[PATCH] xilinx: Sync CONFIG_DEFAULT_DEVICE_TREE position
Kconfig layout has changed that's why option has been moved.
configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 2 +- configs/bitmain_antminer_s9_defconfig | 2 +- configs/microblaze-generic_defconfig | 2 +- configs/syzygy_hub_defconfig | 2 +- configs/topic_miami_defconfig | 2 +- configs/topic_miamilite_defconfig | 2 +- configs/topic_miamiplus_defconfig | 2 +- configs/xilinx_versal_mini_defconfig | 2 +- configs/xilinx_versal_mini_emmc0_defconfig | 2 +- configs/xilinx_versal_mini_emmc1_defconfig | 2 +- configs/xilinx_zynq_virt_defconfig | 2 +- configs/xilinx_zynqmp_mini_defconfig | 2 +- configs/xilinx_zynqmp_mini_emmc0_defconfig | 2 +- configs/xilinx_zynqmp_mini_emmc1_defconfig | 2 +- configs/xilinx_zynqmp_mini_nand_defconfig | 2 +- configs/xilinx_zynqmp_mini_nand_single_defconfig | 2 +- configs/xilinx_zynqmp_mini_qspi_defconfig | 2 +- configs/xilinx_zynqmp_r5_defconfig | 2 +- configs/xilinx_zynqmp_virt_defconfig | 2 +- configs/zynq_cse_nand_defconfig | 2 +- configs/zynq_cse_nor_defconfig | 2 +- configs/zynq_cse_qspi_defconfig | 2 +- 22 files changed, 22 insertions(+), 22 deletions(-)
diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index 6c0d22c2ab71..dbbe2d5d66c7 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0" CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 @@ -12,7 +13,6 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_ZYNQ_MAC_IN_EEPROM=y CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xfa -CONFIG_DEFAULT_DEVICE_TREE="avnet-ultrazedev-cc-v1.0-ultrazedev-som-v1.0" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/bitmain_antminer_s9_defconfig b/configs/bitmain_antminer_s9_defconfig index 76cccfa586c5..299206e85b30 100644 --- a/configs/bitmain_antminer_s9_defconfig +++ b/configs/bitmain_antminer_s9_defconfig @@ -7,12 +7,12 @@ CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="bitmain-antminer-s9" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SYS_BOOTCOUNT_ADDR=0xEFFFFF0 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0001000 CONFIG_DEBUG_UART_CLOCK=50000000 -CONFIG_DEFAULT_DEVICE_TREE="bitmain-antminer-s9" CONFIG_DEBUG_UART=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 245763b40877..309522670817 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_TARGET_MICROBLAZE_GENERIC=y @@ -11,7 +12,6 @@ CONFIG_XILINX_MICROBLAZE0_USE_MSR_INSTR=1 CONFIG_XILINX_MICROBLAZE0_USE_BARREL=1 CONFIG_XILINX_MICROBLAZE0_USE_DIV=1 CONFIG_XILINX_MICROBLAZE0_USE_HW_MUL=1 -CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 276c476baebc..b5ec025db9c3 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -5,13 +5,13 @@ CONFIG_SPL_SYS_DCACHE_OFF=y CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-syzygy-hub" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 CONFIG_DEBUG_UART_CLOCK=50000000 CONFIG_ZYNQ_MAC_IN_EEPROM=y CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0xFA -CONFIG_DEFAULT_DEVICE_TREE="zynq-syzygy-hub" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index ec66bb09584a..d9490cd9b77e 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -9,12 +9,12 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miami" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miami/ps7_regs.txt" -CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miami" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index e4145948859e..31b9dd912cb7 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -9,12 +9,12 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamilite" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamilite/ps7_regs.txt" -CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamilite" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 0041ee153669..37e0d15a1b42 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -9,12 +9,12 @@ CONFIG_SYS_MEMTEST_END=0x18000000 CONFIG_ENV_SIZE=0x8000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x20000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamiplus" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xe0000000 CONFIG_DEBUG_UART_CLOCK=100000000 CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamiplus/ps7_regs.txt" -CONFIG_DEFAULT_DEVICE_TREE="zynq-topic-miamiplus" CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y diff --git a/configs/xilinx_versal_mini_defconfig b/configs/xilinx_versal_mini_defconfig index 85d783c07cbd..7f75f9bb9ce8 100644 --- a/configs/xilinx_versal_mini_defconfig +++ b/configs/xilinx_versal_mini_defconfig @@ -8,10 +8,10 @@ CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_ENV_SIZE=0x80 CONFIG_SYS_MALLOC_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini" CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_COUNTER_FREQUENCY=100000000 # CONFIG_PSCI_RESET is not set -CONFIG_DEFAULT_DEVICE_TREE="versal-mini" # CONFIG_EXPERT is not set # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_versal_mini_emmc0_defconfig b/configs/xilinx_versal_mini_emmc0_defconfig index 5721e005d7cb..7547b2699cbe 100644 --- a/configs/xilinx_versal_mini_emmc0_defconfig +++ b/configs/xilinx_versal_mini_emmc0_defconfig @@ -6,9 +6,9 @@ CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 CONFIG_SYS_MALLOC_LEN=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-emmc0" CONFIG_COUNTER_FREQUENCY=100000000 # CONFIG_PSCI_RESET is not set -CONFIG_DEFAULT_DEVICE_TREE="versal-mini-emmc0" # CONFIG_EXPERT is not set # CONFIG_AUTOBOOT is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/xilinx_versal_mini_emmc1_defconfig b/configs/xilinx_versal_mini_emmc1_defconfig index db06ea3ab649..0854d50eb492 100644 --- a/configs/xilinx_versal_mini_emmc1_defconfig +++ b/configs/xilinx_versal_mini_emmc1_defconfig @@ -6,9 +6,9 @@ CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 CONFIG_SYS_MALLOC_LEN=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="versal-mini-emmc1" CONFIG_COUNTER_FREQUENCY=100000000 # CONFIG_PSCI_RESET is not set -CONFIG_DEFAULT_DEVICE_TREE="versal-mini-emmc1" # CONFIG_EXPERT is not set # CONFIG_AUTOBOOT is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 7e56395a521f..3b34cf59a73c 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -7,11 +7,11 @@ CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_ENV_OFFSET=0xE00000 CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_CMD_FRU=y CONFIG_CMD_ZYNQ_AES=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-zc706" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index 64989db29177..b0fd86175836 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -6,10 +6,10 @@ CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini" CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_ZYNQMP_PSU_INIT_ENABLED=y # CONFIG_CMD_ZYNQMP is not set -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini" # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_AUTOBOOT is not set # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index bafbd8a3d317..f9b2c0ade458 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -6,10 +6,10 @@ CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc0" CONFIG_SPL_SYS_MALLOC_F_LEN=0x600 CONFIG_SPL=y # CONFIG_CMD_ZYNQMP is not set -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc0" CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index ef2be75e1fa6..996e65d58cfa 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -6,10 +6,10 @@ CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc1" CONFIG_SPL_SYS_MALLOC_F_LEN=0x600 CONFIG_SPL=y # CONFIG_CMD_ZYNQMP is not set -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc1" CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_zynqmp_mini_nand_defconfig b/configs/xilinx_zynqmp_mini_nand_defconfig index a61507ea7ae8..dbe5c42ffb16 100644 --- a/configs/xilinx_zynqmp_mini_nand_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_defconfig @@ -5,8 +5,8 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 -# CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" +# CONFIG_CMD_ZYNQMP is not set CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig index cd5f6de635f6..e16b9f4127ab 100644 --- a/configs/xilinx_zynqmp_mini_nand_single_defconfig +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -5,8 +5,8 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x10000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 -# CONFIG_CMD_ZYNQMP is not set CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" +# CONFIG_CMD_ZYNQMP is not set CONFIG_FIT=y CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 15cba60d5356..5d6537149824 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -5,12 +5,12 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x80 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-qspi" CONFIG_SPL=y CONFIG_SYS_MEM_RSVD_FOR_MMU=y CONFIG_ZYNQMP_NO_DDR=y # CONFIG_CMD_ZYNQMP is not set # CONFIG_PSCI_RESET is not set -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-qspi" # CONFIG_EXPERT is not set # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_AUTOBOOT is not set diff --git a/configs/xilinx_zynqmp_r5_defconfig b/configs/xilinx_zynqmp_r5_defconfig index f7433e994d39..143c253f0efd 100644 --- a/configs/xilinx_zynqmp_r5_defconfig +++ b/configs/xilinx_zynqmp_r5_defconfig @@ -4,9 +4,9 @@ CONFIG_SYS_TEXT_BASE=0x10000000 CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-r5" CONFIG_DEBUG_UART_BASE=0xff010000 CONFIG_DEBUG_UART_CLOCK=100000000 -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-r5" CONFIG_DEBUG_UART=y CONFIG_BOOTSTAGE=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index dc5778fb4704..dc057f427e90 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SYS_MEMTEST_START=0x00000000 CONFIG_SYS_MEMTEST_END=0x00001000 CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y @@ -13,7 +14,6 @@ CONFIG_ZYNQ_MAC_IN_EEPROM=y CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 CONFIG_CMD_FRU=y CONFIG_ZYNQMP_USB=y -CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu100-revC" CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index b36fd4a43c67..2386da77ed66 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -6,9 +6,9 @@ CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x100000 CONFIG_ENV_SIZE=0x190 CONFIG_SYS_MALLOC_LEN=0x8000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" # CONFIG_AUTOBOOT is not set diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 3e614dfc86f2..d19170da8e4c 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -6,9 +6,9 @@ CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_ENV_SIZE=0x190 CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y -CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds" # CONFIG_AUTOBOOT is not set diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 7cb1d6122d4e..3d0f742798f8 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -7,13 +7,13 @@ CONFIG_SYS_TEXT_BASE=0xFFFC0000 CONFIG_ENV_SIZE=0x190 CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-qspi-single" CONFIG_SPL_STACK_R_ADDR=0x200000 CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x0 CONFIG_DEBUG_UART_CLOCK=0 # CONFIG_ZYNQ_DDRC_INIT is not set # CONFIG_CMD_ZYNQ is not set -CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-qspi-single" CONFIG_DEBUG_UART=y CONFIG_SYS_CUSTOM_LDSCRIPT=y CONFIG_SYS_LDSCRIPT="arch/arm/mach-zynq/u-boot.lds"
In that I'm going to include a global resync like I typically do on tagged releases shortly, nak.
I thought that you will do it.
Thanks, Michal
Michal Simek
