[U-Boot] [PATCH V2] OMAP3: Various: Update serial platdata to update reg_offset to 0
V2: I hastily copy-pasted the boards without looking at the UART number. This addresses 3 boards that use UART3 and not UART1.
With commit: d9a3bec682f9 "dm: ns16550: Add support for reg-offset property" reg_offset is added to the struct ns16550_platdata to be dt compatible with Linux kernel driver. A variety of OMAP3 boards are broken as the serial platdata is missing offsets. By explicitly naming the entry, this should also help 'future-proof' if more entries get added but are not needed for OMAP3. Tested on the Logic PD Torpedo + Wireless.
I only changed a handful of devices that used the same syntax as the Logic board. Appologies if I missed one or stepped on toes. Thanks to Derald Woods and Alexander Graf.
Signed-off-by: Adam Ford aford173@gmail.com --- board/isee/igep00x0/igep00x0.c | 7 ++++--- board/logicpd/omap3som/omap3logic.c | 7 ++++--- board/logicpd/zoom1/zoom1.c | 7 ++++--- board/overo/overo.c | 7 ++++--- board/quipos/cairo/cairo.c | 7 ++++--- board/ti/beagle/beagle.c | 7 ++++--- board/timll/devkit8000/devkit8000.c | 7 ++++--- 7 files changed, 28 insertions(+), 21 deletions(-)
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index e2fce50..63489e5 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -34,9 +34,10 @@ static const u32 gpmc_lan_config[] = { #endif
static const struct ns16550_platdata igep_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART1, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(igep_uart) = { diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 668f684..0e72a5a 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -47,9 +47,10 @@ DECLARE_GLOBAL_DATA_PTR; */
static const struct ns16550_platdata omap3logic_serial = { - OMAP34XX_UART1, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART1, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(omap3logic_uart) = { diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index 4040114..3d34919 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -44,9 +44,10 @@ static const u32 gpmc_lab_enet[] = { };
static const struct ns16550_platdata zoom1_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART1, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(zoom1_uart) = { diff --git a/board/overo/overo.c b/board/overo/overo.c index a38b959..3da80e9 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -68,9 +68,10 @@ static struct { } expansion_config = {0x0};
static const struct ns16550_platdata overo_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(overo_uart) = { diff --git a/board/quipos/cairo/cairo.c b/board/quipos/cairo/cairo.c index 21793e8..15d68c1 100644 --- a/board/quipos/cairo/cairo.c +++ b/board/quipos/cairo/cairo.c @@ -91,9 +91,10 @@ void get_board_mem_timings(struct board_sdrc_timings *timings) #endif
static const struct ns16550_platdata cairo_serial = { - OMAP34XX_UART2, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART1, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(cairo_uart) = { diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index ff317ef..a5f2af7 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -73,9 +73,10 @@ static struct { } expansion_config;
static const struct ns16550_platdata beagle_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(beagle_uart) = { diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 1a447c7..fb8e357 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -46,9 +46,10 @@ static u32 gpmc_net_config[GPMC_MAX_REG] = { };
static const struct ns16550_platdata devkit8000_serial = { - OMAP34XX_UART3, - 2, - V_NS16550_CLK + .base = OMAP34XX_UART3, + .reg_offset = 0, + .reg_shift = 2, + .clock = V_NS16550_CLK };
U_BOOT_DEVICE(devkit8000_uart) = {
Hello Adam,
Am 29.02.2016 um 12:53 schrieb Adam Ford:
What has changed exactly in v2 ?
Beside of this: Reviewed-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART1,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART2,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
V1 I changed all the platform data to explicitly name the entries instead of just using a table of numbers. This would hopefully address future proofing against the header changing order. I copy-pasted the table from my board to a series of boards and then later realized I had accidentally changed the UART number which would have broken a few boards.
V2, Fixes that issue because igep, overo, beagle and devkit8000 used UART3 instead of UART1, so it was a correction on my part. The change from V1 was kept, but the correct UART was referenced.
On Mon, Feb 29, 2016 at 6:29 AM, Heiko Schocher hs@denx.de wrote:
Hello Adam,
Thanks!
bye, Heiko
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART1,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART2,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Hello Adam,
Am 29.02.2016 um 13:51 schrieb Adam Ford:
Please add this information below the "---" in your next version, thanks!
