generate tispl.bin and u-boot.img.
Support has been added for both HS-SE(SR 1.1), HS-FS(SR 2.0) and GP images In HS-SE, the encrypted system firmware binary must be signed along with the signed certificate binary.
HS-SE: * tiboot3-j721e_sr1_1-hs-evm.bin * sysfw-j721e_sr1_1-hs-evm.itb * tispl.bin * u-boot.img
HS-FS: * tiboot3-j721e_sr2-hs-fs-evm.bin * sysfw-j721e_sr2-hs-fs-evm.itb * tispl.bin * u-boot.img
GP: * tiboot3.bin -->tiboot3-j721e-gp-evm.bin * sysfw.itb --> sysfw-j721e-gp-evm.itb * tispl.bin_unsigned * u-boot.img_unsigned
It is to be noted that the bootflow followed by J721E requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs
sysfw.itb: * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-j721e-binman.dtsi | 701 ++++++++++++++++++ .../k3-j721e-common-proc-board-u-boot.dtsi | 1 + .../arm/dts/k3-j721e-r5-common-proc-board.dts | 1 + arch/arm/dts/k3-j721e-sk-u-boot.dtsi | 1 + board/ti/j721e/Kconfig | 2 + 5 files changed, 706 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-binman.dtsi
diff --git a/arch/arm/dts/k3-j721e-binman.dtsi b/arch/arm/dts/k3-j721e-binman.dtsi new file mode 100644 index 0000000000..0455deb6ca --- /dev/null +++ b/arch/arm/dts/k3-j721e-binman.dtsi @@ -0,0 +1,701 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_J721E_R5_EVM + +&binman { + tiboot3-j721e_sr1_1-hs-evm.bin { + filename = "tiboot3-j721e_sr1_1-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + keyfile = "custMpk.pem"; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + }; + sysfw { + filename = "sysfw.bin"; + ti-secure-rom { + content = <&ti_fs_cert>; + core = "secure"; + load = <0x40000>; + keyfile = "custMpk.pem"; + countersign; + }; + ti_fs_cert: ti-fs-cert.bin { + filename = "ti-sysfw/ti-fs-firmware-j721e_sr1_1-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + ti-fs-firmware-j721e_sr1_1-hs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j721e_sr1_1-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + }; + itb { + filename = "sysfw-j721e_sr1_1-hs-evm.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&board_cfg>; + keyfile = "custMpk.pem"; + }; + board_cfg: board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&pm_cfg>; + keyfile = "custMpk.pem"; + }; + pm_cfg: pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&rm_cfg>; + keyfile = "custMpk.pem"; + }; + rm_cfg: rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&sec_cfg>; + keyfile = "custMpk.pem"; + }; + sec_cfg: sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +&binman { + tiboot3-j721e_sr2-hs-fs-evm.bin { + filename = "tiboot3-j721e_sr2-hs-fs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + }; + sysfw_fs { + filename = "sysfw.bin_fs"; + ti-fs-cert-fs.bin { + filename = "ti-sysfw/ti-fs-firmware-j721e_sr2-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + ti-fs-firmware-j721e-hs-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j721e_sr2-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + }; + itb_fs { + filename = "sysfw-j721e_sr2-hs-fs-evm.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_fs"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +&binman { + tiboot3-j721e-gp-evm.bin { + filename = "tiboot3-j721e-gp-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + }; + sysfw_gp { + filename = "sysfw.bin_gp"; + ti-secure-rom { + content = <&ti_fs>; + core = "secure"; + load = <0x40000>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + ti_fs: ti-fs.bin { + filename = "ti-sysfw/ti-fs-firmware-j721e-gp.bin"; + type = "blob-ext"; + optional; + }; + }; + itb_gp { + filename = "sysfw-j721e-gp-evm.itb"; + symlink = "sysfw.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_gp"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; +#endif + +#ifdef CONFIG_TARGET_J721E_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J721E_EVM_DTB "spl/dts/k3-j721e-common-proc-board.dtb" +#define SPL_J721E_SK_DTB "spl/dts/k3-j721e-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J721E_EVM_DTB "arch/arm/dts/k3-j721e-common-proc-board.dtb" +#define J721E_SK_DTB "arch/arm/dts/k3-j721e-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721e_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j721e_evm_dtb: blob-ext { + filename = SPL_J721E_EVM_DTB; + }; + }; + + fdt-1 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721e_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + spl_j721e_sk_dtb: blob-ext { + filename = SPL_J721E_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-j721e-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for j721e board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721e_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + j721e_evm_dtb: blob-ext { + filename = J721E_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721e_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + j721e_sk_dtb: blob-ext { + filename = J721E_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721e-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-j721e-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721E_EVM_DTB; + }; + }; + + fdt-1 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721E_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721e-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-j721e-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for j721e board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721E_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j721e-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721E_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721e-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-j721e-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi index 867ec2bb1a..540c847eb3 100644 --- a/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include <dt-bindings/net/ti-dp83867.h> +#include "k3-j721e-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index 1b40cf2580..32f71e9b6a 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -8,6 +8,7 @@ #include "k3-j721e-som-p0.dtsi" #include "k3-j721e-ddr-evm-lp4-4266.dtsi" #include "k3-j721e-ddr.dtsi" +#include "k3-j721e-binman.dtsi" #include <dt-bindings/phy/phy-cadence.h>
/ { diff --git a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi index 31f979f3bb..205dacff4d 100644 --- a/arch/arm/dts/k3-j721e-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-sk-u-boot.dtsi @@ -4,6 +4,7 @@ */
/ { chosen { diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index 84bca32712..4a127c4a10 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -13,6 +13,7 @@ config TARGET_J721E_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721E_R5_EVM bool "TI K3 based J721E EVM running on R5" @@ -22,6 +23,7 @@ config TARGET_J721E_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML configs for J7200
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/j721e/board-cfg_j7200.yaml | 36 + board/ti/j721e/pm-cfg_j7200.yaml | 12 + board/ti/j721e/rm-cfg_j7200.yaml | 2065 +++++++++++++++++++++++++++ board/ti/j721e/sec-cfg_j7200.yaml | 380 +++++ 4 files changed, 2493 insertions(+) create mode 100644 board/ti/j721e/board-cfg_j7200.yaml create mode 100644 board/ti/j721e/pm-cfg_j7200.yaml create mode 100644 board/ti/j721e/rm-cfg_j7200.yaml create mode 100644 board/ti/j721e/sec-cfg_j7200.yaml
diff --git a/board/ti/j721e/board-cfg_j7200.yaml b/board/ti/j721e/board-cfg_j7200.yaml new file mode 100644 index 0000000000..1453317ecb --- /dev/null +++ b/board/ti/j721e/board-cfg_j7200.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J7200 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/j721e/pm-cfg_j7200.yaml b/board/ti/j721e/pm-cfg_j7200.yaml new file mode 100644 index 0000000000..588a1d530d --- /dev/null +++ b/board/ti/j721e/pm-cfg_j7200.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J7200 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/j721e/rm-cfg_j7200.yaml b/board/ti/j721e/rm-cfg_j7200.yaml new file mode 100644 index 0000000000..66b589f370 --- /dev/null +++ b/board/ti/j721e/rm-cfg_j7200.yaml @@ -0,0 +1,2065 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J7200 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 35 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 37 + allowed_atype : 0b101010 + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #8 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #9 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #10 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #11 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 2048 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 32 + type: 8192 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 32 + type: 8192 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 8320 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 24 + type: 8320 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8384 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8384 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 8384 + host_id: 35 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 8384 + host_id: 37 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 8384 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 8384 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 48 + type: 8704 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8768 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8768 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 8768 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 8768 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13258 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 13261 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 13322 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 13325 + host_id: 128 + reserved: 0 + + - + start_resource: 18 + num_resource: 86 + type: 13386 + host_id: 12 + reserved: 0 + + - + start_resource: 104 + num_resource: 32 + type: 13386 + host_id: 13 + reserved: 0 + + - + start_resource: 136 + num_resource: 16 + type: 13386 + host_id: 3 + reserved: 0 + + - + start_resource: 152 + num_resource: 16 + type: 13386 + host_id: 5 + reserved: 0 + + - + start_resource: 168 + num_resource: 32 + type: 13386 + host_id: 35 + reserved: 0 + + - + start_resource: 200 + num_resource: 24 + type: 13386 + host_id: 37 + reserved: 0 + + - + start_resource: 224 + num_resource: 32 + type: 13386 + host_id: 128 + reserved: 0 + + - + start_resource: 18 + num_resource: 1024 + type: 13389 + host_id: 12 + reserved: 0 + + - + start_resource: 1042 + num_resource: 512 + type: 13389 + host_id: 13 + reserved: 0 + + - + start_resource: 1554 + num_resource: 128 + type: 13389 + host_id: 3 + reserved: 0 + + - + start_resource: 1682 + num_resource: 128 + type: 13389 + host_id: 5 + reserved: 0 + + - + start_resource: 1810 + num_resource: 256 + type: 13389 + host_id: 35 + reserved: 0 + + - + start_resource: 2066 + num_resource: 512 + type: 13389 + host_id: 37 + reserved: 0 + + - + start_resource: 2578 + num_resource: 2030 + type: 13389 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 13440 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13440 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 13440 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 13440 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 13440 + host_id: 35 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 13440 + host_id: 37 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 13440 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13504 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 200 + type: 13505 + host_id: 12 + reserved: 0 + + - + start_resource: 320 + num_resource: 40 + type: 13505 + host_id: 13 + reserved: 0 + + - + start_resource: 360 + num_resource: 32 + type: 13505 + host_id: 3 + reserved: 0 + + - + start_resource: 392 + num_resource: 32 + type: 13505 + host_id: 5 + reserved: 0 + + - + start_resource: 424 + num_resource: 256 + type: 13505 + host_id: 35 + reserved: 0 + + - + start_resource: 680 + num_resource: 256 + type: 13505 + host_id: 37 + reserved: 0 + + - + start_resource: 936 + num_resource: 38 + type: 13505 + host_id: 128 + reserved: 0 + + - + start_resource: 64 + num_resource: 4 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 68 + num_resource: 2 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 70 + num_resource: 2 + type: 13506 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 2 + type: 13506 + host_id: 5 + reserved: 0 + + - + start_resource: 74 + num_resource: 2 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 76 + num_resource: 2 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 78 + num_resource: 20 + type: 13506 + host_id: 12 + reserved: 0 + + - + start_resource: 98 + num_resource: 4 + type: 13506 + host_id: 13 + reserved: 0 + + - + start_resource: 102 + num_resource: 8 + type: 13506 + host_id: 35 + reserved: 0 + + - + start_resource: 110 + num_resource: 8 + type: 13506 + host_id: 37 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 13506 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13507 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13507 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13507 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13507 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13507 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13507 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13507 + host_id: 128 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 62 + num_resource: 1 + type: 13509 + host_id: 12 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 63 + num_resource: 1 + type: 13509 + host_id: 35 + reserved: 0 + + - + start_resource: 60 + num_resource: 0 + type: 13510 + host_id: 37 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 13510 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13511 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13511 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13512 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13512 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13514 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13514 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 13515 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 13515 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 1 + type: 13515 + host_id: 3 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 13515 + host_id: 5 + reserved: 0 + + - + start_resource: 7 + num_resource: 16 + type: 13515 + host_id: 35 + reserved: 0 + + - + start_resource: 23 + num_resource: 8 + type: 13515 + host_id: 37 + reserved: 0 + + - + start_resource: 31 + num_resource: 1 + type: 13515 + host_id: 128 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 13568 + host_id: 12 + reserved: 0 + + - + start_resource: 68 + num_resource: 8 + type: 13568 + host_id: 13 + reserved: 0 + + - + start_resource: 76 + num_resource: 8 + type: 13568 + host_id: 37 + reserved: 0 + + - + start_resource: 84 + num_resource: 66 + type: 13568 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13569 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 13570 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 13571 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13578 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13578 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13578 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13578 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13578 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13578 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13578 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13579 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13579 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13580 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13580 + host_id: 37 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 13581 + host_id: 3 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 13581 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 2 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 18 + num_resource: 20 + type: 13581 + host_id: 12 + reserved: 0 + + - + start_resource: 38 + num_resource: 4 + type: 13581 + host_id: 13 + reserved: 0 + + - + start_resource: 42 + num_resource: 8 + type: 13581 + host_id: 35 + reserved: 0 + + - + start_resource: 50 + num_resource: 8 + type: 13581 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 2 + type: 13581 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 13583 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 13583 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 13584 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 13584 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 128 + type: 13632 + host_id: 12 + reserved: 0 + + - + start_resource: 138 + num_resource: 54 + type: 13632 + host_id: 13 + reserved: 0 + + - + start_resource: 196 + num_resource: 28 + type: 13632 + host_id: 35 + reserved: 0 + + - + start_resource: 228 + num_resource: 28 + type: 13632 + host_id: 37 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 13632 + host_id: 3 + reserved: 0 + + - + start_resource: 404 + num_resource: 4 + type: 13632 + host_id: 5 + reserved: 0 + + - + start_resource: 15 + num_resource: 32 + type: 14922 + host_id: 12 + reserved: 0 + + - + start_resource: 47 + num_resource: 16 + type: 14922 + host_id: 13 + reserved: 0 + + - + start_resource: 63 + num_resource: 64 + type: 14922 + host_id: 3 + reserved: 0 + + - + start_resource: 127 + num_resource: 32 + type: 14922 + host_id: 5 + reserved: 0 + + - + start_resource: 159 + num_resource: 16 + type: 14922 + host_id: 35 + reserved: 0 + + - + start_resource: 175 + num_resource: 16 + type: 14922 + host_id: 37 + reserved: 0 + + - + start_resource: 191 + num_resource: 65 + type: 14922 + host_id: 128 + reserved: 0 + + - + start_resource: 16399 + num_resource: 128 + type: 14925 + host_id: 12 + reserved: 0 + + - + start_resource: 16527 + num_resource: 128 + type: 14925 + host_id: 13 + reserved: 0 + + - + start_resource: 16655 + num_resource: 256 + type: 14925 + host_id: 3 + reserved: 0 + + - + start_resource: 16911 + num_resource: 128 + type: 14925 + host_id: 5 + reserved: 0 + + - + start_resource: 17039 + num_resource: 128 + type: 14925 + host_id: 35 + reserved: 0 + + - + start_resource: 17167 + num_resource: 128 + type: 14925 + host_id: 37 + reserved: 0 + + - + start_resource: 17295 + num_resource: 625 + type: 14925 + host_id: 128 + reserved: 0 + + - + start_resource: 1 + num_resource: 8 + type: 14976 + host_id: 12 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 14976 + host_id: 13 + reserved: 0 + + - + start_resource: 13 + num_resource: 16 + type: 14976 + host_id: 3 + reserved: 0 + + - + start_resource: 29 + num_resource: 16 + type: 14976 + host_id: 5 + reserved: 0 + + - + start_resource: 45 + num_resource: 8 + type: 14976 + host_id: 35 + reserved: 0 + + - + start_resource: 53 + num_resource: 8 + type: 14976 + host_id: 37 + reserved: 0 + + - + start_resource: 61 + num_resource: 3 + type: 14976 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15040 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 32 + type: 15041 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 15041 + host_id: 13 + reserved: 0 + + - + start_resource: 144 + num_resource: 32 + type: 15041 + host_id: 3 + reserved: 0 + + - + start_resource: 176 + num_resource: 32 + type: 15041 + host_id: 5 + reserved: 0 + + - + start_resource: 208 + num_resource: 16 + type: 15041 + host_id: 35 + reserved: 0 + + - + start_resource: 224 + num_resource: 16 + type: 15041 + host_id: 37 + reserved: 0 + + - + start_resource: 240 + num_resource: 12 + type: 15041 + host_id: 128 + reserved: 0 + + - + start_resource: 50 + num_resource: 3 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 53 + num_resource: 2 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 2 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 57 + num_resource: 2 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 59 + num_resource: 2 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 61 + num_resource: 2 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 63 + num_resource: 9 + type: 15042 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 4 + type: 15042 + host_id: 13 + reserved: 0 + + - + start_resource: 76 + num_resource: 4 + type: 15042 + host_id: 3 + reserved: 0 + + - + start_resource: 80 + num_resource: 4 + type: 15042 + host_id: 5 + reserved: 0 + + - + start_resource: 84 + num_resource: 4 + type: 15042 + host_id: 35 + reserved: 0 + + - + start_resource: 88 + num_resource: 4 + type: 15042 + host_id: 37 + reserved: 0 + + - + start_resource: 92 + num_resource: 1 + type: 15042 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15043 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15043 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15043 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15043 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15043 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15043 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 2 + type: 15043 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 15045 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 1 + type: 15045 + host_id: 12 + reserved: 0 + + - + start_resource: 49 + num_resource: 1 + type: 15045 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15047 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15047 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15047 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 15050 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 15050 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 15051 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 15051 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 6 + type: 15051 + host_id: 3 + reserved: 0 + + - + start_resource: 11 + num_resource: 6 + type: 15051 + host_id: 5 + reserved: 0 + + - + start_resource: 17 + num_resource: 5 + type: 15051 + host_id: 35 + reserved: 0 + + - + start_resource: 22 + num_resource: 5 + type: 15051 + host_id: 37 + reserved: 0 + + - + start_resource: 27 + num_resource: 5 + type: 15051 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 8 + type: 15104 + host_id: 12 + reserved: 0 + + - + start_resource: 56 + num_resource: 4 + type: 15104 + host_id: 13 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 15104 + host_id: 3 + reserved: 0 + + - + start_resource: 68 + num_resource: 4 + type: 15104 + host_id: 5 + reserved: 0 + + - + start_resource: 72 + num_resource: 8 + type: 15104 + host_id: 35 + reserved: 0 + + - + start_resource: 80 + num_resource: 4 + type: 15104 + host_id: 37 + reserved: 0 + + - + start_resource: 84 + num_resource: 12 + type: 15104 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15105 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 15106 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15107 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15114 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15114 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15114 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15114 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15114 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15114 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 1 + type: 15114 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15115 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15115 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15115 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 3 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 2 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 9 + num_resource: 2 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 11 + num_resource: 2 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 15 + num_resource: 9 + type: 15117 + host_id: 12 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 15117 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 15117 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 15117 + host_id: 5 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 15117 + host_id: 35 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 15117 + host_id: 37 + reserved: 0 + + - + start_resource: 44 + num_resource: 2 + type: 15117 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 15119 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 15119 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 15119 + host_id: 3 + reserved: 0 + + - + start_resource: 11 + num_resource: 20 + type: 15168 + host_id: 3 + reserved: 0 + + - + start_resource: 36 + num_resource: 28 + type: 15168 + host_id: 5 + reserved: 0 diff --git a/board/ti/j721e/sec-cfg_j7200.yaml b/board/ti/j721e/sec-cfg_j7200.yaml new file mode 100644 index 0000000000..69038834c0 --- /dev/null +++ b/board/ti/j721e/sec-cfg_j7200.yaml @@ -0,0 +1,380 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for J7200 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0 + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd : 0 + rsvd : 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support has been added for both HS-SE(SR 2.0), HS-FS(SR 2.0) and GP images.
