[U-Boot] [PATCH v2] dwmmc: make driver usable for non-exynos platforms
There's no point in having of "dwmmc.h" per architecure - we're talking about device driver (DesignWare MMC controller) which is expected to work with any CPU it is attached to.
Actually this change should have been an essential part of commit: ======= 6f0b7caa671f92c2d4676c84381d17fb90f7d2cd DWMMC: SMDK5420: Disable SMU for eMMC =======
Or even better I'd prefer all non pure DW MMC functionality (those item in ifdefs) to be moved to corresponding files like "exynos_dw_mmc.c" via call-backs etc. This will keep DW MMC driver clean and simple.
As it is said in http://www.denx.de/wiki/U-Boot/DesignPrinciples: ======= 8. Keep it Maintainable Avoid #ifdefs where possible =======
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com
Cc: Mischa Jonker mjonker@synopsys.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Andy Fleming afleming@gmail.com Cc: Alim Akhtar alim.akhtar@samsung.com Cc: Rajeshwari Shinde rajeshwari.s@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Pantelis Antoniou panto@antoniou-consulting.com
Changes compared to initial version: Instead of modification of headers only disable some parts of code with ifdefs. --- drivers/mmc/dw_mmc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 1e0f72b..fdae40b 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -11,7 +11,9 @@ #include <mmc.h> #include <dwmmc.h> #include <asm-generic/errno.h> +#ifdef CONFIG_EXYNOS5420 #include <asm/arch/dwmmc.h> +#endif
#define PAGE_SIZE 4096
@@ -302,6 +304,7 @@ static int dwmci_init(struct mmc *mmc) struct dwmci_host *host = (struct dwmci_host *)mmc->priv; u32 fifo_size;
+#ifdef CONFIG_EXYNOS5420 if (host->quirks & DWMCI_QUIRK_DISABLE_SMU) { dwmci_writel(host, EMMCP_MPSBEGIN0, 0); dwmci_writel(host, EMMCP_SEND0, 0); @@ -311,6 +314,7 @@ static int dwmci_init(struct mmc *mmc) MPSCTRL_NON_SECURE_READ_BIT | MPSCTRL_NON_SECURE_WRITE_BIT | MPSCTRL_VALID); } +#endif
dwmci_writel(host, DWMCI_PWREN, 1);
Hi Alexey,
I have replied the previous patch.
- Keep it Maintainable
Just remove this.
remove this and use callback function like the host->board_init()? if (host->board_init()) host->board_init(host);
Then we can reuse the this function for board specific code. Anyway, I think that exynos code didn't exist at here(dw-mmc.c).
Best Regards, Jaehoon Chung
I may do this change but I don't own corresponding HW (Exynos-5420 based) so I won't be able to test my changes.
And that's why I propose to apply this patch so driver is now again gets built for any platform and if anybody who have access to Exynos-5420 HW have some time to clean-up then it's good, anyways people will be happy again :)
-Alexey
P.S. I saw you reply on v1 patch you just sent - so feel free to clean-up the driver if it's ok for you or let's keep my "work-around" for now.
Hi Alexey,
-Alexey
All looks good from my side;
Please do a boot test on the real hardware and let me know before I can apply.
Regards
-- Pantelis
Hi All,
Iam a bit confused here. After Jaehoon Chung has submitted the following patch: "https://www.mail-archive.com/u-boot@lists.denx.de/msg126921.html"
Do we need to include this patch also?
Regards, Rajeshwari Shinde.
On Fri, Nov 29, 2013 at 5:46 PM, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
Hi Pantelis,
confirming - builds/works good for me.
-Alexey _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi, Rajeshwari
It didn't need to include this patch.
On 12/02/2013 02:39 PM, Rajeshwari Birje wrote:
Hi All,
Hi Pantelis,
On Mon, 2013-12-02 at 14:45 +0900, Jaehoon Chung wrote:
Hi, Rajeshwari
Agree, there's no need in this particular patch any more. Jaehoon Chung did appropriate changes in dwmmc driver.
Thanks for collaboration.
-Alexey
Alexey Brodkin
Jaehoon Chung
Pantelis Antoniou
Rajeshwari Birje
