[U-Boot] [PATCH 1/1] stmf32f4: soc: fix buildman compilation error
fix the following compilation error reported by buidlman:
arm: + stm32f429-discovery +arch/arm/mach-stm32/stm32f4/soc.c: In function 'arch_cpu_init': +arch/arm/mach-stm32/stm32f4/soc.c:30:2: error: 'for' loop initial declarations are only allowed in C99 or C11 mode + for (int i = 0; i < ARRAY_SIZE(stm32_region_config); i++) + ^ +arch/arm/mach-stm32/stm32f4/soc.c:30:2: note: use option -std=c99, -std=gnu99, -std=c11 or -std=gnu11 to compile your code +make[3]: *** [arch/arm/mach-stm32/stm32f4/soc.o] Error 1 +make[2]: *** [arch/arm/mach-stm32/stm32f4] Error 2 +make[1]: *** [arch/arm/mach-stm32] Error 2 +make: *** [sub-make] Error 2
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/mach-stm32/stm32f4/soc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-stm32/stm32f4/soc.c b/arch/arm/mach-stm32/stm32f4/soc.c index 3f45a25..958be22 100644 --- a/arch/arm/mach-stm32/stm32f4/soc.c +++ b/arch/arm/mach-stm32/stm32f4/soc.c @@ -21,6 +21,8 @@ int arch_cpu_init(void) { 0x00000000, REGION_0, XN_DIS, PRIV_RW_USR_RW, STRONG_ORDER, REGION_4GB }, }; + int i; + configure_clocks(); /* * Configure the memory protection unit (MPU) to allow full access to
wrong patch sent, a correct one will be sent to replace it
Patrice
- for (int i = 0; i < ARRAY_SIZE(stm32_region_config); i++)
- int i;
- configure_clocks(); /*
- Configure the memory protection unit (MPU) to allow full access to
Patrice CHOTARD