HS-SE: * tiboot3-j7200_sr2-hs-evm.bin * tispl.bin * u-boot.img
HS-FS: * tiboot3-j7200_sr2-hs-fs-evm.bin * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-j7200-gp-evm.bin * tispl.bin_unsigned * u-boot.img_unsigned
It is to be noted that the bootflow followed by J7200 requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-j7200-binman.dtsi | 502 ++++++++++++++++++ .../k3-j7200-common-proc-board-u-boot.dtsi | 2 + board/ti/j721e/Kconfig | 2 + 3 files changed, 506 insertions(+) create mode 100644 arch/arm/dts/k3-j7200-binman.dtsi
diff --git a/arch/arm/dts/k3-j7200-binman.dtsi b/arch/arm/dts/k3-j7200-binman.dtsi new file mode 100644 index 0000000000..61bf576970 --- /dev/null +++ b/arch/arm/dts/k3-j7200-binman.dtsi @@ -0,0 +1,502 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_J7200_R5_EVM + +&bcfg_yaml { + config = "board-cfg_j7200.yaml"; +}; + +&rcfg_yaml { + config = "rm-cfg_j7200.yaml"; +}; + +&pcfg_yaml { + config = "pm-cfg_j7200.yaml"; +}; + +&scfg_yaml { + config = "sec-cfg_j7200.yaml"; +}; + +&bcfg_yaml_tifs { + config = "board-cfg_j7200.yaml"; +}; + +&rcfg_yaml_tifs { + config = "rm-cfg_j7200.yaml"; +}; + +&pcfg_yaml_tifs { + config = "pm-cfg_j7200.yaml"; +}; + +&scfg_yaml_tifs { + config = "sec-cfg_j7200.yaml"; +}; + +&rcfg_yaml_dm { + config = "rm-cfg_j7200.yaml"; +}; + +&pcfg_yaml_dm { + config = "pm-cfg_j7200.yaml"; +}; + +&binman { + tiboot3-j7200_sr2-hs-evm.bin { + filename = "tiboot3-j7200_sr2-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x7f000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j7200_sr2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-j7200_sr2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-j7200_sr2-hs-fs-evm.bin { + filename = "tiboot3-j7200_sr2-hs-fs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x7f000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j7200_sr2-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-j7200_sr2-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-j7200-gp-evm.bin { + filename = "tiboot3-j7200-gp-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x41c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x7f000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x41c80000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-j7200-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_J7200_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J7200_EVM_DTB "spl/dts/k3-j7200-common-proc-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J7200_EVM_DTB "arch/arm/dts/k3-j7200-common-proc-board.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/j7200/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j7200_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j7200_evm_dtb: blob-ext { + filename = SPL_J7200_EVM_DTB; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j7200-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J7200 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j7200_evm_dtb>; + keyfile = "custMpk.pem"; + }; + j7200_evm_dtb: blob-ext { + filename = J7200_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j7200-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = SPL_NODTB; + }; + }; + + fdt-1 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J7200_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j7200-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J7200 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-j7200-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J7200_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-1"; + + conf-1 { + description = "k3-j7200-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f57c2306ba..f25c7136c9 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-j7200-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/board/ti/j721e/Kconfig b/board/ti/j721e/Kconfig index 4a127c4a10..e6cb21f77b 100644 --- a/board/ti/j721e/Kconfig +++ b/board/ti/j721e/Kconfig @@ -33,6 +33,7 @@ config TARGET_J7200_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J7200_R5_EVM bool "TI K3 based J7200 EVM running on R5" @@ -42,6 +43,7 @@ config TARGET_J7200_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML configs for AM65x
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am65x/board-cfg.yaml | 36 + board/ti/am65x/pm-cfg.yaml | 12 + board/ti/am65x/rm-cfg.yaml | 2068 +++++++++++++++++++++++++++++++++ board/ti/am65x/sec-cfg.yaml | 379 ++++++ 4 files changed, 2495 insertions(+) create mode 100644 board/ti/am65x/board-cfg.yaml create mode 100644 board/ti/am65x/pm-cfg.yaml create mode 100644 board/ti/am65x/rm-cfg.yaml create mode 100644 board/ti/am65x/sec-cfg.yaml
diff --git a/board/ti/am65x/board-cfg.yaml b/board/ti/am65x/board-cfg.yaml new file mode 100644 index 0000000000..133720ec3e --- /dev/null +++ b/board/ti/am65x/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM65x +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am65x/pm-cfg.yaml b/board/ti/am65x/pm-cfg.yaml new file mode 100644 index 0000000000..4b1ce475cd --- /dev/null +++ b/board/ti/am65x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM65x +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am65x/rm-cfg.yaml b/board/ti/am65x/rm-cfg.yaml new file mode 100644 index 0000000000..61acd0aa60 --- /dev/null +++ b/board/ti/am65x/rm-cfg.yaml @@ -0,0 +1,2068 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM65x +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 2080 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 12 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 192 + host_id: 13 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 192 + host_id: 3 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 192 + host_id: 4 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 192 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 6208 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 32 + type: 6208 + host_id: 4 + reserved: 0 + + - + start_resource: 32 + num_resource: 32 + type: 6208 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 6272 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 6272 + host_id: 4 + reserved: 0 + + - + start_resource: 24 + num_resource: 24 + type: 6272 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 20 + type: 6400 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 6400 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 6400 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 6400 + host_id: 4 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 6400 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 9280 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 9280 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 9280 + host_id: 5 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 9280 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 9984 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 9984 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 9984 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 9984 + host_id: 4 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 9984 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 80 + type: 11466 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 30 + type: 11466 + host_id: 13 + reserved: 0 + + - + start_resource: 126 + num_resource: 50 + type: 11466 + host_id: 3 + reserved: 0 + + - + start_resource: 126 + num_resource: 50 + type: 11466 + host_id: 4 + reserved: 0 + + - + start_resource: 176 + num_resource: 50 + type: 11466 + host_id: 5 + reserved: 0 + + - + start_resource: 226 + num_resource: 30 + type: 11466 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 1024 + type: 11469 + host_id: 12 + reserved: 0 + + - + start_resource: 1040 + num_resource: 512 + type: 11469 + host_id: 13 + reserved: 0 + + - + start_resource: 1552 + num_resource: 512 + type: 11469 + host_id: 3 + reserved: 0 + + - + start_resource: 1552 + num_resource: 512 + type: 11469 + host_id: 4 + reserved: 0 + + - + start_resource: 2064 + num_resource: 512 + type: 11469 + host_id: 5 + reserved: 0 + + - + start_resource: 2576 + num_resource: 2032 + type: 11469 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 11530 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 11533 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 11594 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 11597 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 11648 + host_id: 12 + reserved: 0 + + - + start_resource: 80 + num_resource: 40 + type: 11648 + host_id: 13 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 11648 + host_id: 3 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 11648 + host_id: 4 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 11648 + host_id: 5 + reserved: 0 + + - + start_resource: 128 + num_resource: 24 + type: 11648 + host_id: 128 + reserved: 0 + + - + start_resource: 1 + num_resource: 12 + type: 11840 + host_id: 12 + reserved: 0 + + - + start_resource: 13 + num_resource: 4 + type: 11840 + host_id: 13 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 11840 + host_id: 3 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 11840 + host_id: 4 + reserved: 0 + + - + start_resource: 33 + num_resource: 16 + type: 11840 + host_id: 5 + reserved: 0 + + - + start_resource: 49 + num_resource: 15 + type: 11840 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 11968 + host_id: 128 + reserved: 0 + + - + start_resource: 304 + num_resource: 100 + type: 11969 + host_id: 12 + reserved: 0 + + - + start_resource: 404 + num_resource: 50 + type: 11969 + host_id: 13 + reserved: 0 + + - + start_resource: 454 + num_resource: 256 + type: 11969 + host_id: 3 + reserved: 0 + + - + start_resource: 454 + num_resource: 256 + type: 11969 + host_id: 4 + reserved: 0 + + - + start_resource: 710 + num_resource: 32 + type: 11969 + host_id: 5 + reserved: 0 + + - + start_resource: 742 + num_resource: 26 + type: 11969 + host_id: 128 + reserved: 0 + + - + start_resource: 160 + num_resource: 12 + type: 11970 + host_id: 12 + reserved: 0 + + - + start_resource: 172 + num_resource: 4 + type: 11970 + host_id: 3 + reserved: 0 + + - + start_resource: 172 + num_resource: 4 + type: 11970 + host_id: 4 + reserved: 0 + + - + start_resource: 172 + num_resource: 0 + type: 11970 + host_id: 13 + reserved: 0 + + - + start_resource: 176 + num_resource: 2 + type: 11970 + host_id: 5 + reserved: 0 + + - + start_resource: 178 + num_resource: 52 + type: 11970 + host_id: 12 + reserved: 0 + + - + start_resource: 230 + num_resource: 8 + type: 11970 + host_id: 13 + reserved: 0 + + - + start_resource: 238 + num_resource: 32 + type: 11970 + host_id: 3 + reserved: 0 + + - + start_resource: 238 + num_resource: 32 + type: 11970 + host_id: 4 + reserved: 0 + + - + start_resource: 270 + num_resource: 14 + type: 11970 + host_id: 5 + reserved: 0 + + - + start_resource: 284 + num_resource: 18 + type: 11970 + host_id: 128 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 11971 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 11971 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 11971 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 11971 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 11971 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 38 + type: 11971 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 8 + type: 11971 + host_id: 13 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 11971 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 11971 + host_id: 4 + reserved: 0 + + - + start_resource: 104 + num_resource: 14 + type: 11971 + host_id: 5 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 11971 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 11972 + host_id: 12 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 11972 + host_id: 13 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 11972 + host_id: 3 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 11972 + host_id: 4 + reserved: 0 + + - + start_resource: 140 + num_resource: 12 + type: 11972 + host_id: 5 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 11973 + host_id: 3 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 11973 + host_id: 4 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 11973 + host_id: 5 + reserved: 0 + + - + start_resource: 154 + num_resource: 0 + type: 11973 + host_id: 12 + reserved: 0 + + - + start_resource: 154 + num_resource: 2 + type: 11973 + host_id: 12 + reserved: 0 + + - + start_resource: 156 + num_resource: 2 + type: 11973 + host_id: 3 + reserved: 0 + + - + start_resource: 156 + num_resource: 2 + type: 11973 + host_id: 4 + reserved: 0 + + - + start_resource: 158 + num_resource: 2 + type: 11973 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 11975 + host_id: 3 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 11975 + host_id: 4 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 11975 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 11975 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 3 + type: 11975 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 11975 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 11975 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 11975 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 11978 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 11978 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 11979 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 11979 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 11979 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 11979 + host_id: 5 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 11979 + host_id: 128 + reserved: 0 + + - + start_resource: 150 + num_resource: 64 + type: 12032 + host_id: 12 + reserved: 0 + + - + start_resource: 214 + num_resource: 8 + type: 12032 + host_id: 13 + reserved: 0 + + - + start_resource: 222 + num_resource: 64 + type: 12032 + host_id: 3 + reserved: 0 + + - + start_resource: 222 + num_resource: 64 + type: 12032 + host_id: 4 + reserved: 0 + + - + start_resource: 286 + num_resource: 8 + type: 12032 + host_id: 5 + reserved: 0 + + - + start_resource: 294 + num_resource: 6 + type: 12032 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12033 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 12034 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12035 + host_id: 128 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 12042 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 12042 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 12042 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 12042 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 12042 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 52 + type: 12042 + host_id: 12 + reserved: 0 + + - + start_resource: 78 + num_resource: 8 + type: 12042 + host_id: 13 + reserved: 0 + + - + start_resource: 86 + num_resource: 32 + type: 12042 + host_id: 3 + reserved: 0 + + - + start_resource: 86 + num_resource: 32 + type: 12042 + host_id: 4 + reserved: 0 + + - + start_resource: 118 + num_resource: 14 + type: 12042 + host_id: 5 + reserved: 0 + + - + start_resource: 132 + num_resource: 18 + type: 12042 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 12043 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 12043 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 12043 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 0 + type: 12043 + host_id: 12 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 12043 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 12043 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 12043 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 12043 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 12 + type: 12045 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 12045 + host_id: 3 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 12045 + host_id: 4 + reserved: 0 + + - + start_resource: 20 + num_resource: 0 + type: 12045 + host_id: 13 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 12045 + host_id: 5 + reserved: 0 + + - + start_resource: 26 + num_resource: 38 + type: 12045 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 8 + type: 12045 + host_id: 13 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 12045 + host_id: 3 + reserved: 0 + + - + start_resource: 72 + num_resource: 32 + type: 12045 + host_id: 4 + reserved: 0 + + - + start_resource: 104 + num_resource: 14 + type: 12045 + host_id: 5 + reserved: 0 + + - + start_resource: 118 + num_resource: 2 + type: 12045 + host_id: 128 + reserved: 0 + + - + start_resource: 120 + num_resource: 4 + type: 12046 + host_id: 12 + reserved: 0 + + - + start_resource: 124 + num_resource: 4 + type: 12046 + host_id: 13 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 12046 + host_id: 3 + reserved: 0 + + - + start_resource: 128 + num_resource: 12 + type: 12046 + host_id: 4 + reserved: 0 + + - + start_resource: 140 + num_resource: 12 + type: 12046 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 12047 + host_id: 3 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 12047 + host_id: 4 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 12047 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 0 + type: 12047 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 3 + type: 12047 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 12047 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 2 + type: 12047 + host_id: 4 + reserved: 0 + + - + start_resource: 6 + num_resource: 2 + type: 12047 + host_id: 5 + reserved: 0 + + - + start_resource: 8 + num_resource: 80 + type: 12106 + host_id: 12 + reserved: 0 + + - + start_resource: 88 + num_resource: 30 + type: 12106 + host_id: 13 + reserved: 0 + + - + start_resource: 118 + num_resource: 50 + type: 12106 + host_id: 3 + reserved: 0 + + - + start_resource: 118 + num_resource: 50 + type: 12106 + host_id: 4 + reserved: 0 + + - + start_resource: 168 + num_resource: 50 + type: 12106 + host_id: 5 + reserved: 0 + + - + start_resource: 218 + num_resource: 38 + type: 12106 + host_id: 128 + reserved: 0 + + - + start_resource: 16392 + num_resource: 512 + type: 12109 + host_id: 12 + reserved: 0 + + - + start_resource: 16904 + num_resource: 128 + type: 12109 + host_id: 13 + reserved: 0 + + - + start_resource: 17032 + num_resource: 256 + type: 12109 + host_id: 3 + reserved: 0 + + - + start_resource: 17032 + num_resource: 256 + type: 12109 + host_id: 4 + reserved: 0 + + - + start_resource: 17288 + num_resource: 256 + type: 12109 + host_id: 5 + reserved: 0 + + - + start_resource: 17544 + num_resource: 376 + type: 12109 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 28 + type: 12160 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 28 + type: 12160 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 28 + type: 12160 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 12224 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 12224 + host_id: 13 + reserved: 0 + + - + start_resource: 16 + num_resource: 24 + type: 12224 + host_id: 3 + reserved: 0 + + - + start_resource: 16 + num_resource: 24 + type: 12224 + host_id: 4 + reserved: 0 + + - + start_resource: 40 + num_resource: 24 + type: 12224 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 12416 + host_id: 12 + reserved: 0 + + - + start_resource: 64 + num_resource: 4 + type: 12416 + host_id: 13 + reserved: 0 + + - + start_resource: 68 + num_resource: 16 + type: 12416 + host_id: 3 + reserved: 0 + + - + start_resource: 68 + num_resource: 16 + type: 12416 + host_id: 4 + reserved: 0 + + - + start_resource: 84 + num_resource: 8 + type: 12416 + host_id: 5 + reserved: 0 + + - + start_resource: 92 + num_resource: 4 + type: 12416 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12417 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 12418 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12419 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 12426 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12426 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12426 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 12426 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 12426 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 12426 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 12426 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12426 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12426 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 12426 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12427 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12427 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12427 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12427 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 12429 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12429 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12429 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 12429 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 12429 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 12429 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 12429 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12429 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12429 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 12429 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12431 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12431 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12431 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12431 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12480 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 32 + type: 12481 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 8 + type: 12481 + host_id: 13 + reserved: 0 + + - + start_resource: 136 + num_resource: 60 + type: 12481 + host_id: 3 + reserved: 0 + + - + start_resource: 136 + num_resource: 60 + type: 12481 + host_id: 4 + reserved: 0 + + - + start_resource: 196 + num_resource: 60 + type: 12481 + host_id: 5 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 12482 + host_id: 12 + reserved: 0 + + - + start_resource: 52 + num_resource: 4 + type: 12482 + host_id: 3 + reserved: 0 + + - + start_resource: 52 + num_resource: 4 + type: 12482 + host_id: 4 + reserved: 0 + + - + start_resource: 52 + num_resource: 0 + type: 12482 + host_id: 13 + reserved: 0 + + - + start_resource: 56 + num_resource: 2 + type: 12482 + host_id: 5 + reserved: 0 + + - + start_resource: 58 + num_resource: 12 + type: 12482 + host_id: 12 + reserved: 0 + + - + start_resource: 70 + num_resource: 4 + type: 12482 + host_id: 13 + reserved: 0 + + - + start_resource: 74 + num_resource: 10 + type: 12482 + host_id: 3 + reserved: 0 + + - + start_resource: 74 + num_resource: 10 + type: 12482 + host_id: 4 + reserved: 0 + + - + start_resource: 84 + num_resource: 12 + type: 12482 + host_id: 5 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 12483 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12483 + host_id: 3 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 12483 + host_id: 4 + reserved: 0 + + - + start_resource: 4 + num_resource: 0 + type: 12483 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 2 + type: 12483 + host_id: 5 + reserved: 0 + + - + start_resource: 10 + num_resource: 12 + type: 12483 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 4 + type: 12483 + host_id: 13 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12483 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 10 + type: 12483 + host_id: 4 + reserved: 0 + + - + start_resource: 36 + num_resource: 12 + type: 12483 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 12485 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 12485 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 12485 + host_id: 4 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 12485 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12487 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12487 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 12487 + host_id: 4 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 12487 + host_id: 4 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 12490 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 12490 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 12491 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 12491 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 12491 + host_id: 4 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 12491 + host_id: 5 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 12491 + host_id: 128 + reserved: 0 diff --git a/board/ti/am65x/sec-cfg.yaml b/board/ti/am65x/sec-cfg.yaml new file mode 100644 index 0000000000..ebf1b8b134 --- /dev/null +++ b/board/ti/am65x/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM65x +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0 + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support has been added for both HS-SE(SR 2.0) and GP(SR 2.0) images.
HS-SE: * tiboot3-am65x_sr2-hs-evm.bin * sysfw-am65x_sr2-hs-evm.itb * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-am65x_sr2-gp-evm.bin * sysfw.itb --> sysfw-am65x_sr2-gp-evm.itb * tispl.bin_unsigned * u-boot.img_unsigned
Note that the bootflow followed by AM65x requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs sysfw.itb: * sysfw * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * ATF * OPTEE * A53 SPL * A53 SPL dtbs
u-boot.img: * A53 U-Boot * A53 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 1 + .../dts/k3-am654-r5-base-board-u-boot.dtsi | 1 + arch/arm/dts/k3-am65x-binman.dtsi | 518 ++++++++++++++++++ board/ti/am65x/Kconfig | 2 + 4 files changed, 522 insertions(+) create mode 100644 arch/arm/dts/k3-am65x-binman.dtsi
diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index 0c1305df7e..e4cbc47c2a 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "k3-am654-r5-base-board-u-boot.dtsi" +#include "k3-am65x-binman.dtsi"
&pru0_0 { remoteproc-name = "pru0_0"; diff --git a/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi index 4516ab1437..949320c91d 100644 --- a/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-r5-base-board-u-boot.dtsi @@ -5,6 +5,7 @@
#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/net/ti-dp83867.h> +#include "k3-am65x-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-am65x-binman.dtsi b/arch/arm/dts/k3-am65x-binman.dtsi new file mode 100644 index 0000000000..6535b9fec2 --- /dev/null +++ b/arch/arm/dts/k3-am65x-binman.dtsi @@ -0,0 +1,518 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_AM654_R5_EVM + +&binman { + tiboot3-am65x_sr2-hs-evm.bin { + filename = "tiboot3-am65x_sr2-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + keyfile = "custMpk.pem"; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + }; + sysfw { + filename = "sysfw.bin"; + ti-secure-rom { + content = <&ti_sci_cert>; + core = "secure"; + load = <0x40000>; + keyfile = "custMpk.pem"; + countersign; + }; + ti_sci_cert: ti-sci-cert.bin { + filename = "ti-sysfw/ti-sci-firmware-am65x_sr2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + ti-sci-firmware-am65x-hs-enc.bin { + filename = "ti-sysfw/ti-sci-firmware-am65x_sr2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + }; + itb { + filename = "sysfw-am65x_sr2-hs-evm.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&board_cfg>; + keyfile = "custMpk.pem"; + }; + board_cfg: board-cfg { + filename = "board-cfg.bin"; + type = "blob-ext"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&pm_cfg>; + keyfile = "custMpk.pem"; + }; + pm_cfg: pm-cfg { + filename = "pm-cfg.bin"; + type = "blob-ext"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&rm_cfg>; + keyfile = "custMpk.pem";\ + }; + rm_cfg: rm-cfg { + filename = "rm-cfg.bin"; + type = "blob-ext"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&sec_cfg>; + keyfile = "custMpk.pem"; + }; + sec_cfg: sec-cfg { + filename = "sec-cfg.bin"; + type = "blob-ext"; + }; + }; + }; + }; + }; +}; + +&binman { + tiboot3-am65x_sr2-gp-evm.bin { + filename = "tiboot3-am65x_sr2-gp-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>; + core = "public"; + load = <CONFIG_SPL_TEXT_BASE>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + }; + sysfw_gp { + filename = "sysfw.bin_gp"; + ti-secure-rom { + content = <&ti_sci>; + core = "secure"; + load = <0x40000>; + sw-rev = <CONFIG_K3_X509_SWRV>; + keyfile = "ti-degenerate-key.pem"; + }; + ti_sci: ti-sci.bin { + filename = "ti-sysfw/ti-sci-firmware-am65x_sr2-gp.bin"; + type = "blob-ext"; + optional; + }; + }; + itb_gp { + filename = "sysfw-am65x_sr2-gp-evm.itb"; + symlink = "sysfw.itb"; + fit { + description = "SYSFW and Config fragments"; + #address-cells = <1>; + images { + sysfw.bin { + description = "sysfw"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sysfw.bin_gp"; + }; + }; + board-cfg.bin { + description = "board-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "board-cfg.bin"; + }; + }; + pm-cfg.bin { + description = "pm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "pm-cfg.bin"; + }; + }; + rm-cfg.bin { + description = "rm-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "rm-cfg.bin"; + }; + }; + sec-cfg.bin { + description = "sec-cfg"; + type = "firmware"; + arch = "arm"; + compression = "none"; + blob-ext { + filename = "sec-cfg.bin"; + }; + }; + }; + }; + }; +}; +#endif + +#ifdef CONFIG_TARGET_AM654_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM654_EVM_DTB "spl/dts/k3-am654-base-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM654_EVM_DTB "arch/arm/dts/k3-am654-base-board.dtb" + +&binman { + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am65x_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am65x_evm_dtb: blob-ext { + filename = SPL_AM654_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM65 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am65x_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + am65x_evm_dtb: blob-ext { + filename = AM654_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j721e-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM654_EVM_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM65 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am654-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM654_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am654-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; +#endif diff --git a/board/ti/am65x/Kconfig b/board/ti/am65x/Kconfig index 220dd0234c..5fd19d652a 100644 --- a/board/ti/am65x/Kconfig +++ b/board/ti/am65x/Kconfig @@ -12,6 +12,7 @@ config TARGET_AM654_A53_EVM select ARM64 select SYS_DISABLE_DCACHE_OPS select BOARD_LATE_INIT + select BINMAN imply TI_I2C_BOARD_DETECT
config TARGET_AM654_R5_EVM @@ -20,6 +21,7 @@ config TARGET_AM654_R5_EVM select SYS_THUMB_BUILD select K3_LOAD_SYSFW select K3_AM654_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML configs for AM64xx
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am64x/board-cfg.yaml | 37 + board/ti/am64x/pm-cfg.yaml | 12 + board/ti/am64x/rm-cfg.yaml | 1400 +++++++++++++++++++++++++++++++++ board/ti/am64x/sec-cfg.yaml | 380 +++++++++ 4 files changed, 1829 insertions(+) create mode 100644 board/ti/am64x/board-cfg.yaml create mode 100644 board/ti/am64x/pm-cfg.yaml create mode 100644 board/ti/am64x/rm-cfg.yaml create mode 100644 board/ti/am64x/sec-cfg.yaml