Maybe you want to try "u-boot:tools/patman/patman", which helps a lot
bye, Heiko
Hello Adam,
Thanks!
bye, Heiko
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART1,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART2,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
- .base = OMAP34XX_UART1,
This looks wrong
- .reg_offset = 0,
I'd say just leave reg_offset out in all the structs. It gets initialized to 0 by default.
.reg_shift = 2,
- OMAP34XX_UART1,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
looks wrong too
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART2,
- 2,
- V_NS16550_CLK
wrong?
Given the number of typos, maybe try and create a coccinelle script instead? :)
Alex
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
- OMAP34XX_UART3,
- 2,
- V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
I won't be able to fix it tonight, but I'll try to look at this tomorrow. Sorry, I was in a hurry this morning. Does anyone have an opinion on whether or not I should I also remove the 'const' part of the declaration? I wonder how much longer we'll be using this mechanism before the device trees take over. It seems like only a handful of omap boards use it.
adam
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index e2fce50..63489e5 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -34,9 +34,10 @@ static const u32 gpmc_lan_config[] = { #endif static const struct ns16550_platdata igep_serial = {
OMAP34XX_UART3,
2,
V_NS16550_CLK
This looks wrong
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(igep_uart) = {.clock = V_NS16550_CLK
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 668f684..0e72a5a 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -47,9 +47,10 @@ DECLARE_GLOBAL_DATA_PTR; */ static const struct ns16550_platdata omap3logic_serial = {
OMAP34XX_UART1,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(omap3logic_uart) = {.clock = V_NS16550_CLK
diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index 4040114..3d34919 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -44,9 +44,10 @@ static const u32 gpmc_lab_enet[] = { }; static const struct ns16550_platdata zoom1_serial = {
OMAP34XX_UART3,
2,
V_NS16550_CLK
looks wrong too
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(zoom1_uart) = {.clock = V_NS16550_CLK
diff --git a/board/overo/overo.c b/board/overo/overo.c index a38b959..3da80e9 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -68,9 +68,10 @@ static struct { } expansion_config = {0x0}; static const struct ns16550_platdata overo_serial = {
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(overo_uart) = {.clock = V_NS16550_CLK
diff --git a/board/quipos/cairo/cairo.c b/board/quipos/cairo/cairo.c index 21793e8..15d68c1 100644 --- a/board/quipos/cairo/cairo.c +++ b/board/quipos/cairo/cairo.c @@ -91,9 +91,10 @@ void get_board_mem_timings(struct board_sdrc_timings *timings) #endif static const struct ns16550_platdata cairo_serial = {
OMAP34XX_UART2,
2,
V_NS16550_CLK
wrong?
Alex
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(cairo_uart) = {.clock = V_NS16550_CLK
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index ff317ef..a5f2af7 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -73,9 +73,10 @@ static struct { } expansion_config; static const struct ns16550_platdata beagle_serial = {
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(beagle_uart) = {.clock = V_NS16550_CLK
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 1a447c7..fb8e357 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -46,9 +46,10 @@ static u32 gpmc_net_config[GPMC_MAX_REG] = { }; static const struct ns16550_platdata devkit8000_serial = {
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
}; U_BOOT_DEVICE(devkit8000_uart) = {.clock = V_NS16550_CLK
The commit was reverted this morning. There is no need for a patch now. U-Boot 'master' has been updated.
- Derald
adam
OMAP34XX_UART3,
2,
V_NS16550_CLK
This looks wrong
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART1,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
looks wrong too
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART2,
2,
V_NS16550_CLK
wrong?
Alex
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
So, for the moment, no rush. I reverted the dm commit for this release.
adam
OMAP34XX_UART3,
2,
V_NS16550_CLK
This looks wrong
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART1,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
looks wrong too
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART2,
2,
V_NS16550_CLK
wrong?
Alex
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
OMAP34XX_UART3,
2,
V_NS16550_CLK
.reg_offset = 0,
.reg_shift = 2,
participants (5)
Adam Ford
Alexander Graf
Derald D. Woods
Heiko Schocher
