[U-Boot] [PATCH] arm: dts: k3-am654: Sync IOPAD macros with Linux
Transition to the IOPAD macros as used in Linux in which the pin mux mode is specified using a dedicated parameter while also dropping the related MUX_MODEx macros that are no longer needed. This transition will allow us to keep both Linux and U-Boot DTS in sync more easily.
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 46 ++++++++++---------- arch/arm/dts/k3-am654-r5-base-board.dts | 10 ++--- include/dt-bindings/pinctrl/k3-am65.h | 15 +------ 3 files changed, 30 insertions(+), 41 deletions(-)
diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi index c5d23d0203..dc8b05c263 100644 --- a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -144,41 +144,41 @@ u-boot,dm-spl; main_uart0_pins_default: main_uart0_pins_default { pinctrl-single,pins = < - AM65X_IOPAD(0x01e4, PIN_INPUT | MUX_MODE0) /* (AF11) UART0_RXD */ - AM65X_IOPAD(0x01e8, PIN_OUTPUT | MUX_MODE0) /* (AE11) UART0_TXD */ - AM65X_IOPAD(0x01ec, PIN_INPUT | MUX_MODE0) /* (AG11) UART0_CTSn */ - AM65X_IOPAD(0x01f0, PIN_OUTPUT | MUX_MODE0) /* (AD11) UART0_RTSn */ + AM65X_IOPAD(0x01e4, PIN_INPUT, 0) /* (AF11) UART0_RXD */ + AM65X_IOPAD(0x01e8, PIN_OUTPUT, 0) /* (AE11) UART0_TXD */ + AM65X_IOPAD(0x01ec, PIN_INPUT, 0) /* (AG11) UART0_CTSn */ + AM65X_IOPAD(0x01f0, PIN_OUTPUT, 0) /* (AD11) UART0_RTSn */ >; u-boot,dm-spl; };
main_mmc0_pins_default: main_mmc0_pins_default { pinctrl-single,pins = < - AM65X_IOPAD(0x01a8, PIN_INPUT_PULLDOWN | MUX_MODE0) /* (B25) MMC0_CLK */ - AM65X_IOPAD(0x01aC, PIN_INPUT_PULLUP | MUX_MODE0) /* (B27) MMC0_CMD */ - AM65X_IOPAD(0x01a4, PIN_INPUT_PULLUP | MUX_MODE0) /* (A26) MMC0_DAT0 */ - AM65X_IOPAD(0x01a0, PIN_INPUT_PULLUP | MUX_MODE0) /* (E25) MMC0_DAT1 */ - AM65X_IOPAD(0x019c, PIN_INPUT_PULLUP | MUX_MODE0) /* (C26) MMC0_DAT2 */ - AM65X_IOPAD(0x0198, PIN_INPUT_PULLUP | MUX_MODE0) /* (A25) MMC0_DAT3 */ - AM65X_IOPAD(0x0194, PIN_INPUT_PULLUP | MUX_MODE0) /* (E24) MMC0_DAT4 */ - AM65X_IOPAD(0x0190, PIN_INPUT_PULLUP | MUX_MODE0) /* (A24) MMC0_DAT5 */ - AM65X_IOPAD(0x018c, PIN_INPUT_PULLUP | MUX_MODE0) /* (B26) MMC0_DAT6 */ - AM65X_IOPAD(0x0188, PIN_INPUT_PULLUP | MUX_MODE0) /* (D25) MMC0_DAT7 */ - AM65X_IOPAD(0x01b0, PIN_INPUT | MUX_MODE0) /* (C25) MMC0_DS */ + AM65X_IOPAD(0x01a8, PIN_INPUT_PULLDOWN, 0) /* (B25) MMC0_CLK */ + AM65X_IOPAD(0x01aC, PIN_INPUT_PULLUP, 0) /* (B27) MMC0_CMD */ + AM65X_IOPAD(0x01a4, PIN_INPUT_PULLUP, 0) /* (A26) MMC0_DAT0 */ + AM65X_IOPAD(0x01a0, PIN_INPUT_PULLUP, 0) /* (E25) MMC0_DAT1 */ + AM65X_IOPAD(0x019c, PIN_INPUT_PULLUP, 0) /* (C26) MMC0_DAT2 */ + AM65X_IOPAD(0x0198, PIN_INPUT_PULLUP, 0) /* (A25) MMC0_DAT3 */ + AM65X_IOPAD(0x0194, PIN_INPUT_PULLUP, 0) /* (E24) MMC0_DAT4 */ + AM65X_IOPAD(0x0190, PIN_INPUT_PULLUP, 0) /* (A24) MMC0_DAT5 */ + AM65X_IOPAD(0x018c, PIN_INPUT_PULLUP, 0) /* (B26) MMC0_DAT6 */ + AM65X_IOPAD(0x0188, PIN_INPUT_PULLUP, 0) /* (D25) MMC0_DAT7 */ + AM65X_IOPAD(0x01b0, PIN_INPUT, 0) /* (C25) MMC0_DS */ >; u-boot,dm-spl; };
main_mmc1_pins_default: main_mmc1_pins_default { pinctrl-single,pins = < - AM65X_IOPAD(0x02d4, PIN_INPUT_PULLDOWN | MUX_MODE0) /* (C27) MMC1_CLK */ - AM65X_IOPAD(0x02d8, PIN_INPUT_PULLUP | MUX_MODE0) /* (C28) MMC1_CMD */ - AM65X_IOPAD(0x02d0, PIN_INPUT_PULLUP | MUX_MODE0) /* (D28) MMC1_DAT0 */ - AM65X_IOPAD(0x02cc, PIN_INPUT_PULLUP | MUX_MODE0) /* (E27) MMC1_DAT1 */ - AM65X_IOPAD(0x02c8, PIN_INPUT_PULLUP | MUX_MODE0) /* (D26) MMC1_DAT2 */ - AM65X_IOPAD(0x02c4, PIN_INPUT_PULLUP | MUX_MODE0) /* (D27) MMC1_DAT3 */ - AM65X_IOPAD(0x02dc, PIN_INPUT_PULLUP | MUX_MODE0) /* (B24) MMC1_SDCD */ - AM65X_IOPAD(0x02e0, PIN_INPUT | MUX_MODE0) /* (C24) MMC1_SDWP */ + AM65X_IOPAD(0x02d4, PIN_INPUT_PULLDOWN, 0) /* (C27) MMC1_CLK */ + AM65X_IOPAD(0x02d8, PIN_INPUT_PULLUP, 0) /* (C28) MMC1_CMD */ + AM65X_IOPAD(0x02d0, PIN_INPUT_PULLUP, 0) /* (D28) MMC1_DAT0 */ + AM65X_IOPAD(0x02cc, PIN_INPUT_PULLUP, 0) /* (E27) MMC1_DAT1 */ + AM65X_IOPAD(0x02c8, PIN_INPUT_PULLUP, 0) /* (D26) MMC1_DAT2 */ + AM65X_IOPAD(0x02c4, PIN_INPUT_PULLUP, 0) /* (D27) MMC1_DAT3 */ + AM65X_IOPAD(0x02dc, PIN_INPUT_PULLUP, 0) /* (B24) MMC1_SDCD */ + AM65X_IOPAD(0x02e0, PIN_INPUT, 0) /* (C24) MMC1_SDWP */ >; u-boot,dm-spl; }; diff --git a/arch/arm/dts/k3-am654-r5-base-board.dts b/arch/arm/dts/k3-am654-r5-base-board.dts index 72039ac870..a07038be70 100644 --- a/arch/arm/dts/k3-am654-r5-base-board.dts +++ b/arch/arm/dts/k3-am654-r5-base-board.dts @@ -116,17 +116,17 @@ u-boot,dm-spl; wkup_uart0_pins_default: wkup_uart0_pins_default { pinctrl-single,pins = < - AM65X_WKUP_IOPAD(0x00a0, PIN_INPUT | MUX_MODE0) /* (AB1) WKUP_UART0_RXD */ - AM65X_WKUP_IOPAD(0x00a4, PIN_OUTPUT | MUX_MODE0) /* (AB5) WKUP_UART0_TXD */ - AM65X_WKUP_IOPAD(0x00c8, PIN_INPUT | MUX_MODE1) /* (AC2) WKUP_GPIO0_6.WKUP_UART0_CTSn */ - AM65X_WKUP_IOPAD(0x00cc, PIN_OUTPUT | MUX_MODE1) /* (AC1) WKUP_GPIO0_7.WKUP_UART0_RTSn */ + AM65X_WKUP_IOPAD(0x00a0, PIN_INPUT, 0) /* (AB1) WKUP_UART0_RXD */ + AM65X_WKUP_IOPAD(0x00a4, PIN_OUTPUT, 0) /* (AB5) WKUP_UART0_TXD */ + AM65X_WKUP_IOPAD(0x00c8, PIN_INPUT, 1) /* (AC2) WKUP_GPIO0_6.WKUP_UART0_CTSn */ + AM65X_WKUP_IOPAD(0x00cc, PIN_OUTPUT, 1) /* (AC1) WKUP_GPIO0_7.WKUP_UART0_RTSn */ >; u-boot,dm-spl; };
wkup_vtt_pins_default: wkup_vtt_pins_default { pinctrl-single,pins = < - AM65X_WKUP_IOPAD(0x0040, PIN_OUTPUT_PULLUP | MUX_MODE7) /* WKUP_GPIO0_28 */ + AM65X_WKUP_IOPAD(0x0040, PIN_OUTPUT_PULLUP, 7) /* WKUP_GPIO0_28 */ >; u-boot,dm-spl; }; diff --git a/include/dt-bindings/pinctrl/k3-am65.h b/include/dt-bindings/pinctrl/k3-am65.h index c86c9fd4ce..a67521cdc4 100644 --- a/include/dt-bindings/pinctrl/k3-am65.h +++ b/include/dt-bindings/pinctrl/k3-am65.h @@ -7,17 +7,6 @@ #ifndef _DT_BINDINGS_PINCTRL_TI_K3_AM65_H #define _DT_BINDINGS_PINCTRL_TI_K3_AM65_H
-/* K3 mux mode options for each pin. See TRM for options */ -#define MUX_MODE0 0 -#define MUX_MODE1 1 -#define MUX_MODE2 2 -#define MUX_MODE3 3 -#define MUX_MODE4 4 -#define MUX_MODE5 5 -#define MUX_MODE6 6 -#define MUX_MODE7 7 -#define MUX_MODE15 15 - #define PULL_DISABLE (1 << 16) #define PULL_UP (1 << 17) #define INPUT_EN (1 << 18) @@ -43,7 +32,7 @@ #define PIN_INPUT_PULLUP (INPUT_EN | PULL_UP) #define PIN_INPUT_PULLDOWN (INPUT_EN)
-#define AM65X_IOPAD(pa, val) (((pa) & 0x1fff)) (val) -#define AM65X_WKUP_IOPAD(pa, val) (((pa) & 0x1fff)) (val) +#define AM65X_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode)) +#define AM65X_WKUP_IOPAD(pa, val, muxmode) (((pa) & 0x1fff)) ((val) | (muxmode))
#endif
u-boot,dm-spl; };
u-boot,dm-spl; };
;u-boot,dm-spl; };diff --git a/arch/arm/dts/k3-am654-r5-base-board.dts b/arch/arm/dts/k3-am654-r5-base-board.dts index 72039ac870..a07038be70 100644 --- a/arch/arm/dts/k3-am654-r5-base-board.dts +++ b/arch/arm/dts/k3-am654-r5-base-board.dts @@ -116,17 +116,17 @@ u-boot,dm-spl; wkup_uart0_pins_default: wkup_uart0_pins_default { pinctrl-single,pins = <
u-boot,dm-spl; };
;u-boot,dm-spl; };diff --git a/include/dt-bindings/pinctrl/k3-am65.h b/include/dt-bindings/pinctrl/k3-am65.h index c86c9fd4ce..a67521cdc4 100644 --- a/include/dt-bindings/pinctrl/k3-am65.h +++ b/include/dt-bindings/pinctrl/k3-am65.h
Can you rename it to k3.h?
Thanks and regards, Lokesh
#endif
Andreas Dannenberg
Lokesh Vutla