diff --git a/board/ti/am64x/board-cfg.yaml b/board/ti/am64x/board-cfg.yaml new file mode 100644 index 0000000000..f1f7c68d50 --- /dev/null +++ b/board/ti/am64x/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM64x +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 + diff --git a/board/ti/am64x/pm-cfg.yaml b/board/ti/am64x/pm-cfg.yaml new file mode 100644 index 0000000000..c97495f482 --- /dev/null +++ b/board/ti/am64x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM64x +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am64x/rm-cfg.yaml b/board/ti/am64x/rm-cfg.yaml new file mode 100644 index 0000000000..1e6b07aef6 --- /dev/null +++ b/board/ti/am64x/rm-cfg.yaml @@ -0,0 +1,1400 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM64x +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 38 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 41 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 43 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #8 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #9 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #10 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #11 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #12 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #13 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #14 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #15 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #16 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #17 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #18 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #19 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #20 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #21 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #22 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #23 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #24 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #25 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #26 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #27 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #28 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #29 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #30 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #31 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + + - #32 + host_id: 0 + allowed_atype: 0 + allowed_qos: 0 + allowed_orderid: 0 + allowed_priority: 0 + allowed_sched_priority: 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 1288 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 64 + host_id: 38 + reserved: 0 + + - + start_resource: 24 + num_resource: 4 + type: 64 + host_id: 41 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 64 + host_id: 43 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 64 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 192 + host_id: 41 + reserved: 0 + + - + start_resource: 14 + num_resource: 2 + type: 192 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 41 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 136 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1677 + host_id: 38 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 1677 + host_id: 41 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 43 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 6 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 54 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 1678 + host_id: 38 + reserved: 0 + + - + start_resource: 62 + num_resource: 4 + type: 1678 + host_id: 41 + reserved: 0 + + - + start_resource: 66 + num_resource: 2 + type: 1678 + host_id: 43 + reserved: 0 + + - + start_resource: 28 + num_resource: 6 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 34 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 40 + num_resource: 2 + type: 1679 + host_id: 38 + reserved: 0 + + - + start_resource: 42 + num_resource: 4 + type: 1679 + host_id: 41 + reserved: 0 + + - + start_resource: 46 + num_resource: 2 + type: 1679 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1696 + host_id: 38 + reserved: 0 + + - + start_resource: 20 + num_resource: 4 + type: 1696 + host_id: 41 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 43 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 1697 + host_id: 38 + reserved: 0 + + - + start_resource: 14 + num_resource: 4 + type: 1697 + host_id: 41 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1697 + host_id: 43 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 6 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 1698 + host_id: 38 + reserved: 0 + + - + start_resource: 14 + num_resource: 4 + type: 1698 + host_id: 41 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 43 + reserved: 0 + + - + start_resource: 5 + num_resource: 35 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 14 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 14 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 58 + num_resource: 14 + type: 1802 + host_id: 38 + reserved: 0 + + - + start_resource: 92 + num_resource: 14 + type: 1802 + host_id: 41 + reserved: 0 + + - + start_resource: 106 + num_resource: 14 + type: 1802 + host_id: 43 + reserved: 0 + + - + start_resource: 168 + num_resource: 16 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 528 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 528 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 784 + num_resource: 192 + type: 1805 + host_id: 38 + reserved: 0 + + - + start_resource: 976 + num_resource: 256 + type: 1805 + host_id: 41 + reserved: 0 + + - + start_resource: 1232 + num_resource: 192 + type: 1805 + host_id: 43 + reserved: 0 + + - + start_resource: 1424 + num_resource: 96 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 1520 + num_resource: 16 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 42 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 112 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 29 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 176 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 176 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 176 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 28 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 28 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 28 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 20 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 20 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 20 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 20 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 20 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 20 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1936 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1936 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1936 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 64 + type: 1937 + host_id: 35 + reserved: 0 + + - + start_resource: 88 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 96 + num_resource: 8 + type: 1940 + host_id: 12 + reserved: 0 + + - + start_resource: 104 + num_resource: 8 + type: 1941 + host_id: 12 + reserved: 0 + + - + start_resource: 112 + num_resource: 4 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 116 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 116 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 119 + num_resource: 2 + type: 1942 + host_id: 38 + reserved: 0 + + - + start_resource: 121 + num_resource: 4 + type: 1942 + host_id: 41 + reserved: 0 + + - + start_resource: 125 + num_resource: 2 + type: 1942 + host_id: 43 + reserved: 0 + + - + start_resource: 127 + num_resource: 1 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 128 + num_resource: 16 + type: 1943 + host_id: 35 + reserved: 0 + + - + start_resource: 144 + num_resource: 8 + type: 1945 + host_id: 128 + reserved: 0 + + - + start_resource: 152 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 152 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 160 + num_resource: 64 + type: 1948 + host_id: 12 + reserved: 0 + + - + start_resource: 224 + num_resource: 64 + type: 1949 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1955 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1955 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1955 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 1956 + host_id: 35 + reserved: 0 + + - + start_resource: 25 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 26 + num_resource: 8 + type: 1959 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 8 + type: 1960 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1961 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1961 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1961 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 7 + num_resource: 2 + type: 1962 + host_id: 38 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 1962 + host_id: 41 + reserved: 0 + + - + start_resource: 13 + num_resource: 2 + type: 1962 + host_id: 43 + reserved: 0 + + - + start_resource: 15 + num_resource: 1 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 1 + type: 1963 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 1964 + host_id: 35 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 1966 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 8 + type: 1968 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 40 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 40 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 4 + type: 1973 + host_id: 12 + reserved: 0 + + - + start_resource: 48 + num_resource: 64 + type: 1974 + host_id: 12 + reserved: 0 + + - + start_resource: 25 + num_resource: 4 + type: 1975 + host_id: 12 + reserved: 0 + + - + start_resource: 112 + num_resource: 64 + type: 1976 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2124 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 2124 + host_id: 36 + reserved: 0 + + - + start_resource: 22 + num_resource: 2 + type: 2124 + host_id: 38 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 2124 + host_id: 41 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 2124 + host_id: 43 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 2124 + host_id: 128 + reserved: 0 diff --git a/board/ti/am64x/sec-cfg.yaml b/board/ti/am64x/sec-cfg.yaml new file mode 100644 index 0000000000..2779f2943d --- /dev/null +++ b/board/ti/am64x/sec-cfg.yaml @@ -0,0 +1,380 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for AM64x +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0 + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd : 0 + rsvd : 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
+board-cfg:
rev:
control:
subhdr:
magic: 0xC1D3
secproxy:
subhdr:
magic: 0x1207
msmc:
subhdr:
magic: 0xA5C3
debug_cfg:
subhdr:
magic: 0x020C
+pm-cfg:
rev:
+rm-cfg:
rm_boardcfg:
rev:
host_cfg:
subhdr:
magic: 0x4C41
host_cfg_entries:
- #1
host_id: 12
- #2
host_id: 30
- #3
host_id: 36
- #4
host_id: 38
- #5
host_id: 41
- #6
host_id: 43
- #7
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #8
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #9
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #10
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #11
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #12
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #13
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #14
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #15
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #16
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #17
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #18
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #19
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #20
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #21
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #22
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #23
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #24
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #25
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #26
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #27
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #28
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #29
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #30
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #31
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
- #32
host_id: 0
allowed_atype: 0
allowed_qos: 0
allowed_orderid: 0
allowed_priority: 0
resasg:
subhdr:
magic: 0x7B25
reserved : 0
resasg_entries:
start_resource: 0
num_resource: 16
type: 64
host_id: 12
reserved: 0
start_resource: 16
num_resource: 4
type: 64
host_id: 35
reserved: 0
start_resource: 16
num_resource: 4
type: 64
host_id: 36
reserved: 0
start_resource: 20
num_resource: 4
type: 64
host_id: 38
reserved: 0
start_resource: 24
num_resource: 4
type: 64
host_id: 41
reserved: 0
start_resource: 28
num_resource: 4
type: 64
host_id: 43
reserved: 0
start_resource: 32
num_resource: 8
type: 64
host_id: 128
reserved: 0
start_resource: 0
num_resource: 12
type: 192
host_id: 12
reserved: 0
start_resource: 12
num_resource: 2
type: 192
host_id: 41
reserved: 0
start_resource: 14
num_resource: 2
type: 192
host_id: 43
reserved: 0
start_resource: 0
num_resource: 4
type: 320
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 320
host_id: 30
reserved: 0
start_resource: 0
num_resource: 41
type: 384
host_id: 128
reserved: 0
num_resource: 136
type: 1666
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 1667
host_id: 128
reserved: 0
start_resource: 0
num_resource: 12
type: 1677
host_id: 12
reserved: 0
start_resource: 12
num_resource: 6
type: 1677
host_id: 35
reserved: 0
start_resource: 12
num_resource: 6
type: 1677
host_id: 36
reserved: 0
start_resource: 18
num_resource: 2
type: 1677
host_id: 38
reserved: 0
start_resource: 20
num_resource: 4
type: 1677
host_id: 41
reserved: 0
start_resource: 24
num_resource: 2
type: 1677
host_id: 43
reserved: 0
start_resource: 26
num_resource: 1
type: 1677
host_id: 30
reserved: 0
start_resource: 27
num_resource: 1
type: 1677
host_id: 128
reserved: 0
start_resource: 48
num_resource: 6
type: 1678
host_id: 12
reserved: 0
start_resource: 54
num_resource: 6
type: 1678
host_id: 35
reserved: 0
start_resource: 54
num_resource: 6
type: 1678
host_id: 36
reserved: 0
start_resource: 60
num_resource: 2
type: 1678
host_id: 38
reserved: 0
start_resource: 62
num_resource: 4
type: 1678
host_id: 41
reserved: 0
start_resource: 66
num_resource: 2
type: 1678
host_id: 43
reserved: 0
start_resource: 28
num_resource: 6
type: 1679
host_id: 12
reserved: 0
start_resource: 34
num_resource: 6
type: 1679
host_id: 35
reserved: 0
start_resource: 34
num_resource: 6
type: 1679
host_id: 36
reserved: 0
start_resource: 40
num_resource: 2
type: 1679
host_id: 38
reserved: 0
start_resource: 42
num_resource: 4
type: 1679
host_id: 41
reserved: 0
start_resource: 46
num_resource: 2
type: 1679
host_id: 43
reserved: 0
start_resource: 0
num_resource: 12
type: 1696
host_id: 12
reserved: 0
start_resource: 12
num_resource: 6
type: 1696
host_id: 35
reserved: 0
start_resource: 12
num_resource: 6
type: 1696
host_id: 36
reserved: 0
start_resource: 18
num_resource: 2
type: 1696
host_id: 38
reserved: 0
start_resource: 20
num_resource: 4
type: 1696
host_id: 41
reserved: 0
start_resource: 24
num_resource: 2
type: 1696
host_id: 43
reserved: 0
start_resource: 26
num_resource: 1
type: 1696
host_id: 30
reserved: 0
start_resource: 27
num_resource: 1
type: 1696
host_id: 128
reserved: 0
start_resource: 0
num_resource: 6
type: 1697
host_id: 12
reserved: 0
start_resource: 6
num_resource: 6
type: 1697
host_id: 35
reserved: 0
start_resource: 6
num_resource: 6
type: 1697
host_id: 36
reserved: 0
start_resource: 12
num_resource: 2
type: 1697
host_id: 38
reserved: 0
start_resource: 14
num_resource: 4
type: 1697
host_id: 41
reserved: 0
start_resource: 18
num_resource: 2
type: 1697
host_id: 43
reserved: 0
start_resource: 0
num_resource: 6
type: 1698
host_id: 12
reserved: 0
start_resource: 6
num_resource: 6
type: 1698
host_id: 35
reserved: 0
start_resource: 6
num_resource: 6
type: 1698
host_id: 36
reserved: 0
start_resource: 12
num_resource: 2
type: 1698
host_id: 38
reserved: 0
start_resource: 14
num_resource: 4
type: 1698
host_id: 41
reserved: 0
start_resource: 18
num_resource: 2
type: 1698
host_id: 43
reserved: 0
start_resource: 5
num_resource: 35
type: 1802
host_id: 12
reserved: 0
start_resource: 44
num_resource: 14
type: 1802
host_id: 35
reserved: 0
start_resource: 44
num_resource: 14
type: 1802
host_id: 36
reserved: 0
start_resource: 58
num_resource: 14
type: 1802
host_id: 38
reserved: 0
start_resource: 92
num_resource: 14
type: 1802
host_id: 41
reserved: 0
start_resource: 106
num_resource: 14
type: 1802
host_id: 43
reserved: 0
start_resource: 168
num_resource: 16
type: 1802
host_id: 30
reserved: 0
start_resource: 16
num_resource: 512
type: 1805
host_id: 12
reserved: 0
start_resource: 528
num_resource: 256
type: 1805
host_id: 35
reserved: 0
start_resource: 528
num_resource: 256
type: 1805
host_id: 36
reserved: 0
start_resource: 784
num_resource: 192
type: 1805
host_id: 38
reserved: 0
start_resource: 976
num_resource: 256
type: 1805
host_id: 41
reserved: 0
num_resource: 192
type: 1805
host_id: 43
reserved: 0
num_resource: 96
type: 1805
host_id: 30
reserved: 0
num_resource: 16
type: 1805
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1024
type: 1807
host_id: 128
reserved: 0
num_resource: 42
type: 1808
host_id: 128
reserved: 0
num_resource: 112
type: 1809
host_id: 128
reserved: 0
num_resource: 29
type: 1810
host_id: 128
reserved: 0
num_resource: 176
type: 1811
host_id: 128
reserved: 0
num_resource: 176
type: 1812
host_id: 128
reserved: 0
num_resource: 176
type: 1813
host_id: 128
reserved: 0
num_resource: 28
type: 1814
host_id: 128
reserved: 0
num_resource: 28
type: 1815
host_id: 128
reserved: 0
num_resource: 28
type: 1816
host_id: 128
reserved: 0
num_resource: 20
type: 1817
host_id: 128
reserved: 0
num_resource: 20
type: 1818
host_id: 128
reserved: 0
num_resource: 20
type: 1819
host_id: 128
reserved: 0
num_resource: 20
type: 1820
host_id: 128
reserved: 0
num_resource: 20
type: 1821
host_id: 128
reserved: 0
num_resource: 20
type: 1822
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 1923
host_id: 128
reserved: 0
start_resource: 0
num_resource: 4
type: 1936
host_id: 12
reserved: 0
start_resource: 4
num_resource: 3
type: 1936
host_id: 35
reserved: 0
start_resource: 4
num_resource: 3
type: 1936
host_id: 36
reserved: 0
start_resource: 7
num_resource: 2
type: 1936
host_id: 38
reserved: 0
start_resource: 9
num_resource: 4
type: 1936
host_id: 41
reserved: 0
start_resource: 13
num_resource: 2
type: 1936
host_id: 43
reserved: 0
start_resource: 15
num_resource: 1
type: 1936
host_id: 30
reserved: 0
start_resource: 16
num_resource: 64
type: 1937
host_id: 12
reserved: 0
start_resource: 16
num_resource: 64
type: 1937
host_id: 35
reserved: 0
start_resource: 88
num_resource: 8
type: 1939
host_id: 12
reserved: 0
start_resource: 96
num_resource: 8
type: 1940
host_id: 12
reserved: 0
start_resource: 104
num_resource: 8
type: 1941
host_id: 12
reserved: 0
start_resource: 112
num_resource: 4
type: 1942
host_id: 12
reserved: 0
start_resource: 116
num_resource: 3
type: 1942
host_id: 35
reserved: 0
start_resource: 116
num_resource: 3
type: 1942
host_id: 36
reserved: 0
start_resource: 119
num_resource: 2
type: 1942
host_id: 38
reserved: 0
start_resource: 121
num_resource: 4
type: 1942
host_id: 41
reserved: 0
start_resource: 125
num_resource: 2
type: 1942
host_id: 43
reserved: 0
start_resource: 127
num_resource: 1
type: 1942
host_id: 30
reserved: 0
start_resource: 128
num_resource: 16
type: 1943
host_id: 12
reserved: 0
start_resource: 128
num_resource: 16
type: 1943
host_id: 35
reserved: 0
start_resource: 144
num_resource: 8
type: 1945
host_id: 128
reserved: 0
start_resource: 152
num_resource: 8
type: 1946
host_id: 12
reserved: 0
start_resource: 152
num_resource: 8
type: 1947
host_id: 12
reserved: 0
start_resource: 160
num_resource: 64
type: 1948
host_id: 12
reserved: 0
start_resource: 224
num_resource: 64
type: 1949
host_id: 12
reserved: 0
start_resource: 0
num_resource: 4
type: 1955
host_id: 12
reserved: 0
start_resource: 4
num_resource: 3
type: 1955
host_id: 35
reserved: 0
start_resource: 4
num_resource: 3
type: 1955
host_id: 36
reserved: 0
start_resource: 7
num_resource: 2
type: 1955
host_id: 38
reserved: 0
start_resource: 9
num_resource: 4
type: 1955
host_id: 41
reserved: 0
start_resource: 13
num_resource: 2
type: 1955
host_id: 43
reserved: 0
start_resource: 15
num_resource: 1
type: 1955
host_id: 30
reserved: 0
start_resource: 16
num_resource: 8
type: 1956
host_id: 12
reserved: 0
start_resource: 16
num_resource: 8
type: 1956
host_id: 35
reserved: 0
start_resource: 25
num_resource: 1
type: 1958
host_id: 12
reserved: 0
start_resource: 26
num_resource: 8
type: 1959
host_id: 12
reserved: 0
start_resource: 34
num_resource: 8
type: 1960
host_id: 12
reserved: 0
start_resource: 0
num_resource: 4
type: 1961
host_id: 12
reserved: 0
start_resource: 4
num_resource: 3
type: 1961
host_id: 35
reserved: 0
start_resource: 4
num_resource: 3
type: 1961
host_id: 36
reserved: 0
start_resource: 7
num_resource: 2
type: 1961
host_id: 38
reserved: 0
start_resource: 9
num_resource: 4
type: 1961
host_id: 41
reserved: 0
start_resource: 13
num_resource: 2
type: 1961
host_id: 43
reserved: 0
start_resource: 15
num_resource: 1
type: 1961
host_id: 30
reserved: 0
start_resource: 0
num_resource: 4
type: 1962
host_id: 12
reserved: 0
start_resource: 4
num_resource: 3
type: 1962
host_id: 35
reserved: 0
start_resource: 4
num_resource: 3
type: 1962
host_id: 36
reserved: 0
start_resource: 7
num_resource: 2
type: 1962
host_id: 38
reserved: 0
start_resource: 9
num_resource: 4
type: 1962
host_id: 41
reserved: 0
start_resource: 13
num_resource: 2
type: 1962
host_id: 43
reserved: 0
start_resource: 15
num_resource: 1
type: 1962
host_id: 30
reserved: 0
start_resource: 16
num_resource: 1
type: 1963
host_id: 12
reserved: 0
start_resource: 16
num_resource: 1
type: 1963
host_id: 35
reserved: 0
start_resource: 16
num_resource: 16
type: 1964
host_id: 12
reserved: 0
start_resource: 16
num_resource: 16
type: 1964
host_id: 35
reserved: 0
start_resource: 32
num_resource: 8
type: 1966
host_id: 128
reserved: 0
start_resource: 32
num_resource: 8
type: 1968
host_id: 128
reserved: 0
start_resource: 19
num_resource: 1
type: 1969
host_id: 12
reserved: 0
start_resource: 40
num_resource: 8
type: 1970
host_id: 12
reserved: 0
start_resource: 20
num_resource: 1
type: 1971
host_id: 12
reserved: 0
start_resource: 40
num_resource: 8
type: 1972
host_id: 12
reserved: 0
start_resource: 21
num_resource: 4
type: 1973
host_id: 12
reserved: 0
start_resource: 48
num_resource: 64
type: 1974
host_id: 12
reserved: 0
start_resource: 25
num_resource: 4
type: 1975
host_id: 12
reserved: 0
start_resource: 112
num_resource: 64
type: 1976
host_id: 12
reserved: 0
start_resource: 0
num_resource: 1
type: 2112
host_id: 128
reserved: 0
start_resource: 2
num_resource: 2
type: 2122
host_id: 12
reserved: 0
start_resource: 20
num_resource: 2
type: 2124
host_id: 35
reserved: 0
start_resource: 20
num_resource: 2
type: 2124
host_id: 36
reserved: 0
start_resource: 22
num_resource: 2
type: 2124
host_id: 38
reserved: 0
start_resource: 24
num_resource: 2
type: 2124
host_id: 41
reserved: 0
start_resource: 26
num_resource: 2
type: 2124
host_id: 43
reserved: 0
start_resource: 28
num_resource: 4
type: 2124
host_id: 128
reserved: 0
+sec-cfg:
rev:
processor_acl_list:
subhdr:
magic: 0xF1EA
proc_acl_entries:
- #1
processor_id: 0
- #2
processor_id: 0
- #3
processor_id: 0
- #4
processor_id: 0
- #5
processor_id: 0
- #6
processor_id: 0
- #7
processor_id: 0
- #8
processor_id: 0
- #9
processor_id: 0
- #10
processor_id: 0
- #11
processor_id: 0
- #12
processor_id: 0
- #13
processor_id: 0
- #14
processor_id: 0
- #15
processor_id: 0
- #16
processor_id: 0
- #17
processor_id: 0
- #18
processor_id: 0
- #19
processor_id: 0
- #20
processor_id: 0
- #21
processor_id: 0
- #22
processor_id: 0
- #23
processor_id: 0
- #24
processor_id: 0
- #25
processor_id: 0
- #26
processor_id: 0
- #27
processor_id: 0
- #28
processor_id: 0
- #29
processor_id: 0
- #30
processor_id: 0
- #31
processor_id: 0
- #32
processor_id: 0
host_hierarchy:
subhdr:
magic: 0x8D27
- #1
host_id: 0
- #2
host_id: 0
- #3
host_id: 0
- #4
host_id: 0
- #5
host_id: 0
- #6
host_id: 0
- #7
host_id: 0
- #8
host_id: 0
- #9
host_id: 0
- #10
host_id: 0
- #11
host_id: 0
- #12
host_id: 0
- #13
host_id: 0
- #14
host_id: 0
- #15
host_id: 0
- #16
host_id: 0
- #17
host_id: 0
- #18
host_id: 0
- #19
host_id: 0
- #20
host_id: 0
- #21
host_id: 0
- #22
host_id: 0
- #23
host_id: 0
- #24
host_id: 0
- #25
host_id: 0
- #26
host_id: 0
- #27
host_id: 0
- #28
host_id: 0
- #29
host_id: 0
- #30
host_id: 0
- #31
host_id: 0
- #32
host_id: 0
otp_config:
subhdr:
magic: 0x4081
write_host_id : 0
otp_entry:
- #1
host_id: 0
host_perms: 0
- #2
host_id: 0
host_perms: 0
- #3
host_id: 0
host_perms: 0
- #4
host_id: 0
host_perms: 0
- #5
host_id: 0
host_perms: 0
- #6
host_id: 0
host_perms: 0
- #7
host_id: 0
host_perms: 0
- #8
host_id: 0
host_perms: 0
- #9
host_id: 0
host_perms: 0
- #10
host_id: 0
host_perms: 0
- #11
host_id: 0
host_perms: 0
- #12
host_id: 0
host_perms: 0
- #13
host_id: 0
host_perms: 0
- #14
host_id: 0
host_perms: 0
- #15
host_id: 0
host_perms: 0
- #16
host_id: 0
host_perms: 0
- #17
host_id: 0
host_perms: 0
- #18
host_id: 0
host_perms: 0
- #19
host_id: 0
host_perms: 0
- #20
host_id: 0
host_perms: 0
- #21
host_id: 0
host_perms: 0
- #22
host_id: 0
host_perms: 0
- #23
host_id: 0
host_perms: 0
- #24
host_id: 0
host_perms: 0
- #25
host_id: 0
host_perms: 0
- #26
host_id: 0
host_perms: 0
- #27
host_id: 0
host_perms: 0
- #28
host_id: 0
host_perms: 0
- #29
host_id: 0
host_perms: 0
- #30
host_id: 0
host_perms: 0
- #31
host_id: 0
host_perms: 0
- #32
host_id: 0
host_perms: 0
dkek_config:
subhdr:
magic: 0x5170
rsvd: [0, 0, 0]
sa2ul_cfg:
subhdr:
magic: 0x23BE
rsvd: [0, 0]
sec_dbg_config:
subhdr:
magic: 0x42AF
rsvd : 0
min_cert_rev : 0x0
sec_handover_cfg:
subhdr:
magic: 0x608F
rsvd: [0, 0, 0, 0]
... Applying: am64x: yaml: Add board configs for AM64x .git/rebase-apply/patch:54: new blank line at EOF. + warning: 1 line adds whitespace errors.
Jan
Support added for HS and GP boot binaries for AM64x.
HS-SE: * tiboot3-am64x_sr2-hs-evm.bin * tispl.bin * u-boot.img
HS-FS: * tiboot3-am64x_sr2-hs-fs-evm.bin * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-am64x-gp-evm.bin * tispl.bin_unsigned * u-boot.img_unsigned
Note that the bootflow followed by AM64x requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * sysfw * board-cfg * pm-cfg * sec-cfg * rm-cfg
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am642-evm-u-boot.dtsi | 2 + arch/arm/dts/k3-am642-r5-evm.dts | 1 + arch/arm/dts/k3-am642-sk-u-boot.dtsi | 2 + arch/arm/dts/k3-am64x-binman.dtsi | 515 ++++++++++++++++++++++++++ board/ti/am64x/Kconfig | 2 + 5 files changed, 522 insertions(+) create mode 100644 arch/arm/dts/k3-am64x-binman.dtsi
diff --git a/arch/arm/dts/k3-am642-evm-u-boot.dtsi b/arch/arm/dts/k3-am642-evm-u-boot.dtsi index 64857b0909..73577e8cfd 100644 --- a/arch/arm/dts/k3-am642-evm-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-evm-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2020-2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-am64x-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-am642-r5-evm.dts b/arch/arm/dts/k3-am642-r5-evm.dts index e870492a69..b49064181a 100644 --- a/arch/arm/dts/k3-am642-r5-evm.dts +++ b/arch/arm/dts/k3-am642-r5-evm.dts @@ -8,6 +8,7 @@ #include "k3-am642.dtsi" #include "k3-am64-evm-ddr4-1600MTs.dtsi" #include "k3-am64-ddr.dtsi" +#include "k3-am64x-binman.dtsi"
/ { chosen { diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index 69dbe943bd..3d6be025bd 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-am64x-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-am64x-binman.dtsi b/arch/arm/dts/k3-am64x-binman.dtsi new file mode 100644 index 0000000000..e6ca2457b4 --- /dev/null +++ b/arch/arm/dts/k3-am64x-binman.dtsi @@ -0,0 +1,515 @@ +// SPDX-License-Identifier: GPL-2.0+ +// Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_AM642_R5_EVM + +&binman { + tiboot3-am64x_sr2-hs-evm.bin { + filename = "tiboot3-am64x_sr2-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_sci_enc>, + <&combined_sysfw_cfg>, <&sysfw_inner_cert>; + combined; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_sci_enc>; + content-sysfw-data = <&combined_sysfw_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + load = <0x70000000>; + load-sysfw = <0x44000>; + load-sysfw-data = <0x7b000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_sci_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-sci-firmware-am64x_sr2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_sysfw_cfg: combined-sysfw-cfg.bin { + filename = "combined-sysfw-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-sci-firmware-am64x_sr2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3-am64x_sr2-hs-fs-evm.bin { + filename = "tiboot3-am64x_sr2-hs-fs-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_sci_enc_fs>, + <&combined_sysfw_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_sci_enc_fs>; + content-sysfw-data = <&combined_sysfw_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + load = <0x70000000>; + load-sysfw = <0x44000>; + load-sysfw-data = <0x7b000>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_sci_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-sci-firmware-am64x_sr2-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_sysfw_cfg_fs: combined-sysfw-cfg.bin { + filename = "combined-sysfw-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-sci-firmware-am64x_sr2-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + + }; +}; + +&binman { + tiboot3-am64x-gp-evm.bin { + filename = "tiboot3-am64x-gp-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_sci_gp>, <&combined_sysfw_cfg_gp>; + combined; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x70000000>; + content-sysfw = <&ti_sci_gp>; + load-sysfw = <0x44000>; + content-sysfw-data = <&combined_sysfw_cfg_gp>; + load-sysfw-data = <0x7b000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_sci_gp: ti-sci-gp.bin { + filename = "ti-sysfw/ti-sci-firmware-am64x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_sysfw_cfg_gp: combined-sysfw-cfg-gp.bin { + filename = "combined-sysfw-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM642_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM642_EVM_DTB "spl/dts/k3-am642-evm.dtb" +#define SPL_AM642_SK_DTB "spl/dts/k3-am642-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM642_EVM_DTB "arch/arm/dts/k3-am642-evm.dtb" +#define AM642_SK_DTB "arch/arm/dts/k3-am642-sk.dtb" + +&binman { + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am64x_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am64x_evm_dtb: blob-ext { + filename = SPL_AM642_EVM_DTB; + }; + + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am64x_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am64x_sk_dtb: blob-ext { + filename = SPL_AM642_SK_DTB; + }; + + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM64 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am64x_evm_dtb>; + keyfile = "custMpk.pem"; + + }; + am64x_evm_dtb: blob-ext { + filename = AM642_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am64x_sk_dtb>; + keyfile = "custMpk.pem"; + + }; + am64x_sk_dtb: blob-ext { + filename = AM642_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM642_EVM_DTB; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM642_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM64 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am642-evm"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM642_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am642-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM642_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am642-evm"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am642-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/board/ti/am64x/Kconfig b/board/ti/am64x/Kconfig index afb54f8cda..fb596e4adf 100644 --- a/board/ti/am64x/Kconfig +++ b/board/ti/am64x/Kconfig @@ -9,6 +9,7 @@ choice config TARGET_AM642_A53_EVM bool "TI K3 based AM642 EVM running on A53" select ARM64 + select BINMAN imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -21,6 +22,7 @@ config TARGET_AM642_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Hi Neha,
tispl.bin: * ATF * OPTEE * A53 SPL * A53 SPL dtbs
u-boot.img: * A53 U-Boot * A53 U-Boot dtbs
It looks like the template feature (see pending patches) might help reduce the size of the .dtsi, but we can worry about that later.
Hi Simon
On 07/07/23 23:05, Simon Glass wrote:
Hi Neha,
Right, I'll have a shot at it once this series is up. Thanks!
On 10.07.23 11:12, Neha Malcom Francis wrote:
Hi Simon
Hi Neha,
tispl.bin: Â Â Â Â Â Â Â Â * ATF Â Â Â Â Â Â Â Â * OPTEE Â Â Â Â Â Â Â Â * A53 SPL Â Â Â Â Â Â Â Â * A53 SPL dtbs
I would recommend testing it earlier locally if you are interested - there might be still some edges left, and early feedback already helped to improve it.
