[U-Boot] [PATCH v2] fdt_support: Check for bank size before updating memory node
In case if one of the bank that is passed is of size zero, then u-boot will be updating memory node with a bank of size zero. There is no need to update memory node if size is zero, so check for bank size before updating.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Fixed a typo in commit message.
common/fdt_support.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/fdt_support.c b/common/fdt_support.c index f86365e..0019eef 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -401,6 +401,9 @@ static int fdt_pack_reg(const void *fdt, void *buf, u64 *address, u64 *size, char *p = buf;
for (i = 0; i < n; i++) { + if (size[i] == 0) + continue; + if (address_cells == 2) *(fdt64_t *)p = cpu_to_fdt64(address[i]); else
Changes since v1:
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Acked-by: Simon Glass sjg@chromium.org
So, I thought about this more, and looked at device trees, more, and concluded, we're stuck with the interface we have. Today there's still many boards (such as the whole Beaglebone family!) that are setting incorrect sizes in the DTS but being correctly fixed up. We'll need to continue with the other tricks that can be done to pass in more memory in the memory node.
Lokesh Vutla
