[U-Boot] [PATCH v3] Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS
Linker needs to use the proper endian/bfd flags even when doing partial linking. LDFLAGS_u-boot sets linker option which is called it when U-boot is built (u-boot final). LDFLAGS sets necessary option by partial linking (use in cmd_link_o_target).
CC: Mike Frysinger vapier@gentoo.org Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- V3: Remove trailing space.
Makefile | 2 +- arch/blackfin/config.mk | 3 ++- arch/i386/config.mk | 3 ++- arch/nios2/config.mk | 2 +- arch/powerpc/config.mk | 4 ++-- arch/sh/config.mk | 2 +- arch/sh/cpu/sh2/config.mk | 4 +++- config.mk | 8 +++++--- 8 files changed, 17 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index 9055028..d6884ea 100644 --- a/Makefile +++ b/Makefile @@ -369,7 +369,7 @@ $(obj)u-boot.dis: $(obj)u-boot GEN_UBOOT = \ UNDEF_SYM=`$(OBJDUMP) -x $(LIBBOARD) $(LIBS) | \ sed -n -e 's/.*($(SYM_PREFIX)__u_boot_cmd_.*)/-u\1/p'|sort|uniq`;\ - cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \ + cd $(LNDIR) && $(LD) $(LDFLAGS) $(LDFLAGS_$(@F)) $$UNDEF_SYM $(__OBJS) \ --start-group $(__LIBS) --end-group $(PLATFORM_LIBS) \ -Map u-boot.map -o u-boot $(obj)u-boot: depend \ diff --git a/arch/blackfin/config.mk b/arch/blackfin/config.mk index ab117ca..0cba294 100644 --- a/arch/blackfin/config.mk +++ b/arch/blackfin/config.mk @@ -30,7 +30,8 @@ CONFIG_BFIN_BOOT_MODE := $(strip $(subst ",,$(CONFIG_BFIN_BOOT_MODE))) PLATFORM_RELFLAGS += -ffixed-P3 -fomit-frame-pointer -mno-fdpic PLATFORM_CPPFLAGS += -DCONFIG_BLACKFIN
-LDFLAGS += --gc-sections -m elf32bfin +LDFLAGS_u-boot += --gc-sections +LDFLAGS += -m elf32bfin PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections
PLATFORM_CPPFLAGS += -DBFIN_CPU='"$(CONFIG_BFIN_CPU)"' diff --git a/arch/i386/config.mk b/arch/i386/config.mk index 8743f1a..3fb97c1 100644 --- a/arch/i386/config.mk +++ b/arch/i386/config.mk @@ -35,5 +35,6 @@ PLATFORM_CPPFLAGS += $(call cc-option, -fno-stack-protector) PLATFORM_CPPFLAGS += $(call cc-option, -mpreferred-stack-boundary=2) PLATFORM_CPPFLAGS += -DCONFIG_I386 -D__I386__
-LDFLAGS += --cref --gc-sections +LDFLAGS += --cref +LDFLAGS_u-boot += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections diff --git a/arch/nios2/config.mk b/arch/nios2/config.mk index aba96b3..fa93180 100644 --- a/arch/nios2/config.mk +++ b/arch/nios2/config.mk @@ -31,5 +31,5 @@ PLATFORM_CPPFLAGS += -G0
LDSCRIPT ?= $(SRCTREE)/$(CPUDIR)/u-boot.lds
-LDFLAGS += --gc-sections +LDFLAGS_u-boot += --gc-sections PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections diff --git a/arch/powerpc/config.mk b/arch/powerpc/config.mk index 2912604..64191c7 100644 --- a/arch/powerpc/config.mk +++ b/arch/powerpc/config.mk @@ -24,10 +24,10 @@ CROSS_COMPILE ?= ppc_8xx-
STANDALONE_LOAD_ADDR = 0x40000 - +LDFLAGS_u-boot = --gc-sections PLATFORM_RELFLAGS += -mrelocatable -ffunction-sections -fdata-sections PLATFORM_CPPFLAGS += -DCONFIG_PPC -D__powerpc__ -PLATFORM_LDFLAGS += -n --gc-sections +PLATFORM_LDFLAGS += -n
ifdef CONFIG_SYS_LDSCRIPT # need to strip off double quotes diff --git a/arch/sh/config.mk b/arch/sh/config.mk index 415c949..4ef85e3 100644 --- a/arch/sh/config.mk +++ b/arch/sh/config.mk @@ -30,5 +30,5 @@ endif
PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ PLATFORM_LDFLAGS += -e $(CONFIG_SYS_TEXT_BASE) --defsym reloc_dst=$(CONFIG_SYS_TEXT_BASE) - +LDFLAGS_u-boot = --gc-sections LDSCRIPT := $(SRCTREE)/$(CPUDIR)/u-boot.lds diff --git a/arch/sh/cpu/sh2/config.mk b/arch/sh/cpu/sh2/config.mk index 52d5a0f..f2d40aa 100644 --- a/arch/sh/cpu/sh2/config.mk +++ b/arch/sh/cpu/sh2/config.mk @@ -21,6 +21,8 @@ # MA 02111-1307 USA # # +ENDIANNESS += -EB + PLATFORM_CPPFLAGS += -m3e -mb PLATFORM_RELFLAGS += -ffixed-r13 -PLATFORM_LDFLAGS += -EB +PLATFORM_LDFLAGS += $(ENDIANNESS) diff --git a/config.mk b/config.mk index 66f8fe6..5147c35 100644 --- a/config.mk +++ b/config.mk @@ -204,9 +204,11 @@ endif
AFLAGS := $(AFLAGS_DEBUG) -D__ASSEMBLY__ $(CPPFLAGS)
-LDFLAGS += -Bstatic -T $(obj)u-boot.lds $(PLATFORM_LDFLAGS) +LDFLAGS += $(PLATFORM_LDFLAGS) + +LDFLAGS_u-boot += -Bstatic -T $(obj)u-boot.lds $(PLATFORM_LDFLAGS) ifneq ($(CONFIG_SYS_TEXT_BASE),) -LDFLAGS += -Ttext $(CONFIG_SYS_TEXT_BASE) +LDFLAGS_u-boot += -Ttext $(CONFIG_SYS_TEXT_BASE) endif
# Location of a usable BFD library, where we define "usable" as @@ -259,7 +261,7 @@ $(obj)%.s: %.c
# If the list of objects to link is empty, just create an empty built-in.o cmd_link_o_target = $(if $(strip $1),\ - $(LD) -r -o $@ $1 ,\ + $(LD) $(LDFLAGS) -r -o $@ $1,\ rm -f $@; $(AR) rcs $@ )
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Dear Nobuhiro Iwamatsu,
This patch does no longer apply. Is it still needed? If yes, please rebase and resubmit. Thanks.
It's already been applied (8aba9dceebb14144e07d19593111ee3a999c37fc)...
-Scott
# Scott has already replied, too. You applied this patch by commit 8aba9dceebb14144e07d19593111ee3a999c37fc.
Best regards, Nobuhiro
2011/4/12 Wolfgang Denk wd@denx.de:
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "It is easier to port a shell than a shell script." - Larry Wall
Mike Frysinger
Nobuhiro Iwamatsu
Scott Wood