Jan
Added YAML configs for J721S2
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/j721s2/board-cfg.yaml | 37 + board/ti/j721s2/pm-cfg.yaml | 12 + board/ti/j721s2/rm-cfg.yaml | 2901 ++++++++++++++++++++++++++++++++ board/ti/j721s2/sec-cfg.yaml | 379 +++++ 4 files changed, 3329 insertions(+) create mode 100644 board/ti/j721s2/board-cfg.yaml create mode 100644 board/ti/j721s2/pm-cfg.yaml create mode 100644 board/ti/j721s2/rm-cfg.yaml create mode 100644 board/ti/j721s2/sec-cfg.yaml
diff --git a/board/ti/j721s2/board-cfg.yaml b/board/ti/j721s2/board-cfg.yaml new file mode 100644 index 0000000000..d80f308ca6 --- /dev/null +++ b/board/ti/j721s2/board-cfg.yaml @@ -0,0 +1,37 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for J721S2 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 + diff --git a/board/ti/j721s2/pm-cfg.yaml b/board/ti/j721s2/pm-cfg.yaml new file mode 100644 index 0000000000..45994e23cc --- /dev/null +++ b/board/ti/j721s2/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for J721S2 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/j721s2/rm-cfg.yaml b/board/ti/j721s2/rm-cfg.yaml new file mode 100644 index 0000000000..6058f3b35c --- /dev/null +++ b/board/ti/j721s2/rm-cfg.yaml @@ -0,0 +1,2901 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for J721S2 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 3 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 5 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 13 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #5 + host_id: 21 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #6 + host_id: 23 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #7 + host_id: 35 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #8 + host_id: 37 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #9 + host_id: 40 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #10 + host_id: 42 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 3032 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 32 + type: 7744 + host_id: 3 + reserved: 0 + + - + start_resource: 32 + num_resource: 24 + type: 7744 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 24 + type: 7808 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 16 + type: 7808 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 48 + type: 7936 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 8000 + host_id: 3 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 8000 + host_id: 5 + reserved: 0 + + - + start_resource: 16 + num_resource: 6 + type: 8000 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 6 + type: 8000 + host_id: 13 + reserved: 0 + + - + start_resource: 28 + num_resource: 2 + type: 8000 + host_id: 35 + reserved: 0 + + - + start_resource: 30 + num_resource: 2 + type: 8000 + host_id: 37 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 9472 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 9472 + host_id: 37 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 9472 + host_id: 40 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 9472 + host_id: 42 + reserved: 0 + + - + start_resource: 16 + num_resource: 8 + type: 9472 + host_id: 3 + reserved: 0 + + - + start_resource: 24 + num_resource: 8 + type: 9472 + host_id: 5 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 9472 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 12 + type: 9472 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 9600 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 96 + type: 14402 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 14403 + host_id: 128 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 14414 + host_id: 12 + reserved: 0 + + - + start_resource: 32 + num_resource: 16 + type: 14414 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 14415 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 14415 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 14433 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 16 + type: 14433 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 14434 + host_id: 12 + reserved: 0 + + - + start_resource: 8 + num_resource: 8 + type: 14434 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 100 + type: 14528 + host_id: 12 + reserved: 0 + + - + start_resource: 110 + num_resource: 32 + type: 14528 + host_id: 13 + reserved: 0 + + - + start_resource: 142 + num_resource: 21 + type: 14528 + host_id: 21 + reserved: 0 + + - + start_resource: 163 + num_resource: 21 + type: 14528 + host_id: 23 + reserved: 0 + + - + start_resource: 196 + num_resource: 28 + type: 14528 + host_id: 35 + reserved: 0 + + - + start_resource: 228 + num_resource: 28 + type: 14528 + host_id: 37 + reserved: 0 + + - + start_resource: 260 + num_resource: 28 + type: 14528 + host_id: 40 + reserved: 0 + + - + start_resource: 292 + num_resource: 28 + type: 14528 + host_id: 42 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 14528 + host_id: 3 + reserved: 0 + + - + start_resource: 404 + num_resource: 4 + type: 14528 + host_id: 5 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 16266 + host_id: 128 + reserved: 0 + + - + start_resource: 20480 + num_resource: 1024 + type: 16269 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 64 + type: 16330 + host_id: 128 + reserved: 0 + + - + start_resource: 22528 + num_resource: 1024 + type: 16333 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 16384 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 16384 + host_id: 13 + reserved: 0 + + - + start_resource: 8 + num_resource: 4 + type: 16384 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 4 + type: 16384 + host_id: 23 + reserved: 0 + + - + start_resource: 16 + num_resource: 12 + type: 16384 + host_id: 35 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 16384 + host_id: 37 + reserved: 0 + + - + start_resource: 32 + num_resource: 4 + type: 16384 + host_id: 40 + reserved: 0 + + - + start_resource: 36 + num_resource: 4 + type: 16384 + host_id: 42 + reserved: 0 + + - + start_resource: 40 + num_resource: 4 + type: 16384 + host_id: 3 + reserved: 0 + + - + start_resource: 44 + num_resource: 4 + type: 16384 + host_id: 5 + reserved: 0 + + - + start_resource: 48 + num_resource: 16 + type: 16384 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16576 + host_id: 128 + reserved: 0 + + - + start_resource: 423 + num_resource: 32 + type: 16577 + host_id: 21 + reserved: 0 + + - + start_resource: 455 + num_resource: 32 + type: 16577 + host_id: 23 + reserved: 0 + + - + start_resource: 487 + num_resource: 182 + type: 16577 + host_id: 35 + reserved: 0 + + - + start_resource: 669 + num_resource: 40 + type: 16577 + host_id: 37 + reserved: 0 + + - + start_resource: 709 + num_resource: 10 + type: 16577 + host_id: 40 + reserved: 0 + + - + start_resource: 719 + num_resource: 10 + type: 16577 + host_id: 42 + reserved: 0 + + - + start_resource: 729 + num_resource: 6 + type: 16577 + host_id: 3 + reserved: 0 + + - + start_resource: 735 + num_resource: 6 + type: 16577 + host_id: 5 + reserved: 0 + + - + start_resource: 878 + num_resource: 128 + type: 16577 + host_id: 12 + reserved: 0 + + - + start_resource: 1006 + num_resource: 10 + type: 16577 + host_id: 13 + reserved: 0 + + - + start_resource: 345 + num_resource: 6 + type: 16578 + host_id: 12 + reserved: 0 + + - + start_resource: 351 + num_resource: 0 + type: 16578 + host_id: 13 + reserved: 0 + + - + start_resource: 351 + num_resource: 2 + type: 16578 + host_id: 21 + reserved: 0 + + - + start_resource: 353 + num_resource: 2 + type: 16578 + host_id: 23 + reserved: 0 + + - + start_resource: 355 + num_resource: 6 + type: 16578 + host_id: 35 + reserved: 0 + + - + start_resource: 361 + num_resource: 1 + type: 16578 + host_id: 37 + reserved: 0 + + - + start_resource: 362 + num_resource: 1 + type: 16578 + host_id: 40 + reserved: 0 + + - + start_resource: 363 + num_resource: 1 + type: 16578 + host_id: 42 + reserved: 0 + + - + start_resource: 364 + num_resource: 2 + type: 16578 + host_id: 3 + reserved: 0 + + - + start_resource: 366 + num_resource: 2 + type: 16578 + host_id: 5 + reserved: 0 + + - + start_resource: 368 + num_resource: 22 + type: 16578 + host_id: 12 + reserved: 0 + + - + start_resource: 390 + num_resource: 6 + type: 16578 + host_id: 13 + reserved: 0 + + - + start_resource: 396 + num_resource: 4 + type: 16578 + host_id: 21 + reserved: 0 + + - + start_resource: 400 + num_resource: 4 + type: 16578 + host_id: 23 + reserved: 0 + + - + start_resource: 404 + num_resource: 12 + type: 16578 + host_id: 35 + reserved: 0 + + - + start_resource: 416 + num_resource: 1 + type: 16578 + host_id: 37 + reserved: 0 + + - + start_resource: 417 + num_resource: 2 + type: 16578 + host_id: 40 + reserved: 0 + + - + start_resource: 419 + num_resource: 2 + type: 16578 + host_id: 42 + reserved: 0 + + - + start_resource: 421 + num_resource: 2 + type: 16578 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 16579 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 16579 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 16579 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 16579 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 16579 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 16579 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 16579 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 16579 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 16579 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 16579 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 22 + type: 16579 + host_id: 12 + reserved: 0 + + - + start_resource: 49 + num_resource: 6 + type: 16579 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 16579 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 16579 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 16579 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 4 + type: 16579 + host_id: 37 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 16579 + host_id: 40 + reserved: 0 + + - + start_resource: 81 + num_resource: 2 + type: 16579 + host_id: 42 + reserved: 0 + + - + start_resource: 83 + num_resource: 2 + type: 16579 + host_id: 128 + reserved: 0 + + - + start_resource: 85 + num_resource: 16 + type: 16580 + host_id: 21 + reserved: 0 + + - + start_resource: 101 + num_resource: 12 + type: 16580 + host_id: 23 + reserved: 0 + + - + start_resource: 113 + num_resource: 2 + type: 16580 + host_id: 35 + reserved: 0 + + - + start_resource: 115 + num_resource: 2 + type: 16580 + host_id: 37 + reserved: 0 + + - + start_resource: 117 + num_resource: 96 + type: 16580 + host_id: 35 + reserved: 0 + + - + start_resource: 309 + num_resource: 32 + type: 16580 + host_id: 37 + reserved: 0 + + - + start_resource: 343 + num_resource: 1 + type: 16581 + host_id: 12 + reserved: 0 + + - + start_resource: 344 + num_resource: 1 + type: 16581 + host_id: 35 + reserved: 0 + + - + start_resource: 341 + num_resource: 1 + type: 16582 + host_id: 12 + reserved: 0 + + - + start_resource: 342 + num_resource: 1 + type: 16582 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 16583 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 16583 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16584 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 16584 + host_id: 35 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 16586 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 16586 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 16587 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 16587 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 3 + type: 16587 + host_id: 21 + reserved: 0 + + - + start_resource: 8 + num_resource: 3 + type: 16587 + host_id: 23 + reserved: 0 + + - + start_resource: 11 + num_resource: 6 + type: 16587 + host_id: 35 + reserved: 0 + + - + start_resource: 17 + num_resource: 3 + type: 16587 + host_id: 37 + reserved: 0 + + - + start_resource: 20 + num_resource: 3 + type: 16587 + host_id: 40 + reserved: 0 + + - + start_resource: 23 + num_resource: 3 + type: 16587 + host_id: 42 + reserved: 0 + + - + start_resource: 26 + num_resource: 1 + type: 16587 + host_id: 3 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 16587 + host_id: 5 + reserved: 0 + + - + start_resource: 28 + num_resource: 4 + type: 16587 + host_id: 128 + reserved: 0 + + - + start_resource: 82 + num_resource: 16 + type: 16832 + host_id: 12 + reserved: 0 + + - + start_resource: 98 + num_resource: 16 + type: 16832 + host_id: 13 + reserved: 0 + + - + start_resource: 114 + num_resource: 110 + type: 16832 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16833 + host_id: 128 + reserved: 0 + + - + start_resource: 49152 + num_resource: 1024 + type: 16834 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16835 + host_id: 128 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 16842 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 16842 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 16842 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 16842 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 16842 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 16842 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 16842 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 16842 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 16842 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 16842 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 22 + type: 16842 + host_id: 12 + reserved: 0 + + - + start_resource: 49 + num_resource: 6 + type: 16842 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 16842 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 16842 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 16842 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 1 + type: 16842 + host_id: 37 + reserved: 0 + + - + start_resource: 76 + num_resource: 2 + type: 16842 + host_id: 40 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 16842 + host_id: 42 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 16842 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 16843 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 16843 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16844 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 16844 + host_id: 35 + reserved: 0 + + - + start_resource: 4 + num_resource: 6 + type: 16845 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 0 + type: 16845 + host_id: 13 + reserved: 0 + + - + start_resource: 10 + num_resource: 2 + type: 16845 + host_id: 21 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 16845 + host_id: 23 + reserved: 0 + + - + start_resource: 14 + num_resource: 6 + type: 16845 + host_id: 35 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 16845 + host_id: 37 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 16845 + host_id: 40 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 16845 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 2 + type: 16845 + host_id: 3 + reserved: 0 + + - + start_resource: 25 + num_resource: 2 + type: 16845 + host_id: 5 + reserved: 0 + + - + start_resource: 27 + num_resource: 22 + type: 16845 + host_id: 12 + reserved: 0 + + - + start_resource: 49 + num_resource: 6 + type: 16845 + host_id: 13 + reserved: 0 + + - + start_resource: 55 + num_resource: 4 + type: 16845 + host_id: 21 + reserved: 0 + + - + start_resource: 59 + num_resource: 4 + type: 16845 + host_id: 23 + reserved: 0 + + - + start_resource: 63 + num_resource: 12 + type: 16845 + host_id: 35 + reserved: 0 + + - + start_resource: 75 + num_resource: 4 + type: 16845 + host_id: 37 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 16845 + host_id: 40 + reserved: 0 + + - + start_resource: 81 + num_resource: 2 + type: 16845 + host_id: 42 + reserved: 0 + + - + start_resource: 83 + num_resource: 2 + type: 16845 + host_id: 128 + reserved: 0 + + - + start_resource: 85 + num_resource: 16 + type: 16846 + host_id: 21 + reserved: 0 + + - + start_resource: 101 + num_resource: 12 + type: 16846 + host_id: 23 + reserved: 0 + + - + start_resource: 113 + num_resource: 2 + type: 16846 + host_id: 35 + reserved: 0 + + - + start_resource: 115 + num_resource: 2 + type: 16846 + host_id: 37 + reserved: 0 + + - + start_resource: 117 + num_resource: 96 + type: 16846 + host_id: 35 + reserved: 0 + + - + start_resource: 309 + num_resource: 32 + type: 16846 + host_id: 37 + reserved: 0 + + - + start_resource: 2 + num_resource: 1 + type: 16847 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 1 + type: 16847 + host_id: 35 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 16848 + host_id: 12 + reserved: 0 + + - + start_resource: 1 + num_resource: 1 + type: 16848 + host_id: 35 + reserved: 0 + + - + start_resource: 34 + num_resource: 86 + type: 16970 + host_id: 12 + reserved: 0 + + - + start_resource: 120 + num_resource: 32 + type: 16970 + host_id: 13 + reserved: 0 + + - + start_resource: 152 + num_resource: 12 + type: 16970 + host_id: 21 + reserved: 0 + + - + start_resource: 164 + num_resource: 12 + type: 16970 + host_id: 23 + reserved: 0 + + - + start_resource: 176 + num_resource: 28 + type: 16970 + host_id: 35 + reserved: 0 + + - + start_resource: 204 + num_resource: 8 + type: 16970 + host_id: 37 + reserved: 0 + + - + start_resource: 212 + num_resource: 12 + type: 16970 + host_id: 40 + reserved: 0 + + - + start_resource: 224 + num_resource: 12 + type: 16970 + host_id: 42 + reserved: 0 + + - + start_resource: 236 + num_resource: 20 + type: 16970 + host_id: 128 + reserved: 0 + + - + start_resource: 34 + num_resource: 1024 + type: 16973 + host_id: 12 + reserved: 0 + + - + start_resource: 1058 + num_resource: 512 + type: 16973 + host_id: 13 + reserved: 0 + + - + start_resource: 1570 + num_resource: 256 + type: 16973 + host_id: 21 + reserved: 0 + + - + start_resource: 1826 + num_resource: 256 + type: 16973 + host_id: 23 + reserved: 0 + + - + start_resource: 2082 + num_resource: 512 + type: 16973 + host_id: 35 + reserved: 0 + + - + start_resource: 2594 + num_resource: 256 + type: 16973 + host_id: 37 + reserved: 0 + + - + start_resource: 2850 + num_resource: 256 + type: 16973 + host_id: 40 + reserved: 0 + + - + start_resource: 3106 + num_resource: 256 + type: 16973 + host_id: 42 + reserved: 0 + + - + start_resource: 3362 + num_resource: 32 + type: 16973 + host_id: 3 + reserved: 0 + + - + start_resource: 3394 + num_resource: 32 + type: 16973 + host_id: 5 + reserved: 0 + + - + start_resource: 3426 + num_resource: 1182 + type: 16973 + host_id: 128 + reserved: 0 + + - + start_resource: 1536 + num_resource: 16 + type: 16975 + host_id: 128 + reserved: 0 + + - + start_resource: 2048 + num_resource: 16 + type: 16976 + host_id: 128 + reserved: 0 + + - + start_resource: 2560 + num_resource: 16 + type: 16977 + host_id: 128 + reserved: 0 + + - + start_resource: 3072 + num_resource: 32 + type: 16978 + host_id: 128 + reserved: 0 + + - + start_resource: 3584 + num_resource: 32 + type: 16979 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 32 + type: 16980 + host_id: 128 + reserved: 0 + + - + start_resource: 12 + num_resource: 12 + type: 17152 + host_id: 3 + reserved: 0 + + - + start_resource: 36 + num_resource: 20 + type: 17152 + host_id: 5 + reserved: 0 + + - + start_resource: 1 + num_resource: 4 + type: 17344 + host_id: 12 + reserved: 0 + + - + start_resource: 5 + num_resource: 4 + type: 17344 + host_id: 13 + reserved: 0 + + - + start_resource: 9 + num_resource: 4 + type: 17344 + host_id: 21 + reserved: 0 + + - + start_resource: 13 + num_resource: 4 + type: 17344 + host_id: 23 + reserved: 0 + + - + start_resource: 17 + num_resource: 16 + type: 17344 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 4 + type: 17344 + host_id: 37 + reserved: 0 + + - + start_resource: 37 + num_resource: 4 + type: 17344 + host_id: 40 + reserved: 0 + + - + start_resource: 41 + num_resource: 4 + type: 17344 + host_id: 42 + reserved: 0 + + - + start_resource: 45 + num_resource: 4 + type: 17344 + host_id: 3 + reserved: 0 + + - + start_resource: 49 + num_resource: 4 + type: 17344 + host_id: 5 + reserved: 0 + + - + start_resource: 53 + num_resource: 11 + type: 17344 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 17408 + host_id: 128 + reserved: 0 + + - + start_resource: 96 + num_resource: 20 + type: 17409 + host_id: 12 + reserved: 0 + + - + start_resource: 116 + num_resource: 8 + type: 17409 + host_id: 13 + reserved: 0 + + - + start_resource: 124 + num_resource: 8 + type: 17409 + host_id: 21 + reserved: 0 + + - + start_resource: 132 + num_resource: 8 + type: 17409 + host_id: 23 + reserved: 0 + + - + start_resource: 140 + num_resource: 16 + type: 17409 + host_id: 35 + reserved: 0 + + - + start_resource: 156 + num_resource: 8 + type: 17409 + host_id: 37 + reserved: 0 + + - + start_resource: 164 + num_resource: 8 + type: 17409 + host_id: 40 + reserved: 0 + + - + start_resource: 172 + num_resource: 8 + type: 17409 + host_id: 42 + reserved: 0 + + - + start_resource: 180 + num_resource: 32 + type: 17409 + host_id: 3 + reserved: 0 + + - + start_resource: 212 + num_resource: 12 + type: 17409 + host_id: 5 + reserved: 0 + + - + start_resource: 224 + num_resource: 28 + type: 17409 + host_id: 128 + reserved: 0 + + - + start_resource: 50 + num_resource: 4 + type: 17410 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 0 + type: 17410 + host_id: 13 + reserved: 0 + + - + start_resource: 54 + num_resource: 1 + type: 17410 + host_id: 21 + reserved: 0 + + - + start_resource: 55 + num_resource: 1 + type: 17410 + host_id: 23 + reserved: 0 + + - + start_resource: 56 + num_resource: 1 + type: 17410 + host_id: 35 + reserved: 0 + + - + start_resource: 57 + num_resource: 1 + type: 17410 + host_id: 37 + reserved: 0 + + - + start_resource: 58 + num_resource: 1 + type: 17410 + host_id: 40 + reserved: 0 + + - + start_resource: 59 + num_resource: 1 + type: 17410 + host_id: 42 + reserved: 0 + + - + start_resource: 60 + num_resource: 2 + type: 17410 + host_id: 3 + reserved: 0 + + - + start_resource: 62 + num_resource: 0 + type: 17410 + host_id: 5 + reserved: 0 + + - + start_resource: 62 + num_resource: 9 + type: 17410 + host_id: 12 + reserved: 0 + + - + start_resource: 71 + num_resource: 6 + type: 17410 + host_id: 13 + reserved: 0 + + - + start_resource: 77 + num_resource: 1 + type: 17410 + host_id: 21 + reserved: 0 + + - + start_resource: 78 + num_resource: 1 + type: 17410 + host_id: 23 + reserved: 0 + + - + start_resource: 79 + num_resource: 2 + type: 17410 + host_id: 35 + reserved: 0 + + - + start_resource: 81 + num_resource: 1 + type: 17410 + host_id: 37 + reserved: 0 + + - + start_resource: 82 + num_resource: 1 + type: 17410 + host_id: 40 + reserved: 0 + + - + start_resource: 83 + num_resource: 1 + type: 17410 + host_id: 42 + reserved: 0 + + - + start_resource: 84 + num_resource: 3 + type: 17410 + host_id: 3 + reserved: 0 + + - + start_resource: 87 + num_resource: 2 + type: 17410 + host_id: 5 + reserved: 0 + + - + start_resource: 89 + num_resource: 4 + type: 17410 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 17411 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 17411 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 17411 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 17411 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 17411 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 17411 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 17411 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 17411 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 17411 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 17411 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 17411 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 17411 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 17411 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 17411 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 17411 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 17411 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 17411 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 17411 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 17411 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 17411 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 5 + type: 17411 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 0 + type: 17413 + host_id: 3 + reserved: 0 + + - + start_resource: 48 + num_resource: 2 + type: 17413 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 17415 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 17415 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 5 + type: 17418 + host_id: 12 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 17418 + host_id: 13 + reserved: 0 + + - + start_resource: 0 + num_resource: 3 + type: 17419 + host_id: 12 + reserved: 0 + + - + start_resource: 3 + num_resource: 2 + type: 17419 + host_id: 13 + reserved: 0 + + - + start_resource: 5 + num_resource: 3 + type: 17419 + host_id: 21 + reserved: 0 + + - + start_resource: 8 + num_resource: 3 + type: 17419 + host_id: 23 + reserved: 0 + + - + start_resource: 11 + num_resource: 3 + type: 17419 + host_id: 35 + reserved: 0 + + - + start_resource: 14 + num_resource: 3 + type: 17419 + host_id: 37 + reserved: 0 + + - + start_resource: 17 + num_resource: 3 + type: 17419 + host_id: 40 + reserved: 0 + + - + start_resource: 20 + num_resource: 3 + type: 17419 + host_id: 42 + reserved: 0 + + - + start_resource: 23 + num_resource: 3 + type: 17419 + host_id: 3 + reserved: 0 + + - + start_resource: 26 + num_resource: 3 + type: 17419 + host_id: 5 + reserved: 0 + + - + start_resource: 29 + num_resource: 3 + type: 17419 + host_id: 128 + reserved: 0 + + - + start_resource: 48 + num_resource: 8 + type: 17472 + host_id: 12 + reserved: 0 + + - + start_resource: 56 + num_resource: 4 + type: 17472 + host_id: 13 + reserved: 0 + + - + start_resource: 60 + num_resource: 8 + type: 17472 + host_id: 35 + reserved: 0 + + - + start_resource: 68 + num_resource: 4 + type: 17472 + host_id: 37 + reserved: 0 + + - + start_resource: 72 + num_resource: 4 + type: 17472 + host_id: 40 + reserved: 0 + + - + start_resource: 76 + num_resource: 4 + type: 17472 + host_id: 42 + reserved: 0 + + - + start_resource: 80 + num_resource: 8 + type: 17472 + host_id: 3 + reserved: 0 + + - + start_resource: 88 + num_resource: 4 + type: 17472 + host_id: 5 + reserved: 0 + + - + start_resource: 92 + num_resource: 4 + type: 17472 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 17473 + host_id: 128 + reserved: 0 + + - + start_resource: 56320 + num_resource: 256 + type: 17474 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 17475 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 17482 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 17482 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 17482 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 17482 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 17482 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 17482 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 17482 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 17482 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 17482 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 17482 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 17482 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 17482 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 17482 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 17482 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 17482 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 17482 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 17482 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 17482 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 17482 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 17482 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 4 + type: 17482 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 17483 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 17483 + host_id: 3 + reserved: 0 + + - + start_resource: 2 + num_resource: 4 + type: 17485 + host_id: 12 + reserved: 0 + + - + start_resource: 6 + num_resource: 0 + type: 17485 + host_id: 13 + reserved: 0 + + - + start_resource: 6 + num_resource: 1 + type: 17485 + host_id: 21 + reserved: 0 + + - + start_resource: 7 + num_resource: 1 + type: 17485 + host_id: 23 + reserved: 0 + + - + start_resource: 8 + num_resource: 1 + type: 17485 + host_id: 35 + reserved: 0 + + - + start_resource: 9 + num_resource: 1 + type: 17485 + host_id: 37 + reserved: 0 + + - + start_resource: 10 + num_resource: 1 + type: 17485 + host_id: 40 + reserved: 0 + + - + start_resource: 11 + num_resource: 1 + type: 17485 + host_id: 42 + reserved: 0 + + - + start_resource: 12 + num_resource: 2 + type: 17485 + host_id: 3 + reserved: 0 + + - + start_resource: 14 + num_resource: 0 + type: 17485 + host_id: 5 + reserved: 0 + + - + start_resource: 14 + num_resource: 9 + type: 17485 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 6 + type: 17485 + host_id: 13 + reserved: 0 + + - + start_resource: 29 + num_resource: 1 + type: 17485 + host_id: 21 + reserved: 0 + + - + start_resource: 30 + num_resource: 1 + type: 17485 + host_id: 23 + reserved: 0 + + - + start_resource: 31 + num_resource: 2 + type: 17485 + host_id: 35 + reserved: 0 + + - + start_resource: 33 + num_resource: 1 + type: 17485 + host_id: 37 + reserved: 0 + + - + start_resource: 34 + num_resource: 1 + type: 17485 + host_id: 40 + reserved: 0 + + - + start_resource: 35 + num_resource: 1 + type: 17485 + host_id: 42 + reserved: 0 + + - + start_resource: 36 + num_resource: 3 + type: 17485 + host_id: 3 + reserved: 0 + + - + start_resource: 39 + num_resource: 2 + type: 17485 + host_id: 5 + reserved: 0 + + - + start_resource: 41 + num_resource: 5 + type: 17485 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 0 + type: 17487 + host_id: 3 + reserved: 0 + + - + start_resource: 0 + num_resource: 2 + type: 17487 + host_id: 3 + reserved: 0 + + - + start_resource: 22 + num_resource: 32 + type: 17610 + host_id: 12 + reserved: 0 + + - + start_resource: 54 + num_resource: 16 + type: 17610 + host_id: 13 + reserved: 0 + + - + start_resource: 70 + num_resource: 8 + type: 17610 + host_id: 21 + reserved: 0 + + - + start_resource: 78 + num_resource: 8 + type: 17610 + host_id: 23 + reserved: 0 + + - + start_resource: 86 + num_resource: 24 + type: 17610 + host_id: 35 + reserved: 0 + + - + start_resource: 110 + num_resource: 8 + type: 17610 + host_id: 37 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 17610 + host_id: 40 + reserved: 0 + + - + start_resource: 134 + num_resource: 16 + type: 17610 + host_id: 42 + reserved: 0 + + - + start_resource: 150 + num_resource: 64 + type: 17610 + host_id: 3 + reserved: 0 + + - + start_resource: 214 + num_resource: 4 + type: 17610 + host_id: 5 + reserved: 0 + + - + start_resource: 218 + num_resource: 38 + type: 17610 + host_id: 128 + reserved: 0 + + - + start_resource: 16406 + num_resource: 128 + type: 17613 + host_id: 12 + reserved: 0 + + - + start_resource: 16534 + num_resource: 128 + type: 17613 + host_id: 13 + reserved: 0 + + - + start_resource: 16662 + num_resource: 64 + type: 17613 + host_id: 21 + reserved: 0 + + - + start_resource: 16726 + num_resource: 64 + type: 17613 + host_id: 23 + reserved: 0 + + - + start_resource: 16790 + num_resource: 128 + type: 17613 + host_id: 35 + reserved: 0 + + - + start_resource: 16918 + num_resource: 128 + type: 17613 + host_id: 37 + reserved: 0 + + - + start_resource: 17046 + num_resource: 128 + type: 17613 + host_id: 40 + reserved: 0 + + - + start_resource: 17174 + num_resource: 128 + type: 17613 + host_id: 42 + reserved: 0 + + - + start_resource: 17302 + num_resource: 256 + type: 17613 + host_id: 3 + reserved: 0 + + - + start_resource: 17558 + num_resource: 64 + type: 17613 + host_id: 5 + reserved: 0 + + - + start_resource: 17622 + num_resource: 298 + type: 17613 + host_id: 128 + reserved: 0 diff --git a/board/ti/j721s2/sec-cfg.yaml b/board/ti/j721s2/sec-cfg.yaml new file mode 100644 index 0000000000..7484a1b58e --- /dev/null +++ b/board/ti/j721s2/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for J721S2 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0 + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x0 + allow_wildcard_unlock : 0x0 + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
+board-cfg:
- rev:
- control:
subhdr:
magic: 0xC1D3
- secproxy:
subhdr:
magic: 0x1207
- msmc:
subhdr:
magic: 0xA5C3
- debug_cfg:
subhdr:
magic: 0x020C
+pm-cfg:
- rev:
+rm-cfg:
- rm_boardcfg:
rev:
host_cfg:
subhdr:
magic: 0x4C41
host_cfg_entries:
- #1
host_id: 3
- #2
host_id: 5
- #3
host_id: 12
- #4
host_id: 13
- #5
host_id: 21
- #6
host_id: 23
- #7
host_id: 35
- #8
host_id: 37
- #9
host_id: 40
- #10
host_id: 42
- #11
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #12
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #13
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #14
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #15
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #16
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #17
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #18
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #19
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #20
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #21
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #22
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #23
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #24
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #25
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #26
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #27
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #28
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #29
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #30
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #31
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
- #32
host_id: 0
allowed_atype : 0
allowed_qos : 0
allowed_orderid : 0
resasg:
subhdr:
magic: 0x7B25
reserved : 0
- resasg_entries:
start_resource: 0
num_resource: 32
type: 7744
host_id: 3
reserved: 0
start_resource: 32
num_resource: 24
type: 7744
host_id: 5
reserved: 0
start_resource: 0
num_resource: 24
type: 7808
host_id: 3
reserved: 0
start_resource: 24
num_resource: 16
type: 7808
host_id: 5
reserved: 0
start_resource: 0
num_resource: 48
type: 7936
host_id: 128
reserved: 0
start_resource: 0
num_resource: 8
type: 8000
host_id: 3
reserved: 0
start_resource: 8
num_resource: 8
type: 8000
host_id: 5
reserved: 0
start_resource: 16
num_resource: 6
type: 8000
host_id: 12
reserved: 0
start_resource: 22
num_resource: 6
type: 8000
host_id: 13
reserved: 0
start_resource: 28
num_resource: 2
type: 8000
host_id: 35
reserved: 0
start_resource: 30
num_resource: 2
type: 8000
host_id: 37
reserved: 0
start_resource: 0
num_resource: 4
type: 9472
host_id: 35
reserved: 0
start_resource: 4
num_resource: 4
type: 9472
host_id: 37
reserved: 0
start_resource: 8
num_resource: 4
type: 9472
host_id: 40
reserved: 0
start_resource: 12
num_resource: 4
type: 9472
host_id: 42
reserved: 0
start_resource: 16
num_resource: 8
type: 9472
host_id: 3
reserved: 0
start_resource: 24
num_resource: 8
type: 9472
host_id: 5
reserved: 0
start_resource: 32
num_resource: 12
type: 9472
host_id: 12
reserved: 0
start_resource: 44
num_resource: 12
type: 9472
host_id: 13
reserved: 0
start_resource: 0
num_resource: 16
type: 9600
host_id: 128
reserved: 0
num_resource: 96
type: 14402
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 14403
host_id: 128
reserved: 0
start_resource: 16
num_resource: 16
type: 14414
host_id: 12
reserved: 0
start_resource: 32
num_resource: 16
type: 14414
host_id: 35
reserved: 0
start_resource: 0
num_resource: 8
type: 14415
host_id: 12
reserved: 0
start_resource: 8
num_resource: 8
type: 14415
host_id: 35
reserved: 0
start_resource: 0
num_resource: 16
type: 14433
host_id: 12
reserved: 0
start_resource: 16
num_resource: 16
type: 14433
host_id: 35
reserved: 0
start_resource: 0
num_resource: 8
type: 14434
host_id: 12
reserved: 0
start_resource: 8
num_resource: 8
type: 14434
host_id: 35
reserved: 0
start_resource: 10
num_resource: 100
type: 14528
host_id: 12
reserved: 0
start_resource: 110
num_resource: 32
type: 14528
host_id: 13
reserved: 0
start_resource: 142
num_resource: 21
type: 14528
host_id: 21
reserved: 0
start_resource: 163
num_resource: 21
type: 14528
host_id: 23
reserved: 0
start_resource: 196
num_resource: 28
type: 14528
host_id: 35
reserved: 0
start_resource: 228
num_resource: 28
type: 14528
host_id: 37
reserved: 0
start_resource: 260
num_resource: 28
type: 14528
host_id: 40
reserved: 0
start_resource: 292
num_resource: 28
type: 14528
host_id: 42
reserved: 0
start_resource: 400
num_resource: 4
type: 14528
host_id: 3
reserved: 0
start_resource: 404
num_resource: 4
type: 14528
host_id: 5
reserved: 0
start_resource: 0
num_resource: 64
type: 16266
host_id: 128
reserved: 0
num_resource: 1024
type: 16269
host_id: 128
reserved: 0
start_resource: 0
num_resource: 64
type: 16330
host_id: 128
reserved: 0
num_resource: 1024
type: 16333
host_id: 128
reserved: 0
start_resource: 0
num_resource: 4
type: 16384
host_id: 12
reserved: 0
start_resource: 4
num_resource: 4
type: 16384
host_id: 13
reserved: 0
start_resource: 8
num_resource: 4
type: 16384
host_id: 21
reserved: 0
start_resource: 12
num_resource: 4
type: 16384
host_id: 23
reserved: 0
start_resource: 16
num_resource: 12
type: 16384
host_id: 35
reserved: 0
start_resource: 28
num_resource: 4
type: 16384
host_id: 37
reserved: 0
start_resource: 32
num_resource: 4
type: 16384
host_id: 40
reserved: 0
start_resource: 36
num_resource: 4
type: 16384
host_id: 42
reserved: 0
start_resource: 40
num_resource: 4
type: 16384
host_id: 3
reserved: 0
start_resource: 44
num_resource: 4
type: 16384
host_id: 5
reserved: 0
start_resource: 48
num_resource: 16
type: 16384
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 16576
host_id: 128
reserved: 0
start_resource: 423
num_resource: 32
type: 16577
host_id: 21
reserved: 0
start_resource: 455
num_resource: 32
type: 16577
host_id: 23
reserved: 0
start_resource: 487
num_resource: 182
type: 16577
host_id: 35
reserved: 0
start_resource: 669
num_resource: 40
type: 16577
host_id: 37
reserved: 0
start_resource: 709
num_resource: 10
type: 16577
host_id: 40
reserved: 0
start_resource: 719
num_resource: 10
type: 16577
host_id: 42
reserved: 0
start_resource: 729
num_resource: 6
type: 16577
host_id: 3
reserved: 0
start_resource: 735
num_resource: 6
type: 16577
host_id: 5
reserved: 0
start_resource: 878
num_resource: 128
type: 16577
host_id: 12
reserved: 0
num_resource: 10
type: 16577
host_id: 13
reserved: 0
start_resource: 345
num_resource: 6
type: 16578
host_id: 12
reserved: 0
start_resource: 351
num_resource: 0
type: 16578
host_id: 13
reserved: 0
start_resource: 351
num_resource: 2
type: 16578
host_id: 21
reserved: 0
start_resource: 353
num_resource: 2
type: 16578
host_id: 23
reserved: 0
start_resource: 355
num_resource: 6
type: 16578
host_id: 35
reserved: 0
start_resource: 361
num_resource: 1
type: 16578
host_id: 37
reserved: 0
start_resource: 362
num_resource: 1
type: 16578
host_id: 40
reserved: 0
start_resource: 363
num_resource: 1
type: 16578
host_id: 42
reserved: 0
start_resource: 364
num_resource: 2
type: 16578
host_id: 3
reserved: 0
start_resource: 366
num_resource: 2
type: 16578
host_id: 5
reserved: 0
start_resource: 368
num_resource: 22
type: 16578
host_id: 12
reserved: 0
start_resource: 390
num_resource: 6
type: 16578
host_id: 13
reserved: 0
start_resource: 396
num_resource: 4
type: 16578
host_id: 21
reserved: 0
start_resource: 400
num_resource: 4
type: 16578
host_id: 23
reserved: 0
start_resource: 404
num_resource: 12
type: 16578
host_id: 35
reserved: 0
start_resource: 416
num_resource: 1
type: 16578
host_id: 37
reserved: 0
start_resource: 417
num_resource: 2
type: 16578
host_id: 40
reserved: 0
start_resource: 419
num_resource: 2
type: 16578
host_id: 42
reserved: 0
start_resource: 421
num_resource: 2
type: 16578
host_id: 128
reserved: 0
start_resource: 4
num_resource: 6
type: 16579
host_id: 12
reserved: 0
start_resource: 10
num_resource: 0
type: 16579
host_id: 13
reserved: 0
start_resource: 10
num_resource: 2
type: 16579
host_id: 21
reserved: 0
start_resource: 12
num_resource: 2
type: 16579
host_id: 23
reserved: 0
start_resource: 14
num_resource: 6
type: 16579
host_id: 35
reserved: 0
start_resource: 20
num_resource: 1
type: 16579
host_id: 37
reserved: 0
start_resource: 21
num_resource: 1
type: 16579
host_id: 40
reserved: 0
start_resource: 22
num_resource: 1
type: 16579
host_id: 42
reserved: 0
start_resource: 23
num_resource: 2
type: 16579
host_id: 3
reserved: 0
start_resource: 25
num_resource: 2
type: 16579
host_id: 5
reserved: 0
start_resource: 27
num_resource: 22
type: 16579
host_id: 12
reserved: 0
start_resource: 49
num_resource: 6
type: 16579
host_id: 13
reserved: 0
start_resource: 55
num_resource: 4
type: 16579
host_id: 21
reserved: 0
start_resource: 59
num_resource: 4
type: 16579
host_id: 23
reserved: 0
start_resource: 63
num_resource: 12
type: 16579
host_id: 35
reserved: 0
start_resource: 75
num_resource: 4
type: 16579
host_id: 37
reserved: 0
start_resource: 79
num_resource: 2
type: 16579
host_id: 40
reserved: 0
start_resource: 81
num_resource: 2
type: 16579
host_id: 42
reserved: 0
start_resource: 83
num_resource: 2
type: 16579
host_id: 128
reserved: 0
start_resource: 85
num_resource: 16
type: 16580
host_id: 21
reserved: 0
start_resource: 101
num_resource: 12
type: 16580
host_id: 23
reserved: 0
start_resource: 113
num_resource: 2
type: 16580
host_id: 35
reserved: 0
start_resource: 115
num_resource: 2
type: 16580
host_id: 37
reserved: 0
start_resource: 117
num_resource: 96
type: 16580
host_id: 35
reserved: 0
start_resource: 309
num_resource: 32
type: 16580
host_id: 37
reserved: 0
start_resource: 343
num_resource: 1
type: 16581
host_id: 12
reserved: 0
start_resource: 344
num_resource: 1
type: 16581
host_id: 35
reserved: 0
start_resource: 341
num_resource: 1
type: 16582
host_id: 12
reserved: 0
start_resource: 342
num_resource: 1
type: 16582
host_id: 35
reserved: 0
start_resource: 2
num_resource: 1
type: 16583
host_id: 12
reserved: 0
start_resource: 3
num_resource: 1
type: 16583
host_id: 35
reserved: 0
start_resource: 0
num_resource: 1
type: 16584
host_id: 12
reserved: 0
start_resource: 1
num_resource: 1
type: 16584
host_id: 35
reserved: 0
start_resource: 2
num_resource: 5
type: 16586
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 16586
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 16587
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 16587
host_id: 13
reserved: 0
start_resource: 5
num_resource: 3
type: 16587
host_id: 21
reserved: 0
start_resource: 8
num_resource: 3
type: 16587
host_id: 23
reserved: 0
start_resource: 11
num_resource: 6
type: 16587
host_id: 35
reserved: 0
start_resource: 17
num_resource: 3
type: 16587
host_id: 37
reserved: 0
start_resource: 20
num_resource: 3
type: 16587
host_id: 40
reserved: 0
start_resource: 23
num_resource: 3
type: 16587
host_id: 42
reserved: 0
start_resource: 26
num_resource: 1
type: 16587
host_id: 3
reserved: 0
start_resource: 27
num_resource: 1
type: 16587
host_id: 5
reserved: 0
start_resource: 28
num_resource: 4
type: 16587
host_id: 128
reserved: 0
start_resource: 82
num_resource: 16
type: 16832
host_id: 12
reserved: 0
start_resource: 98
num_resource: 16
type: 16832
host_id: 13
reserved: 0
start_resource: 114
num_resource: 110
type: 16832
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 16833
host_id: 128
reserved: 0
num_resource: 1024
type: 16834
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 16835
host_id: 128
reserved: 0
start_resource: 4
num_resource: 6
type: 16842
host_id: 12
reserved: 0
start_resource: 10
num_resource: 0
type: 16842
host_id: 13
reserved: 0
start_resource: 10
num_resource: 2
type: 16842
host_id: 21
reserved: 0
start_resource: 12
num_resource: 2
type: 16842
host_id: 23
reserved: 0
start_resource: 14
num_resource: 6
type: 16842
host_id: 35
reserved: 0
start_resource: 20
num_resource: 1
type: 16842
host_id: 37
reserved: 0
start_resource: 21
num_resource: 1
type: 16842
host_id: 40
reserved: 0
start_resource: 22
num_resource: 1
type: 16842
host_id: 42
reserved: 0
start_resource: 23
num_resource: 2
type: 16842
host_id: 3
reserved: 0
start_resource: 25
num_resource: 2
type: 16842
host_id: 5
reserved: 0
start_resource: 27
num_resource: 22
type: 16842
host_id: 12
reserved: 0
start_resource: 49
num_resource: 6
type: 16842
host_id: 13
reserved: 0
start_resource: 55
num_resource: 4
type: 16842
host_id: 21
reserved: 0
start_resource: 59
num_resource: 4
type: 16842
host_id: 23
reserved: 0
start_resource: 63
num_resource: 12
type: 16842
host_id: 35
reserved: 0
start_resource: 75
num_resource: 1
type: 16842
host_id: 37
reserved: 0
start_resource: 76
num_resource: 2
type: 16842
host_id: 40
reserved: 0
start_resource: 78
num_resource: 2
type: 16842
host_id: 42
reserved: 0
start_resource: 80
num_resource: 2
type: 16842
host_id: 128
reserved: 0
start_resource: 2
num_resource: 1
type: 16843
host_id: 12
reserved: 0
start_resource: 3
num_resource: 1
type: 16843
host_id: 35
reserved: 0
start_resource: 0
num_resource: 1
type: 16844
host_id: 12
reserved: 0
start_resource: 1
num_resource: 1
type: 16844
host_id: 35
reserved: 0
start_resource: 4
num_resource: 6
type: 16845
host_id: 12
reserved: 0
start_resource: 10
num_resource: 0
type: 16845
host_id: 13
reserved: 0
start_resource: 10
num_resource: 2
type: 16845
host_id: 21
reserved: 0
start_resource: 12
num_resource: 2
type: 16845
host_id: 23
reserved: 0
start_resource: 14
num_resource: 6
type: 16845
host_id: 35
reserved: 0
start_resource: 20
num_resource: 1
type: 16845
host_id: 37
reserved: 0
start_resource: 21
num_resource: 1
type: 16845
host_id: 40
reserved: 0
start_resource: 22
num_resource: 1
type: 16845
host_id: 42
reserved: 0
start_resource: 23
num_resource: 2
type: 16845
host_id: 3
reserved: 0
start_resource: 25
num_resource: 2
type: 16845
host_id: 5
reserved: 0
start_resource: 27
num_resource: 22
type: 16845
host_id: 12
reserved: 0
start_resource: 49
num_resource: 6
type: 16845
host_id: 13
reserved: 0
start_resource: 55
num_resource: 4
type: 16845
host_id: 21
reserved: 0
start_resource: 59
num_resource: 4
type: 16845
host_id: 23
reserved: 0
start_resource: 63
num_resource: 12
type: 16845
host_id: 35
reserved: 0
start_resource: 75
num_resource: 4
type: 16845
host_id: 37
reserved: 0
start_resource: 79
num_resource: 2
type: 16845
host_id: 40
reserved: 0
start_resource: 81
num_resource: 2
type: 16845
host_id: 42
reserved: 0
start_resource: 83
num_resource: 2
type: 16845
host_id: 128
reserved: 0
start_resource: 85
num_resource: 16
type: 16846
host_id: 21
reserved: 0
start_resource: 101
num_resource: 12
type: 16846
host_id: 23
reserved: 0
start_resource: 113
num_resource: 2
type: 16846
host_id: 35
reserved: 0
start_resource: 115
num_resource: 2
type: 16846
host_id: 37
reserved: 0
start_resource: 117
num_resource: 96
type: 16846
host_id: 35
reserved: 0
start_resource: 309
num_resource: 32
type: 16846
host_id: 37
reserved: 0
start_resource: 2
num_resource: 1
type: 16847
host_id: 12
reserved: 0
start_resource: 3
num_resource: 1
type: 16847
host_id: 35
reserved: 0
start_resource: 0
num_resource: 1
type: 16848
host_id: 12
reserved: 0
start_resource: 1
num_resource: 1
type: 16848
host_id: 35
reserved: 0
start_resource: 34
num_resource: 86
type: 16970
host_id: 12
reserved: 0
start_resource: 120
num_resource: 32
type: 16970
host_id: 13
reserved: 0
start_resource: 152
num_resource: 12
type: 16970
host_id: 21
reserved: 0
start_resource: 164
num_resource: 12
type: 16970
host_id: 23
reserved: 0
start_resource: 176
num_resource: 28
type: 16970
host_id: 35
reserved: 0
start_resource: 204
num_resource: 8
type: 16970
host_id: 37
reserved: 0
start_resource: 212
num_resource: 12
type: 16970
host_id: 40
reserved: 0
start_resource: 224
num_resource: 12
type: 16970
host_id: 42
reserved: 0
start_resource: 236
num_resource: 20
type: 16970
host_id: 128
reserved: 0
start_resource: 34
num_resource: 1024
type: 16973
host_id: 12
reserved: 0
num_resource: 512
type: 16973
host_id: 13
reserved: 0
num_resource: 256
type: 16973
host_id: 21
reserved: 0
num_resource: 256
type: 16973
host_id: 23
reserved: 0
num_resource: 512
type: 16973
host_id: 35
reserved: 0
num_resource: 256
type: 16973
host_id: 37
reserved: 0
num_resource: 256
type: 16973
host_id: 40
reserved: 0
num_resource: 256
type: 16973
host_id: 42
reserved: 0
num_resource: 32
type: 16973
host_id: 3
reserved: 0
num_resource: 32
type: 16973
host_id: 5
reserved: 0
num_resource: 1182
type: 16973
host_id: 128
reserved: 0
num_resource: 16
type: 16975
host_id: 128
reserved: 0
num_resource: 16
type: 16976
host_id: 128
reserved: 0
num_resource: 16
type: 16977
host_id: 128
reserved: 0
num_resource: 32
type: 16978
host_id: 128
reserved: 0
num_resource: 32
type: 16979
host_id: 128
reserved: 0
num_resource: 32
type: 16980
host_id: 128
reserved: 0
start_resource: 12
num_resource: 12
type: 17152
host_id: 3
reserved: 0
start_resource: 36
num_resource: 20
type: 17152
host_id: 5
reserved: 0
start_resource: 1
num_resource: 4
type: 17344
host_id: 12
reserved: 0
start_resource: 5
num_resource: 4
type: 17344
host_id: 13
reserved: 0
start_resource: 9
num_resource: 4
type: 17344
host_id: 21
reserved: 0
start_resource: 13
num_resource: 4
type: 17344
host_id: 23
reserved: 0
start_resource: 17
num_resource: 16
type: 17344
host_id: 35
reserved: 0
start_resource: 33
num_resource: 4
type: 17344
host_id: 37
reserved: 0
start_resource: 37
num_resource: 4
type: 17344
host_id: 40
reserved: 0
start_resource: 41
num_resource: 4
type: 17344
host_id: 42
reserved: 0
start_resource: 45
num_resource: 4
type: 17344
host_id: 3
reserved: 0
start_resource: 49
num_resource: 4
type: 17344
host_id: 5
reserved: 0
start_resource: 53
num_resource: 11
type: 17344
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 17408
host_id: 128
reserved: 0
start_resource: 96
num_resource: 20
type: 17409
host_id: 12
reserved: 0
start_resource: 116
num_resource: 8
type: 17409
host_id: 13
reserved: 0
start_resource: 124
num_resource: 8
type: 17409
host_id: 21
reserved: 0
start_resource: 132
num_resource: 8
type: 17409
host_id: 23
reserved: 0
start_resource: 140
num_resource: 16
type: 17409
host_id: 35
reserved: 0
start_resource: 156
num_resource: 8
type: 17409
host_id: 37
reserved: 0
start_resource: 164
num_resource: 8
type: 17409
host_id: 40
reserved: 0
start_resource: 172
num_resource: 8
type: 17409
host_id: 42
reserved: 0
start_resource: 180
num_resource: 32
type: 17409
host_id: 3
reserved: 0
start_resource: 212
num_resource: 12
type: 17409
host_id: 5
reserved: 0
start_resource: 224
num_resource: 28
type: 17409
host_id: 128
reserved: 0
start_resource: 50
num_resource: 4
type: 17410
host_id: 12
reserved: 0
start_resource: 54
num_resource: 0
type: 17410
host_id: 13
reserved: 0
start_resource: 54
num_resource: 1
type: 17410
host_id: 21
reserved: 0
start_resource: 55
num_resource: 1
type: 17410
host_id: 23
reserved: 0
start_resource: 56
num_resource: 1
type: 17410
host_id: 35
reserved: 0
start_resource: 57
num_resource: 1
type: 17410
host_id: 37
reserved: 0
start_resource: 58
num_resource: 1
type: 17410
host_id: 40
reserved: 0
start_resource: 59
num_resource: 1
type: 17410
host_id: 42
reserved: 0
start_resource: 60
num_resource: 2
type: 17410
host_id: 3
reserved: 0
start_resource: 62
num_resource: 0
type: 17410
host_id: 5
reserved: 0
start_resource: 62
num_resource: 9
type: 17410
host_id: 12
reserved: 0
start_resource: 71
num_resource: 6
type: 17410
host_id: 13
reserved: 0
start_resource: 77
num_resource: 1
type: 17410
host_id: 21
reserved: 0
start_resource: 78
num_resource: 1
type: 17410
host_id: 23
reserved: 0
start_resource: 79
num_resource: 2
type: 17410
host_id: 35
reserved: 0
start_resource: 81
num_resource: 1
type: 17410
host_id: 37
reserved: 0
start_resource: 82
num_resource: 1
type: 17410
host_id: 40
reserved: 0
start_resource: 83
num_resource: 1
type: 17410
host_id: 42
reserved: 0
start_resource: 84
num_resource: 3
type: 17410
host_id: 3
reserved: 0
start_resource: 87
num_resource: 2
type: 17410
host_id: 5
reserved: 0
start_resource: 89
num_resource: 4
type: 17410
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 17411
host_id: 12
reserved: 0
start_resource: 6
num_resource: 0
type: 17411
host_id: 13
reserved: 0
start_resource: 6
num_resource: 1
type: 17411
host_id: 21
reserved: 0
start_resource: 7
num_resource: 1
type: 17411
host_id: 23
reserved: 0
start_resource: 8
num_resource: 1
type: 17411
host_id: 35
reserved: 0
start_resource: 9
num_resource: 1
type: 17411
host_id: 37
reserved: 0
start_resource: 10
num_resource: 1
type: 17411
host_id: 40
reserved: 0
start_resource: 11
num_resource: 1
type: 17411
host_id: 42
reserved: 0
start_resource: 12
num_resource: 2
type: 17411
host_id: 3
reserved: 0
start_resource: 14
num_resource: 0
type: 17411
host_id: 5
reserved: 0
start_resource: 14
num_resource: 9
type: 17411
host_id: 12
reserved: 0
start_resource: 23
num_resource: 6
type: 17411
host_id: 13
reserved: 0
start_resource: 29
num_resource: 1
type: 17411
host_id: 21
reserved: 0
start_resource: 30
num_resource: 1
type: 17411
host_id: 23
reserved: 0
start_resource: 31
num_resource: 2
type: 17411
host_id: 35
reserved: 0
start_resource: 33
num_resource: 1
type: 17411
host_id: 37
reserved: 0
start_resource: 34
num_resource: 1
type: 17411
host_id: 40
reserved: 0
start_resource: 35
num_resource: 1
type: 17411
host_id: 42
reserved: 0
start_resource: 36
num_resource: 3
type: 17411
host_id: 3
reserved: 0
start_resource: 39
num_resource: 2
type: 17411
host_id: 5
reserved: 0
start_resource: 41
num_resource: 5
type: 17411
host_id: 128
reserved: 0
start_resource: 48
num_resource: 0
type: 17413
host_id: 3
reserved: 0
start_resource: 48
num_resource: 2
type: 17413
host_id: 3
reserved: 0
start_resource: 0
num_resource: 0
type: 17415
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 17415
host_id: 3
reserved: 0
start_resource: 2
num_resource: 5
type: 17418
host_id: 12
reserved: 0
start_resource: 7
num_resource: 1
type: 17418
host_id: 13
reserved: 0
start_resource: 0
num_resource: 3
type: 17419
host_id: 12
reserved: 0
start_resource: 3
num_resource: 2
type: 17419
host_id: 13
reserved: 0
start_resource: 5
num_resource: 3
type: 17419
host_id: 21
reserved: 0
start_resource: 8
num_resource: 3
type: 17419
host_id: 23
reserved: 0
start_resource: 11
num_resource: 3
type: 17419
host_id: 35
reserved: 0
start_resource: 14
num_resource: 3
type: 17419
host_id: 37
reserved: 0
start_resource: 17
num_resource: 3
type: 17419
host_id: 40
reserved: 0
start_resource: 20
num_resource: 3
type: 17419
host_id: 42
reserved: 0
start_resource: 23
num_resource: 3
type: 17419
host_id: 3
reserved: 0
start_resource: 26
num_resource: 3
type: 17419
host_id: 5
reserved: 0
start_resource: 29
num_resource: 3
type: 17419
host_id: 128
reserved: 0
start_resource: 48
num_resource: 8
type: 17472
host_id: 12
reserved: 0
start_resource: 56
num_resource: 4
type: 17472
host_id: 13
reserved: 0
start_resource: 60
num_resource: 8
type: 17472
host_id: 35
reserved: 0
start_resource: 68
num_resource: 4
type: 17472
host_id: 37
reserved: 0
start_resource: 72
num_resource: 4
type: 17472
host_id: 40
reserved: 0
start_resource: 76
num_resource: 4
type: 17472
host_id: 42
reserved: 0
start_resource: 80
num_resource: 8
type: 17472
host_id: 3
reserved: 0
start_resource: 88
num_resource: 4
type: 17472
host_id: 5
reserved: 0
start_resource: 92
num_resource: 4
type: 17472
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 17473
host_id: 128
reserved: 0
num_resource: 256
type: 17474
host_id: 128
reserved: 0
start_resource: 0
num_resource: 1
type: 17475
host_id: 128
reserved: 0
start_resource: 2
num_resource: 4
type: 17482
host_id: 12
reserved: 0
start_resource: 6
num_resource: 0
type: 17482
host_id: 13
reserved: 0
start_resource: 6
num_resource: 1
type: 17482
host_id: 21
reserved: 0
start_resource: 7
num_resource: 1
type: 17482
host_id: 23
reserved: 0
start_resource: 8
num_resource: 1
type: 17482
host_id: 35
reserved: 0
start_resource: 9
num_resource: 1
type: 17482
host_id: 37
reserved: 0
start_resource: 10
num_resource: 1
type: 17482
host_id: 40
reserved: 0
start_resource: 11
num_resource: 1
type: 17482
host_id: 42
reserved: 0
start_resource: 12
num_resource: 2
type: 17482
host_id: 3
reserved: 0
start_resource: 14
num_resource: 0
type: 17482
host_id: 5
reserved: 0
start_resource: 14
num_resource: 9
type: 17482
host_id: 12
reserved: 0
start_resource: 23
num_resource: 6
type: 17482
host_id: 13
reserved: 0
start_resource: 29
num_resource: 1
type: 17482
host_id: 21
reserved: 0
start_resource: 30
num_resource: 1
type: 17482
host_id: 23
reserved: 0
start_resource: 31
num_resource: 2
type: 17482
host_id: 35
reserved: 0
start_resource: 33
num_resource: 1
type: 17482
host_id: 37
reserved: 0
start_resource: 34
num_resource: 1
type: 17482
host_id: 40
reserved: 0
start_resource: 35
num_resource: 1
type: 17482
host_id: 42
reserved: 0
start_resource: 36
num_resource: 3
type: 17482
host_id: 3
reserved: 0
start_resource: 39
num_resource: 2
type: 17482
host_id: 5
reserved: 0
start_resource: 41
num_resource: 4
type: 17482
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 17483
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 17483
host_id: 3
reserved: 0
start_resource: 2
num_resource: 4
type: 17485
host_id: 12
reserved: 0
start_resource: 6
num_resource: 0
type: 17485
host_id: 13
reserved: 0
start_resource: 6
num_resource: 1
type: 17485
host_id: 21
reserved: 0
start_resource: 7
num_resource: 1
type: 17485
host_id: 23
reserved: 0
start_resource: 8
num_resource: 1
type: 17485
host_id: 35
reserved: 0
start_resource: 9
num_resource: 1
type: 17485
host_id: 37
reserved: 0
start_resource: 10
num_resource: 1
type: 17485
host_id: 40
reserved: 0
start_resource: 11
num_resource: 1
type: 17485
host_id: 42
reserved: 0
start_resource: 12
num_resource: 2
type: 17485
host_id: 3
reserved: 0
start_resource: 14
num_resource: 0
type: 17485
host_id: 5
reserved: 0
start_resource: 14
num_resource: 9
type: 17485
host_id: 12
reserved: 0
start_resource: 23
num_resource: 6
type: 17485
host_id: 13
reserved: 0
start_resource: 29
num_resource: 1
type: 17485
host_id: 21
reserved: 0
start_resource: 30
num_resource: 1
type: 17485
host_id: 23
reserved: 0
start_resource: 31
num_resource: 2
type: 17485
host_id: 35
reserved: 0
start_resource: 33
num_resource: 1
type: 17485
host_id: 37
reserved: 0
start_resource: 34
num_resource: 1
type: 17485
host_id: 40
reserved: 0
start_resource: 35
num_resource: 1
type: 17485
host_id: 42
reserved: 0
start_resource: 36
num_resource: 3
type: 17485
host_id: 3
reserved: 0
start_resource: 39
num_resource: 2
type: 17485
host_id: 5
reserved: 0
start_resource: 41
num_resource: 5
type: 17485
host_id: 128
reserved: 0
start_resource: 0
num_resource: 0
type: 17487
host_id: 3
reserved: 0
start_resource: 0
num_resource: 2
type: 17487
host_id: 3
reserved: 0
start_resource: 22
num_resource: 32
type: 17610
host_id: 12
reserved: 0
start_resource: 54
num_resource: 16
type: 17610
host_id: 13
reserved: 0
start_resource: 70
num_resource: 8
type: 17610
host_id: 21
reserved: 0
start_resource: 78
num_resource: 8
type: 17610
host_id: 23
reserved: 0
start_resource: 86
num_resource: 24
type: 17610
host_id: 35
reserved: 0
start_resource: 110
num_resource: 8
type: 17610
host_id: 37
reserved: 0
start_resource: 118
num_resource: 16
type: 17610
host_id: 40
reserved: 0
start_resource: 134
num_resource: 16
type: 17610
host_id: 42
reserved: 0
start_resource: 150
num_resource: 64
type: 17610
host_id: 3
reserved: 0
start_resource: 214
num_resource: 4
type: 17610
host_id: 5
reserved: 0
start_resource: 218
num_resource: 38
type: 17610
host_id: 128
reserved: 0
num_resource: 128
type: 17613
host_id: 12
reserved: 0
num_resource: 128
type: 17613
host_id: 13
reserved: 0
num_resource: 64
type: 17613
host_id: 21
reserved: 0
num_resource: 64
type: 17613
host_id: 23
reserved: 0
num_resource: 128
type: 17613
host_id: 35
reserved: 0
num_resource: 128
type: 17613
host_id: 37
reserved: 0
num_resource: 128
type: 17613
host_id: 40
reserved: 0
num_resource: 128
type: 17613
host_id: 42
reserved: 0
num_resource: 256
type: 17613
host_id: 3
reserved: 0
num_resource: 64
type: 17613
host_id: 5
reserved: 0
num_resource: 298
type: 17613
host_id: 128
reserved: 0
+sec-cfg:
- rev:
- processor_acl_list:
subhdr:
magic: 0xF1EA
proc_acl_entries:
- #1
processor_id: 0
- #2
processor_id: 0
- #3
processor_id: 0
- #4
processor_id: 0
- #5
processor_id: 0
- #6
processor_id: 0
- #7
processor_id: 0
- #8
processor_id: 0
- #9
processor_id: 0
- #10
processor_id: 0
- #11
processor_id: 0
- #12
processor_id: 0
- #13
processor_id: 0
- #14
processor_id: 0
- #15
processor_id: 0
- #16
processor_id: 0
- #17
processor_id: 0
- #18
processor_id: 0
- #19
processor_id: 0
- #20
processor_id: 0
- #21
processor_id: 0
- #22
processor_id: 0
- #23
processor_id: 0
- #24
processor_id: 0
- #25
processor_id: 0
- #26
processor_id: 0
- #27
processor_id: 0
- #28
processor_id: 0
- #29
processor_id: 0
- #30
processor_id: 0
- #31
processor_id: 0
- #32
processor_id: 0
- host_hierarchy:
subhdr:
magic: 0x8D27
- #1
host_id: 0
- #2
host_id: 0
- #3
host_id: 0
- #4
host_id: 0
- #5
host_id: 0
- #6
host_id: 0
- #7
host_id: 0
- #8
host_id: 0
- #9
host_id: 0
- #10
host_id: 0
- #11
host_id: 0
- #12
host_id: 0
- #13
host_id: 0
- #14
host_id: 0
- #15
host_id: 0
- #16
host_id: 0
- #17
host_id: 0
- #18
host_id: 0
- #19
host_id: 0
- #20
host_id: 0
- #21
host_id: 0
- #22
host_id: 0
- #23
host_id: 0
- #24
host_id: 0
- #25
host_id: 0
- #26
host_id: 0
- #27
host_id: 0
- #28
host_id: 0
- #29
host_id: 0
- #30
host_id: 0
- #31
host_id: 0
- #32
host_id: 0
- otp_config:
subhdr:
magic: 0x4081
write_host_id : 0
otp_entry:
- #1
host_id: 0
host_perms: 0
- #2
host_id: 0
host_perms: 0
- #3
host_id: 0
host_perms: 0
- #4
host_id: 0
host_perms: 0
- #5
host_id: 0
host_perms: 0
- #6
host_id: 0
host_perms: 0
- #7
host_id: 0
host_perms: 0
- #8
host_id: 0
host_perms: 0
- #9
host_id: 0
host_perms: 0
- #10
host_id: 0
host_perms: 0
- #11
host_id: 0
host_perms: 0
- #12
host_id: 0
host_perms: 0
- #13
host_id: 0
host_perms: 0
- #14
host_id: 0
host_perms: 0
- #15
host_id: 0
host_perms: 0
- #16
host_id: 0
host_perms: 0
- #17
host_id: 0
host_perms: 0
- #18
host_id: 0
host_perms: 0
- #19
host_id: 0
host_perms: 0
- #20
host_id: 0
host_perms: 0
- #21
host_id: 0
host_perms: 0
- #22
host_id: 0
host_perms: 0
- #23
host_id: 0
host_perms: 0
- #24
host_id: 0
host_perms: 0
- #25
host_id: 0
host_perms: 0
- #26
host_id: 0
host_perms: 0
- #27
host_id: 0
host_perms: 0
- #28
host_id: 0
host_perms: 0
- #29
host_id: 0
host_perms: 0
- #30
host_id: 0
host_perms: 0
- #31
host_id: 0
host_perms: 0
- #32
host_id: 0
host_perms: 0
- dkek_config:
subhdr:
magic: 0x5170
rsvd: [0, 0, 0]
- sa2ul_cfg:
subhdr:
magic: 0x23BE
rsvd: [0, 0]
- sec_dbg_config:
subhdr:
magic: 0x42AF
rsvd: 0
min_cert_rev : 0x0
- sec_handover_cfg:
subhdr:
magic: 0x608F
rsvd: [0, 0, 0, 0]
Applying: j721s2: yaml: Add board configs for J721S2 .git/rebase-apply/patch:54: new blank line at EOF. + warning: 1 line adds whitespace errors.
Jan
Support has been added for both HS-SE, HS-FS and GP images.
HS-SE: * tiboot3-j721s2-hs-evm.bin * tispl.bin * u-boot.img
HS-FS: * tiboot3-j721s2-hs-fs-evm.bin * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-j721s2-gp-evm.bin * tispl.bin_unsigned * u-boot.img_unsigned
It is to be noted that the bootflow followed by J721S2 requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 2 + arch/arm/dts/k3-j721s2-binman.dtsi | 546 ++++++++++++++++++ .../k3-j721s2-common-proc-board-u-boot.dtsi | 2 + .../dts/k3-j721s2-r5-common-proc-board.dts | 1 + board/ti/j721s2/Kconfig | 2 + 5 files changed, 553 insertions(+) create mode 100644 arch/arm/dts/k3-j721s2-binman.dtsi
diff --git a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi index ee31b1ebe7..79faa1b573 100644 --- a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-j721s2-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-j721s2-binman.dtsi b/arch/arm/dts/k3-j721s2-binman.dtsi new file mode 100644 index 0000000000..7fd7ba8e5d --- /dev/null +++ b/arch/arm/dts/k3-j721s2-binman.dtsi @@ -0,0 +1,546 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_J721S2_R5_EVM + +&binman { + tiboot3-j721s2-hs-evm.bin { + filename = "tiboot3-j721s2-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j721s2-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-j721s2-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-j721s2-hs-fs-evm.bin { + filename = "tiboot3-j721s2-hs-fs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x41c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x41c80000>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-j721s2-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-j721s2-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-j721s2-gp-evm.bin { + filename = "tiboot3-j721s2-gp-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x41c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x41c80000>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-j721s2-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + + }; +}; + +#endif + +#ifdef CONFIG_TARGET_J721S2_A72_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_J721S2_EVM_DTB "spl/dts/k3-j721s2-common-proc-board.dtb" +#define SPL_AM68_SK_DTB "spl/dts/k3-am68-sk-base-board.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define J721S2_EVM_DTB "arch/arm/dts/k3-j721s2-common-proc-board.dtb" +#define AM68_SK_DTB "arch/arm/dts/k3-am68-sk-base-board.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/j721s2/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_j721s2_evm_dtb>; + keyfile = "custMpk.pem"; + }; + spl_j721s2_evm_dtb: blob-ext { + filename = SPL_J721S2_EVM_DTB; + }; + + }; + + fdt-1 { + description = "k3-am68-sk-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am68_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am68_sk_dtb: blob-ext { + filename = SPL_AM68_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + + conf-1 { + description = "k3-am68-sk-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J721S2 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&j721s2_evm_dtb>; + keyfile = "custMpk.pem"; + }; + j721s2_evm_dtb: blob-ext { + filename = J721S2_EVM_DTB; + }; + + hash { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "k3-am68-sk-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am68_sk_dtb>; + keyfile = "custMpk.pem"; + }; + am68_sk_dtb: blob-ext { + filename = AM68_SK_DTB; + }; + + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + conf-1 { + description = "k3-am68-sk-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_J721S2_EVM_DTB; + }; + }; + fdt-1 { + description = "k3-am68-sk-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM68_SK_DTB; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + conf-1 { + description = "k3-am68-sk-base-board"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for J721S2 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-j721s2-common-proc-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = J721S2_EVM_DTB; + }; + hash { + algo = "crc32"; + }; + }; + fdt-1 { + description = "k3-am68-sk-base-board"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM68_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-j721s2-common-proc-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + conf-1 { + description = "k3-am68-sk-base-board"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-1"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi index 4fd6d36417..f940ffee87 100644 --- a/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721s2-common-proc-board-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-j721s2-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts index e02b334d10..c74e8e58ae 100644 --- a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts @@ -8,6 +8,7 @@ #include "k3-j721s2-som-p0.dtsi" #include "k3-j721s2-ddr-evm-lp4-4266.dtsi" #include "k3-j721s2-ddr.dtsi" +#include "k3-j721s2-binman.dtsi"
/ { chosen { diff --git a/board/ti/j721s2/Kconfig b/board/ti/j721s2/Kconfig index a24641f8cf..f6d1cb5765 100644 --- a/board/ti/j721s2/Kconfig +++ b/board/ti/j721s2/Kconfig @@ -13,6 +13,7 @@ config TARGET_J721S2_A72_EVM select BOARD_LATE_INIT imply TI_I2C_BOARD_DETECT select SYS_DISABLE_DCACHE_OPS + select BINMAN
config TARGET_J721S2_R5_EVM bool "TI K3 based J721S2 EVM running on R5" @@ -22,6 +23,7 @@ config TARGET_J721S2_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Added YAML configs for AM62
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am62x/board-cfg.yaml | 36 ++ board/ti/am62x/pm-cfg.yaml | 12 + board/ti/am62x/rm-cfg.yaml | 1088 +++++++++++++++++++++++++++++++++ board/ti/am62x/sec-cfg.yaml | 379 ++++++++++++ 4 files changed, 1515 insertions(+) create mode 100644 board/ti/am62x/board-cfg.yaml create mode 100644 board/ti/am62x/pm-cfg.yaml create mode 100644 board/ti/am62x/rm-cfg.yaml create mode 100644 board/ti/am62x/sec-cfg.yaml
diff --git a/board/ti/am62x/board-cfg.yaml b/board/ti/am62x/board-cfg.yaml new file mode 100644 index 0000000000..a26ef55bd4 --- /dev/null +++ b/board/ti/am62x/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am62x/pm-cfg.yaml b/board/ti/am62x/pm-cfg.yaml new file mode 100644 index 0000000000..aa94097e97 --- /dev/null +++ b/board/ti/am62x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am62x/rm-cfg.yaml b/board/ti/am62x/rm-cfg.yaml new file mode 100644 index 0000000000..1e8678c30b --- /dev/null +++ b/board/ti/am62x/rm-cfg.yaml @@ -0,0 +1,1088 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 960 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 1678 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 1678 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 1679 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 1679 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1697 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 1697 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 1698 + host_id: 128 + reserved: 0 + + - + start_resource: 5 + num_resource: 35 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 13 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 781 + num_resource: 128 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 909 + num_resource: 627 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1936 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 36 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 1938 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 1942 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 36 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1944 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1945 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1955 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 36 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1957 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1961 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1962 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 36 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1965 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1966 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 1967 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1968 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 diff --git a/board/ti/am62x/sec-cfg.yaml b/board/ti/am62x/sec-cfg.yaml new file mode 100644 index 0000000000..bd5ed418e8 --- /dev/null +++ b/board/ti/am62x/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM62 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0x5A + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0]
Support added for HS-SE, HS-FS and GP boot binaries for AM62.
HS-SE: * tiboot3-am62x-hs-evm.bin * tispl.bin * u-boot.img
HS-FS: * tiboot3-am62x-hs-fs-evm.bin * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-am62x-gp-evm.bin * tispl.bin_unsigned * u-boot.img_unsigned
It is to be noted that the bootflow followed by AM62 requires:
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am625-r5-sk.dts | 1 + arch/arm/dts/k3-am625-sk-binman.dtsi | 463 +++++++++++++++++++++++++++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 2 + board/ti/am62x/Kconfig | 2 + 4 files changed, 468 insertions(+) create mode 100644 arch/arm/dts/k3-am625-sk-binman.dtsi
diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index 78df7cec3f..3ec5bad735 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -9,6 +9,7 @@ #include "k3-am62-ddr.dtsi"
#include "k3-am625-sk-u-boot.dtsi" +#include "k3-am625-sk-binman.dtsi"
/ { aliases { diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi new file mode 100644 index 0000000000..c5bd9e48d0 --- /dev/null +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -0,0 +1,463 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_AM625_R5_EVM + +&binman { + tiboot3-am62x-hs-evm.bin { + filename = "tiboot3-am62x-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-hs-fs-evm.bin { + filename = "tiboot3-am62x-hs-fs-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-gp-evm.bin { + filename = "tiboot3-am62x-gp-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM625_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM625_SK_DTB "spl/dts/k3-am625-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM625_SK_DTB "arch/arm/dts/k3-am625-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am625_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am625_sk_dtb: blob-ext { + filename = SPL_AM625_SK_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am625_sk_dtb>; + keyfile = "custMpk.pem"; + }; + am625_sk_dtb: blob-ext { + filename = AM625_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM625_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM625 board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am625-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM625_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 249155733a..a60c37f1db 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -4,6 +4,8 @@ * Copyright (C) 2021-2022 Texas Instruments Incorporated - https://www.ti.com/ */
+#include "k3-am625-sk-binman.dtsi" + / { chosen { stdout-path = "serial2:115200n8"; diff --git a/board/ti/am62x/Kconfig b/board/ti/am62x/Kconfig index 5e8dfa3cc4..cd17e939e5 100644 --- a/board/ti/am62x/Kconfig +++ b/board/ti/am62x/Kconfig @@ -10,6 +10,7 @@ choice config TARGET_AM625_A53_EVM bool "TI K3 based AM625 EVM running on A53" select ARM64 + select BINMAN
config TARGET_AM625_R5_EVM bool "TI K3 based AM625 EVM running on R5" @@ -19,6 +20,7 @@ config TARGET_AM625_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF
endchoice
Added YAML configs for AM62ax
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- board/ti/am62ax/board-cfg.yaml | 36 + board/ti/am62ax/pm-cfg.yaml | 12 + board/ti/am62ax/rm-cfg.yaml | 1151 ++++++++++++++++++++++++++++++ board/ti/am62ax/sec-cfg.yaml | 379 ++++++++++ board/ti/am62ax/tifs-rm-cfg.yaml | 1011 ++++++++++++++++++++++++++ 5 files changed, 2589 insertions(+) create mode 100644 board/ti/am62ax/board-cfg.yaml create mode 100644 board/ti/am62ax/pm-cfg.yaml create mode 100644 board/ti/am62ax/rm-cfg.yaml create mode 100644 board/ti/am62ax/sec-cfg.yaml create mode 100644 board/ti/am62ax/tifs-rm-cfg.yaml
diff --git a/board/ti/am62ax/board-cfg.yaml b/board/ti/am62ax/board-cfg.yaml new file mode 100644 index 0000000000..6e45b494e0 --- /dev/null +++ b/board/ti/am62ax/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62ax +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x10 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/ti/am62ax/pm-cfg.yaml b/board/ti/am62ax/pm-cfg.yaml new file mode 100644 index 0000000000..a491f11260 --- /dev/null +++ b/board/ti/am62ax/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62ax +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/ti/am62ax/rm-cfg.yaml b/board/ti/am62ax/rm-cfg.yaml new file mode 100644 index 0000000000..0e11bd3e3c --- /dev/null +++ b/board/ti/am62ax/rm-cfg.yaml @@ -0,0 +1,1151 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62ax +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 1032 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 1678 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 1678 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 1679 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 1679 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1697 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 1697 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 1698 + host_id: 128 + reserved: 0 + + - + start_resource: 6 + num_resource: 34 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 14 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 526 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 526 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 782 + num_resource: 128 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 910 + num_resource: 626 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1936 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 30 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 1938 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 1942 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 30 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1944 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1945 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1955 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1957 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1961 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1962 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 30 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1965 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1966 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 1967 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1968 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 + + - + start_resource: 51200 + num_resource: 12 + type: 12738 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 12739 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 12750 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 12769 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 12810 + host_id: 12 + reserved: 0 + + - + start_resource: 12288 + num_resource: 128 + type: 12813 + host_id: 12 + reserved: 0 + + - + start_resource: 3072 + num_resource: 6 + type: 12828 + host_id: 128 + reserved: 0 + + - + start_resource: 3584 + num_resource: 6 + type: 12829 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 6 + type: 12830 + host_id: 128 + reserved: 0 diff --git a/board/ti/am62ax/sec-cfg.yaml b/board/ti/am62ax/sec-cfg.yaml new file mode 100644 index 0000000000..f01f19cbdc --- /dev/null +++ b/board/ti/am62ax/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security configuration for AM62ax +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0x5A + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0] diff --git a/board/ti/am62ax/tifs-rm-cfg.yaml b/board/ti/am62ax/tifs-rm-cfg.yaml new file mode 100644 index 0000000000..8e002e6304 --- /dev/null +++ b/board/ti/am62ax/tifs-rm-cfg.yaml @@ -0,0 +1,1011 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62AX +# + +--- + +tifs-rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 872 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 18 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 1678 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 1678 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 1679 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 1679 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1697 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 1697 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 1698 + host_id: 128 + reserved: 0 + + - + start_resource: 6 + num_resource: 34 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1936 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 30 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 1938 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 1942 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 30 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1944 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1945 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1955 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 30 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1957 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1961 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1962 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 30 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1965 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1966 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 1967 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1968 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 12750 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 6 + type: 12769 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 8 + type: 12810 + host_id: 12 + reserved: 0 + + - + start_resource: 3072 + num_resource: 6 + type: 12828 + host_id: 128 + reserved: 0 + + - + start_resource: 3584 + num_resource: 6 + type: 12829 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 6 + type: 12830 + host_id: 128 + reserved: 0
Support added for HS-SE, HS-FS and GP boot binaries for AM62ax.
HS-SE: * tiboot3-am62ax-hs-evm.bin * tispl.bin * u-boot.img
HS-FS: * tiboot3-am62ax-hs-fs-evm.bin * tispl.bin * u-boot.img
GP: * tiboot3.bin --> tiboot3-am62ax-gp-evm.bin * tispl.bin_unsigned * u-boot.img_unsigned
It is to be noted that the bootflow followed by AM62ax requires:
tiboot3.bin: * R5 SPL * R5 SPL dtbs * TIFS * board-cfg * pm-cfg * sec-cfg * rm-cfg
tispl.bin: * DM * ATF * OPTEE * A72 SPL * A72 SPL dtbs
u-boot.img: * A72 U-Boot * A72 U-Boot dtbs
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org [afd@ti.com: changed output binary names appropriately] Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/dts/k3-am62a-sk-binman.dtsi | 466 +++++++++++++++++++++++++++ arch/arm/dts/k3-am62a7-r5-sk.dts | 1 + arch/arm/dts/k3-am62a7-sk.dts | 1 + board/ti/am62ax/Kconfig | 2 + 4 files changed, 470 insertions(+) create mode 100644 arch/arm/dts/k3-am62a-sk-binman.dtsi
diff --git a/arch/arm/dts/k3-am62a-sk-binman.dtsi b/arch/arm/dts/k3-am62a-sk-binman.dtsi new file mode 100644 index 0000000000..abbac8f084 --- /dev/null +++ b/arch/arm/dts/k3-am62a-sk-binman.dtsi @@ -0,0 +1,466 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include "k3-binman.dtsi" + +#ifdef CONFIG_TARGET_AM62A7_R5_EVM + +&rcfg_yaml_tifs { + config = "tifs-rm-cfg.yaml"; +}; + +&binman { + tiboot3-am62ax-hs-evm.bin { + filename = "tiboot3-am62ax-hs-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62ax-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62ax-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62ax-hs-fs-evm.bin { + filename = "tiboot3-am62ax-hs-fs-evm.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62ax-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62ax-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62ax-gp-evm.bin { + filename = "tiboot3-am62ax-gp-evm.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-am62ax-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +#endif + +#ifdef CONFIG_TARGET_AM62A7_A53_EVM + +#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" +#define SPL_AM62A7_SK_DTB "spl/dts/k3-am62a7-sk.dtb" + +#define UBOOT_NODTB "u-boot-nodtb.bin" +#define AM62A7_SK_DTB "arch/arm/dts/k3-am62a7-sk.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/am62axx/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + filename = "tispl.bin"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + ti-secure { + content = <&atf>; + keyfile = "custMpk.pem"; + }; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + ti-secure { + content = <&tee>; + keyfile = "custMpk.pem"; + }; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + ti-secure { + content = <&u_boot_spl_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_spl_nodtb: blob-ext { + filename = SPL_NODTB; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am62a7_sk_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am62a7_sk_dtb: blob-ext { + filename = SPL_AM62A7_SK_DTB; + }; + + }; + + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + filename = "u-boot.img"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM62Ax board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + ti-secure { + content = <&u_boot_nodtb>; + keyfile = "custMpk.pem"; + }; + u_boot_nodtb: u-boot-nodtb { + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am62a7_sk_dtb>; + keyfile = "custMpk.pem"; + }; + am62a7_sk_dtb: blob-ext { + filename = AM62A7_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + filename = "tispl.bin_unsigned"; + pad-byte = <0xff>; + + fit { + description = "Configuration to load ATF and SPL"; + #address-cells = <1>; + + images { + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf-bl31 { + filename = "bl31.bin"; + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee-os { + filename = "tee-pager_v2.bin"; + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + blob { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = SPL_AM62A7_SK_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + filename = "u-boot.img_unsigned"; + pad-byte = <0xff>; + + fit { + description = "FIT image with multiple configurations"; + + images { + uboot { + description = "U-Boot for AM62Ax board"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compression = "none"; + load = <CONFIG_TEXT_BASE>; + blob { + filename = UBOOT_NODTB; + }; + hash { + algo = "crc32"; + }; + }; + + fdt-0 { + description = "k3-am62a7-sk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + blob { + filename = AM62A7_SK_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am62a7-sk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; +#endif diff --git a/arch/arm/dts/k3-am62a7-r5-sk.dts b/arch/arm/dts/k3-am62a7-r5-sk.dts index cc4b179e27..bbbd9e51d6 100644 --- a/arch/arm/dts/k3-am62a7-r5-sk.dts +++ b/arch/arm/dts/k3-am62a7-r5-sk.dts @@ -7,6 +7,7 @@ #include "k3-am62a7-sk.dts" #include "k3-am62a-ddr-1866mhz-32bit.dtsi" #include "k3-am62a-ddr.dtsi" +#include "k3-am62a-sk-binman.dtsi"
#include "k3-am62a7-sk-u-boot.dtsi"
diff --git a/arch/arm/dts/k3-am62a7-sk.dts b/arch/arm/dts/k3-am62a7-sk.dts index b08a083d72..270e669f65 100644 --- a/arch/arm/dts/k3-am62a7-sk.dts +++ b/arch/arm/dts/k3-am62a7-sk.dts @@ -10,6 +10,7 @@ #include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/gpio.h> #include "k3-am62a7.dtsi" +#include "k3-am62a-sk-binman.dtsi"
/ { compatible = "ti,am62a7-sk", "ti,am62a7"; diff --git a/board/ti/am62ax/Kconfig b/board/ti/am62ax/Kconfig index 9b868e4553..61f289facc 100644 --- a/board/ti/am62ax/Kconfig +++ b/board/ti/am62ax/Kconfig @@ -10,6 +10,7 @@ choice config TARGET_AM62A7_A53_EVM bool "TI K3 based AM62A7 EVM running on A53" select ARM64 + select BINMAN imply BOARD imply SPL_BOARD imply TI_I2C_BOARD_DETECT @@ -22,6 +23,7 @@ config TARGET_AM62A7_R5_EVM select RAM select SPL_RAM select K3_DDRSS + select BINMAN imply SYS_K3_SPL_ATF imply TI_I2C_BOARD_DETECT
Move to using binman to generate tispl.bin which is used to generate the final flash.bin bootloader for iot2050 boards.
Signed-off-by: Neha Malcom Francis n-francis@ti.com Cc: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 76 +++++++++++++++++++- 1 file changed, 74 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 03ccc54329..9d83898d33 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -26,9 +26,81 @@ missing-msg = "iot2050-seboot"; };
- blob@0x180000 { + fit@0x180000 { offset = <0x180000>; - filename = "tispl.bin"; + pad-byte = <0xff>; + description = "Configuration to load ATF and SPL"; + + images { + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + os = "arm-trusted-firmware"; + load = <CONFIG_K3_ATF_LOAD_ADDR>; + entry = <CONFIG_K3_ATF_LOAD_ADDR>; + atf: atf-bl31 { + }; + }; + + tee { + description = "OPTEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <0x9e800000>; + entry = <0x9e800000>; + tee: tee-os { + }; + }; + + dm { + description = "DM binary"; + type = "firmware"; + arch = "arm32"; + compression = "none"; + os = "DM"; + load = <0x89000000>; + entry = <0x89000000>; + blob-ext { + filename = "/dev/null"; + }; + }; + + spl { + description = "SPL (64-bit)"; + type = "standalone"; + os = "U-Boot"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SPL_TEXT_BASE>; + entry = <CONFIG_SPL_TEXT_BASE>; + u_boot_spl_nodtb: blob-ext { + filename = "spl/u-boot-spl-nodtb.bin"; + }; + }; + + fdt-0 { + description = "k3-am65-iot2050-spl.dtb"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + spl_am65x_evm_dtb: blob-ext { + filename = "spl/dts/k3-am65-iot2050-spl.dtb"; + }; + }; + }; + + configurations { + default = "spl"; + spl { + fdt = "fdt-0"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + }; + }; };
fit@0x380000 {
blob@0x180000 {
pad-byte = <0xff>;
images {
atf {
type = "firmware";
arch = "arm64";
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
blob-ext {
spl {
os = "U-Boot";
arch = "arm64";
fdt-0 {
type = "flat_dt";
arch = "arm";
configurations {
default = "spl";
spl {
fdt = "fdt-0";
firmware = "atf";
fit@0x380000 {
Looks ok (will have to test), but this lacks adjustment of tools/iot2050-sign-fw.sh, probably something around s/tispl.bin/fit@0x180000/g.
Jan
Hi Jan
blob@0x180000 {
pad-byte = <0xff>;
images {
atf {
type = "firmware";
arch = "arm64";
atf: atf-bl31 {
tee {
type = "tee";
arch = "arm64";
os = "tee";
tee: tee-os {
dm {
type = "firmware";
arch = "arm32";
os = "DM";
blob-ext {
spl {
os = "U-Boot";
arch = "arm64";
fdt-0 {
type = "flat_dt";
arch = "arm";
configurations {
default = "spl";
spl {
fdt = "fdt-0";
firmware = "atf";
fit@0x380000 {
Okay, let us know once tested.
Regarding the naming used in tools/iot2050-sign-fw.sh; would you like me to preserve tispl.bin naming in the dts?
Jan
On 10.07.23 09:50, Neha Malcom Francis wrote:
Hi Jan
arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 76 +++++++++++++++++++- Â 1 file changed, 74 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 03ccc54329..9d83898d33 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -26,9 +26,81 @@ Â Â Â Â Â Â Â Â Â Â Â Â Â missing-msg = "iot2050-seboot"; Â Â Â Â Â Â Â Â Â }; Â -Â Â Â Â Â Â Â blob@0x180000 { +Â Â Â Â Â Â Â fit@0x180000 { Â Â Â Â Â Â Â Â Â Â Â Â Â offset = <0x180000>; -Â Â Â Â Â Â Â Â Â Â Â filename = "tispl.bin"; +Â Â Â Â Â Â Â Â Â Â Â pad-byte = <0xff>; +Â Â Â Â Â Â Â Â Â Â Â description = "Configuration to load ATF and SPL";
+Â Â Â Â Â Â Â Â Â Â Â images { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â atf { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â description = "ARM Trusted Firmware"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "firmware"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â arch = "arm64"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compression = "none"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â os = "arm-trusted-firmware"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â load = <CONFIG_K3_ATF_LOAD_ADDR>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â entry = <CONFIG_K3_ATF_LOAD_ADDR>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â atf: atf-bl31 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â tee { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â description = "OPTEE"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "tee"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â arch = "arm64"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compression = "none"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â os = "tee"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â load = <0x9e800000>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â entry = <0x9e800000>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â tee: tee-os { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â dm { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â description = "DM binary"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "firmware"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â arch = "arm32"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compression = "none"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â os = "DM"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â load = <0x89000000>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â entry = <0x89000000>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â blob-ext { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â filename = "/dev/null"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â spl { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â description = "SPL (64-bit)"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "standalone"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â os = "U-Boot"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â arch = "arm64"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compression = "none"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â load = <CONFIG_SPL_TEXT_BASE>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â entry = <CONFIG_SPL_TEXT_BASE>; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â u_boot_spl_nodtb: blob-ext { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â filename = "spl/u-boot-spl-nodtb.bin"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â fdt-0 { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â description = "k3-am65-iot2050-spl.dtb"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â type = "flat_dt"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â arch = "arm"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â compression = "none"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â spl_am65x_evm_dtb: blob-ext { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â filename = "spl/dts/k3-am65-iot2050-spl.dtb"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â };
+Â Â Â Â Â Â Â Â Â Â Â configurations { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â default = "spl"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â spl { +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â fdt = "fdt-0"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â firmware = "atf"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â loadables = "tee", "dm", "spl"; +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â }; +Â Â Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â }; Â Â Â Â Â Â Â Â Â Â fit@0x380000 {
Done successfully, using this diff:
diff --git a/tools/iot2050-sign-fw.sh b/tools/iot2050-sign-fw.sh index 4d1d79498c2..598482311ca 100755 --- a/tools/iot2050-sign-fw.sh +++ b/tools/iot2050-sign-fw.sh @@ -8,8 +8,8 @@ fi TEMP_X509=$(mktemp XXXXXXXX.temp)
REVISION=${2:-0} -SHA_VAL=$(openssl dgst -sha512 -hex tispl.bin | sed -e "s/^.*= //g") -BIN_SIZE=$(stat -c %s tispl.bin) +SHA_VAL=$(openssl dgst -sha512 -hex fit@0x180000.fit | sed -e "s/^.*= //g") +BIN_SIZE=$(stat -c %s fit@0x180000.fit)
cat <<EOF >$TEMP_X509 [ req ] @@ -38,10 +38,10 @@ EOF CERT_X509=$(mktemp XXXXXXXX.crt)
openssl req -new -x509 -key $1 -nodes -outform DER -out $CERT_X509 -config $TEMP_X509 -sha512 -cat $CERT_X509 tispl.bin > tispl.bin_signed +cat $CERT_X509 fit@0x180000.fit > fit@0x180000.fit_signed # currently broken in upstream #source/tools/binman/binman replace -i flash.bin -f tispl.bin_signed blob@0x180000 -dd if=tispl.bin_signed of=flash.bin bs=$((0x1000)) seek=$((0x180000/0x1000)) conv=notrunc +dd if=fit@0x180000.fit_signed of=flash.bin bs=$((0x1000)) seek=$((0x180000/0x1000)) conv=notrunc
rm $TEMP_X509 $CERT_X509
I don't mind, the naming is internal (thanks to the script).
Jan
Since binman is used to package bootloader images for all K3 devices, we do not have to rely on the earlier methods to package them.
Scripts that were used to generate x509 certificate for tiboot3.bin and generate tispl.bin, u-boot.img have been removed.
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- arch/arm/mach-k3/config.mk | 103 --------------- tools/k3_fit_atf.sh | 123 ----------------- tools/k3_gen_x509_cert.sh | 262 ------------------------------------- 3 files changed, 488 deletions(-) delete mode 100644 arch/arm/mach-k3/config.mk delete mode 100755 tools/k3_fit_atf.sh delete mode 100755 tools/k3_gen_x509_cert.sh
diff --git a/arch/arm/mach-k3/config.mk b/arch/arm/mach-k3/config.mk deleted file mode 100644 index cbf9c10210..0000000000 --- a/arch/arm/mach-k3/config.mk +++ /dev/null @@ -1,103 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ -# Lokesh Vutla lokeshvutla@ti.com - -ifdef CONFIG_SPL_BUILD - -# Openssl is required to generate x509 certificate. -# Error out if openssl is not available. -ifeq ($(shell which openssl),) -$(error "No openssl in $(PATH), consider installing openssl") -endif - -IMAGE_SIZE= $(shell cat $(obj)/u-boot-spl.bin | wc -c) -MAX_SIZE= $(shell printf "%d" $(CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE)) - -ifeq ($(CONFIG_SYS_K3_KEY), "") -KEY="" -# On HS use real key or warn if not available -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/keys/custMpk.pem),) -KEY=$(TI_SECURE_DEV_PKG)/keys/custMpk.pem -else -$(warning "WARNING: signing key not found. Random key will NOT work on HS hardware!") -endif -endif -else -KEY=$(patsubst "%",$(srctree)/%,$(CONFIG_SYS_K3_KEY)) -endif - -# X509 SWRV default -SWRV = $(CONFIG_K3_X509_SWRV) -# On HS use SECDEV provided software revision or warn if not available -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -ifneq ($(wildcard $(TI_SECURE_DEV_PKG)/keys/swrv.txt),) -SWRV= $(shell cat $(TI_SECURE_DEV_PKG)/keys/swrv.txt) -else -$(warning "WARNING: Software revision file not found. Default may not work on HS hardware.") -endif -endif - -# tiboot3.bin is mandated by ROM and ROM only supports R5 boot. -# So restrict tiboot3.bin creation for CPU_V7R. -ifdef CONFIG_CPU_V7R -image_check: $(obj)/u-boot-spl.bin FORCE - @if [ $(IMAGE_SIZE) -gt $(MAX_SIZE) ]; then \ - echo "===============================================" >&2; \ - echo "ERROR: Final Image too big. " >&2; \ - echo "$< size = $(IMAGE_SIZE), max size = $(MAX_SIZE)" >&2; \ - echo "===============================================" >&2; \ - exit 1; \ - fi - -tiboot3.bin: image_check FORCE - $(srctree)/tools/k3_gen_x509_cert.sh -c 16 -b $(obj)/u-boot-spl.bin \ - -o $@ -l $(CONFIG_SPL_TEXT_BASE) -r $(SWRV) -k $(KEY) - -INPUTS-y += tiboot3.bin -endif - -ifdef CONFIG_ARM64 - -ifeq ($(CONFIG_SOC_K3_J721E),) -export DM := /dev/null -endif - -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -SPL_ITS := u-boot-spl-k3_HS.its -$(SPL_ITS): export IS_HS=1 -INPUTS-y += tispl.bin_HS -INPUTS-y += tispl.bin -tispl.bin: $(obj)/u-boot-spl-nodtb.bin_HS $(patsubst %,$(obj)/dts/%.dtb_HS,$(subst ",,$(CONFIG_SPL_OF_LIST))) -else -SPL_ITS := u-boot-spl-k3.its -INPUTS-y += tispl.bin -endif - -ifeq ($(CONFIG_SPL_OF_LIST),) -LIST_OF_DTB := $(CONFIG_DEFAULT_DEVICE_TREE) -else -LIST_OF_DTB := $(CONFIG_SPL_OF_LIST) -endif - -quiet_cmd_k3_mkits = MKITS $@ -cmd_k3_mkits = \ - $(srctree)/tools/k3_fit_atf.sh \ - $(CONFIG_K3_ATF_LOAD_ADDR) \ - $(patsubst %,$(obj)/dts/%.dtb,$(subst ",,$(LIST_OF_DTB))) > $@ - -$(SPL_ITS): FORCE - $(call cmd,k3_mkits) -endif - -else - -ifeq ($(CONFIG_TI_SECURE_DEVICE),y) -INPUTS-y += u-boot.img_HS -else -INPUTS-y += u-boot.img -endif -endif - -include $(srctree)/arch/arm/mach-k3/config_secure.mk diff --git a/tools/k3_fit_atf.sh b/tools/k3_fit_atf.sh deleted file mode 100755 index 7bc07ad074..0000000000 --- a/tools/k3_fit_atf.sh +++ /dev/null @@ -1,123 +0,0 @@ -#!/bin/sh -# SPDX-License-Identifier: GPL-2.0+ -# -# script to generate FIT image source for K3 Family boards with -# ATF, OPTEE, SPL and multiple device trees (given on the command line). -# Inspired from board/sunxi/mksunxi_fit_atf.sh -# -# usage: $0 <atf_load_addr> <dt_name> [<dt_name> [<dt_name] ...] - -[ -z "$ATF" ] && ATF="bl31.bin" - -if [ ! -f $ATF ]; then - echo "WARNING ATF file $ATF NOT found, resulting binary is non-functional" >&2 - ATF=/dev/null -fi - -[ -z "$TEE" ] && TEE="bl32.bin" - -if [ ! -f $TEE ]; then - echo "WARNING OPTEE file $TEE NOT found, resulting might be non-functional" >&2 - TEE=/dev/null -fi - -[ -z "$DM" ] && DM="dm.bin" - -if [ ! -e $DM ]; then - echo "WARNING DM file $DM NOT found, resulting might be non-functional" >&2 - DM=/dev/null -fi - -if [ ! -z "$IS_HS" ]; then - HS_APPEND=_HS -fi - -cat << __HEADER_EOF -/dts-v1/; - -/ { - description = "Configuration to load ATF and SPL"; - #address-cells = <1>; - - images { - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("$ATF"); - type = "firmware"; - arch = "arm64"; - compression = "none"; - os = "arm-trusted-firmware"; - load = <$1>; - entry = <$1>; - }; - tee { - description = "OPTEE"; - data = /incbin/("$TEE"); - type = "tee"; - arch = "arm64"; - compression = "none"; - os = "tee"; - load = <0x9e800000>; - entry = <0x9e800000>; - }; - dm { - description = "DM binary"; - data = /incbin/("$DM"); - type = "firmware"; - arch = "arm32"; - compression = "none"; - os = "DM"; - load = <0x89000000>; - entry = <0x89000000>; - }; - spl { - description = "SPL (64-bit)"; - data = /incbin/("spl/u-boot-spl-nodtb.bin$HS_APPEND"); - type = "standalone"; - os = "U-Boot"; - arch = "arm64"; - compression = "none"; - load = <0x80080000>; - entry = <0x80080000>; - }; -__HEADER_EOF - -# shift through ATF load address in the command line arguments -shift - -for dtname in $* -do - cat << __FDT_IMAGE_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - data = /incbin/("$dtname$HS_APPEND"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; -__FDT_IMAGE_EOF -done - -cat << __CONF_HEADER_EOF - }; - configurations { - default = "$(basename $1)"; - -__CONF_HEADER_EOF - -for dtname in $* -do - cat << __CONF_SECTION_EOF - $(basename $dtname) { - description = "$(basename $dtname .dtb)"; - firmware = "atf"; - loadables = "tee", "dm", "spl"; - fdt = "$(basename $dtname)"; - }; -__CONF_SECTION_EOF -done - -cat << __ITS_EOF - }; -}; -__ITS_EOF diff --git a/tools/k3_gen_x509_cert.sh b/tools/k3_gen_x509_cert.sh deleted file mode 100755 index d9cde07417..0000000000 --- a/tools/k3_gen_x509_cert.sh +++ /dev/null @@ -1,262 +0,0 @@ -#!/bin/bash -# SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -# -# Script to add K3 specific x509 cetificate to a binary. -# - -# Variables -OUTPUT=tiboot3.bin -TEMP_X509=x509-temp.cert -CERT=certificate.bin -RAND_KEY=eckey.pem -LOADADDR=0x41c00000 -BOOTCORE_OPTS=0 -BOOTCORE=16 -DEBUG_TYPE=0 -SWRV=1 - -gen_degen_template() { -cat << 'EOF' > degen-template.txt - -asn1=SEQUENCE:rsa_key - -[rsa_key] -version=INTEGER:0 -modulus=INTEGER:0xDEGEN_MODULUS -pubExp=INTEGER:1 -privExp=INTEGER:1 -p=INTEGER:0xDEGEN_P -q=INTEGER:0xDEGEN_Q -e1=INTEGER:1 -e2=INTEGER:1 -coeff=INTEGER:0xDEGEN_COEFF -EOF -} - -# Generate x509 Template -gen_template() { -cat << 'EOF' > x509-template.txt - [ req ] - distinguished_name = req_distinguished_name - x509_extensions = v3_ca - prompt = no - dirstring_type = nobmp - - [ req_distinguished_name ] - C = US - ST = TX - L = Dallas - O = Texas Instruments Incorporated - OU = Processors - CN = TI support - emailAddress = support@ti.com - - [ v3_ca ] - basicConstraints = CA:true - 1.3.6.1.4.1.294.1.1 = ASN1:SEQUENCE:boot_seq - 1.3.6.1.4.1.294.1.2 = ASN1:SEQUENCE:image_integrity - 1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv -# 1.3.6.1.4.1.294.1.4 = ASN1:SEQUENCE:encryption - 1.3.6.1.4.1.294.1.8 = ASN1:SEQUENCE:debug - - [ boot_seq ] - certType = INTEGER:TEST_CERT_TYPE - bootCore = INTEGER:TEST_BOOT_CORE - bootCoreOpts = INTEGER:TEST_BOOT_CORE_OPTS - destAddr = FORMAT:HEX,OCT:TEST_BOOT_ADDR - imageSize = INTEGER:TEST_IMAGE_LENGTH - - [ image_integrity ] - shaType = OID:2.16.840.1.101.3.4.2.3 - shaValue = FORMAT:HEX,OCT:TEST_IMAGE_SHA_VAL - - [ swrv ] - swrv = INTEGER:TEST_SWRV - -# [ encryption ] -# initalVector = FORMAT:HEX,OCT:TEST_IMAGE_ENC_IV -# randomString = FORMAT:HEX,OCT:TEST_IMAGE_ENC_RS -# iterationCnt = INTEGER:TEST_IMAGE_KEY_DERIVE_INDEX -# salt = FORMAT:HEX,OCT:TEST_IMAGE_KEY_DERIVE_SALT - - [ debug ] - debugUID = FORMAT:HEX,OCT:0000000000000000000000000000000000000000000000000000000000000000 - debugType = INTEGER:TEST_DEBUG_TYPE - coreDbgEn = INTEGER:0 - coreDbgSecEn = INTEGER:0 -EOF -} - -parse_key() { - sed '/ /s/://g' key.txt | \ - awk '!/ / {printf("\n%s\n", $0)}; / / {printf("%s", $0)}' | \ - sed 's/ //g' | \ - awk "/$1:/{getline; print}" -} - -gen_degen_key() { -# Generate a 4096 bit RSA Key - openssl genrsa -out key.pem 1024 >>/dev/null 2>&1 - openssl rsa -in key.pem -text -out key.txt >>/dev/null 2>&1 - DEGEN_MODULUS=$( parse_key 'modulus' ) - DEGEN_P=$( parse_key 'prime1' ) - DEGEN_Q=$( parse_key 'prime2' ) - DEGEN_COEFF=$( parse_key 'coefficient' ) - gen_degen_template - - sed -e "s/DEGEN_MODULUS/$DEGEN_MODULUS/"\ - -e "s/DEGEN_P/$DEGEN_P/" \ - -e "s/DEGEN_Q/$DEGEN_Q/" \ - -e "s/DEGEN_COEFF/$DEGEN_COEFF/" \ - degen-template.txt > degenerateKey.txt - - openssl asn1parse -genconf degenerateKey.txt -out degenerateKey.der >>/dev/null 2>&1 - openssl rsa -in degenerateKey.der -inform DER -outform PEM -out $RAND_KEY >>/dev/null 2>&1 - KEY=$RAND_KEY - rm key.pem key.txt degen-template.txt degenerateKey.txt degenerateKey.der -} - -declare -A options_help -usage() { - if [ -n "$*" ]; then - echo "ERROR: $*" - fi - echo -n "Usage: $0 " - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - if [ -n "$arg" ]; then - arg=" $arg" - fi - echo -n "[-$option$arg] " - done - echo - echo -e "\nWhere:" - for option in "${!options_help[@]}" - do - arg=`echo ${options_help[$option]}|cut -d ':' -f1` - txt=`echo ${options_help[$option]}|cut -d ':' -f2` - tb="\t\t\t" - if [ -n "$arg" ]; then - arg=" $arg" - tb="\t" - fi - echo -e " -$option$arg:$tb$txt" - done - echo - echo "Examples of usage:-" - echo "# Example of signing the SYSFW binary with rsa degenerate key" - echo " $0 -c 0 -b ti-sci-firmware-am6x.bin -o sysfw.bin -l 0x40000" - echo "# Example of signing the SPL binary with rsa degenerate key" - echo " $0 -c 16 -b spl/u-boot-spl.bin -o tiboot3.bin -l 0x41c00000" -} - -options_help[b]="bin_file:Bin file that needs to be signed" -options_help[k]="key_file:file with key inside it. If not provided script generates a rsa degenerate key." -options_help[o]="output_file:Name of the final output file. default to $OUTPUT" -options_help[c]="core_id:target core id on which the image would be running. Default to $BOOTCORE" -options_help[l]="loadaddr: Target load address of the binary in hex. Default to $LOADADDR" -options_help[d]="debug_type: Debug type, set to 4 to enable early JTAG. Default to $DEBUG_TYPE" -options_help[r]="SWRV: Software Rev for X509 certificate" - -while getopts "b:k:o:c:l:d:h:r:" opt -do - case $opt in - b) - BIN=$OPTARG - ;; - k) - KEY=$OPTARG - ;; - o) - OUTPUT=$OPTARG - ;; - l) - LOADADDR=$OPTARG - ;; - c) - BOOTCORE=$OPTARG - ;; - d) - DEBUG_TYPE=$OPTARG - ;; - r) - SWRV=$OPTARG - ;; - h) - usage - exit 0 - ;; - ?) - usage "Invalid Option '-$OPTARG'" - exit 1 - ;; - :) - usage "Option '-$OPTARG' Needs an argument." - exit 1 - ;; - esac -done - -if [ "$#" -eq 0 ]; then - usage "Arguments missing" - exit 1 -fi - -if [ -z "$BIN" ]; then - usage "Bin file missing in arguments" - exit 1 -fi - -# Generate rsa degenerate key if user doesn't provide a key -if [ -z "$KEY" ]; then - gen_degen_key -fi - -if [ $BOOTCORE == 0 ]; then # BOOTCORE M3, loaded by ROM - CERTTYPE=2 -elif [ $BOOTCORE == 16 ]; then # BOOTCORE R5, loaded by ROM - CERTTYPE=1 -else # Non BOOTCORE, loaded by SYSFW - BOOTCORE_OPTS_VER=$(printf "%01x" 1) - # Add input args option for SET and CLR flags. - BOOTCORE_OPTS_SETFLAG=$(printf "%08x" 0) - BOOTCORE_OPTS_CLRFLAG=$(printf "%08x" 0x100) # Clear FLAG_ARMV8_AARCH32 - BOOTCORE_OPTS="0x$BOOTCORE_OPTS_VER$BOOTCORE_OPTS_SETFLAG$BOOTCORE_OPTS_CLRFLAG" - # Set the cert type to zero. - # We are not using public/private key store now - CERTTYPE=$(printf "0x%08x" 0) -fi - -SHA_VAL=`openssl dgst -sha512 -hex $BIN | sed -e "s/^.*= //g"` -BIN_SIZE=`cat $BIN | wc -c` -ADDR=`printf "%08x" $LOADADDR` - -gen_cert() { - #echo "Certificate being generated :" - #echo " LOADADDR = 0x$ADDR" - #echo " IMAGE_SIZE = $BIN_SIZE" - #echo " CERT_TYPE = $CERTTYPE" - #echo " DEBUG_TYPE = $DEBUG_TYPE" - #echo " SWRV = $SWRV" - sed -e "s/TEST_IMAGE_LENGTH/$BIN_SIZE/" \ - -e "s/TEST_IMAGE_SHA_VAL/$SHA_VAL/" \ - -e "s/TEST_CERT_TYPE/$CERTTYPE/" \ - -e "s/TEST_BOOT_CORE_OPTS/$BOOTCORE_OPTS/" \ - -e "s/TEST_BOOT_CORE/$BOOTCORE/" \ - -e "s/TEST_BOOT_ADDR/$ADDR/" \ - -e "s/TEST_DEBUG_TYPE/$DEBUG_TYPE/" \ - -e "s/TEST_SWRV/$SWRV/" \ - x509-template.txt > $TEMP_X509 - openssl req -new -x509 -key $KEY -nodes -outform DER -out $CERT -config $TEMP_X509 -sha512 -} - -gen_template -gen_cert -cat $CERT $BIN > $OUTPUT - -# Remove all intermediate files -rm $TEMP_X509 $CERT x509-template.txt -if [ "$KEY" == "$RAND_KEY" ]; then - rm $RAND_KEY -fi
Earlier documentation specified builds for generating bootloader images using an external TI repository k3-image-gen and core-secdev-k3. Modify this to using the binman flow so that user understands how to build the final boot images.
Signed-off-by: Neha Malcom Francis n-francis@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- doc/board/ti/am62x_sk.rst | 42 ++++++++--------- doc/board/ti/j721e_evm.rst | 50 +++++++++----------- doc/board/ti/k3.rst | 95 +++++++++++++------------------------- 3 files changed, 73 insertions(+), 114 deletions(-)
diff --git a/doc/board/ti/am62x_sk.rst b/doc/board/ti/am62x_sk.rst index 27d7b527c6..e4d58b4958 100644 --- a/doc/board/ti/am62x_sk.rst +++ b/doc/board/ti/am62x_sk.rst @@ -115,23 +115,19 @@ Below is the pictorial representation of boot flow:
Sources: -------- -1. SYSFW: - Tree: git://git.ti.com/k3-image-gen/k3-image-gen.git - Branch: master - -2. ATF: +1. ATF: Tree: https://github.com/ARM-software/arm-trusted-firmware.git Branch: master
-3. OPTEE: +2. OPTEE: Tree: https://github.com/OP-TEE/optee_os.git Branch: master
-4. U-Boot: +3. U-Boot: Tree: https://source.denx.de/u-boot/u-boot Branch: master
-5. TI Linux Firmware: +4. TI Linux Firmware: Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git Branch: ti-linux-firmware
@@ -139,35 +135,37 @@ Build procedure: ---------------- 1. ATF:
-.. code-block:: text +.. code-block:: bash
- $ make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=lite SPD=opteed + $ make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=k3 \ + TARGET_BOARD=lite SPD=opteed
2. OPTEE:
- $ make PLATFORM=k3 CFG_ARM64_core=y CROSS_COMPILE=arm-none-linux-gnueabihf- CROSS_COMPILE64=aarch64-none-linux-gnu- + $ make PLATFORM=k3 CFG_ARM64_core=y CROSS_COMPILE=arm-none-linux-gnueabihf- \ + CROSS_COMPILE64=aarch64-none-linux-gnu-
3. U-Boot:
* 3.1 R5:
- $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- am62x_evm_r5_defconfig O=/tmp/r5 - $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- O=/tmp/r5 - $ cd <k3-image-gen> - $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- SOC=am62x SBL=/tmp/r5/spl/u-boot-spl.bin SYSFW_PATH=<path to ti-linux-firmware>/ti-sysfw/ti-fs-firmware-am62x-gp.bin - -Use the tiboot3.bin generated from last command + $ make ARCH=arm am62x_evm_r5_defconfig + $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- \ + BINMAN_INDIRS=<path/to/ti-linux-firmware>
* 3.2 A53:
- $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- am62x_evm_a53_defconfig O=/tmp/a53 - $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- ATF=<path to ATF dir>/build/k3/lite/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<path to ti-linux-firmware>/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f O=/tmp/a53 + $ make ARCH=arm am62x_evm_a53_defconfig + $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- \ + BL31=<path to ATF dir>/build/k3/lite/release/bl31.bin \ + TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin \ + BINMAN_INDIRS=<path/to/ti-linux-firmware>
Target Images -------------- diff --git a/doc/board/ti/j721e_evm.rst b/doc/board/ti/j721e_evm.rst index feaa2da5e9..9e604f6f12 100644 --- a/doc/board/ti/j721e_evm.rst +++ b/doc/board/ti/j721e_evm.rst @@ -130,67 +130,61 @@ support. Below is the pictorial representation of boot flow:
-4. DM Firmware: - Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git - Branch: ti-linux-firmware - -5. U-Boot: +3. U-Boot: Tree: https://source.denx.de/u-boot/u-boot Branch: master
+4. TI Linux Firmware: + Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git + Branch: ti-linux-firmware + Build procedure: ---------------- -1. SYSFW: - -.. code-block:: bash - - make CROSS_COMPILE=arm-linux-gnueabihf- SOC=j721e - -2. ATF: +1. ATF:
- make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed + $ make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 \ + TARGET_BOARD=generic SPD=opteed
- make PLATFORM=k3-j721e CFG_ARM64_core=y + $ make PLATFORM=k3-j721e CFG_ARM64_core=y
* 4.1 R5:
- make CROSS_COMPILE=arm-linux-gnueabihf- j721e_evm_r5_defconfig O=build/r5 - make CROSS_COMPILE=arm-linux-gnueabihf- O=build/r5 + $ make j721e_evm_r5_defconfig + $ make CROSS_COMPILE=arm-linux-gnueabihf- \ + BINMAN_INDIRS=<path/to/ti-linux-firmware>
* 4.2 A72:
- make CROSS_COMPILE=aarch64-linux-gnu- j721e_evm_a72_defconfig O=build/a72 - make CROSS_COMPILE=aarch64-linux-gnu- ATF=<ATF dir>/build/k3/generic/release/bl31.bin TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<DM firmware>/ti-dm/j721e/ipc_echo_testb_mcu1_0_release_strip.xer5f O=build/a72 + $ make j721e_evm_a72_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- \ + BL31=<ATF dir>/build/k3/generic/release/bl31.bin \ + TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin \ + BINMAN_INDIRS=<path/to/ti-linux-firmware>
Target Images -------------- Copy the below images to an SD card and boot: - - sysfw.itb from step 1 - - tiboot3.bin from step 4.1 + - tiboot3.bin and sysfw.itb from step 4.1 - tispl.bin, u-boot.img from 4.2
Image formats: diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index 2b2f4bb8bb..214a22b1ae 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -115,11 +115,6 @@ online | **source:** https://source.denx.de/u-boot/u-boot.git | **branch:** master
-* **K3 Image Gen** - - | **source:** https://git.ti.com/git/k3-image-gen/k3-image-gen.git - | **branch:** master - * **ARM Trusted Firmware (ATF)**
| **source:** https://github.com/ARM-software/arm-trusted-firmware.git @@ -135,11 +130,6 @@ online | **source:** https://git.ti.com/git/processor-firmware/ti-linux-firmware.git | **branch:** ti-linux-firmware
-* **TI's Security Development Tools** - - | **source:** https://git.ti.com/git/security-development-tools/core-secdev-k3.git - | **branch:** master - Build Procedure ---------------
@@ -161,54 +151,37 @@ All of that to say you will need both a 32bit and 64bit cross compiler
- export CC32=arm-linux-gnueabihf- - export CC64=aarch64-linux-gnu- + $ export CC32=arm-linux-gnueabihf- + $ export CC64=aarch64-linux-gnu-
Building tiboot3.bin ^^^^^^^^^^^^^^^^^^^^^
1. To generate the U-Boot SPL for the wakeup domain, use the following commands, substituting :code:`{SOC}` for the name of your device (eg: - am62x) - -.. code-block:: bash - - # inside u-boot source - make ARCH=arm O=build/wkup CROSS_COMPILE=$CC32 {SOC}_evm_r5_defconfig - make ARCH=arm O=build/wkup CROSS_COMPILE=$CC32 + am62x) to package the various firmware and the wakeup UBoot SPL into + the final `tiboot3.bin` binary. (or the `sysfw.itb` if your device + uses the split binary flow)
-2. Next we will use the K3 Image Gen scripts to package the various - firmware and the wakeup UBoot SPL into the final `tiboot3.bin` - binary. (or the `sysfw.itb` if your device uses the split binary - flow)
- # inside k3-image-gen source - make CROSS_COMPILE=$CC32 SOC={SOC} SOC_TYPE={hs,gp} \ - TI_SECURE_DEV_PKG=<path/to/securit-development-tools> \ - SYSFW_PATH=<path/to/ti-sysfw/ti-fs-firmware-{SOC}-{hs|gp}.bin> \ - SYSFW_HS_INNER_CERT_PATH=<path/to/ti-sysfw/ti-fs-firmware-{SOC}-hs-cert.bin - -For devices that use the *combined binary flow*, you will also need to -supply the location of the SPL we created in step 1 above, so it can be -packaged into the final `tiboot3.bin`. - -.. code-block:: bash - - SBL=<path/to/wakeup/u-boot-spl.bin> + $ # inside u-boot source + $ make ARCH=arm {SOC}_evm_r5_defconfig + $ make ARCH=arm CROSS_COMPILE=$CC32 \ + BINMAN_INDIRS=<path/to/ti-linux-firmware>
At this point you should have all the needed binaries to boot the wakeup domain of your K3 SoC.
**Combined Binary Boot Flow** (eg: am62x, am64x, ... )
- `k3-image-gen/tiboot3-{SOC}-{hs,gp}-evm.bin` + `tiboot3.bin`
**Split Binary Boot Flow** (eg: j721e, am65x)
- | `u-boot/build/wkup/tiboot3.bin` - | `k3-image-gen/sysfw-{SOC}-evm.bin` + | `tiboot3.bin` + | `sysfw-{SOC}-evm.itb`
.. note ::
@@ -223,53 +196,47 @@ The `tispl.bin` is a standard fitImage combining the firmware need for the main domain to function properly as well as Device Management (DM) firmware if your device using a split firmware.
-3. We will first need ATF, as it's the first thing to run on the 'big' +2. We will first need ATF, as it's the first thing to run on the 'big' application cores on the main domain.
- # inside arm-trusted-firmware source - make CROSS_COMPILE=$CC64 ARCH=aarch64 PLAT=k3 \ - TARGET_BOARD={lite|generic} \ - SPD=opteed \ + $ # inside arm-trusted-firmware source + $ make CROSS_COMPILE=$CC64 ARCH=aarch64 PLAT=k3 \ + TARGET_BOARD={lite|generic|j784s4} \ + SPD=opteed
-Typically all `j7*` devices will use `TARGET_BOARD=generic` while all -Sitara (`am6*`) devices use the `lite` option. +Typically all `j7*` devices will use `TARGET_BOARD=generic` or `TARGET_BOARD +=j784s4` (if it is a J784S4 device), while all Sitara (`am6*`) devices +use the `lite` option.
-4. The Open Portable Trusted Execution Environment (OPTEE) is designed +3. The Open Portable Trusted Execution Environment (OPTEE) is designed to run as a companion to a non-secure Linux kernel for Cortex-A cores using the TrustZone technology built into the core.
- # inside optee_os source - make CROSS_COMPILE=$CC32 CROSS_COMPILE64=$CC64 \ + $ # inside optee_os source + $ make CROSS_COMPILE=$CC32 CROSS_COMPILE64=$CC64 \ PLATFORM=k3 CFG_ARM64_core=y
-5. Finally, after ATF has initialized the main domain and OPTEE has +4. Finally, after ATF has initialized the main domain and OPTEE has finished, we can jump back into U-Boot again, this time running on a 64bit core in the main domain.
- # inside u-boot source - make ARCH=arm O=build/main CROSS_COMPILE=$CC64 {SOC}_evm_a{53,72}_defconfig - make ARCH=arm O=build/main CROSS_COMPILE=$CC64 \ - ATF=<path/to/atf/bl31.bin \ + $ # inside u-boot source + $ make ARCH=arm {SOC}_evm_a{53,72}_defconfig + $ make ARCH=arm CROSS_COMPILE=$CC64 \ + BINMAN_INDIRS=<path/to/ti-linux-firmware> \ + BL31=<path/to/atf/bl31.bin \ TEE=<path/to/optee/tee-pager_v2.bin
-If your device uses a split firmware, you will also need to supply the -path to the Device Management (DM) Firmware to be included in the final -`tispl.bin` binary - -.. code-block:: bash - - DM=<path/to/ti-linux-firmware/ti-dm/ipc_echo_testb_mcu1_0_release_strip.xer5f> - At this point you should have every binary needed initialize both the wakeup and main domain and to boot to the U-Boot prompt
**Main Domain Bootloader**
- | `u-boot/build/main/tispl.bin` - | `u-boot/build/main/u-boot.img` + | `tispl.bin` + | `u-boot.img`
Sources:
-1. SYSFW:
- Branch: master
-2. ATF: +1. ATF:
Minor nitpick: ATF was the old name https://community.arm.com/oss-platforms/w/docs/483/trusted-firmware-a Trusted Firmware-A is the new name.
I believe the official repo is https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git/
- ATF:
- $ make CROSS_COMPILE=aarch64-none-linux-gnu- ARCH=aarch64 PLAT=k3 \
- OPTEE:
- $ make PLATFORM=k3 CFG_ARM64_core=y CROSS_COMPILE=arm-none-linux-gnueabihf- \
- U-Boot:
- 3.1 R5:
- $ make ARCH=arm am62x_evm_r5_defconfig
- $ make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- \
- 3.2 A53:
- $ make ARCH=arm am62x_evm_a53_defconfig
- $ make ARCH=arm CROSS_COMPILE=aarch64-none-linux-gnu- \
Note that since OP-TEE 3.21.0, tee-raw.bin could/should be used instead of tee-pager_v2.bin. Indeed when the "pager" feature is not enabled, the two binaries are identical, and the newer name is hopefully less confusing.
- ATF:
- OPTEE:
- U-Boot:
- 3.1 R5:
- 3.2 A53:
Ah, interesting. That will affect doc/board/siemens/iot2050.rst as well (and our integration recipes).
Jan
- ATF:
PLAT=k3
PLAT=k3 \
- OPTEE:
linux-gnueabihf- \
- U-Boot:
- 3.1 R5:
O=/tmp/r5
SOC=am62x
- $ make ARCH=arm am62x_evm_r5_defconfig $ make ARCH=arm
- CROSS_COMPILE=arm-none-linux-gnueabihf- \
- 3.2 A53:
to
ATF dir>/build/k3/lite/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<path to ti-linux-firmware>/ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.x er5f O=/tmp/a53
- $ make ARCH=arm am62x_evm_a53_defconfig $ make ARCH=arm
- CROSS_COMPILE=aarch64-none-linux-gnu- \
- dir>/out/arm-plat-k3/core/tee-pager_v2.bin \
less confusing.
And J7200 docs as well, however this doc is on next
https://github.com/u-boot/u-boot/blob/next/doc/board/ti/j7200_evm.rst
Jan
-- Siemens AG, Technology Competence Center Embedded Linux
Without this re-building will fail with an error when trying to create the symlink for the second time with an already exists error.
Signed-off-by: Andrew Davis afd@ti.com Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/binman/image.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/binman/image.py b/tools/binman/image.py index 8ebf71d61a..e77b5d0d97 100644 --- a/tools/binman/image.py +++ b/tools/binman/image.py @@ -182,6 +182,8 @@ class Image(section.Entry_section): # Create symlink to file if symlink given if self._symlink is not None: sname = tools.get_output_filename(self._symlink) + if os.path.islink(sname): + os.remove(sname) os.symlink(fname, sname)
def WriteMap(self):
Hi Neha,
def WriteMap(self):
-- 2.34.1
This breaks test coverage. Please add a test to ftest.py. You can probably run _DoTestFile() on an output directory with a in it?
At this point, buildman requires a few different modules and so we need a requirements.txt to track what modules are needed.
Cc: Simon Glass sjg@chromium.org Cc: Neha Malcom Francis n-francis@ti.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/buildman/requirements.txt | 2 ++ 1 file changed, 2 insertions(+) create mode 100644 tools/buildman/requirements.txt
diff --git a/tools/buildman/requirements.txt b/tools/buildman/requirements.txt new file mode 100644 index 0000000000..a1efcb9d4b --- /dev/null +++ b/tools/buildman/requirements.txt @@ -0,0 +1,2 @@ +jsonschema==4.17.3 +pyyaml==6.0
Now that buildman has a requirements.txt file we need to make use of it.
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org [n-francis@ti.com: Adding missing command from .azure-pipelines.yml] Signed-off-by: Neha Malcom Francis n-francis@ti.com --- .azure-pipelines.yml | 4 ++++ .gitlab-ci.yml | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 06c46b681c..8626b27d4b 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -162,6 +162,7 @@ stages: virtualenv -p /usr/bin/python3 /tmp/venv . /tmp/venv/bin/activate pip install -r test/py/requirements.txt + pip install -r tools/buildman/requirements.txt export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl export PYTHONPATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt export PATH=${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH} @@ -209,6 +210,7 @@ stages: git config --global --add safe.directory $(work_dir) export USER=azure pip install -r test/py/requirements.txt + pip install -r tools/buildman/requirements.txt pip install asteval pylint==2.12.2 pyopenssl export PATH=${PATH}:~/.local/bin echo "[MASTER]" >> .pylintrc @@ -404,6 +406,7 @@ stages: if [ -n "${BUILD_ENV}" ]; then export ${BUILD_ENV}; fi + pip install -r tools/buildman/requirements.txt tools/buildman/buildman -o ${UBOOT_TRAVIS_BUILD_DIR} -w -E -W -e --board ${TEST_PY_BD} ${OVERRIDE} cp ~/grub_x86.efi ${UBOOT_TRAVIS_BUILD_DIR}/ cp ~/grub_x64.efi ${UBOOT_TRAVIS_BUILD_DIR}/ @@ -583,6 +586,7 @@ stages: # make environment variables available as tests are running inside a container export BUILDMAN="${BUILDMAN}" git config --global --add safe.directory ${WORK_DIR} + pip install -r tools/buildman/requirements.txt EOF cat << "EOF" >> build.sh if [[ "${BUILDMAN}" != "" ]]; then diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index cfd58513c3..07d8ba5ac2 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -97,6 +97,7 @@ build all 32bit ARM platforms: script: - ret=0; git config --global --add safe.directory "${CI_PROJECT_DIR}"; + pip install -r tools/buildman/requirements.txt; ./tools/buildman/buildman -o /tmp -PEWM arm -x aarch64 || ret=$?; if [[ $ret -ne 0 ]]; then ./tools/buildman/buildman -o /tmp -seP; @@ -110,6 +111,7 @@ build all 64bit ARM platforms: - . /tmp/venv/bin/activate - ret=0; git config --global --add safe.directory "${CI_PROJECT_DIR}"; + pip install -r tools/buildman/requirements.txt; ./tools/buildman/buildman -o /tmp -PEWM aarch64 || ret=$?; if [[ $ret -ne 0 ]]; then ./tools/buildman/buildman -o /tmp -seP; @@ -208,6 +210,7 @@ Run binman, buildman, dtoc, Kconfig and patman testsuites: virtualenv -p /usr/bin/python3 /tmp/venv; . /tmp/venv/bin/activate; pip install -r test/py/requirements.txt; + pip install -r tools/buildman/requirements.txt; export UBOOT_TRAVIS_BUILD_DIR=/tmp/sandbox_spl; export PYTHONPATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc/pylibfdt"; export PATH="${UBOOT_TRAVIS_BUILD_DIR}/scripts/dtc:${PATH}"; @@ -240,6 +243,7 @@ Run pylint: script: - git config --global --add safe.directory "${CI_PROJECT_DIR}" - pip install -r test/py/requirements.txt + - pip install -r tools/buildman/requirements.txt - pip install asteval pylint==2.12.2 pyopenssl - export PATH=${PATH}:~/.local/bin - echo "[MASTER]" >> .pylintrc
participants (6)
Jan Kiszka
Jerome Forissier
Kumar, Udit
Neha Malcom Francis
Nishanth Menon
